POV-Ray : Newsgroups : povray.pov4.discussion.general : Next Generation SDL Brainstorming Server Time
14 Mar 2026 03:27:46 EDT (-0400)
  Next Generation SDL Brainstorming (Message 33 to 42 of 92)
Subject: Re: Next Generation SDL Brainstorming
Date: 28 Mar 2009 01:50:01
Message: <web.49cdba1fad594047dc4099c40@news.povray.org>
nemesis <nam### [at] nospam-gmailcom> wrote:
> (for i from 0 to 9 => (vector-set! vec i (* i i)))
> Nevertheless, don't you find it amazing to be able to simply churn out
> new syntax as you see fit?
#define FROM for(int
#define TO ;!(
#define INCREMENT );
#define BEGIN ++){
#define END }
FROM i = 1 TO i = 10 INCREMENT i
BEGIN
END
didn't test it, but if I'm not mistaken it should be perfectly valid C++ code.
I have one word for that:
    Inconsistency.
*You* can read it, but someone else must first learn your brand-new churned-out
syntax to grasp your code.
Yes, great for obfuscating. No, bad for anything that requires teamwork.
> Frankly, is the above syntax truly hard to figure it out?
Yes - not primarily because the syntax is hard to read, but primarily because
I'm not accustomed to this kind of basic approach. The shorthand syntax just
makes things worse by not giving any clue (just like for someone just learning
C, I guess).
> But yes, C is digestible simply because of sheer familiarity.
> It's like Windows.
No, its higher digestibility lies not only in the sheer familiarity of C itself
(and its heirs), but mainly in that the basic *concept* is probably familiar to
*any* programmer. I can't imagine a programmer who has in his whole life never
ever gotten in touch with imperative programming. But I know a whole bunch of
software developers who, confronted with the question what functional
programming languages they know, would probably answer with a puzzled "what?"
So it's not like Windows. It's like GUI. Everyone has seen it, and everyone
knows at least a *bit* of how to get along in it somehow; even if all your
computer experience was from a Mac, you'd have at least some vague idea of how
to do *something* in Windows - and vice versa; even those who prefer to work
with vi typically know at least a bit about how to operate a GUI. - But place a
random person in front of a console with vi running, and they'll be lost.
Utterly. They wouldn't even be able to shut down the computer (well, unless
they have access to the power switch).
Date: 28 Mar 2009 03:47:34
Message: <49cdd616@news.povray.org>
> #define TO ;!(
> #define BEGIN ++){
> #define END }
> BEGIN
> END
It's a very cheap and limited preprocessing trick which won't work if
you want to place things differently.  In Scheme/Lisp you have true
syntatic abstraction and it's used for very good purposes.  Macros are
an intrinsic part of Lisp.
For instance, I can rewrite the same syntax for various purposes:
(define-syntax for
     (syntax-rules (=> from to in resulting initially do:)
       ; simple list iteration
       ((for i in ls do: body ...)
        (for-each (lambda (x) (let ((i x)) body ...)) ls))
       ; imperative iteration over numeric range
       ((for i from x to y do: body ...)
        ((range x y) #t (lambda (i o) (begin body ...) o)))
       ; functional iteration over numeric range
       ((for i from x to y resulting j initially init do: body ...)
        ((range x y) init (lambda (i o) (let ((j o)) body ...))))))
and then use :
 > (for x from 1 to 2 do:
       (for y from 1 to 3 do: (display x)(display y)(newline)))
11
12
13
21
22
23
true
 > (for item in '(1 2 3) do: (display item)(newline))
1
2
3
 > (for x from 5 to 1 resulting y initially () do: (cons (* 2 x) y))
`(2 4 6 8 10)
And the real bad deal:  your example looks more like pascal than C.
Lisp code is extremely regular, it always look alike, despite new handy
syntax.
Plus, if I want to DECREMENT in your example I'm screwed, most likely
having to resort to a different "begin" to try to get around the fact
that the new "syntax" has its semantics fixed in place but scattered all
around the labels.
>     Inconsistency.
Indeed.
Not a problem in Lisp culture, where people read the code by scope.
 > C itself (and its heirs), but mainly in that the basic *concept* is
 > probably familiar to *any* programmer.
Funnily enough, and except for the syntatic abstraction, my example
dealt only with function definition and function application.  I thought
those concepts were flying around for ages now.
well, ok, functions returning functions is not generally mainstream...
It's an interesting comparison.
Here's a more interesting one:  put a novice with no knowledge of
programming languages in front of the monitor and ask him/her what
he/she figures out of this one:
(for x from 1 to 5 do: (display x)(newline))
and then this one:
int i; for(i = 1; i <= 5; i++) printf("%d\n", i);
What is the point of this little experiment?  To show that creating your
own syntax clearly has many benefits (specially for DSLs) -- like making
it more suited for the audience/domain or if you simply don't dig the
basic cryptic one -- and that awkwardness is in the eyes of the
beholder.  Lisp folks are known to create the language most well suited
and then program in that.
Scheme is often taught in first year compsci courses because of its
simplicity:  function definition and function application is all there
really is to it, predefined syntatic details is minimal.  So, I feel
astonished when people find it overwhelming.
That said, I wasn't *seriously* proposing Scheme for povray's scripting
language in the first place although I do believe it could be beneficial
in many ways.
Date: 28 Mar 2009 04:45:00
Message: <web.49cde32ead594047609a56250@news.povray.org>
> > Errata: read v as vec. :P
> Ah, yes, maybe *that's* why I didn't get it?! ;P
> > Let's put c and my scheme idiom side-by-side:
> > ((range 0 9) '() (lambda (i o) (vector-set! vec i (* i i)) o))
> > for(int i=0;i++<10;)vec[i]=i*i;
> Well, that's (1) not plain C but C++, and (b) obfuscated. Plain, common-style C
> would be:
> int i; for (i=0;i<10;i++) vec[i]=i*i;
> > (for i 0 9 => (@! vec i (* i i)))
> > Much better. :)
> Um... for an obfuscated code contest - yes, I guess so :P
> I don't claim the C family of languages to have a less obfuscated syntax - but I
> have a feeling that at least the basic concept is much more "digestible" to the
> average programmer...
If it can be useful the point of view of a non-programmer and a beginner in
POV-ray...
POV language is simple and intuitive, and there are not hateful things, like:
- *<>* or *</>* for each line...
- long word, filled with *__*, etc.
- billion of brackets of all types that disorientate...
Here, would it be possible to make the POV-language more powerful while
preserving the characteristics of simplicity?
Carlo
Date: 28 Mar 2009 05:06:27
Message: <49cde893@news.povray.org>
  That has been valid C for 10 years now.
Date: 28 Mar 2009 07:39:21
Message: <49ce0c69@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:49cd21cc$1@news.povray.org...
> In fact, if that's the case then the current parser could be kept for
> backwards compatability, activated by an appropriate #version directive
> (or whatever the equivalent would be in the new language) but remain
> static and disallowing access to features exclusive to the new language.
This would make a lot of sense, at the very least as a transition strategy.
Otherwise the cutover is likely to leave most of the existing community
using the scene files, macros and utilities that they know work with the old
software and a small new community that learns the new software.
Having such a transition would permit teething problems with the new
unproven approach to be ironed out and omissions, where the new software
can't do all that the old software did, to be bridged. It would also allow
time for a reasonable proportion of the assets developed for POV-Ray to be
migrated across. A process that won't really even be able to start in
earnest until V4 is demonstrably stable (unless of course we build 6 years
of Beta testing in the plan :-)).
Chris B.
Date: 28 Mar 2009 07:39:51
Message: <49ce0c87@news.povray.org>
"Mueen Nawaz" <m.n### [at] ieeeorg> wrote in message
news:49cbd590$1@news.povray.org...
> Chris B wrote:
>> Backwards Compatibility
>> There's a lot of time been invested in tutorials, interfaces, macros and
>> objects.
>> Much of the written information out on the Internet (including the years
>> of newsgroup postings) doesn't specify which version it relates to, so
>> if this material is rendered largely redundant it's probably going to be
>> wise to totally change the product name. Otherwise there's a risk of
>> years of confusion that may create difficult barriers to new users.
> I doubt a product name change is necessary. However, it should be made
> clear all over the place (docs, Web site, etc) that the latest Pov will
> break compatibility with anything before v4.
When you say "all over the place" you may be able to access a few sites, but
when newbies do a Google and discover thousands of sites containing
materials most of which just inexplicably don't work and can't readily be
made to work then it's likely to have a very negative effect on their
impression of the software.
> I personally don't think there's a great need to maintain backward
> compatibility as far as syntax/code goes. I think the hope is that the
> new SDL will provide "nicer"/"better" ways to do stuff than the old SDL
> - and so we wouldn't want people being hampered by tutorials from the
> past - but force them to learn the new way of thinking.
Well yes. Hope springs eternal :-) But reality depends upon people who hope
that they will show an aptitude for developing a fantastic new computer
language (when they've probably never done that before) realising their
particular dreams in a way that other people can stomach.
> One possibility is to try to find lots of good tutorials, put them onto
> the Wiki (if permission can be acquired), and before POV4 is released,
> update the tutorials to show how to get each effect using POV4.
As one of the few who has added stuff to the Wiki I can testify to how
quickly that sort of thing falls onto the shoulders of a very small number
of people. The amount of such work that can be realistically completed is
invariably tiny compared with initial expectations.
In this case there are some very practical problems with this as it would
require people with a reasonable knowledge of the old SDL and a good
knowledge of how the future SDL would best achieve the same results. Doing
this before the code is finished might require a disproportionately high
number
of genius level experts.
Also, this misses the point a bit in that you can create up-to-date
tutorials
but they'll be competing for prominance in Google with a greater number of
better established, but out of date tutorials that don't contain any
indication
that they may be out of date.
Chris B.
Date: 28 Mar 2009 08:01:20
Message: <49ce1190@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:49ce0c87@news.povray.org...
> hope
No offense intended :-)
Chris B.
Date: 28 Mar 2009 09:15:00
Message: <web.49ce22b5ad59404722390e420@news.povray.org>
Nor is functional programming in general.
Sure, Pascal has functions. Basic has functions. In C, the whole program is
comprised of functions, and the methods omnipresent in its heirs like C++ and
Java can be seen as another flavor of the same thing.
But if you look closer at these languages, you will find that those functions
are still both defined and used in an imperative fashion. (And all of these
languages actually have not only functions, but also procedures, that don't
return a value at all but just cause side effects. Even C has "functions" that
return "void", i.e. nothing.) It's only recently that design patterns borrowed
from functional programming are gaining popularity.
Maybe it's a bit like Go: The rules are mind-boggingly simple. But winning a
game of Go takes more than knowing the rules.
And first years compsci courses are given to people who have time to dig into
new concepts. Many programmers I know don't come from a compsci background. And
you don't learn functional programming in places where there's work to do. Not
typically, at least.
I never really assumed you were ;)
Date: 28 Mar 2009 10:05:00
Message: <web.49ce2e2bad59404722390e420@news.povray.org>
> POV-ray...
.... which is well appreciated and actually of high valuable in this context, as
it is virtually *impossible* for any programmer to assess a programming
language's "approachability" (or absense thereof) to beginners.
Maybe it's the most important point of view we need to take into account. After
all, POV-Ray is a raytracer first, and although it is obviously primarily aimed
at people who can get along quite well without a "wysiwyg" type of 3D modelling
tool, and one of its *strenths* is its integrated programming language, still
it aims for a much broader audience than just full-fledged software developers.
I bet (and hope and pray!) POV's SDL will *not* go XML ;)
Doesn't remind me of a particular language. But I guess what you're saying is
that a POV language should use short (yet clear) words.
Like in that language occasionally referred to as "the duct-tape of the
Internet"? Yeah, with duct tape you can do just about anything quite fast, but
the result always looks ugly, and you better have the job re-visited soon in a
more professional fashion ;) (Well, after all, "perl" is not a "pearl" ;))
(Then again, I'm not perfectly sure whether that is the kind of stuff you are
referring to.)
Yes, the typical POV script has those omnipresent curly braces for nesting
objects and their properties, some parentheses for some mathematical formulae,
and an occasional square bracket for array indices, and that's it, basically.
Which is possibly why I'm still irritated at the square brackets used for maps.
You definitely have a point here.
Date: 28 Mar 2009 10:30:00
Message: <web.49ce3420ad59404722390e420@news.povray.org>
There are still environments where the original C89 ANSI-C is *the* C standard.
Not only because of compiler availablility.
For instance, high-reliability systems written in C are often required to be
MISRA-C compliant - which as of today still demands use of plain vanilla C90
ANSI-C (if I'm not mistaken; it may be even C89).
The least common denominator today is still C89 ANSI-C (and actually only a
subset thereof, namely that which is not specified as leading to
compiler-specific or undefined behavior).
