POV-Ray : Newsgroups : povray.pov4.discussion.general : HELP: INI Settings Wrong Server Time
17 Mar 2026 04:04:55 EDT (-0400)
  HELP: INI Settings Wrong (Message 1 to 4 of 4)
Subject: HELP: INI Settings Wrong
Date: 2 Apr 2020 15:25:28
Message: <5e863c28$1@news.povray.org>
I have a problem: I changed my harddrives and order of drive letters.
POV-Ray still starts, but it cannot find any INI files etc, as they are
not on C but on drive F.
I also cannot find any longer the POV-Ray master Ini file. In the past,
there was a button to load that INI file.
And I also searched the Windows registry for a place where I could
correct the path, but the only path I found was only for scene files
which I set to drive F.
How to make POV-Ray, when starting, searching for the files on drive F
instead of drive C?
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: HELP: INI Settings Wrong
Date: 4 Apr 2020 06:12:17
Message: <5e885d81$1@news.povray.org>
On 4/2/20 3:25 PM, Sven Littkowski wrote:
> Hi,
> instead of drive C?
On windows unsure...
On unix based systems you can set an environment variable POVINI to
point to an ini file setting up pointers to whatever directories you
want. Unsure if the mechanism exists for windows POV-Ray installs?
On unix based systems it's also possible to symbolically link across
file systems. Possible to point from a "C drive" directory to the real
directory and files on the "F drive" by setting up a link.
I'd suppose similar mechanisms exist to do such things on windows
systems - but I again don't know. Sorry.
Bill P.
Date: 4 Apr 2020 09:15:01
Message: <web.5e888793dd1a5c95fb0b41570@news.povray.org>
Hi Sven - I hope you are in better health, spirits, and things are looking up.
My naive untested solution would be to look at / solicit feedback about / check
the docs for - where the files normally get installed, and then just change
everything to F: where C: exists.
(/media/oem/OS/ is the windows partition on my C drive)
executables are in: /media/oem/OS/Program Files/POV-Ray/v3.7/bin/
but I can't seem to find the directory with the ini files.
(This secret info ought to be written to a log and stored in a .txt file in the
user directory.)
> > instead of drive C?
http://wiki.povray.org/content/Documentation:Windows_Section_3
I'd say for the present, just start searching the system for the filenames and
try to find out where they all are by brute force.
Can you provide a working example of how to do this with the Windows font
directory?  (use a dummy Linux directory as a surrogate)
I tried the symbolic link, but it doesn't really seem to work for me at present,
so it apparently still needs some small tweak.
Date: 5 Apr 2020 07:02:23
Message: <5e89babf$1@news.povray.org>
I'm not completely sure what you're asking. Off the top of my head I
don't know how to generically link from say the linux subsystem
on windows back into windows itself - though expect there is a way.
When I've used fonts not built into POV-Ray I've always copied the ttf
font file into the working scene directory(1). So, I've created the
scene below to try specifying the location of the font files in
different ways including creating a symbolically linked directory in my
/tmp back to my real personal font collection(see scene comment). All
tests with current v38 master.
Surprised to find a full path specification of a font file didn't work.
I always needed to extend the Library_Path to include the directory with
the particular font - works even with the full path specifies to be
elsewhere... Anyway the test scene follows. Hope some help.
Aside: On Debian based systems like Ubuntu there is a file called
/etc/fonts/fonts.conf which lists the font directories on the system.
It should be your can add one or more of these with +L or via ini file
edits once you find the ttf particular sub-directories with fonts you
want to use. I now doubt full sub-directory tree structures are searched
for font files - but not tried this.
Bill P.
(1) - So it's in the archive file when I archive it.
#version 3.8;
#declare Grey50 = srgb <0.5,0.5,0.5>;
background { color Grey50 }
#declare Camera00 = camera {
     perspective
     location <3,3,-3.001>
     sky y
     angle 35
     right x*(image_width/image_height)
     look_at <0,0,0>
#declare White = srgb <1,1,1>;
#declare Light00 = light_source { <50,150,-250>, White }
#declare Red = srgb <1,0,0>;
#declare CylinderX = cylinder { -1*x, 1*x, 0.01 pigment { Red } }
#declare Green = srgb <0,1,0>;
#declare CylinderY = cylinder { -1*y, 1*y, 0.01 pigment { Green } }
#declare Blue = srgb <0,0,1>;
#declare CylinderZ = cylinder { -1*z, 1*z, 0.01 pigment { Blue } }
// Point to a font file using a full path specification.
// Which does not work for me without also +L...
#declare Rose = srgb <1,0,0.49804>;
#declare Text00 = text {
     ttf "/home/pokorny/Fonts/LiberationMono-Regular.ttf" "Bald_Eagle"
     0.2, 0.1*x
     pigment { color Rose }
     scale 0.2
     translate <0.05,0.05,0>
// Specify just the font file and then the search directory by
// extending the Library_Path via the command line:
//     povray my.pov ... +L/home/pokorny/Fonts
// or in an ini file with a line like
//     Library_Path=/home/pokorny/Fonts
#declare Orange = srgb <1,0.50196,0>;
#declare Text01 = text {
     ttf "LiberationMono-Italic.ttf" "Bald_Eagle"
     0.2, 0.1*x
     pigment { color Orange }
     scale 0.2
     translate <0.05,0.25,0>
// First symbolically link font directory in xterm window with:
//     ln -s /home/pokorny/Fonts /tmp/FontsSymLinkedDir
#declare Amazonite = srgb <0,0.76863,0.6902>;
#declare Text02 = text {
     ttf "LiberationMono-Bold.ttf" "Bald_Eagle"
     0.2, 0.1*x
     pigment { color Amazonite }
     scale 0.2
     translate <0.05,0.45,0>
//--- scene ---
     camera { Camera00 }
     light_source { Light00 }
     object { CylinderX }
     object { CylinderY }
     object { CylinderZ }
     object { Text00 } // povray tmp.pov  <- FAILS without +L below!
     object { Text01 } // povray tmp.pov +L/home/pokorny/Fonts <- OK
     object { Text02 } // povray tmp.pov +L/tmp/FontsSymLinkedDir  <- OK
