POV-Ray : Newsgroups : povray.pov4.discussion.general : Random POV-Ray 4 SDL proposal, #1 Server Time
1 Jun 2024 19:29:39 EDT (-0400)
  Random POV-Ray 4 SDL proposal, #1 (Message 26 to 35 of 38)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Random POV-Ray 4 SDL proposal, #1
Date: 12 Jul 2021 09:05:00
Message: <web.60ec3d1b2ab8183e16086ed03f378f2@news.povray.org>
Bump! (unless discussion is going on elsewhere, if so, sorry for missing it) and
not knowing much about json yet, I have a remark / question to the experts.
I also like the idea to use end of lines for ending some statements. To me that
is one cause for the popularity of python, staying as close to pseudo code as
possible in the core functionality. (which doesn't prevent to use stuff like
brackets for list comprehensions or more recently type annotations, depending on
the scope of the snippet or project written. There's even some days when you
forget the colon after concentrating on formulation of an if clause, and you
think; couldn't we do without it?
However , I have to assume that some of the syntax previously mentionned is
organically intertwined within JSON core syntax... But I do not have the
experience to distinguish which at all.
So my question to the experts is, could end of line statement still be
compatible with the proposed json paradigm / standard ? maybe in the worse case,
breaking away from the standard but by chosing a subset of it... or whatever
shift...?
(I only asked because it would seem that we would be at leat two in favour of
such a feature, but I for one would gladly give the request up after being
explained a reason, such as performance gain etc...)
Date: 12 Jul 2021 10:54:35
Message: <60ec57ab$1@news.povray.org>
Am 12.07.2021 um 15:01 schrieb Mr:
> shift...?
One of the key features of the proposed language would be that any valid
JSON file would automatically qualify as valid POV-Ray SDL file
(provided the "document object model", aka "schema", matches, i.e. the
hierarchy of how and what stuff is nested where).
Allowing for line endings to terminate statements might break that
compatibility, because the JSON standard allows line endings anywhere it
allows for whitespace.
I used JSON as a starting point for the proposed SDL format not only to
start _somewhere_ but specifically because being 100% compatible with
JSON would have the advantage that there are tools and libraries galore
out there to generate that format.
JSON is one of just a handful of probably the top most popular formats
for storage and exhange of structured data:
- XML
- JSON
- YAML
XML is painfully verbose, and therefore not an option. YAML is very
concise, but assigns semantics not only to line endings but also to
indentation, and that is something I'm anything but a fan of.
Which leaves us with JSON as the next most obvious choice - which
happens to be similar to POV-Ray's current SDL both in terms of
verbosity and overall look & feel (thanks to both ultimately being
inspired by C).
Also, categorically making any line ending end a statement has the big
drawback that any statement must be written on a single line. To work
around this, the statement-ending semantics of line endings would have
to be weakened depending on context, which in turn would add more
complexity to the parser, and moreover to the language itself,
potentially making it difficult for users to grasp how the line-ending
rules work.
An alternative would be to make some of the commas optional, but at
least as soon as we add certain of our own features we'd run into
similar problems to avoid ambiguities.
Compatibility with the base format, keeping the format free from
ambigiuties, and keeping the format reasonably easy for users to grasp.
That's pretty much all the reason there is to not assign special
semantics to line endings.
In terms of performance, it probably wouldn't make much of a difference.
Date: 13 Jul 2021 06:10:00
Message: <web.60ed654f2ab8183e16086ed03f378f2@news.povray.org>
> > shift...?
> - XML
> - JSON
> - YAML
Thanks a lot for this answer clarifying the stakes, Now I'll feel more at peace
when POV4 will keep its tolerant and meaningless line endings behaviour .
I would also hate it to be like xml compared to the other two options. So I
looked here https://levelup.gitconnected.com/json-vs-yaml-6aa0243aefc6
Coming from Python I know that my apriori not (yet) feeling the same about this
is probably thus biased, but could you please also develop more about why as a
user you would prefer an abundant punctuation over a meaningful indentation
system ?
Date: 13 Jul 2021 10:46:35
Message: <60eda74b@news.povray.org>
Am 13.07.2021 um 12:05 schrieb Mr:
> system ?
Indentation is trouble.
If you ever encounter a source file that mixes tab-indented and
space-indented code, you may realize what I mean. In languages that
don't assign semantics to indentation, such a mix results in eyesores at
worst. In languages where whitespace matters, it can get far worse.
The core problem there of course is that there are different standards
how many spaces a tab should be worth: Two? Four? Eight? Three? Six?
Five? Been there, seen all of those.
And it's not like you can tell at a single glance what's going wrong
there, with tabs and spaces both being entirely invisible and therefore
looking identical.
And if you've ever edited makefiles (or proto-makefiles as used in
Autoconf-based build systems), you really learn to hate languages that
assign semantics to whitespace. If you set your editor to replace tabs
with spaces, you _will_ break your makefiles.
(Granted, most indentation-aware languages don't assign different
semantics to tab indentation vs. space indentation.)
So there's the tab issue, for starters.
The next issue of indentation-structured languages - or at least those
that use a hard "end of line is end of statement" rule - is that they
put a practical limit on how complex you can make a single statement. If
you have a very complex mathematical formula, you need to break it up
into smaller chunks, assign those to variables, and then assemble those
into your final result. Or even more interim results first.
Now it can be argued that this forces you to give more structure to your
code, thus making it easier to understand.
However, breaking up an expression into named sub-expressions is not the
only way to structure complex formula. Specifically, even short formulae
might benefit from being spread out over multiple lines. And maybe
liberally peppered with indentation without having to worry about
breaking semantics.
And what if you're just using a formula from someplace else, and have no
idea whatsoever what the individual portions of the formula really mean?
Or if you've optimized a mathematical expression for performance in such
a way that its original "natural structure" is no longer visible anyway?
What you'll then do is use meaningless single-letter variable names to
the sub-expression, and the resulting code will look far more complex
and far more difficult to grasp than it would have, could you have
written it as a single expression spread over multiple lines and
indented freely.
And speaking of variable names, restricting the practical length of a
statement may actually lead to poorer rather than better code, in that
people may develop a habit of keeping variable names short and thus
potentially more cryptic.
(Some "end-of-line-aware" programming languages allow spreading
statements across multiple line by "invalidating" a line ending, but the
corresponding syntax tends to be somewhat clunky. If you've ever done
much C/C++ preprocessor programming, you'll know what I mean. What's
more, such syntax often breaks in the presence of stray blanks at the
end of a line, which are a pain to find.)
Also, sometimes it may actually improve readability to put multiple
short statements on a single line (especially when there's a group of
statements that repeats in structure). Some end-of-line-aware languages
allow this (e.g. shell scripts), but again generally at the cost of
added symbols and therefore clunkiness.
Of course it can be argued that whitespace-agnostic languages need the
same extra symbols between statements, not only in a single line but
also between lines. But in my mind separator characters become less
clunky if they're used consistently throughout, as opposed to just on
special occasions.
And then there's the matter of copy-and-pasting:
When you copy-and-paste code from arbitrary sources (a web page here, a
PDF there, a terminal window over there, and what else you might happen
to come across), you may end up with broken indentation.
If the code is reasonably complex, have fun faithfully restoring the
original semantics.
If the semantics is all in the non-whitespace, smart editors may
actually be able to restore the original indentation, at least to the
point that its structure is agion easy enough to grasp for a human. If
semantics is in the indentation itself, how could an editor ever restore
that indentation?
Also, look at written human language: There's a reason we're using
special characters to indicate the boundaries between sentences and
subclauses, rather than using a "one line = one sentence" default rule
and using special syntax to spread sentences across multiple lines.
Now I can't rule out that Python may for some reason manage to get
around each and every one of the above issues - I've had virtually no
exposure to that language yet. But based on my experience with other
end-of-line- and indentation-aware languages, my guess is that at least
some of those issues do apply.
But even if Python should be entirely immune, that doesn't mean it would
be easy to design a new POV-Ray SDL that is also indentation-aware and
has the same level of immunity as Python.
And yet, feel free to throw together a corresponding proposal, and
present it here. Even if it should turn out to be seriously flawed,
there may still be interesting and inspiring morsels in there.
Heck, I've never claimed that my own proposal was really any good. I
just threw it out there to have _some_ starting point. For discussion at
worst, or for further development at best.
As a matter of fact, I don't even _particularly_ like it. It's not very
elegant, because it is not custom-tailored to our needs. It is derived
from an existing base. It does have interesting properties though, one
of which arises _specifically_ out of being derived from an existing
base. And for now I think it has the potential to be useful, and maybe
even reasonably good.
No worse than the current SDL, and better structured - that's all I'm
asking of a new SDL. Ideally with consistent syntax between scene
descriptions and functions, and maybe with a rigorous enough structure
to allow for a compiling rather than interpreting parser.
Date: 14 Jul 2021 05:40:00
Message: <web.60eeafce2ab8183e5e0fed26cde94f1@news.povray.org>
hi,
have you looked at Tcl/Tk yet, for inspiration?  has many (imo) natty features,
nice, clean syntax, and byte-compiles.
regards, jr.
Date: 14 Jul 2021 14:15:44
Message: <XnsAD67CE1D1A52Cseed7@news.povray.org>
> at worst, or for further development at best.
Lets go wild then. I don't like it. I like how the current SDL is
sufficient. Fit for use. Although there's a lot I would leave out.
#declare, #local be gone! Proper, simple, understandable namespaces and
scoping with maybe a (exportable) global. All the #'s be gone. What's
left then is quite clean. Oh ';' out, out out. Squiggels is enough and
(),[],<>. Vectors are great.
Then there's a few little gripes "for (I, 0, dimension_size(ArrayX, 1)-
1)" for example. I know the dimension_... comes from the multidimensional
arrays, but are they still needed when we have arrays of arrays? "for (I,
0, size(ArrayX)-1)" or "for (I, 0, size(ArrayX[5])-1)".
So, no brand new syntax for me, but a cleaned up version as close as
possible in functionality as the current one. No OOP. Would iterators,
generators make sense? I doubt it. No async. Minimal to no functional
stuff. Also something that relative easily can be converted from old to
new (probably impossible given how the SDL can be 'abused').
Under the hood? I would like to have more access to all kind of variables
POV-Ray calculates so we can create 'things' (textures) depending on
those results.
Ok, now for the crazy one: Wasm. https://webassembly.org/
I like how the compiled functions in math.inc work through an include
file. I like the ideas of adding more of those.
I even more like the idea if we could write dynamic linked libraries,
call them from POV-Ray using a compagnion include file. (something
simmilar is done in SuperCollider c++ for the audio server and a *.sc
file for the scripting side).
Now, what if these wasm's can be used as 'dll's'. It would make them
platform independent plug-in's. Reduction of maintenance. There are a lot
of languages that can be compiled this way, proper toolchains et al.
For what? Not directly for interacting with the ray's, if possible at
all. But for easy access to for example nurbs (Rhino OpenNurbs) of faster
mesh generation or boning and IK and surface subdivison,
http://math.lbl.gov/voro++. Simply put, more extensive and faster include
files (for things you don't want in the core).
Or, the other way around. Could it be made possible to convert a parsed
file into 3D printer data more easily, with checks for holes we don't
need when tracing? OGL visualisations?
Ingo
https://ingoogni.nl
Date: 14 Jul 2021 18:56:40
Message: <60ef6ba8$1@news.povray.org>
Am 14.07.2021 um 11:35 schrieb jr:
> hi,
Unless those features have a direct impact on the core principles of the
language's syntax, I don't care much for them at this point. Also, I
think it would be more productive to name those features that you like
about it, rather than just (to put it into more blunt of a picture than
adequate here) point in the general direction of the language and say,
"I like some of the stuff that's in there, see if you can spot it".
As for nice, clean syntax - I would disagree.
At a very first glance, Tcl/Tk sounds like a promising basis: Its main
purpose (nowadays) is also to describe hierarchical structures (albeit
not geometric objects and surface properties, but rather GUI elements),
with programmatic elements mixed in for good measure. Unfortunately, the
Tk part (which is the description of GUI elements) was bolted on later,
and in my opinion it shows. At its very core, Tcl is a command
shell-style scripting language.
One of the results is that different Tcl statements may have their own
individual quirky "micro-syntax". Just like all of POV-Ray's individual
geometric primitive, pattern and what-have-you statements all have their
own little "micro-syntax" quirks. Any commonalities between them are
just superficial conventions. Which bothers me to no end.
In my opinion, the best approach to judge a language for suitability as
the basis for a new SDL is to ask (and answer) the following three
questions:
- "What is the 'grammar' of this language, i.e. the core principles that
govern its syntax?"
And based on that:
- "How would a simple scene be described in this language?"
(A chrome sphere on a colorful checkered plane, with camera and all, and
maybe a text object to showcase strings, should do as a first example.)
- "How would programmatic elements mesh with this syntax?"
(A simple example with a loop and a few conditionals should be a
reasonable starting point.)
When I do that for Tcl/Tk, I find that the results look - in my mind -
ugly AF.
Date: 14 Jul 2021 19:54:16
Message: <60ef7928$1@news.povray.org>
Am 14.07.2021 um 20:15 schrieb ingo:
So there _is_ something you would add: Namespaces.
Also, for something that is "fit for use", there's quite a lot you would
seem to change ;)
But is it though?
Trim the `#` from the `#version` statement, and it clashes with the
pseudo-variable `version`, for example. Trim the `#` from the `#local`
statement, and it clashes with the `local` pseudo-dictionary.
You're asking for namespaces - you can look at `#` as the namespace for
control statements.
(There's also one particular property the use of `#` has, that is
invaluable at least for the current parser:
It helps a lot in speeding up the parsing of some control structures.
For example, after encountering `#if()` with an expression that is
false, the parser can simply skip from `#` to `#` in search for the
matching `#else` or `#end`, because anything else is guaranteed to not
natter. Likewise, after encountering `#macro(...)`, the parser can
simply skip from `#` to `#` in search for the matching `#end`, because
it will only parse the macro body once it is invoked.
Of course that may be less of an issue once we change the parsing
strategy to scan and tokenize the file only once, and then work on the
"pre-digested" token sequence.)
Genuine multidimensional arrays are easier to set up:
     #declare Foo = array[10][10];
as opposed to:
     #declare Foo = array[10];
     #for (I, 0, 9)
         #declare Foo[I] = array[10];
Also, they guarantee that the size of the second dimension is constant,
whereas arrays of arrays might have different sizes in the second dimension.
They are also more memory-efficient, especially if the last dimension is
comparatively small.
And I guess they are also more efficient in terms of performance,
although that might not show much in comparison to the general slowness
of the current parser.
> No OOP.
I hope you'll be fine with structured data aggregates at the very least
(think POV-Ray v3.8's dictionaries).
And since dictionary entries can be functions (or at least should be
able to; not 100% if that currently works), and I'm determined to make
functions more powerful (wouldn't you want to be able to write tiny
little programs in functions, if only to more easily work with interim
results?), OOP will probably enter the scene as a side effect.
If it weren't for the special syntax of macros (`#macro Foo() ... #end`
instead of `#declare Foo = macro() ... #end`)
Also, my goal is to formalize the object, pattern and whatnot syntax
more, which will feature OOP at least under the hood. And wouldn't it be
nice to implement custom objects that look and feel just like the
inbuilt ones, syntax-wise?
> Would iterators,
I'm not quite so sure. Unless we provide a goot set of container-style
inbuilt data structures (which _are_ useful after all), people will
start to use structured data aggregates to roll their own, and end up
with the desire to use them in a nice elegant `for myElement in myArray`
(or alike) loop. That'll be difficult to implement generically without
the concept of an iterator.
The good news is that iterators are just a matter of proper
implementation, once you provide OOP basics.
> No async.
Sure? It would allow users to leverage multiple CPUs even during parsing.
> stuff.
If you mean syntax to support functional programming, I agree. I can't
wrap my head around that paradigm anyway, so I doubt I could design or
even implement a language to support it properly.
If you mean powerful syntax for functions, I disagree. I do want at
least the ability to easily compute interim results in functions.
You're probably right there: It would be a pain to write a converter.
Because it is a pain to write a parser for the current SDL in the first
place.
> those results.
Ooooh... so maybe some OOP features after all?
Also: Can you be a _little_ bit more specific?
There's a lot of stuff POV-Ray calculates under the hood, but only a
fraction thereof can reasonably accessed from SDL.
I don't think that will happen, at least not anytime soon. Allowing for
arbitrary binaries to be plugged in can open up quite a can of worms,
security issues being only one of them.
Also, I'm sure such plug-ins _will_ create intersections with the world
of OOP.
Possibly, eventually. Long road there. But that's less of a parser
matter, and more of a render pipeline thing. We need to pull that apart
in order to more easily provide SDL-level access to its elements.
Date: 14 Jul 2021 20:15:00
Message: <web.60ef7d852ab8183e1f9dae3025979125@news.povray.org>
> Also, I
> questions:
> govern its syntax?"
As I (and probably most of us) have never really dissected, analyzed, and
evaluated a computer language like that, let alone several - to be able to
compare and contrast - this is likely going to be tough issue to address.
Maybe provide an example or a link to exactly the kind of thing you're talking
about here.
> And based on that:
Now, I can only chime in here with the things I've seen.
OpenGL and Shadertoy seem to have all/most of the things that we want, and
OpenGL is well established, and presumably geared specifically towards graphics.
It seems like a fairly easy and relatively intuitive language for anyone who's
done "regular" basic programming, and played with some of the patterns and
isosurface/parametric stuff.   It seems to be compiled, fast, and have really
user-friendly function and vector features, which would be essential.
I've seen people program things in c++ and python, and I kinda hate it.
I've seen some stuff in Processing and P5JS, but only a very limited amount.
I've heard mention of Lua and Haskell...  :D
Some of things I like about the OpenGL and P5JS work, is that there's a looping,
continually updating output - somewhere - and I wish we had the capability to
have  "a running program that outputs graphics" in place of / in addition to the
2-step edit-then-render a single static image paradigm that we have.
I guess since the languages exist and there are plenty of examples, the syntax
issue can be left to folks better informed than I, but the last two questions
can be seen in action, where objects, light sources, shadows, reflection models,
geometry, and program control directives are all used to create a scene.
In my head, I'm envisioning that an interim "meta-POV-Ray" could be implemented,
where everything is written in user-accessible include files, and a "free for
all with rules" ensues, where people can "access the source code" (the include
files) and edit it to produce new objects, algorithms, reflection models,
geometries, and even object and command syntaxes.  People can then have their
own "anything goes" forks, but team contributions for serious consideration need
to adhere to certain established conventions.   Then a sort of natural evolution
could be allowed to play out, and the various strengths and weaknesses of each
approach could be tested by the community as a whole.
We could have whole algorithms to generate shapes and textures rather than
functions, persistent variables across renders, and a host of other things I
likely can't think of off the top of my head.
The interesting parts that I see about this approach, are that (lets take
Shadertoy as a specific example) the "core" of the application isn't
intermingled with the _things_ that the core handles.  It's a programming
language who's end product is primarily a colored pixel on the screen, but all
of the basic primitives lie outside of the core and are just macros of sorts.
As such, it's wide open to the user to do as they please with.  That takes a lot
of development pressure off the devs and lets users so inclined to code up
whatever cameras, lights, shapes, and patterns that they can think of.  It also
addresses one of the issues that constantly pops up on the forums about "Why
can't POV-Ray...", because then it's easy to point them to the include file
they're invoking for - let's say a shape.  It may be written with very
meaningful variable names or extensively commented, and the actual code that
makes the shape they are interested in is right there for them to see.  It's a
wonderful learning experience for people interested in computer graphics.
POV-Ray's pigment pattern equations are beautiful in their simplicity, and some
of the more complex ones are a wonder to behold.  I'm often sad that the logic
of the pigment patterns isn't up front in the documentation, because it gives a
new user a WAY to think about exactly how the magic on the screen happens.
Most of the people "out there" are POV-Ray _users_, and as you have pointed out,
may only use it as the last link in a software workflow chain.  Most of use
_here_ are "only" users, and not developers who have a good-enough grasp of the
source code and how it all fits together to get to the part that colors the
current pixel.  Something that is still usable but draws the more-than-casual
user into deeper quasi-developer territory would, in my opinion, help address a
lot of the things that we are struggling with.
Basic understanding of "how it all works"
Educating people with programming and mathematical aptitude to make parts of
POV-Ray their own and put on the developer hat.
Greater freedom to edit the source, and a nimbler evolution of future versions.
Less reliance on only 2 or 3 people who know how anything works to a great
enough degree to actually make or change something without breaking the rest of
it.
The addition of new features to POV-Ray, since greater experience with writing
"SDL" de facto translates to writing POV-Ray "source code".
In the case of Shadertoy, it's a browser-driven software, which makes it
inherently cross-platform.
Obviously, there are going to be problems with any of the points I made, and
some are likely painfully naive to the experienced software developer, and
especially to you and others who have a top-down view of the whole inner
workings of the source code and the interplay of all the dependencies - but I'm
just sharing my ideas in this rap session.  Sometimes some of them actually turn
out not to suck.  ;)
Date: 14 Jul 2021 22:16:35
Message: <60ef9a83$1@news.povray.org>
Am 15.07.2021 um 02:12 schrieb Bald Eagle:
I have to ask what exactly you are referring to when you say "OpenGL".
At its core, OpenGL is a library (or, more specifically, a library API):
A collection of functions that can be called from various entirely
different programming languages. The most "native" of those would be C/C++.
Are you perhaps referring to the shader language of OpenGL (GLSL)?
If you love GLSL, then I'm surprised you "kinda hate" C++.
Also, I'm not quite sure how a POV-Ray scene could map to GLSL. It seems
to me like it would have to be described in as clunky a way as it would
in C++.
In essence, most program languages have an imperative approach at the
lowest level; to describe data, you have to instruct the computer to
assemble it step by step, like so (pseudocode):
     Create a sphere S.
     Set the radius of S to 5.
     Set the center of S to <0,1,0>.
     Create a texture T.
     Create a pigment P.
     Set the pigment's pattern to 'checker'.
     Attach P to T.
     Attach T to S.
     Attach S to the scene.
Rather than using a descriptive approach, like so:
     The scene has the following objects:
     - A sphere, with the following properties:
       - a radius of 5.
       - a center of <0,1,0>.
       - a texture with the following properties:
         - a pigment with the following properties:
           - pattern 'checker'
While the difference may not seem obvious at first glance, it tends to
make a huge difference in terms of how much repetitive stuff the syntax
requires. For example, in C++ it might be written like so:
     Object S = new Sphere();
     S.radius = 5;
     S.center = Vector3(0,1,0);
     Texture T = new Texture();
     Pigment P = new Pigment();
     P.pattern.set('checker');
     T.addPigment(P);
     S.addTexture(T);
     Scene.addObject(S);
whereas in a descriptive language it might be as simple as:
     sphere {
       radius 5
       center <0,1,0>
           pattern 'checker'
