POV-Ray : Newsgroups : povray.off-topic : I cannot update my GitHub repo Server Time
5 Jul 2025 22:50:30 EDT (-0400)
  I cannot update my GitHub repo (Message 1 to 10 of 12)
Subject: I cannot update my GitHub repo
Date: 15 Feb 2022 16:45:00
Message: <web.620c1e89db05661160e0cc3d949c357d@news.povray.org>
Getting back to what I was trying to do before my GPG key expired, I cannot push
an update.  This is what I get:
----------[BEGIN TERMINAL SESSION]----------
ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git push origin main
To github.com:CousinRicky/POV-AndroidRobot.git
 ! [rejected]        main -> main (non-fast-forward)
error: failed to push some refs to 'github.com:CousinRicky/POV-AndroidRobot.git'
hint: Updates were rejected because a pushed branch tip is behind its remote
hint: counterpart. Check out this branch and integrate the remote changes
hint: (e.g. 'git pull ...') before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git pull origin main
From github.com:CousinRicky/POV-AndroidRobot
 * branch            main       -> FETCH_HEAD
Already up to date.
-----------[END TERMINAL SESSION]-----------
If a pull is saying it's up to date, why does a push say it's not?
I looked at the note about fast-forwards.  I saw words, I saw letters, but I
could not make it make any meaningful sense to me.
I might as well have been reading Sanskrit.
Help!
Subject: Re: I cannot update my GitHub repo
Date: 15 Feb 2022 17:22:14
Message: <620c2796$1@news.povray.org>
> Already up to date.
Try just "git pull" and "git push".
Also what does "git status" have to say?
dik
Date: 15 Feb 2022 17:55:00
Message: <web.620c2e2ecfbdaf8660e0cc3d949c357d@news.povray.org>
> > Already up to date.
> dik
You are not currently on a branch.
Please specify which branch you want to merge with.
See git-pull(1) for details.
    git pull <remote> <branch>
ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git status
HEAD detached from 638e732
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git restore <file>..." to discard changes in working directory)
        modified:   README.md
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        .gitignore
        README.md~
        androidrobot.pre-4.0.css
        droid-comments.txt
        session.txt
no changes added to commit (use "git add" and/or "git commit -a")
ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> ls -l README.md
-rw-r--r-- 1 ricky users 538 Feb  6 16:32 README.md
Since the git pull didn't work, I didn't bother with the push.
I do not understand what's going on with README.md.  I updated this file back in
late October, and this is what I tried to push.  But now, the git status says
that the file's commit somehow became undone, and the datestamp is today!
Weirder still is that the backup file README.md~ still exists; it should have
been deleted a long time ago by my regular cleanups.  It also has today's
datestamp.
It gets weirder.  When I look at README.md in Git-Cola, it shows the version
from before even the backup file!
Date: 16 Feb 2022 15:37:53
Message: <620d60a1$1@news.povray.org>
These two are not good.
I have run into this before and honestly what I do, and the easiest way
out is to git clone a new workspace. Then copy your old/broken files
(not the .git directory!) over to the new workspace.
dik
Date: 16 Feb 2022 15:41:01
Message: <620d615d$1@news.povray.org>
Broken files might be a bad term.  "Changed files that you want to keep
from the broken workspace".  That's better.
> dik
Date: 16 Feb 2022 21:24:02
Message: <620db1c2$1@news.povray.org>
Do you mean clone the GitHub repo?
Date: 17 Feb 2022 10:59:03
Message: <pan$e8446$50072bbb$7ed71ea2$ae813139@nospam.com>
> ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git pull You
Yeah, I had an issue similar to this a few days ago, and ended up doing
the same thing.  Even stashing the changes I had made didn't work, along
with a hard reset to a known good commit.
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 17 Feb 2022 13:46:42
Message: <620e9812$1@news.povray.org>
yes. Something like
git clone https://github.com/CousinRicky/AndroidRobot.git
(making sure that the AndroidRobot subdirectory does not exist from
where your current directory is.)
I was going to give you the exact line but I couldn't find which
AndroidRobot was yours among the plethora of search results.
Date: 17 Feb 2022 18:17:22
Message: <620ed782$1@news.povray.org>
> yes. Something like
That worked.  As drastic as that is, at least I have a last resort
fallback when I get stuck.
For the record, it's https://github.com/CousinRicky/POV-AndroidRobot
It occurred to me that the reason for the snag /may/ be that I tagged
the repo in GitHub.  I just discovered that tags are not a GitHub
feature, but are part of Git, so tagging it in GitHub probably threw it
out of sync with my local repo.
If that's the case, then I'll need to clone *all* of my repos.  :(
Date: 17 Feb 2022 21:49:31
Message: <620f093b$1@news.povray.org>
No, that wasn't the reason.  My other repos are pushing peacefully.
