POV-Ray : Newsgroups : povray.off-topic : A programmer's etymology Server Time
15 Jan 2026 01:56:35 EST (-0500)
  A programmer's etymology (Message 1 to 10 of 27)
Subject: A programmer's etymology
Date: 23 Jul 2014 02:20:01
Message: <web.53cf52adaaf53cca1538d4890@news.povray.org>
How well do you know your bugs?
bohrbug: a good, solid, bug.  named for the Bohr model of atomic structure.
bohrbugs do not change their behavior and are relatively easily detected.
hindenbug: a bug with catastrophic behavior.
heisenbug: a software bug that seems to disappear when one attempts to study it.
programmer notices that the code should never have worked in the first place.
mandelbug: a bug whose causes are so complex as to defy remediation, or one
which demonstrates seemingly chaotic or even non-deterministic behavior.
I hope you find these as amusing as I did.
A.D.B.
Subject: Re: A programmer's etymology
Date: 23 Jul 2014 08:55:40
Message: <53cfb0cc@news.povray.org>
> Regards,
> A.D.B.
I might steal a few of those.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 Jul 2014 16:30:33
Message: <53d01b69$1@news.povray.org>
I see somebody's been reading the hacker jargon file, then...
We had a catastrophic heisenbug the other week. When you run the
application, if you click on one of the settings on the configuration
page, it actually *runs* the action being configured, rather than just
changing the setting. Utterly mystified as to how such a bizarre thing
could even be remotely possible, we waded through the code. No hint of
what might cause such a thing. So we ran a debug build of the program...
and the bug vanished.
Much poking, and it turns out that if you run the version of the
software produced by the automated build system, the bug is completely
repeatable. If you build the software (in debug or release mode)
yourself, it works perfectly. What the actual hell??
When we actually found the root cause, it was truly horrifying. It seems
that the automated code obfuscation system we run our code through is
BREAKING OUR CODE!!! O_O The "solution" was to turn off code obfuscation
in certain parts of the program. I say "solution" since this obviously
isn't a solution at all; the fact that this event occurred at all proves
that the obfuscater is defective, and that another bug like this could
occur AT ANY MOMENT. It's also provably impossible to test for, since
the obfuscater is also rewriting our tests, and it might rewrite the
test case correctly but the production code incorrectly. So... yeah,
pretty worrying, actually.
Also: Technically it's not a bug unless it's in Hemiptera.
Date: 23 Jul 2014 17:39:20
Message: <53d02b88$1@news.povray.org>
Am 23.07.2014 22:30, schrieb Orchid Win7 v1:
OUCH!
... unless it's a dog.
Date: 24 Jul 2014 01:06:59
Message: <53d09473@news.povray.org>
I think this is the real WTF.
Date: 24 Jul 2014 03:02:10
Message: <53d0af72@news.povray.org>
Am 24.07.2014 07:06, schrieb Warp:
I guess you don't want to obfuscate a large codebase manually. Not only
because it is a lot of work, but also because there is a high risk of
breaking the code...
... oh, wait...
Date: 24 Jul 2014 03:07:39
Message: <53d0b0bb$1@news.povray.org>
The idea is to make it less trivial to reverse-engineer our code and
steal all our secrets.
...which is interesting, really. We make software for idiots. Idiots
generally aren't the type of people you'd expect to be
reverse-engineering computer software. Our software doesn't *do*
anything particularly complicated; it just puts a user-friendly GUI in
front of a bunch of existing tools. That might *sound* easy, but it's
actually surprisingly time-consuming.
Really, if you want to copy our product, it would be quicker to look at
what it does and write your own one from scratch than to try to figure
out how ours works internally. The most likely scenario is somebody
wanting to reverse-engineer our stuff just to disable the license checks.
All the obfuscater actually does is to take every class and rename all
it's methods to A(), B(), C(), etc. And insert lots of complicated flow
control into the method's actual code. It appears in this instance, it
accidentally (!!) renamed two events to the same thing. Oops...
Date: 24 Jul 2014 03:07:56
Message: <53d0b0cc@news.povray.org>
> ... oh, wait...
BOOM!
Date: 24 Jul 2014 03:33:21
Message: <53d0b6c1$1@news.povray.org>
Am 24.07.2014 09:07, schrieb Orchid Win7 v1:
That, most probably.
I guess it's plenty of fun to wade through obfuscated code to figure out
exactly how the hell the 'fuscator fucked it up...
Date: 24 Jul 2014 04:09:30
Message: <53d0bf3a$1@news.povray.org>
So, you are on the poor-side of companies. Richer companies have a
full-time team with lawyers to track and sue such events.
Maybe interpreted language is not the right choice if you want to
protect your code. That's where compiled language have an advantage: the
compilation with full optimisation is already an obfuscation. There is
decompiler... like there is deobfuscater. And they are pretty smart on
small code.
It's one of the three Java issues (Java is about sharing... keeping
secret is not sharing, so the choice of the language for your project
was an error), at least for secretive software. But that's another story.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
