POV-Ray : Newsgroups : povray.off-topic : less Server Time
15 Jan 2026 09:55:46 EST (-0500)
  less (Message 1 to 10 of 31)
Subject: less
Date: 18 Oct 2012 09:00:01
Message: <web.507ffc68d3b694dfc2421da0@news.povray.org>
printer to discuss printing options.  The printer looked over my files and asked
vector graphics.
some of my vector graphics to a programmer friend. The friend reportedly
people.
This morning, I dug up a few old procedurally-created 3D works and sent them to
the printer for a(-nother) laugh. Thinking back to those old works and how
relatively quickly I was able to produce them, I am reminded of what I was able
to accomplish when I spent my time working instead of searching for a panacea.
my work and workout clothes and will somehow make slacks or gym shorts work for
anticipating one perfect occasion to wear it.
But not everything has been so straight forward: I was proud of my personal
aspects of my simplification are actually disguised panacea hunting and/or
self-abuse.
 -Shay
still wept for my wasted hours when I recently installed Mepis on my desktop in
all of ten minutes.
Subject: Re: less
Date: 18 Oct 2012 14:54:54
Message: <5080507e$1@news.povray.org>
> drew me into Linux in the first place.
Wait, you left Windows and went to Linux because of the steep learning
curve of *Windows*??
Subject: Re: less
Date: 18 Oct 2012 15:00:50
Message: <508051E8.1050707@gmail.com>
If those were the intricate mesh object you showed in these newsgroups I
am more amazed that nobody offered you a job before.
Women are the canaries of science. When they are underrepresented
it is a strong indication that non-scientific factors play a role
and the concentration of incorruptible scientists is also too low
Subject: Re: less
Date: 18 Oct 2012 18:00:01
Message: <web.50807af13d7d089c343b23870@news.povray.org>
No, I was enticed by the steep learning curve of Linux. I was convinced that
something earned must be better than something purchased.
That being said, the Win7 "Windows Explorer" is more confusing that any
standard, modern Linux application I can think of.
 -Shay
Subject: Re: less
Date: 18 Oct 2012 18:00:02
Message: <web.50807bcc3d7d089c343b23870@news.povray.org>
Thank you. Amazing enough that anyone remembers that far back.
Subject: Re: less
Date: 19 Oct 2012 04:00:57
Message: <508108b9$1@news.povray.org>
Oh, right. That makes far more sense...
Having said that, from what I can tell, Linux is far more flexible, and
Windows has a far higher probability of actually working.
Really?
Subject: Re: less
Date: 19 Oct 2012 08:15:01
Message: <web.508143493d7d089cc2421da0@news.povray.org>
That about sums it up for laptops with their extra buttons, hard-drive
protection, thumb scanners, etc. Linux "just works" (maybe not 100% optimally,
but you probably wouldn't notice) for a standard desktop.
But Linux has more going for it than "far more flexible". It won't be as
compatible as Windows, but it will do what it does do (e.g., window managers)
better[1]. Windows only wins with top-shelf software installed.
> Really?
Maybe I just don't have it configured correctly. Not in front of it atm, but
iirc, the first screen doesn't show your file system as a connected network of
folders. What you see is shortcuts to various folders in your file system. This
is confusing if you want to go somewhere that doesn't have a shortcut. Two
clicks to get to my home folder, and, in my case, my home folder is called
"LENOVO_USER" in DOS and "Shay" in Windows Explorer. I found it frustrating at
first.
 -Shay
[1] This mirrors my limited experience with IDEs vs. text editors: the IDE can
do a lot of things, but the text editor component is never as nice ime as a
dedicated text editor. Similarly, Windows Explorer, Internet Explorer, and
Explorer shell aren't nearly as nice as their FOSS counterparts.
Subject: Re: less
Date: 19 Oct 2012 17:10:48
Message: <5081c1d8$1@news.povray.org>
This has not been my experience. I'm sure we could have a very long
flamewar about this. (In fact, I can promise you that somebody,
somewhere is having this exact discussion /right now/...)
In essence, my experience has been this:
* If the distro installs it by default, it'll probably work perfectly.
* If there is a package for your version of your distro, you can
/probably/ install it. Often this works perfectly. And often this fails
spectacularly, and it's impossible to figure out why.
* If there isn't a suitable package... you probably need to build the
thing from source. If it's a simple item, this might work. If it has
non-trivial external dependencies... forget it. You could waste several
months of your life utterly failing to make it work. It isn't worth it.
For example, when you run VMware Workstation, you can install "VMware
Tools" on the guest OS, which greatly improves integration with the host
OS. At least, you can if the guest OS is Windows. If it's Linux, then
this never, ever, under any circumstances, works. It's /supposed/ to
work; they provide Linux-compatible packages. They just don't /work/.
I imagine the problem basically comes down to this: "Windows" is one OS.
"Linux" is several hundred similar but incompatible OSes. You haven't
got a snowball's chance in hell of writing an installer that works on
all of them.
That's an interesting choice of example.
 From what I've seen, KDE is reasonable, and GNOME is reasonable. Every
other window manager I've ever seen has been /horrifyingly awful/! I
mean, they're literally /so bad/ that you wonder why the hell anybody
even bothered to build the RPM for it. It looks so utterly hideous, and
it's so difficult to use... WHY WOULD YOU BOTHER?
KDE or GNOME aren't too bad. I haven't really used KDE much recently,
but I think I could probably live with GNOME as my actual desktop. (You
mean, I mean, if I could actually get my software to run on Linux.)
Either of these desktops usually has far more configuration options than
Windows ever had. [Although I see that with GNOME 3 they've removed most
if not all configuration options, for no defined reason...]
>> Really?
> first.
Yeah, I'm not fond of that. Basically Microsoft is all like "why should
you care where your file are, or what the filesystem structure looks
like? Let me hide all that computery stuff away from your so you don't
have to even /touch/ it. Let's just pretend that I'm in charge of your
PC, not you..."
You can fight it, and work around it. But you can't turn it off, sadly...
IME, a good IDE has a text editor roughly comparable to a good
standalone text editor. The difference is, I can press a button and
compile my stuff, or whatever. And I've yet to see a standalone text
editor which understands source code well enough to do really decent
syntax highlighing, much less anything more sophisticated.
What I /will/ say is that most IDEs tend to be unreasonably slow...
I don't like Internet Explorer at all. I use Firefox instead. (I tried
Chrome, but didn't like it.)
However, I prefer Windows Explorer to any FOSS alternative I've seen.
[Not that I've seen any that run on Windows in the first place.] It
defaults to assuming you're a total moron who is too stupid to operate a
computer. Once you turn all that crap off, it looks nicer and works with
less fuss than anything else I've seen.
In Windows 7, the main user shell now basically looks like KDE or GNOME.
I preferred the old one, but it's a mere personal preference rather than
a strong opinion.
Subject: Re: less
Date: 19 Oct 2012 18:06:56
Message: <5081cf00@news.povray.org>
On Fri, 19 Oct 2012 22:10:57 +0100, Orchid Win7 v1 wrote:
> If it's Linux, then this never, ever, under any circumstances, works.
> It's /supposed/ to work; they provide Linux-compatible packages. They
> just don't /work/.
No, it would be accurate for you to say that you've never gotten it to
work.  It's not accurate for you to say it never, ever, under any
circumstances just cannot possibly be made to work by anybody ever in the
entire universe.
The counter example?  I've used the VMware Tools in Linux guests, and
they've worked perfectly.
Jim
Subject: Re: less
Date: 19 Oct 2012 18:13:21
Message: <5081d081$1@news.povray.org>
Me too. So there's at least two of us against one Andrew ;-).
> Jim
-Aero
