POV-Ray : Newsgroups : povray.off-topic : Excel 2007 ?? Server Time
10 Apr 2026 23:57:44 EDT (-0400)
  Excel 2007 ?? (Message 1 to 4 of 4)
Subject: Excel 2007 ??
Date: 6 Mar 2012 08:10:01
Message: <web.4f560b7b11e73672c2421da0@news.povray.org>
I've got a spreadsheet here of employee schedules. Each column represents an
employee, and each row a date. A typical column would look like:
Name
off
off
off
---start
work
work
work
work
work
---end
off
off
off
Looking for a tip for the best way to change the start and end rows and have the
rest update. I know there's a scripting language, but I'm looking for a solution
that won't scare others away. The current copy-paste method being used is
producing a lot of errors.
Subject: Re: Excel 2007 ??
Date: 6 Mar 2012 09:11:16
Message: <4f561b04$1@news.povray.org>
Do you mean put the end rows where the start rows are?
If so select the rows, cut the go to the first start row. Right click
and insert cut cells.
If that is not what you mean, please explain further.
Regards
Date: 6 Mar 2012 09:40:00
Message: <web.4f5620a66c83198d3771cd8e0@news.povray.org>
> Name
> off
> off
> off
> ---start
> work
> work
> work
> work
> work
> ---end
> off
> off
> off
You can do something like that:
=If(OR(C4="";C4="end");"off";IF(OR(C4="start";C4="work");"work";"off"))
Put that in cell C5 (that's where I started) and copy it wherever you need it
It will fill out all cells with "off" if the cell above is anything but "start"
or "work", and anything after "end" is "off" again.
Regards
Aydan
Date: 6 Mar 2012 13:57:34
Message: <4f565e1e@news.povray.org>
 >need it
 >but "start"
Similar effect would be with this formula in the cell C5:
   =if((C4<>"---start")*(C4<>"work");"off";"work")
or, if the list separator is not";" but "," :
   =if((C4<>"---start")*(C4<>"work"),"off","work")
