POV-Ray : Newsgroups : povray.off-topic : Is my life easier yet? Server Time
24 Jun 2026 00:38:29 EDT (-0400)
  Is my life easier yet? (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Is my life easier yet?
Date: 5 Oct 2021 22:19:54
Message: <615d07ca$1@news.povray.org>
On 2021-10-04 7:01 PM (-4), Jim Henderson wrote:
> It sounds like you probably need to do a rebase.  I don't know how to do
> that in git-cola, but basically a pull just pulls the changes from the
> remote repository.  A rebase "is the process of moving or combining a
> sequence of commits to a new base commit. Rebasing is most useful and
> easily visualized in the context of a feature branching workflow." (from
> https://www.atlassian.com/git/tutorials/rewriting-history/git-rebase)
> What I might be inclined to do (I work from the CLI) is:
>  git stash
>  git pull --rebase
>  git stash pop
> Stash puts your changes in a ... stash.  (I know, kinda useless self-
> referential definition).  It sets them aside.  The pull --rebase does the
> rebase, basically making sure you have a clean copy of the upstream repo.
> The stash pop then re-applies the diffs that you stashed.
> From there you should be able to do a commit.
> Of course, if you're the only one committing to the repo, then it's
> unlikely that the remote repo is out of sync with your local copy.
Thanks.  I think the problem was that I obediently added the description
and license, and that caused the conflict with the local repo.  I just
deleted the GitHub repo and started over.  I figure I can add the
description and license later.
I found this tutorial on YouTube.  I still have questions, but it's been
helpful.
  https://youtu.be/RGOj5yH7evk
Date: 5 Oct 2021 23:18:53
Message: <615d159d$1@news.povray.org>
>>  git stash
>>  git pull --rebase
>>  git stash pop
Damn.  I added a license and readme to GitHub, tried to pull the changes
to my local repo, and it's still giving me exit status 128.  Do I have
to do this rebase thing every time I make a change?  Why does every
simple thing have to be so freaking complicated?
Date: 6 Oct 2021 12:09:09
Message: <615dca25$1@news.povray.org>
>>> do that in git-cola, but basically a pull just pulls the changes from
>>> the remote repository.  A rebase "is the process of moving or
>>> combining a sequence of commits to a new base commit. Rebasing is most
>>> useful and easily visualized in the context of a feature branching
>>> workflow." (from
>>>  git stash git pull --rebase git stash pop
>>> the rebase, basically making sure you have a clean copy of the
>>> upstream repo.
>> description and license, and that caused the conflict with the local
>> repo.  I just deleted the GitHub repo and started over.  I figure I can
>> add the description and license later.
A rebase shouldn't be needed every time - how did you add the license/
readme to github?
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 6 Oct 2021 22:55:16
Message: <615e6194$1@news.povray.org>
> readme to github?
When you create an empty repo on GitHub, it encourages you to create a
readme and a license as part of the creation process.
For the rest of my modules, I sidestepped the problem by creating the
readme and license files in my local directories, and uploading them as
part of the initial push.
Date: 7 Oct 2021 08:40:08
Message: <615eeaa8$1@news.povray.org>
>> readme to github?
Ignore that last answer; it's not just that all this wrestling with Git
has caused me to lose track of days, it has caused me to lose track of
my state of confusion.  Actually, after I pushed the project to GitHub,
I used the buttons dedicated to adding the readme and the license.
Date: 8 Oct 2021 11:12:20
Message: <61605fd4$1@news.povray.org>
>>>> changes to my local repo, and it's still giving me exit status 128.
>>>> Do I have to do this rebase thing every time I make a change?  Why
>>>> does every simple thing have to be so freaking complicated?
>>> readme to github?
Once done, you probably just needed to do a pull before making additional
changes in your local copy.  But since those would be the only files that
changed upstream, a rebase (or the stash option I mentioned earlier)
should resolve it.
The only time a rebase should be necessary is if there are changes both
remote and local that need to be reconciled, IIRC.
Jim
Date: 11 Oct 2021 10:50:00
Message: <web.61644e62505a3a0d16086ed03f378f2@news.povray.org>
> >>> readme to github?
> should resolve it.
> Jim
Please the experts correct me if I'm wrong, but here is the beliefs that have
kept me relatively out trouble for a while:
Almost number one thing to understand, maybe someone already explained: but
Remember that commit and push are two different actions (picture attached) and
that you have to do both every time you "finalize" some changes so that your
local(commit) and remote(push) repositories stay in synch.
Git is specific because it is decentralized (every developer works on a local
duplicate copy of the whole project tree) and its workflow can be pictured as a
raft boat floating on the water of that remote whole project, because you can
keep your local changes floating over the changes made by other people while you
were working, by doing a pull --rebase (think of your changes as being held
aside, the other dev's update done
and then your updates layered over as if they had been made after.)
So, it is best practice to *always* do that pull --rebase (avoiding many
blocking  "repo not clean" error) at least before pushing your changes and also
additionally anytime you suspect some remote changes may impact your current
work to correct it accordingly and avoid drafty history.
Date: 11 Oct 2021 15:45:07
Message: <pan$2db8c$b4b33f8a$8131d6d2$f8c8b827@nospam.com>
> have kept me relatively out trouble for a while:
> but
> attached) and that you have to do both every time you "finalize" some
> changes so that your local(commit) and remote(push) repositories stay in
> synch.
That is correct.  Commit just creates a revision in the local repo.  Push
uploads your commits to the remote repo.
> local duplicate copy of the whole project tree) and its workflow can be
> pictured as a raft boat floating on the water of that remote whole
> project, because you can keep your local changes floating over the
> changes made by other people while you were working, by doing a pull
> --rebase (think of your changes as being held aside, the other dev's
> update done and then your updates layered over as if they had been made
> after.)
> and also additionally anytime you suspect some remote changes may impact
> your current work to correct it accordingly and avoid drafty history.
That is a good practice, certainly - I was going with the assumption that
Ricky was the only committer to his repo.
It's generally considered best practice for developers to work in their
own branches, and then to merge their branch back with the main branch
when their work is done.
That way, multiple developers can be working on different things without
stepping on each other - and the merge is the right place to resolve any
conflicts.  This also encourages (per Linus' intention in the design of
git) communication between developers, since file locking isn't a thing
that happens in git (some see that as a weakness; but file locking
encourages less communication, so I see where he's coming from).
(I'm nowhere near an expert, but this is just based on my experience
working with a development team)
Date: 11 Oct 2021 20:22:56
Message: <6164d560$1@news.povray.org>
On 10/3/2021 8:57 PM, Kenneth wrote:
> Cousin Ricky <ric### [at] yahoocom> wrote:
>> I think I've seen enough tutorials to learn the basics of Git, and I've
>> installed Git-Cola because I need an easy visual reference for what's
>> going on.
> Not that I know *anything* about this stuff, but...
> On the Wikipedia page "Comparison of Git GUIs", it lists 50+ apps there, or
> whatever they are. Perhaps there is another easier-to-use (and 'visual') tool
> than git-cola? It's workings sound like a nightmare to fathom, from your
> description.
I really really like SmartGit.
You can't get around having to understand the basics of git (what it
does), but SmartGit does a great job of burying it by default.
Date: 13 Dec 2021 14:26:32
Message: <61b79e68$1@news.povray.org>
On 02-Oct-21 17:10, Cousin Ricky wrote:
> Please don't ask me to use the command line. I cannot remember the CLI
> options from one hour to the next.
Do you only use 3D modelers to come up with POV-Ray scenes, and you use
POV-Ray as a backend only?
