POV-Ray : Newsgroups : povray.off-topic : Uh-oh Server Time
4 Mar 2026 13:56:13 EST (-0500)
  Uh-oh (Message 1 to 10 of 35)
Subject: Uh-oh
Date: 4 Jun 2017 08:36:37
Message: <5933fed5@news.povray.org>
The fan on my computer just became louder, and I thought I detected an
unpleasant smell during my last render.
Looks like I won't be doing any renders until I get the fan replaced.
Subject: Re: Uh-oh
Date: 4 Jun 2017 09:08:59
Message: <5934066b$1@news.povray.org>
Gulp! Good that you caught it early.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 02:49:12
Message: <5934fee8@news.povray.org>
Maybe cleaning away the accumulated dust on the fan will be enough. I
have experienced loud noises before and that was the solution (with
compressed air... carefully).
Subject: Re: Uh-oh
Date: 5 Jun 2017 03:26:53
Message: <593507bd$1@news.povray.org>
I've never thought that using compressed air was a good idea. Unless you
can take the fan out of the machine it just blows it elsewhere. And they
are expensive. I use a clean paintbrush and a vacuum cleaner with an
extension.
About a month ago I noticed a fan on my PC that I had not cleaned for 3
years. It took me over an hour to get access to it and I had to remove
the fan controller. Now one of fans is reporting a speed of zero. The
temperature is okay but I will need to strip the m/c down again to check
it. The fan controller is not very good. (AeroCool Touch-2000)
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 05:38:22
Message: <5935268e$1@news.povray.org>
Got it! :-)
The sensor wire was loose in the connector. I didn't notice it until I
was putting it back together.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 07:23:22
Message: <59353f2a$1@news.povray.org>
> extension.
There is that, however it did the trick for me :-) I got rid of the dust
somehow...
Subject: Re: Uh-oh
Date: 5 Jun 2017 07:42:51
Message: <593543bb$1@news.povray.org>
First thing I tried.  Didn't work.
Subject: Re: Uh-oh
Date: 5 Jun 2017 08:22:29
Message: <59354d05$1@news.povray.org>
If it is making a squealing noise. This might be a short term fix.
In the olden days. If you removed the sticky back cover in the centre of
the fan. There was a small hole where you can put a drop of machine oil
on the bearings.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 09:16:54
Message: <593559c6$1@news.povray.org>
> on the bearings.
It's vibrating.  I'm afraid it's going to shake something loose.  I
think it already has.
A replacement can be had for US$12 on Amazon, and I think would be
totally worth it.  The hardest part would be a software guy like me
fiddling with screwdrivers.  I will most likely end up buying from an
off-island supplier who posted a video on how to do the replacement, for
considerably more than $12.  I'd consider it a gratuity for the video.
I'm looking to buy a replacement power cord for them as well.  My
battery won't charge, which is serious, because my backwards third world
country has power outages almost every day.  I've exhausted almost all
local options; the last chance is paying OfficeMax through the nose for
a Genuine Dell power cord, and the remote supplier has 'em cheaper.
(But then there is shipping.)
Subject: Re: Uh-oh
Date: 5 Jun 2017 10:33:24
Message: <59356bb4$1@news.povray.org>
>> on the bearings.
My first guess would be a broken fan blade throwing it off balance. Or
it could be the bearings.
> totally worth it.
Yes, totally, totally. :)
You might consider buying the fan from Amazon and using the video for
instructions. If the Amazon fan is a genuine replacement. That would be
best. If you are not confident doing it yourself. It might be an idea to
ask one of the computer repair shops to do it for the cost of the labour
if you supply the parts.
You mention that your battery not charging, is it a laptop? That might
make a difference to how easy it is to do.
The next bit of advice will have people screaming. I always use a  1/8"
terminal screwdriver instead of a Phillips or crosshead screwdriver.
Because if Dell use propriety screws you will strip/round the head if
you don't have the right type. (Speaking from long experience on this.)
it goes against the grain but it works for me. And buy the cheapest not
the fancy type. They should be about a dollar or 10 bucks for ten.
Something like this:
http://www.ebay.co.uk/itm/Neill-Tools-Terminal-Screwdriver-100mm-Slotted-P18-4-/152480558413
A small shifting spanner (adjustable wrench) on the end acts as a torque
bar to start them off. (It often makes a cracking sound as if the
plastic has broken.)
BTW keep the screwdriver vertical so it does not slip. [Important]
I hope I am not trying to teach you to suck eggs. :)
> a Genuine Dell power cord, and the remote supplier has 'em cheaper. (But
Are you sure it is not the battery? Every one of my laptop batteries has
died the death because I keep my laptop plugged in. They don't like it.
Regards
