POV-Ray : Newsgroups : povray.off-topic : Linking Server Time
15 Jun 2026 10:28:28 EDT (-0400)
  Linking (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Linking
Date: 29 May 2016 03:48:43
Message: <574a9edb$1@news.povray.org>
On 29/05/2016 06:37 AM, Warp wrote:
> Executable files contain references to dynamically loadable libraries,
> and when you execute such a file, the OS will insert function calls
> into said executable to point to whichever dynamically loadable library
> it needs (which the OS also loads or, most usually, is already loaded
> into memory because most of everything else needs it too.)
I don't have any direct experience with that.
I was *about* to say that I've only done it with AmigaOS - but that's
not quite right. What I was *actually* looking it is calling *the OS*,
which is a bit different.
The way AmigaOS does it, memory address 0x00000004 holds a pointer to
the function table for exec.library. Every function in the library has a
known index in that table, so by adding your index to the address
pointed to, you get a function pointer to the actual library function
that you want. Now since exec.library is the one that contains the
functions to load *other* libraries, from here you can open any other
library you want. This similarly returns a function table base pointer,
which you can use in the same way.
Of course, exec.library is in ROM, as are most of the low-level system
libraries [including the entire GUI]. But you don't need to care about
that. Just call OpenLibrary(), and it'll load from disk if required, and
ultimately give you back a base pointer.
Presumably any self-respecting protected-mode OS does it differently. In
particular, calling the kernel presumably implies a transition to
ring-0, and I don't remember how x86 does that exactly. (From what I
dimly recall, you purposely trigger a kind of software interrupt, but
I'm not sure how you designate what function you're trying to call.)
 From what I can tell, C code does not call the Linux kernel. C code
calls glibc, which then calls the kernel on your behalf. (As evidenced
by several manpages that describe a glibc function and a kernel function
of identical name but subtly different behaviour...)
> The idea with dynamically loadable libraries is, of course, to save
> memory and increase efficiency. Since 99.9% of all executables use
> the same system functions, it's more efficient to have them all share
> the one and same library in memory than to statically link all those
> megabytes of system library code into every single executable.
This gets entertaining when you have one program that uses a dozen
libraries that nobody else is using. Or when every single program on the
system uses a different version of the same library, so they all supply
their own version of it. Then again, if old code doesn't work with a
newer version of some dynamic library, who's fault is that?
Date: 29 May 2016 04:54:22
Message: <574aae3e@news.povray.org>
> work with a newer version of some dynamic library, who's fault is that?
That's why the version numbers of a dynamic library is usually part of the name, even
if a link is available from the name without version.
Of course, it took some time for folks to understand why it is better than a
msvcrt.dll (same name for different versions).
Date: 31 May 2016 13:50:34
Message: <574dceea$1@news.povray.org>
Am 29.05.2016 um 09:26 schrieb Orchid Win7 v1:
>> The linker will later use that table to update those memory locations.
> Oh, I see. So, what, the jump op-code says to jump to address zero, and
> the object metadata tells the linker which bytes to change?
Yup.
>> You /could/ look it up... you know, they have this fancy new thing
>> called the Internet, and search engines and things ;)
> Don't you start. I've already spent a day looking at the output of nm,
> objdump and readelf. :-P The manpages tell you what all the switches do,
> but I still have no idea what .text is supposed to mean.
I haven't ever looked at any of those, but when I hear "text" in the
context of linking, I think of the "text segment", which is where all
the instructions will be stored (aka "code segment" as Intel would call it).
>>> For that matter, is it possible to store *data* in an object file? (As
>>> opposed to executable code.)
>> Absolutely. See the `source/base/font/*.cpp` files in the POV-Ray source
>> code for examples.
> Hmm. Interesting.
>   extern const unsigned char font_timrom[36936]={...
> I didn't think you could make an array const. (Wouldn't that just mean
> the array pointer itself is constant? Not the array it points to.) And I
> thought extern means "this is declared somewhere else"?
The "const unsigned char FOO[...]={...}" means that FOO is an array of
constant unsigned chars.
Without the "const", it would mean that the array, although initialized
at startup, could be tampered with later.
As for the "extern" that keyword does /not/ denote that the thing is
defined(!) "somewhere else", but that the thing "has external linkage",
i.e. is shared by multiple translation units (= .c or .cpp files).
Some library authors seem to go to great lengths to declare stuff as
"extern" when their header files are included from code that uses the
library, but leave out that "extern" when included from the library
itself; I currently don't know why they do that -- according to the C
and C++ standards this can only work because most stuff is implicitly
"extern" anyway unless explicitly declared "static".
It so happens that "const" stuff is one of the few things implicitly
"static" unless explicitly declared "extern".
> [Also... Heh, do you know, when you said it, I was thinking I'd be able
> to browse the source online somewhere. Silly me...]
Silly you indeed for not figuring out that you can indeed browse the
source code on GitHub ;)
https://github.com/POV-Ray/povray/tree/master/source/base/font
Date: 31 May 2016 14:58:24
Message: <574dded0@news.povray.org>
Am 29.05.2016 um 09:48 schrieb Orchid Win7 v1:
That's pretty simple: You pass a kind of function ID in a particular CPU
register.
For instance, in good old DOS, the sole entry point for all operating
system functions was INT 21h, with the AH register indicating which
function you intended to call.
According to Wikipedia, Linux originally used pretty much the same
principle, except with INT 80h and the AX register.
Windows also uses the AX register to identify the kernel function, but
uses the faster dedicated SYSENTER instruction (introduced with the
Pentium II) instead of a software interrupt. (The drawback is that this
instruction doesn't push a return address onto the stack, so a CALL to a
stub is usually employed.)
Likewise, Linux running on modern machines also uses SYSENTER or the
even newer SYSCALL.
The x86 architecture also provides a mechanism known as a "call gate",
which uses a CALL FAR instruction to a segment specifically set up by
the operating system to redirect the call to an entirely different
address while switching privilege level. This mechanism was used by some
operating systems, but has gone out of style. Not sure whether those
systems used a single call gate and a register to pass a function ID, or
whether they used one call gate per kernel function.
Date: 1 Jun 2016 03:22:28
Message: <574e8d34@news.povray.org>
Not a protected-mode OS, but in RISCOS on ARM there is an instruction
"SWI" that triggers a software interrupt. There are 24 bits spare in
that instruction to specify the routine number (the other 8 to identify
the instruction itself and conditional execution flags etc). Routines
have a name and a number, the OS maintains a list if you can only
remember the name (in fact most compilers/interpreters will allow you to
write the name, and automatically substitute the number to the
instruction). The processor registers r0 up to r8 (IIRC) were passed on
to the SWI handler code and returned, so these were used for parameters
and return values.
It was possible to add your own routines to this system, in fact this is
how almost all 3rd party libraries (eg music players, image converters,
compression software,...) were written. The equivalent of how DLLs are
used today I guess.
Date: 1 Jun 2016 12:59:28
Message: <574f1470$1@news.povray.org>
> register.
That's essentially a direct call to the BIOS itself, isn't it? Or does
MS-DOS actually interact with this somehow? (I realise that MS-DOS is a
very thin "OS", if you can even call it that.)
OK...
> even newer SYSCALL.
OK, fair enough.
Both IA32 (and later AMD64) are quite short on registers, which is
presumably why the default C calling convention is seemingly via the
stack. In AmigaOS, running on a Motorola 68000 with a dozen registers,
most of this stuff is via register...
Yeah, I remember reading about that in the IA32 reference manual. I
can't recall the details of how it works though.
OK. Sounds like there's not much point remembering then.
Date: 2 Jun 2016 01:23:06
Message: <574fc2ba$1@news.povray.org>
Am 01.06.2016 um 18:59 schrieb Orchid Win7 v1:
No; the BIOS uses the same principle, but different interrupts.
BIOS-level disk I/O, for instance, uses INT 13h.
Don't worry, the IA32 reference manuals recall the details pretty well ;)
Date: 2 Jun 2016 04:49:05
Message: <574ff301$1@news.povray.org>
Am 2016-06-02 01:22, also sprach clipka:
I haven't been inside of Windows since ... XP.  Do they *still* use
that?  I recall an early Linux decision was to get the hell away from
the BIOS asap and stay away.  -- Device drivers uber alles.
(I kept waiting for M$ to invent the swap partition, to speed things up
a little.)
I was always annoyed that when M$ bought Seattle Computer Products' DOS,
they didn't rearrange the function numbers before releasing it.  It
would have been nice if the disk functions were grouped together for
when referring to The Green Book.  Instead, it was obvious that as each
function was added, it just went to the end of the list. So,
open/read/write/close were like 5/6/7/8. Then delete was 23, rename was
54. A real pita for book referring.
dik
Date: 2 Jun 2016 05:49:39
Message: <57500133$1@news.povray.org>
Am 02.06.2016 um 10:49 schrieb dick balaska:
On machines without UEFI support, both Windows AND Linux still use the
BIOS... for the very first phase of the boot procedure.
From then on, Windows doesn't look back at the BIOS either. It may keep
the BIOS' assignments of resources (I/O addresses, interrupts and DMA
channels) to hardware components, but that's about as far as the BIOS'
influence on the running system goes.
The decision is actually a very pragmatic one: The BIOS has always been
designed to run in 16-bit Real Mode, and invoking it from 32-bit
protected mode (not to mention 64-bit long mode) would add a shitload of
overhead. The 16-bit mode also limits the efficiency of the driver code
itself.
Date: 2 Jun 2016 13:43:07
Message: <5750702b$1@news.povray.org>
> I haven't been inside of Windows since ... XP. Do they *still* use that?
> I recall an early Linux decision was to get the hell away from the BIOS
AFAIK, both Windows and Linux use the BIOS to figure out your hardware
layout early in the boot sequence... and then never touch it ever again.
Basically, once the OS kernel has figured out your memory map and which
regions to not clobber, it switches to its own native device drivers,
exits real mode and enters protected mode, and never looks back.
[U]EFI changes this, in that it allows a protected-mode OS to directly
request services from it. Even so, nobody really uses this except for
boot configuration tasks. (If only because your OS still needs to work
on old BIOS systems as well...)
