POV-Ray : Newsgroups : povray.off-topic : Today's WTF Server Time
27 Jul 2026 21:55:52 EDT (-0400)
  Today's WTF (Message 61 to 70 of 75)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Today's WTF
Date: 29 Oct 2015 07:37:52
Message: <56320510$1@news.povray.org>
> On the Pi, until you poke the GPU, the CPU isn't even *turned on*...
Did you look here:
https://www.cl.cam.ac.uk/projects/raspberrypi/tutorials/os/index.html
The benefit of the pi over IBM-compatible is that (IMHO) the assembler
is much easier to learn and use.
I think if children could see their simple first creations running on
their smartphone or tablet that would encourage them a lot. However you
need a massive chunk of experience and knowledge to even *install* the
Android SDK, let alone start writing a new app.
Date: 29 Oct 2015 13:15:05
Message: <56325419@news.povray.org>
On Thu, 29 Oct 2015 06:35:54 +0000, Stephen wrote:
> On 10/28/2015 11:25 PM, Jim Henderson wrote:
>> So many questions.
> Are we there yet?
On first. :)
>> I think you did it for the points.;)
> And points mean...?
Junctions on railroad lines, naturally. ;)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 29 Oct 2015 14:50:56
Message: <56326a90$1@news.povray.org>
On 10/29/2015 5:15 PM, Jim Henderson wrote:
>> And points mean...?
> Junctions on railroad lines, naturally.;)
Oh! I thought it was 1⁄72 of an inch.
Thanks for that. :-P
Regards
Date: 29 Oct 2015 15:03:12
Message: <56326d70$1@news.povray.org>
Yeah, I haven't done a lot with x86 assembly, but with 40 years of
backwards-compatibility, it's pretty complicated. And ugly to start
with, it seems! (Well, it was originally designed for low-cost pocket
calculators, not supercomputers!)
I often wished more stuff could be like the Motorola 68000. That seemed
like a really nice architecture to work with.
Agree.
> However you
Also agree!
Date: 29 Oct 2015 20:05:17
Message: <5632b43d$1@news.povray.org>
>>> And points mean...?
> Oh! I thought it was 1⁄72 of an inch. Thanks for that. :-P
Always glad to be of service. :)
Jim
Date: 30 Oct 2015 01:28:56
Message: <56330018$1@news.povray.org>
On 10/30/2015 12:05 AM, Jim Henderson wrote:
> Always glad to be of service.:)
Regards
Date: 30 Oct 2015 04:48:02
Message: <56332ec2$1@news.povray.org>
You could probably explain the vast majority of ARM assembler in a
single newsgroup post. The syntax is very simple, and the mnemonics are
mostly obvious or very easy to remember. You're free to use any register
for source or either of the destinations, and all registers are the same
bit-width.
>> However you
> Also agree!
Someone needs to write a wrapper to go on top of the Android SDK that is
a) easy to install and b) uses an easy language that allows you to just
start writing commands to draw stuff without tons of boiler-plate code.
Date: 30 Oct 2015 14:02:27
Message: <5633b0b3$1@news.povray.org>
> bit-width.
The M68k has 8 "data registers" and 8 "address registers", which you can
freely use for any purpose (although the address registers are somewhat
optimised for holding addresses).
x86 has... what... FOUR main registers? And the FPU register stack...
which is also the MMX registers... but then a separate set of XMM
registers added for the SSE instruction set?... but then SSE2 made them
wider, so there's XMMX... WHAT THE HELL IS GOING ON?!?!
I gather ARM is quite a popular architecture. I don't know whether
that's because there's readily available chips and IP-cores, because
it's low-power, or because it's really easy to program...
Meh. Just use Haskell. ;-)
(Seriously, people occasionally ask about cross-compiling to ARM. I
can't think of any other reason why somebody would do that. Apparently
it even *works*, vaguely...)
Date: 2 Nov 2015 03:25:59
Message: <56371e17$1@news.povray.org>
Backwards compatibility is what's going on.
Low power.
Date: 2 Nov 2015 08:01:35
Message: <56375eaf$1@news.povray.org>
The root of all evil, right there.
But hey, Intel invented the Itanium to get away from all that... and
nobody bought it.
> Low power.
Why is that? It is because there's something particular about this
instruction set which makes it especially suitable for low power? Or is
it merely that a lot of people have spent R&D on making low-power
implementations of it?
