POV-Ray : Newsgroups : povray.off-topic : Gravitation Server Time
15 Jun 2026 15:50:30 EDT (-0400)
  Gravitation (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Gravitation
Date: 19 Oct 2015 03:18:55
Message: <5624995f$1@news.povray.org>
> What happens is that Earth, by virtue of having mass, gobbles up space
> inside and around it. Always. Constantly. Whether there are any apples
> out there or not. (So does the apple, but that's negligible compared to
> Earth's dietary budget.) There's no acceleration or even movement
> involved there /per se/ - in the vicinity of matter, distances just
> shrink over time. Fast.
> If it was only for this mechanism, earth would shrivel to nothingness in
> a matter of... minutes? hours? Dunno, but certainly in less than a day.
> Space between the elementary particles would just shrink to zero.
> Fortunately, electromagnetic force comes to our rescue: The electron
> clouds of any two atoms in the universe repel each other. Partially this
> is compensated by the fact that the electron clouds of any atom  in the
> universe also attracts the nucleus of any other atom, but on average the
> net EM force is repelling. And there are a lot of atoms in the Earth. So
> the atoms making up earth constantly accelerate away from each other.
> Earth is exploding.
If gravity (or rather, mass) causes space to contract and get gobbled
up, this must mean then that EM forces (and other equations?) must
somehow be able to measure distances "outside" of this distorted and
gobbled up space? There must be an external "real" space that is somehow
related to the distored spacetime by the distribution of mass around.
Date: 19 Oct 2015 10:06:35
Message: <5624f8eb@news.povray.org>
Am 18.10.2015 um 16:29 schrieb Stephen:
>> Also, think of this: If you throw an apple, it moves through space in a
>> /straight/ line - any apparent curvature of its trajectory is due to
>> Earth's surface constantly accelerating upwards. Not towards the apple
>> but away from Earth's center. In a lump of space that's busy shrinking.
> If you say so. But consider using another inertial frame of reference.
> One that contains both the Earth and the apple. Which object, the Earth
> or the apple, travels a greater distance in the same time frame?
> I hazard a guess that it will be the apple that has the greater velocity
> and thus acceleration.
Whatever frame of reference you choose - if it is truly inertial, you'll
always find the apple (while airborne) moving at constant velocity (or
remaining at rest, which is a special case thereof), and Earth's surface
accelerating radially from its center at 9.81 m/s^2. (As long as you
ignore aerodynamic drag and remain sufficiently close to Earth's surface
and the apple, that is.)
(Hint: What makes a frame of reference inertial? The fact that it
doesn't accelerate. How can you test it? By releasing some item with an
initial velocity of v=0 relative to the frame of reference, and
verifying that the item remains stationary. If you like, do the
experiment inside an elevator cabin with no windows.)
Date: 19 Oct 2015 10:14:03
Message: <5624faab@news.povray.org>
Am 19.10.2015 um 09:18 schrieb scott:
No, there's no need for any "meta-space". In the vicinity of any mass,
EM forces still propagate according to Maxwell's wave equations through
whatever space is there at the very moment the wavefront traverses it.
Which is exactly why light appears to "bend" around massive objects.
Date: 19 Oct 2015 11:18:42
Message: <562509d2$1@news.povray.org>
I suppose that the EM waves travel very much faster than the space is
getting distorted, so in terms of the "reaction time" of atoms being
able to move to keep up it is no problem at all. Until you get to a
black hole :-)
Date: 19 Oct 2015 13:44:48
Message: <56252c10$1@news.povray.org>
On 10/19/2015 3:06 PM, clipka wrote:
> and Earth's surface
I know it is the psilocybin mushroom season but I thought I was the old
hippy who had taken mind bending substances (in the past, I might add in
case PC Plod is listening).
You have lost it dear friend.
You have lost it.
Regards
Date: 19 Oct 2015 17:06:30
Message: <56255b56$1@news.povray.org>
Am 19.10.2015 um 19:44 schrieb Stephen:
>> and Earth's surface
> You have lost it.
Just following Einstein's train of thoughts. No shrooms growing there.
Date: 20 Oct 2015 11:24:11
Message: <56265c9b@news.povray.org>
>>> and Earth's surface
>> You have lost it.
Pity cause they would go well with the potatoes in my ears. :-)
Assuming that you are not trying to wind me up.
What are your reasons for saying that? If your frame of reference was
the apple I would agree with you. But I was talking about a frame of
reference separate from both of the objects.
> and Earth's surface
To me that reads that the Earth's surface (and volume) is expanding.
Something I personally haven't noticed.
Since we are talking about speeds of metres per second I assume we can
dismiss any relativistic effects.
Can you explain why a force of one Newton acting on a mass of 5.97E+24
Kg can produce an acceleration of 9.81 m/s^2?
I make it 0.000000000000000000000000167504 m/s^2
> (As long as you
Granted.
Regards
Date: 20 Oct 2015 17:45:53
Message: <5626b611$1@news.povray.org>
Am 20.10.2015 um 17:24 schrieb Stephen:
Okay, so you agree that the dropping apple's frame of reference is an
inertial one.
Then by definition of what constitutes an inertial frame of reference,
all (sufficiently local) frames of reference in which the apple appears
to be moving at constant speed are inertial, while all in which the
apple appears to be accelerating are non-inertial.
Now no matter what frame of reference you choose, you'll find that
Earth's surface and the apple appear to be accelerating towards each
other; thus any frame of reference in which the apple isn't
accelerating, must have Earth's surface accelerating towards it instead.
>> and Earth's surface
That's because it is in equilibrium with the collapse of space.
What you should be able to notice is you being subject to acceleration:
If someone locked you in an elevator cabin, you couldn't tell the
difference between being "stationary" on Earth's surface, and being
subject to an acceleration of 9.81 m/s^2 in deep space.
Because there is no difference.
Strictly speaking we can't, as the whole thing /is/ a relativistic effect.
No, but why should I?
- Not all of Earth's mass is accelerating at 9.81 m/s^2; the deeper you
go, the smaller the acceration, until it drops to zero at Earth's center.
- I have no idea where you got the one Newton from. The actual force
pushing Earth's surface outward is about _ten_ Newton _per kg of surface
mass_. More precisely it is 9.81 N/kg. Or 9.81 m/s^2.
Yup, that's a mind-bogglingly huge total force acting on Earth's mass.
But electromagnetic forces between atoms under pressure /are/
mind-bogglingly huge.
Date: 20 Oct 2015 23:34:57
Message: <562707e1$1@news.povray.org>
> inertial one.
No, I don't. I selected an observational frame of reference where I
could observe both objects, a few posts back.
I am having difficulty with that. My chosen frame of reference is
inertial and both the apple and Earth are accelerating. Albeit a very
small acceleration in the case of the Earth.
I agree with that.
>>> and Earth's surface
No. I read radially as meaning "Radiating from or converging to a common
centre." Not along a radius.
A bit of a slap in the face with a wet fish. *
Misunderstanding understood.
With a pendulum you could but who am I to teach my grandmother to suck
eggs when it comes to nitpicking. ;-)
Because I asked nicely.
Great! a mass of round about 100 grammes distorts the Earth's surface.
Rough and ready:
http://hypertextbook.com/facts/2004/WaiWingLeung.shtml
Personally I prefer to pick my frames to make sense in the real world.
If you can't hit it with a hammer or build a bridge out of it. Then it
is just an interesting thought.
I found this Wiki entry
https://en.wikipedia.org/wiki/Wikipedia:Whacking_with_a_wet_trout
Regards
Date: 21 Oct 2015 05:37:19
Message: <56275ccf$1@news.povray.org>
Am 21.10.2015 um 05:34 schrieb Stephen:
Then tell me, how do you know that your frame of reference is inertial?
Also note that you need to choose a frame of reference sufficiently
local to both Earth's surface and the apple, otherwise your frame of
reference will distort over time, which you'd then have to factor back
in to judge changes of distance over time.
Maybe one of the fundamental hurdles you need to take is this: Space
distorts over time, and changes in relative position do not necessarily
require an absolute movement of the objects involved.
No, as a matter of pure fact you couldn't (the pendulum thing; I don't
know about your grandmother and the eggs). Not unless you know something
that would win you the Nobel prize :)
>> effect.
Well, /any/ mass distorts the Earth's surface...
> Rough and ready:
Ah, I see - so I understand that you're still obsessed with the apple
having anything to do with the whole smash, when in fact its effects are
(as you correctly note) negligible. It doesn't /cause/ the distortion of
space - that's by far and large Earth's job - its sole purpose is to
help /visualize/ it, by providing an intertial frame of reference.
Well, then you're not the target audience of my post, so move along,
there is nothing for you to see here ;)
