POV-Ray : Newsgroups : povray.off-topic : Display technology Server Time
13 Jun 2026 19:15:24 EDT (-0400)
  Display technology (Message 11 to 20 of 49)
Subject: Re: Display technology
Date: 13 Oct 2015 03:27:14
Message: <561cb252$1@news.povray.org>
> What about the blue/purple ones? You know, like they had on ancient
> laptop screens?
Passive matrix too. The key difference is there is no electronics
per-pixel to hold the voltage over the length of the frame, so the LC
response time must be very slow (much longer than 1 frame) to keep any
decent contrast. On an active matrix display the pixel electronics
(transistor + capacitor) can keep the voltage at whatever you last set
it to for the duration of a frame, so an LC material with very fast
response can be used (eg 1 or 2 ms is common now in monitors).
> Wow. I didn't expect it to be quite *that* cheap. Even a simple resistor
> costs more than that! (Or maybe it doesn't if you buy a thousand of
> them, IDK.)
If you want 1000 or more you don't buy them from maplin, RS or Farnell.
Try this:
http://www.aliexpress.com/item/High-quality-character-LCD-7-segment-LCD-module-3-3V-TN-positive-reflective/32293200442.html
cost must be significantly cheaper:
http://www.amazon.co.uk/Sharp-EL-240SAB-Calculator/dp/B0002I8VLU
>> Price is roughly proportional to screen area (the factory doesn't care
>> much how many screens it gets out of each "mother sheet").
> Linearly proportional? Or is it "more expensive" to buy really big screens?
Roughly linear - the factory costs to run are mostly independent of how
small they chop up the glass at the end.
The only complicating factor is yield. If you get a dead pixel within a
display then you can't sell it at the "dead pixel free" price. Obviously
if you are making two huge TVs from each sheet of glass it is much more
likely you have to scrap (or sell at a discount) 50% of the glass area,
but if you're making 200 mobile phone screens you might only have to
scrap 2 or 3 of them.
> OK. Again, that's not nearly as much as I thought. Makes me wonder why
> makes it a high-colour touch-screen device...
http://www.gearbest.com/lcd-led-display-module/pp_231779.html
> I imagine touch would be really expensive - but IDK...
The expensive bit in capacitive touch is the controller IC that does all
the processing. There is also a premium on this because of the IP that
has gone into the algorithms etc. The physical bit is very cheap, it's
just another sheet of glass with some quite chunky conductive layers.
> I don't know, but I'm guessing it must be reasonably expensive to
> something?)
A good rule of thumb for medium-volume consumer goods like that is that
the cost to manufacture is roughly 25%-33% of what you pay. The rest is
VAT, shipping/logistics, paying for everyone who works in all the
companies involved, and maybe a little bit of profit for each company
along the way.
> Sure, but you don't *make* the switch yourself, surely? You buy an
> off-the-shelf microswitch,
Someone else needs to make it though, my point was for their size/weight
switches are much more expensive than a sheet of bent metal because the
assembly costs are higher (whoever does it).
> machine is one of those rare objects that contains *metal*. Obviously
> it. IDK, but I doubt it. The machine is also probably quite awkward to
> physically assemble. And they're large and heavy, so storing and
> shipping probably isn't cheap.
You might be interested in something like this, it gives a detailed
breakdown of the costs of the parts in the latest iPhone (if you didn't
know this is a very high-end phone that is expected to sell in high
volumes):
http://www.techinsights.com/teardown.com/apple-iphone-6/
Date: 13 Oct 2015 15:17:49
Message: <561d58dd$1@news.povray.org>
>> laptop screens?
OK. So what's the difference between the silver ones and the purple ones?
>> them, IDK.)
[Rant] I remember when Maplin used to sell electronics. Now they're just
a white-box shifting company. You used to be able to go in and just
*buy* a string of 30 resistors or something. Now they're all like "oh,
you want 10? Ooo, we'll have to order those in specially. We only have 4
in stock." WTF?
> Try this:
That's... a dollar per display? Damn, you can't get too much cheaper
than that. I wonder what a Z80 costs these days...
Well, I guess that's true enough!
>> screens?
Yeah, I thought that might be the case.
Damn, that's not bad at all! I'm surprised nobody seems to be using these...
Interesting. I thought all the extra faff of assembling it was the
expensive part.
>> something?)
> along the way.
Interesting. And here I was thinking the metal is expensive. ;-)
Well, I guess.
Now you're typical calculator has one of those rubber keypads. I have
personally assembled those; it's a sheet of rubber, and there's some
wiggly traces under it. Presumably that's cheaper than a microswitch?
(Especially given a calculator has, like, *a dozen* buttons...)
> volumes):
This is interesting on several levels.
2. I didn't know this kind of disassembly was legal. I thought Apple
would try to sue you for distributing trade-secret information.
3. As expected, the display is the most expensive bit. (Then again,
isn't the iPhone kind of renound for having a particularly high-quality
screen?)
4. The next most expensive bit is the CPU, like you'd expect. The RAM
looks surprisingly cheap tho. (No idea how big it is, mind you!) I
wonder what kind of CPU... it... er... oh right, it's a custom ARM SoC.
5. I expected the battery to be way, way more expensive than that.
(Considering that battery life is extremely critical to product success,
you'd expect the best performance part that can possible fit in the space.)
6. I have no idea WTF "BB+XCR" is.
7. I enjoy that "Other" is nearly as expensive as the CPU.
8. Qualcomm manufactured my lawn mower. They make silicon too? WTF?
Subject: Re: Embedded technology
Date: 13 Oct 2015 15:44:28
Message: <561d5f1c$1@news.povray.org>
Actually, the Raspberry Pi is kind of interesting...
When I first heard about it, it was billed as the BBC Micro for the 21st
century. It's supposed to be a disposable-priced computer that will get
kids interested in computer programming.
...expect that you can realistically write bare-metal code for an 8-bit
PC with nothing more than a list of I/O register memory addresses and a
weak knowledge of binary. I actually did this as a 10 year old child on
my dad's Commodore 64. I wrote a tiny machine code program with pencil
and paper. (We couldn't afford an assembler program, but I had an opcode
table, and no friends or social life.)
By stark contrast, you can't do that on a Raspberry Pi. I mean, you
*literally* can't do that; the hardware specs for the GPU are propriety.
You can only look at them if you sign an NDA. Even Raspbian has to use a
closed-source binary blob to drive the video hardware. If the Linux
gurus of the Internet can't do this stuff, a kid has *no* chance! :-P
Yeah, it's kinda cool that you have this little circuit board that's
super-easy to hook up to your computer, and to control other stuff with.
But are kids really going to be that interested? Probably not.
Having looked around, it appears that the Raspberry Pi has actually
spawned an entire new market sector of imitators. There is now the
Orange Pi and the Banana Pi. (No, I'm not making this up!) Both made by
companies completely unrelated to the Raspberry Pi Foundation. There's
the utterly unpronounceable Arduino. There's the BeagleBoard and
BeagleBone. Indeed, it seems that single-board computers are a "thing"
now. Everybody wants a piece of the pie!
The specifications of some of these devices look amazing! For example,
while the most powerful Raspberry Pi system has a single-core 700MHz CPU
and 0.5GB of RAM, the Banana Pi has a dual-core 1GHz CPU and 1GB of RAM.
And the Orange Pi has a quad-core 1.6GHz CPU!
...and then you look at the price tag. And you realise why. The original
Raspberry Pi might have been designed to be a low-cost, disposable
component, but some of the more powerful boards are priced at *hundreds*
of dollars. You could buy an *actual* computer for that! (Although it
would be way bigger, obviously.) Just because it's a naked circuit board
with no case, doesn't automatically mean it's cheap. ;-)
Due to my boss existing, I've started reading Hackaday. I was amused the
other day to see that somebody is trying to build an open-source mobile
phone out of a Raspberry Pi. So... you're taking a SoC originally
designed for the mobile phone industry, and trying to make a mobile
phone out of it? What a rebel. LOL!
Still, the other day I found myself vaguely toying with the idea of
getting a small tablet, just so I can sit in the corner coding when
we're in a deserted forest or something. But why bother paying several
hundred pounds for a tablet if you can actually buy a Raspberry Pi and a
touchscreen for less than the cost of a pub meal?
Mind you... I've yet to actually *see* a Raspberry Pi on sale anywhere
for the reputed price of $15. :-P For example, Maplin want to charge you
(Oh, I'm sure the packet contains way more than just the circuit board.
But that's the only bit I actually *want*...)
Date: 13 Oct 2015 16:04:54
Message: <561d63e6$1@news.povray.org>
> in stock." WTF?
Funnily enough, I went into Maplins yesterday and bought 10 of 20 mm
6.3ma slow blow fuses, off the shelf. (As an after thought)
Regards
Date: 13 Oct 2015 16:15:01
Message: <web.561d65368e3e694a352a052d0@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> On 11/10/2015 08:43 PM, nemesis wrote:
> > orchid, do you ever submit your lengthy rants to
> > http://thedailywtf.com
> Why? Do you think I should? :-P
sure, why limit your reading audience to the tiny povray newsgroups?
your rants are often amusing...
Date: 14 Oct 2015 06:26:38
Message: <561e2dde$1@news.povray.org>
Am 13.10.2015 um 21:17 schrieb Orchid Win7 v1:
The colour ;)
No, seriously - the silver ones are the "reflective" type, designed to
use ambient light for illumination (sometimes exclusively, sometimes
with an optional "backlight" for situations where ambient light is too
low), while the purple ones are of the "transmissive" type, designed to
be always used with a backlight (usually dot matrix with active-white
pixels).
The whole idea of trade secrets is that you keep them secret /because/
you can't sue anyone if the information gets out into the wild.
Also, there is no way you can prohibit anyone from reverse-engineering
your inventions unless you make them sign a non-disclosure agreement.
For instance, once you have legally obtained a copy of a piece of
software, you can freely reverse-engineer it as long as you don't accept
the EULA (which in most cases means you can't install it, so you'll need
to reverse-engineer the installer as well).
What you often /can/ prohibit is the /use/ of the intellectual property
someone has reverse-engineered from your product.
I didn't know they made lawn mowers.
Date: 14 Oct 2015 06:31:51
Message: <561e2f17$1@news.povray.org>
Am 13.10.2015 um 21:44 schrieb Orchid Win7 v1:
Might be a different model. AFAIK there are four models by now: The
original A and B models, and the 2nd generation A and B.
Date: 14 Oct 2015 06:46:15
Message: <561e3277$1@news.povray.org>
No idea (we only made colour active matrix LCDs) - although I guess it
might have something to do with the silver ones being reflective and the
purple ones being transmissive (having a backlight)?
> in stock." WTF?
- Plan in advance and buy from ebay
- Buy one of those 1000 piece packs of resistors of various values for a
few pounds
- Get a job somewhere that has a ready supply of electronic components :-)
Interestingly even if a person goes through all the strictest clean room
processes and clothing requirements the yield still drops noticeably
when they go into the production area (and for some time after they have
left). For this reason usually nobody is allowed in there unless for a
very good reason.
> expensive part.
Even a whole minute of additional manual assembly time (which is a lot)
is surely cheaper than Atmel slapping a $0.50 premium on their latest
design. IIRC a few years ago they were still charging around $5-$10 (at
volume quantities) for the controller ICs, it's probably cheaper now
with patents expiring, much higher volumes and more competition etc.
It is compared to plastic :-)
BB is baseband (the phone/radio bit that nobody actually uses anymore),
no idea what XCR is.
That probably means a whole host of things like the PCB itself, various
connectors, screws, cables etc.
Date: 14 Oct 2015 06:50:41
Message: <561e3381$1@news.povray.org>
various pi's. I think Andrew is looking at those starter kits that
contain PSUs, USB hubs, cases, SD cards etc, and from Maplin which is
probably double the price of amazon by default.
Date: 14 Oct 2015 13:01:55
Message: <561e8a83$1@news.povray.org>
Yeah, I think their "kit" contains a large hard-back tutorial book, a
nice enclosure, a butt-load of peripherals and more. It might actually
don't actually *want* any of that stuff. I just want the device.
