POV-Ray : Newsgroups : povray.off-topic : A question for big brains. Server Time
15 Jun 2026 21:54:25 EDT (-0400)
  A question for big brains. (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: A question for big brains.
Date: 16 Nov 2014 11:42:39
Message: <5468d3ff$1@news.povray.org>
On 16/11/2014 15:48, Thomas de Groot wrote:
> On 16-11-2014 15:13, Stephen wrote:
>> The heat is taken from the air and the hand that is holding it. You can
>> feel the lighter getting cold and you can hear the butane rushing into
>> the lighter. The sound will stop when the pressure has equalised and the
>> lighter will continue to fill up.
> Such a long time since I stopped smoking that I only dimly remember
> these things. The cold comes from the gas expanding, right? Same way as
> a fridge.
Correct.
> Your last sentence seems contradictory to me. With equal
> pressure no further fill up, or am I wrong (probability: 98%)?
And the argument is: If it is not a difference in pressure then it must
be gravity that is making the liquid flow.
And because you do not have the opportunity to do the experiment
yourself. If when you are filling a lighter and you turn the system
upside down so that the lighter is above the gas cylinder. A lot of the
liquid drains into the gas cylinder. Gravity?
Some cigarette lighters have the chamber split into two by a dividing
weir. If you keep the liquid in the chamber underneath the valve. The
liquid will rise to the top of the weir and stop rising. No more gas
will go in. Then if you tip the lighter so that the liquid spills into
other chamber. The empty part (under the valve) can then be filled.
I first had this discussion 25 years ago and would quite like to know
the answer.
Regards
Date: 16 Nov 2014 17:00:01
Message: <web.54691e59d7fb850d5e7df57c0@news.povray.org>
It's sort of both.
Picture instead the ordinary case of filling a vessel with liquid at atmospheric
pressure through a narrow orifice.
At first there may be a rapid flow of liquid until the headspace gets compressed
and builds up pressure.
THEN there needs to be a chance for the gaseous headspace to bubble up and trade
volume with the liquid for there to be a mass transfer.
The problem lies in only one very narrow tube for bidirectional flow.
If there were a two-way filling mechanism, or a way to vent the gaseous
headspace, then you'd get rapid filling.
Another alternative might be to iteratively overfill with liquid by an increase
in pressure, or by chilling and contracting the headspace, and then letting the
back-pressure bubble up back into the fill vessel.
Date: 17 Nov 2014 03:27:51
Message: <5469b187$1@news.povray.org>
> It's sort of both.
I find this explanation neat, although I am not entirely satisfied
somehow. Imho the problem resides in the fact that the liquid is a
compressed gas which will want to expand as soon as there is a
possibility for it. I dimly remember that refilling a lighter often gave
frustrating results as it was impossible to refill up to the initial
level... with the exception of the use of a /pressurised/ filling mechanism.
Date: 17 Nov 2014 04:26:26
Message: <5469bf42$1@news.povray.org>
> But it is only liquid because it is under pressure. As soon as some
> liquid is in the lighter it vaporises to fill the chamber and if the
> resultant pressure is less than the pressure in the gas cylinder more
> liquid will go into the lighter until the system will reach stability.
>> Yes, adding liquid to the lighter gives back a bit of pressure for the
>> lighter's side, but not enough. The fresh liquid could vaporize to
>> provide more gas but that transformation requires a lot of heat which is
>> not available at the refill time.
I haven't had chance to think in detail what is happening (nor do I have
much experience with refilling lighters), but I suspect a good
understanding of vapour pressure and how it changes with temperature is
required:
http://en.wikipedia.org/wiki/Vapor_pressure
http://en.wikipedia.org/wiki/Butane_(data_page)#Vapor_pressure_of_liquid
Also bear in mind that it might not be 100% pure butane in the refill
(or there might be some air in the lighter), so you better also know
about partial pressure :-)
http://en.wikipedia.org/wiki/Partial_pressure
It sounds to me from what you describe that it's got something to do
with things heating up or cooling down, causing the vapour pressure to
change. An interesting experiment would be to prepare the lighter to be
cooler or warmer than the refill canister and note any difference in
behaviour when it is refilled.
Date: 17 Nov 2014 07:25:48
Message: <5469e94c$1@news.povray.org>
One possibility is that the sound you hear is actually a small amount of
gas flowing rapidly into the lighter (or liquid that instantly
evaporates as it hits the low pressure in the empty lighter) before the
liquid starts to flow through the opening. When the sound stops that
isn't because the pressure has equalised, just that it is liquid flowing
much slower then rather than gas flowing quickly.
Download 'croppercapture[7].png' (14 KB)
Preview of image 'croppercapture[7].png'
Date: 17 Nov 2014 09:09:42
Message: <546a01a6$1@news.povray.org>
>> a fridge.
> Correct.
Almost, but not fully.
The cold comes from the phase change from liquid to gas (It takes energy
to evaporate the liquid, and the liquid will happily do so, because the
equilibrium favors the gas phase (lower pressure on the cold side) If
there is not enough pressure on the hot side (i.e. not enough coolant)
to condense the gas to a liquid, the refrigeration is minimal to
nonexistent.
... As for the rest of the conversation, it's fascinating; I think it's
pressure difference that fills the lighter.
Date: 17 Nov 2014 10:07:10
Message: <546a0f1e$1@news.povray.org>
>>>> the
>>> a fridge.
>> Correct.
> nonexistent.
Ah! Thank you for that correction. Phase change indeed.
That's my best guess too.
Date: 17 Nov 2014 12:05:01
Message: <web.546a2a98d7fb850d5e7df57c0@news.povray.org>
Cooling in refrigeration is accomplished by adiabatic expansion of the
refrigerant gas - a rapid increase in the entropy due to the phase change from
liquid to gas.  From the ideal gas laws, P1V1/T1 = P2V2/T2   Change the pressure
and volume, and the temperature changes as a consequence.  See "Carnot cycle".
> possibility for it.
That's irrelevant once the pressure differential between the two containers is
equilibrated.  What evaporated into gas can be recompressed back into liquid.
> Thomas
Yes, when refilling with butane the filling container is obviously pressurized.
I believe that there are several interrelated issues here.
First, most people hold the butane refiller to the refilling valve, depress, and
then it's over and done with.  The system has not been given a chance to attain
equilibrium.
Second, there is likely to be a mixture of gases at play -
From http://lighterreviews.com/butane/  :
"Butane, is either of two isomeric flammable gaseous alkanes C4H10 usually
obtained from petroleum or natural gas and used as a fuel. Most butane for cigar
lighters is a mixture of of butane as noted above, isobutene , propane and a
small amount of air (yup the stuff we breath everyday). "
When you use the lighter, the butane flows from the bottom, through a "dip
tube".
http://www.inpharmix.com/jps/_images/exploded%20lighter%20labeled.jpg
Which means that the less volatile components, the ones that tend to remain
liquid as the lighter gets used, are pushed out by the headspace gas - composed
of the comparatively less liquifiable components.  After several
discharge/refill cycles, the lighter becomes filled with a higher proportion of
less liquifiable compounds, and so requires either more pressure to complete the
same fuel transfer, or venting of the more volatile components.
You could hold down the fuel lever to vent these gases before refilling, or more
effectively, hold the partially full lighter upside down while doing so -
causing the expansion of the less volatile components to push the more volatile
ones out the dip tube (which is now at the top).
You could then refill the lighter which has been depleted of those other
components.
To enhance filling, you could heat the butane refiller while filling with warm
water or a towel soaked in hot water.  Alternatively, you could chill the
lighter in the freezer before filling.
And, you could just wait and keep the filler depressed against the lighter for
far longer than most people do so that equilibrium can be more closely achieved.
Date: 18 Nov 2014 08:44:52
Message: <546b4d54$1@news.povray.org>
Yes, if we ignore heat transfer from the outside it is a closed system.
>> >level... with the exception of the use of a/pressurised/  filling mechanism.
>> >Thomas
Nicely observed and the image is handy too.
I think that there is an additional factor. As Scott pointed out vapour
pressure might have something to do with it as well. I did mention but
it was probably overlooked.
When you fill the lighter the liquid fills the part of the chamber below
the valve then stops. (Using the image you posted. The central divider
in the lighter body, is the other way around and the gap is at the valve
end.) At this point the system is in equilibrium. If you then pour some
of the liquid into the empty part. You can fill the lighter to a similar
level in the first chamber.
So I am guessing that it has to do with a function of vapour pressure
and the distance from the top of the liquid to the inlet valve.
Regards
Date: 18 Nov 2014 08:47:43
Message: <546b4dff$1@news.povray.org>
You could very well be right. I did not think of that.
Someone needs to do a doctoral theses on the subject. :-)
Regards
