![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Let the copyright infringement begin!
Date: 26 May 2014 08:20:12
Message: <5383317c@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
DISCLAIMER: Before clicking the following links, make sure you're fully
prepared! Your ears might not forgive you. You have been warned.
Cough please. Open wide. Now say "AAAH"...
http://download.orphi.me.uk/Music/G3/IKnowWhy-Raw.mp3
This is the original, unprocessed recording. (Except for some stereo
panning.) With a little bit of post-production (i.e., a compressor tuned
to the most aggressive setting I could find) and some backing supplied
by Battery [drums] and Kontakt [double bass and clarinet - I couldn't
find a saxophone], it sounds like this:
http://download.orphi.me.uk/Music/G3/IKnowWhy-Final.mp3
(I don't know if it's Cubase or Kontakt, but the first note on each
instrument seems to randomly get dropped or clipped... Very annoying!)
In case you have no idea WTF this is supposed to be, see for comparison:
https://www.youtube.com/watch?v=AA3LFd8g9bY
This is the version I'm attempting to cover.
Problems:
* Technically, it is illegal for this recording to exist in the first
place. Hopefully nobody will sue me... o_O
* Microphone hiss. Absurd levels of microphone hiss. The extreme
compressor settings only make things worse.
* Breath control. I had real trouble not running out of air on... well,
basically ALL of those chords. But even the bits that aren't chords, I
was constantly breathless. Maybe it's because I'm so unfit, but I
suspect I'm probably just doing it wrong.
* The lead vocals were done in a single take. I really didn't put very
much effort into them at all. It was meant to be a guide track rather
than a final take, so it's not especially accurate. (You may have
noticed that I didn't sing the final verse - mostly because the original
lyrics are unparsable.)
* The finale was EXTREMELY hard to sing. I wasn't expecting it to be,
but I found it nearly impossible to get right. I did endless takes, and
they all sounded terrible. In addition to being out of tune, it's out of
time too!
* The bridge with the key change is my favourite part. But for whatever
reason, when I sing it, every "doo" is 90% D and only 10% OO, so it
sounds rather achromatic. Again, I'm probably just doing it wrong.
* My throat really hurt during this. I can't decide whether I'm just not
used to using my voice, or whether I'm actually doing it wrong. (I spend
most of my life sitting alone, not uttering a word. Whenever I talk to
people, I notice my throat hurts after half an hour of talking. Trying
to sing loudly is presumably much more work than merely talking...)
* The headphones I was using make it difficult to hear both myself and
the backing track. I had to sing this with one ear in and one ear out.
* If I ever get to do this again, remind me to put more pitch references
in the backing track! A lone double-bass doesn't give me much to go on...
* I had serious difficulty mixing the final version. I wanted to *hear*
the vocals, but the signal keeps clipping. I turned the vocals down and
down and down until now they're barely audible, and still the signal is
only just out of the red. Compare my recording to The Senti-Mentals, and
their track is nowhere near the end of the meter, yet sounds
*drastically louder*. WTF?
* I have quite a low voice. Initially I was singing the chords as F4,
A4, C5. But that was too low and rumbling, so I changed it to A4, C5, F5
instead. That sounds much better. Yet somehow, when The Senti-Mentals do
it, their voices sound much brighter and clearer than mine. Not sure if
they're actually singing higher notes, or whether I'm just singing badly.
For extra fun, if you increase the playback speed of the track, my voice
sounds higher, and then you can "make out" the chords properly:
http://download.orphi.me.uk/Music/G3/IKnowWhy-Chipmunk.mp3
It's actually not bad, eh?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 26/05/2014 14:20, Orchid Win7 v1 nous fit lire :
> Problems:
> (I don't know if it's Cubase or Kontakt, but the first note on each instrument seems
Hint: have all partitions' lines start with a note, then padded with
silence. It might be a problem of uninitialized variables, so everybody
says BOO at the start and voilà!
Depends on which country you are. IIRC, it might not be a problem in China.
You seems too near the microphone (saturating ?). The sensibility of it
might also be a problem if you are to move away from it.
The original was probably done about a meter away from the microphone,
with enough volume to not hear breathing. And they stood up. Not sited.
Singing lessons might teach you how to breath silently, or even how to
sing while taking air in! But you need to find an old timer, because
current "singer" just talks... in the head microphone while jumping
around (calling that "dancing")
Practice! A twitting child has something like 2 hours of babbling loud
everyday... if he is quiet. An adult can have a day with as much as
thirty second of vocal ("Hello"..."Thanks" "Goodbye"). There are
muscles, they need to work every day if you want them to run.
And volume comes from the belly or even the pelvic area.
And do not start a marathon head first from your wheeling chair.
(or do not try to lift the 200 kg when entering the weight-lifting club)
Real studio have a feed-back loop in the headphone. Or you need the
opened-ones.
Reference need rythm (but a visual metronom can do), and pitches.
Working in mp3 is not the best thing.
And you might be saturating the microphone.
Thanks for sharing a bit of music in this hard world.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Let the copyright infringement begin!
Date: 27 May 2014 14:19:53
Message: <5384d749@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah, I may have to do that. (I wish I could say this is the first time...)
I had the microphone far enough away that I was surprised it actually
detected my voice. But yeah, it picks up so much background noise -
which has nothing to do with how near or far I am.
I imagine the professional track was done in a recording studio with
sound-proof walls, high-quality microphones, and a recording engineer
who actually knows WTF he's doing.
Yeah, I keep toying with the idea of doing this. Not sure if I have the
nerve though... we'll see.
> opened-ones.
Yeah, these are cheap "gamer" headphones. (I.e., they're designed to
deliver maximum bass power, rather than high fidelity.) Having said
that, they're not as bad as you might imagine... But they're definitely
designed to isolate external noise.
I only transcoded to MP3 so the file download would be small. The
original material is all uncompressed.
No problem. I must admit, though, I was hoping for more of a reaction...
It took me about 5 hours to record the vocals for this, and probably
about 4 hours before-hand preparing the backing track. And another 4
hours afterwards trying to make it sound good...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Problems:
No, he means that the terms of his lease prevent him from singing in his
appartment. Therefore, not only did he do something illegal, he even
posted proof of it on the intertubes.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> China.
No. I recorded this at my mum's house, while she was out of the country.
So it's fine.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 27/05/2014 20:19, Orchid Win7 v1 nous fit lire :
>> opened-ones.
Yep. I enjoy gamer's headphone too for this. Strong isolation and at
good separation (left vs right): can save your "life" to turn/hide from
the small hinting noise of incoming death, out of the view. But for
singing, they isolate too much, so you would need a feed-back loop from
the micro via the mixing table.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
