POV-Ray : Newsgroups : povray.off-topic : Revolving Server Time
16 Jun 2026 10:04:45 EDT (-0400)
  Revolving (Message 81 to 90 of 96)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Revolving
Date: 5 May 2014 10:05:54
Message: <53679ac2$1@news.povray.org>
>> Second, you worked in the chemical industry for over 10 years. I'm sure
>> you're familiar with the names 3M, Dupont and BASF, just to name those.
>> Don't think for a second that these companies don't have large R&D depts
>> that work round the clock trying to come up with newer compounds
> I was under the impression that 3M's main business is *manufacturing*
> plastics, not designing new ones. (Actually, I was under the impression
> that 3M manufactures finished products that have plastic _in_ them, but
> I guess they probably sell raw plastic to other people...)
>> Have you noticed how nowadays most eye glasses are made of plastic?
>> Clear plastics with higher IOR (sorry for getting slightly on-topic for
>> P.O-T) than glass were unheard of 30 years ago. The progresses made in
>> the domain of contact lenses is even more impressive than that of
>> conventional glass lenses.
> Really? I thought *all* transparent materials have an IOR different than
> air. As in, it's impossible to *avoid* this (e.g., if you wanted to make
> a kind of "invisible glass", you can't do it.)
Where did air come from.  I mentioned GLASS?
>> The "technical" garment industry has also greatly benefited from these
>> new polymers. You're a skier, so you've most certainly seen the
>> 74732327523 tags that are sewn or attached on a new ski jacket or
>> gloves, touting the amazing breathability, yet still impermeable,
>> feather light, yet warm as a mammoth pelt, machine washable, yet won't
>> fade properties these clothes now offer.
> I thought that all of those claims were radically exaggerated marketing,
> and that these materials are basically identical to what we had 40 years
> ago.
Then you thought wrong.  Even if the marketing does tend to overstate
their capabilities a bit.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 5 May 2014 10:09:58
Message: <53679bb6$1@news.povray.org>
> On 1-5-2014 22:38, Doctor John wrote:
>> YABAMBA
> not sure what that acronym means but if it means something like GIYF or
> 'why don't you just think before you post' or 'have you heard of the
> concept of newspapers and magazines', I agree.
Look earlier in the thread.  It means
Yet-Another-Bogus-Assumption-Made-By-Andy.
Date: 5 May 2014 23:44:46
Message: <53685aae$1@news.povray.org>
On Fri, 02 May 2014 16:31:42 +0200, andrel wrote:
> On 2-5-2014 15:49, Doctor John wrote:
>> On 02/05/2014 11:53, andrel wrote:
>>>> YABAMBA
>>> or 'why don't you just think before you post' or 'have you heard of
>>> the concept of newspapers and magazines', I agree.
>> Yet Another Bogus Assumption Made By Andy
> yep, that sort of covers it.
> I fear that this could become an often used acronym in this group.
I don't know that I fear that, myself.  I can see its utility in
discussion - a time saving device. ;)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 5 May 2014 23:46:14
Message: <53685b06$1@news.povray.org>
On Wed, 30 Apr 2014 05:30:12 -0500, Tim Cook wrote:
> On 2014-04-24 14:32, Francois Labreque wrote:
>> Andy has also assured me that iPads, Kindles, Nooks, and the various
>> android-based thingamajigs weren't tablets at all, because tablets were
>> 2 inch thick laptops that weigh 20lbs and on which you write with a
>> Palm-Pilot stylus.
> Hear, hear!  Well, augmenting the specifications a little, but I concur
> that these newfangled touch-only widgets aren't REAL tablets...my
> current dream machine is the Fujitsu Stylistic Q584.  2560x1600 screen,
> 10.1"x7.12"x0.39" with proper Wacom pen input, weighs 1.4 lbs.
But surely that's impossible.  Or hideously expensive.  Quite possibly
both at the same time. ;)
> ...oh, and it has loads of other bells and whistles, if you're into
> those things.  But dat display...over four times the resolution of my
> Fujitsu Lifebook (which, at six years old, is rather closer to your
> referred attributes, ahem), in a smaller area.  And it's less than a
> thousand dollars!
> Mind, the Q584's specs are rather unusual and extravagant; most
> pen-input tablets are still poking around the 1280x800 neighbourhood.
In all seriousness, that sounds like a pretty nice piece of kit.
> Also, re. OP:  It's the future.  I was promised flying cars!  But I
> don't see any.  Why?  WHY?
Have you seen how people drive? Do you REALLY want that in 3D? ;)
Jim
Date: 6 May 2014 06:00:59
Message: <5368b2db$1@news.povray.org>
> Given that a 3D prototype will be made of a totally different material
> with totally different properties, I'm not sure how having a prototype
> lets you check this.
As I said, the materials used for 3D prototypes are designed to mimic
real plastics. The properties are very similar (especially for stiffness).
>> FWIW I've *never* seen tooling get
>> made exactly right first time, there is *always* something that needs to
>> be fixed or changed
> Really? I find that quite surprising. (Then again, I don't work in this
> industry.) I had assumed that by now, making something trivial like a
> cube-shaped box would be easy.
Surprisingly something simple like a cube shaped box is problematic for
a variety of reasons. The sides are large, flat and almost perpendicular
to base (or at least you want them to be). This makes it much more
likely the part gets stuck in the tool, parts stuck in tools = $$$.
Plastic shrinks as it cools, large flat surfaces = twisted and warped
parts. Usually you would put supporting ribs on the inside, but in a box
I guess you want to actually use the space inside for storing things, so
you are a bit limited what you can do.
> That's impressive, given that even "real moulded plastic" isn't strong
> enough to make a gun... They're made out of metal for a reason, after all.
Well it's clearly strong enough to fire at least a few rounds (there's a
video on youtube I think). And if you're the sort of person who wants to
try and get a gun through some security checkpoint then you probably
don't mind that it won't be a long lasting reliable weapon.
Date: 10 May 2014 05:52:40
Message: <536df6e8$1@news.povray.org>
> Have you seen how people drive? Do you REALLY want that in 3D?;)
I certainly don't. Too many idiots on the roads if they took to the
skies I would take to my bed. Even then you never know who might drop in
for tea. ;-)
I have been reading a lot of ancient SF recently. The thing that almost
everyone got wrong is mobile phones. It is jarring when the hero has to
stop by a drug store just to phone someone.
Regards
Date: 10 May 2014 06:59:44
Message: <536e06a0$1@news.povray.org>
Le 10/05/2014 11:52, Stephen nous fit lire :
> for tea. ;-)
Have a look at the Shadowrun RPG (as book for ambiance)... targeted
advertisement as you pass by every shop is coming to your mobile phone.
And it is going to be as hostile as it sound. Next, augmented reality to
hit your glass and audio device... still for aggressive advertisements.
Along the revision/Edition, the matrix changed a bit (connection was
more difficult in first edition, wifi is everywhere in latests).
On another hand, triple-A security blocks are emerging too. Some started
with "elderly-only" town (forbidden to less than ~60 years old alone),
but private blocks are not so far.
Arcology are not yet, unless you look at Millenium tower (tokyo,
project), or Dubai... yep, they are coming. Not sure it will not split
population too.
Date: 10 May 2014 15:51:51
Message: <536e8357$1@news.povray.org>
Now that is familiar from more more modern fiction. (Currently reading
Sinister Barrier (Sinister Barrier 1939, by Eric Frank Russell.)
I am not really into games (I'm pretty poor at playing them.) although I
have been playing the Beta of Elite Dangerous. It is just a shoot them
up in your flying saucer ATM. But it has encouraged be to start Pov-ing
after about a year off.
"as above, so below" or art imitates life.
Sounds fine to me. ;-)
> project), or Dubai... yep, they are coming. Not sure it will not split population
too.
I suppose so (Make room! Make room! by Harry Harrison.)
Regards
I solemnly promise to kick the next angle, I see.
Date: 10 May 2014 18:35:18
Message: <536ea9a6$1@news.povray.org>
Lucky duck.  I'm having to wait for final release.  Looking forward to
it, though.
T. Cook
http://empyrean.sjcook.com
Date: 10 May 2014 20:15:23
Message: <536ec11b$1@news.povray.org>
> for tea. ;-)
Yeah, that really is something that is a sign of the times (as it were).
Jim
