POV-Ray : Newsgroups : povray.off-topic : Revolving Server Time
16 Jun 2026 02:37:11 EDT (-0400)
  Revolving (Message 67 to 76 of 96)
Subject: Re: Revolving
Date: 2 May 2014 03:43:26
Message: <53634c9e$1@news.povray.org>
On 1-5-2014 19:41, Orchid Win7 v1 wrote:
> Does anybody really use 3D printers much?
My dentist.
> Also: I was given to believe that 3D printed objects have approximately
> the structural rigidity of jellybaby. It's strong enough to see if
> various printed parts will fit together right, but if you stare at it
> too hard you're gonna break it. But hey, it's only a *prototype*, right?
> It's not like the finished item will be made of the same gel...
My dentist makes bridges and crowns with a 3D printer, and the products
are no jellybabies, thank God. :-)
Date: 2 May 2014 04:12:26
Message: <5363536a$1@news.povray.org>
> I was under the impression that 3M's main business is *manufacturing*
> plastics, not designing new ones.
It's both - if they didn't do the latter they would be no different to
the other 10 million plastic manufacturing plants. If you've ever dealt
with 3M (as a supplier for volume manufacturing) you would know they are
not the cheapest, but they often have materials and technologies that
nobody else has. This is their business model, it is not making
bog-standard plastics cheaper than everyone else (they would never win
this).
> (Actually, I was under the impression
> that 3M manufactures finished products that have plastic _in_ them, but
> I guess they probably sell raw plastic to other people...)
I don't think they do much of that, maybe for some specialised areas but
I've never heard or seen anyone sourcing raw plastic from 3M.
> Really? I thought *all* transparent materials have an IOR different than
> air. As in, it's impossible to *avoid* this (e.g., if you wanted to make
> a kind of "invisible glass", you can't do it.)
You can create a cone structure on the surface of the material (with the
points upwards so it's pointy to touch). Now so long as the size of the
cones is smaller than the wavelength of light then you get a continuous
smooth variation of IOR from the air to the solid. This prevents any
reflections, so the glass looks invisible. I've seen prototypes of this
and it really does look invisible (you can stick a patch of it on glass
and it looks like someone cut a hole in the glass). The obvious problem
with this is the tips of the cones wear off quite easily which starts to
reduce the effect. Again, it's all about developing new materials and
processes to achieve this kind of product.
There are other anti-reflection coatings already in use, with varying
degrees of performance. One of them works by destructive interference
and is used on glasses, outdoor displays etc, you can tell by the
characteristic purple tint of the remaining reflection (it blocks green
reflection mainly).
Date: 2 May 2014 06:53:57
Message: <53637944.4090302@gmail.com>
On 1-5-2014 22:38, Doctor John wrote:
> On 01/05/14 18:41, Orchid Win7 v1 wrote:
>> Granted I don't work in the manufacturing industry. But I would have
>> expected that the market for rapid prototyping is utterly *tiny*
>> compared to the market for actual finished goods.
>> Does anybody really use 3D printers much? I mean, I can imagine there
>> are products for which this might be really useful, but if you're just
>> making (for example) plastic sandwich boxes, do you really need to
>> prototype that?
> YABAMBA
not sure what that acronym means but if it means something like GIYF or
'why don't you just think before you post' or 'have you heard of the
concept of newspapers and magazines', I agree.
Anyway, we use our 3D printers a lot in the hospital, e.g. to plan
operations. Also, have a look at shapeways.com . Do you want plastic
(several varieties) , sandstone, metals, or ceramic?
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
This email is free from viruses and malware because avast! Antivirus protection is
active.
http://www.avast.com
Date: 2 May 2014 08:52:50
Message: <53639522@news.povray.org>
> That's a pretty sharp cuttoff. OTOH, from this scale you can't tell
> whether the filter still passes, say, 1% of the UV. 1% UV is presumably
> still easily enough to utterly destroy whatever is underneith. (E.g., a
> plastic coated in this stuff will get ruined in a few months rather than
> a few days.)
I don't think many dyes fade within a few days of sunlight exposure. A
few months maybe, but then a 1% UV filter will allow them to last a few
decades, which is actually useful for something like a car or a photo.
> So... essentially you're saying the only real change is that plastic is
> cheaper now?
Not really, what I'm saying is that the development of plastics and the
processes that use them have allowed *products* to become cheaper. But
that's pretty much the entire purpose of engineering, to make a product
that meets all the requirements for as low a cost as possible. If you
can come up with a new material (or a variant on an existing one) that
allows an existing product to be made cheaper you will be collecting the
> I knew there were at least 6 main plastic types.
Correct, there are at least 6 :-) Here's a list of the common categories:
http://www.efunda.com/materials/polymers/history/history.cfm?list_order=name
There are about 40 there. If you click on each one it will give you a
list of common grades, about 20 for each of the ones I clicked on.
That's already 800 different grades without even considering various
combinations of other additives to aid manufacturing or specific
properties needed. My point is that if you plot all of these on a
timeline you'll see that most have been developed fairly recently, it's
not like there's no development in plastics.
> (Also, if this plastic as such a high melting point, how do you mould it
> in the first place??)
Make your manufacturing machinery from something with a higher melting
point, say steel? How do they make the steel in the first place? :-)
Date: 2 May 2014 09:49:07
Message: <5363a253$1@news.povray.org>
On 02/05/2014 11:53, andrel wrote:
>> YABAMBA
Yet Another Bogus Assumption Made By Andy
John
Date: 2 May 2014 10:31:43
Message: <5363AC4E.7040402@gmail.com>
>>> YABAMBA
yep, that sort of covers it.
I fear that this could become an often used acronym in this group.
active.
Date: 2 May 2014 10:34:37
Message: <5363acfd$1@news.povray.org>
> prototype that?
So you'd be confident enough that the sandwich box hinge and latching
mechanism was going to work properly and not snap off, and that it would
feel right, and the MD is not going to complain the box feels too
flimsy, just by looking at CAD data on your screen and perhaps some
simulations that tell you the stiffness is X N/mm at certain points and
you need X N of force to open the latch? Confident enough to sign off
$100000 for the tooling to be made? For the sake of $500 to get a few
prototypes made up it's not worth it. FWIW I've *never* seen tooling get
made exactly right first time, there is *always* something that needs to
be fixed or changed, using prototypes just reduces the risk of any big
(=expensive) errors.
Did you miss the story a while back of the guy who made a functional
*gun* from 3D printed parts? The whole point of professional 3D printed
parts is that they match the performance of the real moulded plastic.
FWIW here we put butanone at 6 bar into 3D printed parts without issue.
Date: 2 May 2014 13:26:20
Message: <5363d53c@news.povray.org>
>> prototype that?
Given that a 3D prototype will be made of a totally different material
with totally different properties, I'm not sure how having a prototype
lets you check this.
> be fixed or changed
Really? I find that quite surprising. (Then again, I don't work in this
industry.) I had assumed that by now, making something trivial like a
cube-shaped box would be easy. Of course, if you're making something
complicated like the casing for a camera or something, that seems much
harder to get right...
That's impressive, given that even "real moulded plastic" isn't strong
enough to make a gun... They're made out of metal for a reason, after all.
Date: 2 May 2014 13:27:51
Message: <5363d597@news.povray.org>
That sounds absolutely trippy - and really expensive to manufacture. ;-)
> reflection mainly).
Yeah, interference is wavelength-specific, so you can only make stuff
non-reflective at one wavelength. I've seen Falstad. ;-)
Date: 2 May 2014 15:52:41
Message: <5363f789$1@news.povray.org>
Le 02/05/2014 19:26, Orchid Win7 v1 nous fit lire :
Only if you need to fire more than a few time. The bullet should be
metal, the percussing pin too, and maybe container of powder.
Everything else can be "consumable".
In our modern society, making things that last is so 19th century!
