POV-Ray : Newsgroups : povray.off-topic : An interesting read Server Time
16 Jun 2026 01:56:59 EDT (-0400)
  An interesting read (Message 21 to 28 of 28)
Subject: Re: An interesting read
Date: 13 Jan 2014 17:03:51
Message: <52d462c7@news.povray.org>
On 13/01/2014 09:36 PM, Francois Labreque wrote:
> Le 2014-01-12 05:38, Orchid Win7 v1 a écrit :
>> I don't have the book in front of me now, but prime number sieving is
>> actually one of the examples. They even go so far as to remove the "stop
>> searching after sqrt(max)" optimisation to "make the code simpler".
>> Because most of the time, being able to understand the code is far more
>> important than getting maximum performance out of it.
> If you do leave it in, *that* is worthy of a comment. Not every
> programmer will be good enough with math to figure out why you don't
> need to check for factors > sqrt(max).
I agree. That's the sort of thing that's sufficiently non-obvious that
it ought to be explained somewhere.
Then again, how many programs sieve prime numbers? Most software seems
to just push database records from A to B and back again...
Date: 13 Jan 2014 17:25:20
Message: <52D467C8.8070900@gmail.com>
On 13-1-2014 19:19, clipka wrote:
> Am 13.01.2014 11:19, schrieb andrel:
>> On 13-1-2014 0:56, clipka wrote:
>>> Am 12.01.2014 22:21, schrieb andrel:
>>> As for a function's name, I find it very important that it denotes not
>>> /how/ the function does something, nor just /what/ it does, but also
>>> with what /intention/.
>> True, but this is a general case where the point is that there are still
>> several ways to do things. More specific names are needed lower in the
>> tree.
>> In this case I would go for something like:
>> ECG=ComputeECGfromTiming(Timing,VolumeConductionModel,ElectricalModel,
>> Parameters);
>> or simply
>> ECG=ComputeECGfromTiming(Timing,ForwardModel);
> Sounds like a very good choice to me.
Well, luckily I am not the one that decides.
OTOH I am sort of forced to use it even if it is IMO unsuitable for
research purposes. Perhaps you can understand now some of the reasons why.
One day I might just stand up and give a short introduction on
programming. Which will probably be the end of the cooperation.
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Date: 13 Jan 2014 17:30:30
Message: <52D468FE.2030201@gmail.com>
On 13-1-2014 21:00, Orchid Win7 v1 wrote:
> On 13/01/2014 06:47 PM, clipka wrote:
>> There is one major advantage in "commenting" your code by structuring it
>> and choosing good identifiers, rather than placing comments in there:
>> Comments are typically more prone to become outdated over time.
> This is another of the major themes of the book. Inaccurate comments are
> arguably *worse* than no comments at all.
>> (Provided of course that the code is produced and maintained in an
>> environment where refactoring is encouraged. If the policy is "try to
>> avoid touching any of the existing code", it is easier to fix a comment
>> that has become obsolete, rather than a once-good identifier that no
>> longer matches what the function or variable does.)
> One of the things that frustrates me about my job is that I want to
> refactor things, and people complain that it would take too long and so
> we won't do it.
> Obviously the customers aren't going to be too impressed if we spent 2
> years restructuring the codebase with no user-visible change in
> functionality. But that doesn't mean that *all* refactoring should be
> put off...
When I was working with a colleague we sometimes split. One did all the
interaction with users and the other did the cleanup in a branch.
Now I am just by myself I need to do it incrementally, which does not
work, because I do too many things already. But basically you should
think of it as on-the-fly-garbage-collection. (With the disadvantage
that you first need to cleanup and rewrite to support that)
Date: 13 Jan 2014 17:31:48
Message: <52D4694C.2080506@gmail.com>
Depends on your field of work ;) I don't.
Date: 13 Jan 2014 21:22:43
Message: <52d49f73@news.povray.org>
Am 13.01.2014 21:00, schrieb Orchid Win7 v1:
> we won't do it.
> put off...
Remember that refactoring is not the same as rewriting. Refactoring - at
least as I understand it - is a sequence of many small baby steps.
Ideally, the steps should be small enough that you can formally prove
that they don't change functionality in any way. Such as moving some
portion of code into a separate function. Or making a public member
variable protected and providing getter and setter functions for access.
Or renaming a function.
Each such step is a separate refactoring action, so it shouldn't be too
difficult to interweave it with your daily job.
Make it a habit to always be a bit more invasive than necessary whenever
you need to make a change, so that further modifications in that same
portion of code will be easier.
Make it a habit to set aside, say, two days per month for refactoring work.
Explain to your boss why you're doing this, in terms he can understand:
You're investing time to improve overall code quality, in order to save
more time in the future.
Also tell your boss that this is the kind of smart thinking he hired you
for.
And to stay on good terms with your colleagues, make it clear to them,
your boss, and also to yourself, that it is your /personal/ desire to
improve the overall code quality, and that it's ok for you if your
colleagues don't join in the effort.
Date: 14 Jan 2014 16:05:52
Message: <52d5a6b0$1@news.povray.org>
>> we won't do it.
>> put off...
Another theme of the book. The author states that your goal should be to
have the class fully covered in unit tests, and each change must keep
all the unit tests working.
Suffice it to say, changing code in a way that doesn't break existing
stuff is far, far harder than just throwing the lot in the bin and
starting again.
The other Fun Thing is that there are subsystems which are used
*everywhere*. Some of them have awful design, we all know it's awful,
but if you changed it, you would have to touch every client of that
subsystem - i.e., the entire application. For this reason, we never make
any improvements to these systems.
I personally am of the opinion that it would be *that* damned hard to
change all the code; there are automated refactoring tools and such to
help you do it. But it seems I am in the minority...
Date: 15 Jan 2014 04:57:49
Message: <52d65b9d$1@news.povray.org>
> One
> aspect is about visual perception: In your version, the reader has to
> first figure out what is code and what is explanation, whereas in Andy's
> version it's one and the same.
Except Andy's version doesn't actually have any code, it's hidden away
in a separate method (which you would either need to search or scroll to).
Especially with comments being highlighted in most code editors, I
personally find this much more useful:
prime = array[0]; // get next prime
thank this:
prime = GetNextPrime(array);
What seems to be being advocated is to replace source code like this:
<trivial code> <comment>
with this:
<call a function with "comment" name>
<function definition of "comment">
  <trivial code>
Sorry I don't see the benefit.
Date: 15 Jan 2014 08:37:58
Message: <52d68f36$1@news.povray.org>
Am 15.01.2014 10:57, schrieb scott:
>> One
... if I'd really bother. Which is exactly the point: Usually I won't.
> thank this:
Whoever invented code highlighting does indeed deserve a medal or two.
Typically though, comments are actually "lowlighted"; while it does make
it easier to distinguish between code and comments, it still draws the
attention to the code rather than the comments.
> with this:
>   <trivial code>
As I said, visual perception is only one aspect.
I also don't think the single-line case is typical in practice.
Then there's also the aspect that if you move into functions some
multi-line code sections operating at array access level, it can be
argued that the remaining single-line code sections operating at array
access level should be moved into functions as well, in order to get a
homogenous level of abstraction.
And last not least, I'm not really advocating the above - I just present
arguments in favor (which probably sounds/reads just the same, but
actually isn't). I prefer to leave it up to the reader to decide for
themselves.
