POV-Ray : Newsgroups : povray.off-topic : Where is the world going? Server Time
5 Jul 2026 13:25:07 EDT (-0400)
  Where is the world going? (Message 81 to 90 of 199)
Subject: Re: Where is the world going?
Date: 7 Sep 2013 16:49:34
Message: <522b915e$1@news.povray.org>
On Fri, 06 Sep 2013 17:01:44 -0400, Francois Labreque wrote:
> Why would they need fewer people to support FAT32 by arbitrarily
> limiting the size of the drives you can use it on to 1/1000th of its
> full potential?
Because when the code was written, it was written.  To extend the
limitation requires more code be written.  To support that extra space in
other applications requires testing and QA.
Have you worked in a software company?  Do you know how software
development and QA is done?
Even a /minor/ change to the code (say to make disk space reports not
turn up negative numbers) requires regression testing to make sure it
doesn't break anything else.  *Trivial* stuff being fixed, done by large
software companies, certainly, is not actually a trivial thing.
>>> As for this particular instance, it's no longer an issue.  My employer
>>> has forced all of us off Windows and onto OSX or Linux, for security
>>> reasons, and I have no problem formatting disks there.
>> See?  Problem solved. :)
> Probably not in the way MS expected, though.
Well, MS doesn't always get to win.  In the end, in spite of the
limitations and problems (and I'm speaking as a user of Linux on the
desktop since the late 90's), Microsoft ain't going anywhere, and people
are going to just continue to use it, warts and all.
Jim
Date: 7 Sep 2013 16:51:25
Message: <522b91cd$1@news.povray.org>
On Sat, 07 Sep 2013 03:32:11 -0400, Warp wrote:
> Francois Labreque <fla### [at] videotronca> wrote:
>> >> Where are they saving money?  The code to fdisk a drive with FAT32
>> >> is still there in the code.  In fact, they had to write even more
>> >> code to check the size of the disk before deciding if they would
>> >> make FAT32 one of the available formats.
>> > I would guess that they need fewer staff to support fat32, fewer
>> > developers to maintain it, fewer testers to test it, etc.  It all
>> > adds up.
>> full potential?
> Is there a reason why someone would want to use FAT32 instead of eg.
> NTFS?
> FAT32 is significantly slower than NTFS with some operations. (For
> example,
> defragmenting a large FAT32 partition can take over 24 hours, while the
> exact same partition with the exact same data as NTFS takes something
> like 15 minutes to defragment.)
Arguably, NTFS is a journaled filesystem, and journaled filesystems on
flash media generally burn them out faster.  Wear leveling helps with it,
but the journal really isn't desirable on that type of media because it
shortens the media's life.
FAT32 (or vfat) is also desirable for lots of mobile devices (for that
very reason) and for portability between different operating systems.
While NTFS-3G provides pretty decent NTFS support in Linux, it's still
not as mature as the vfat/fat32 support in the kernel (of course, it
never really will be).
Jim
Date: 8 Sep 2013 11:14:28
Message: <522c9454$1@news.povray.org>
Warp wrote:
> Is there a reason why someone would want to use FAT32 instead of eg. NTFS?
Yes, there is - it's pretty universally supported.
For example my camera doesn't support NTFS on the memory cards. It does
support FAT32, though. And with FAT32 the memory card is fully usable on
my work machines (WinXP, Win2003 and Win7) and my own machine (usually
Linux) without any hassling or problems.
-Aero
Date: 8 Sep 2013 13:24:20
Message: <522cb2c4$1@news.povray.org>
On 9/7/2013 1:46 PM, Jim Henderson wrote:
>> Ur.. I would presume "security". See, the way I see it, this measure
>> they took wasn't to improve security at all, it was to damn up gaps in a
>> wall, so they thieves couldn't get out, while still letting them in
>> through the front gate.
> That's not a specific implementation, Patrick.  Try again.  You want to
> say that the current system sucks, fine - but propose something better.
> Dont' just say "security" as if that's a magic bullet.  That's not
> something specific to be implemented, it's a concept.  You're smarter
> than that.
Sigh.. You do realize that when they came up with this absurd solution
it was back with like 98/XP, where half the security they added since
didn't exist at all? So, sorry, but its not nonsensical to suggest
adding things that don't bloody exist *at all* in the OS in the first
place. As I pointed out, a big solution would be, "don't let people run
things without explicitly saying its OK to do so." We can argue whether
the current MS method of just asking, or the *nix version of having to
know what the F you are doing, in order to explicitly set run
permissions is better, and for whom, but the problem, for years, with
windows, and still is, in some cases, that things can either install
without asking, or circumvent safeguards, or, and this is the stupidest
one - nearly every installer under windows triggers the, "Are you sure
you want this thing to alter your machine?", question, which means
people will ignore the safeguard anyway. At best.. some of them might
question why a flash animation needs to, "change you machine
configuration", but seriously...
>> That would, imho, be a damn good start on it. MS didn't want to fix
>> their core problem, so they came up with one that "broke" existing
>> functionality, probably even for more than just that class of
>> applications, then, 10+ years later they "finally" fixed some of the
>> actual security.
> Technological implementation details, Patrick. Those are important.  Not
> general "just do it" type BS language.  How do you tell if a "small"
> program is a botnet or just a simple CLI utility (as is typical in the
> *nix world) that does a specific task?
I would say, not even a CLI, if it doesn't come with the OS, should be
allowed to do anything, unless you damn well know what it does, and
explicitly allow it. Or, more to the point, **especially** if its
something that small. But, heh, what the F do I know... And, its always
better to make everything "convenient", than make it safe, unless you
plan to make it a) convenient enough, and b) safe to the point where
doing what you want with it will brick the machine - i.e., most Apple
products.
Date: 8 Sep 2013 14:47:43
Message: <522cc64f$1@news.povray.org>
>>> a wall, so they thieves couldn't get out, while still letting them in
>> than that.
> place.
Explain how saying "security" is a *specific* solution, Patrick.  Provide
some details as to what you mean - what would you /specifically/ add to
provide "security"?
UAC.  Already implemented.  Or do you mean every time you launch an
application, you want something to pop-up to say (clippy-style, perhaps)
"I notice that you want to start Microsoft Word.  Are you sure?"
Oh, you want users to actually be required to understand computers before
they use them?
Good luck with that.
>>> actual security.
>> Not general "just do it" type BS language.  How do you tell if a
>> "small" program is a botnet or just a simple CLI utility (as is typical
>> in the *nix world) that does a specific task?
> products.
Oh, so you want a completely locked down system that can only do things
that the OS vendor allows.  Again, no specifics, and in that particular
case, the "abnormal" things you'd want to do would be explicitly
prohibited because they're not allowed.
You're nto making any sense here at all.
Jim
Date: 8 Sep 2013 15:36:28
Message: <522cd1bc@news.povray.org>
Like this? http://en.wikipedia.org/wiki/Microsoft_Security_Essentials
Date: 8 Sep 2013 21:28:47
Message: <522d244f$1@news.povray.org>
>> perhaps)
Basically reactive virus scanning.  Nothing really new there.
Jim
Date: 9 Sep 2013 22:06:51
Message: <522e7ebb$1@news.povray.org>
>> place.
> provide "security"?
Explain how "add a lock" to a door that doesn't have one is a "specific
solution". I mean, your not specifying what sort of lock, right? Sigh...
Enough.
Date: 9 Sep 2013 22:14:44
Message: <522e8094$1@news.povray.org>
Oh, and.. more to the point, now that they have something semi-decent,
they still block networking tools why? Its not like the botnet code is
going to, unless there is something fatally wrong with their "solution",
install itself any more, if the OS warns you now, when an application
tries to make the changes need for it to work, right? So, they are still
blocking the road why?
Date: 10 Sep 2013 00:48:32
Message: <522ea4a0$1@news.povray.org>
>>> place.
>> Provide some details as to what you mean - what would you
>> /specifically/ add to provide "security"?
> Enough.
You're not talking about something as simple as a door lock.  You're
talking about computer security, so you have to be specific.
You want a lock that can distinguish between two identical keys, one used
for "legitimate" uses, and one that isn't.
That sort of lock doesn't exist.
Jim
