POV-Ray : Newsgroups : povray.off-topic : Math questions Server Time
20 Nov 2026 13:36:09 EST (-0500)
  Math questions (Message 41 to 90 of 90)
<<< Previous 40 Messages Goto Initial 50 Messages
Subject: Re: Math questions
Date: 19 Jul 2013 15:13:46
Message: <51e98fea@news.povray.org>
Am 19.07.2013 20:54, schrieb Nekar Xenos:
> Maybe I should start with something simpler.
> Infinity + Infinity = ?
> Is there any other answer than 2(Infinity)?
Yes: Infinity + Infinity = Infinity.
> If so please explain.
I can't. I guess it's just the way infinity is defined.
Note that there's no such thing as infinity in real life, so there's no
"natural" way of dealing with infinity. It's an artificial construct,
and as such is defined in a way that applying the "natural" rules of
arithmetic to it does't yield results too useless for too many
applications too much of the time.
Date: 19 Jul 2013 15:56:15
Message: <op.w0hizxioufxv4h@xena>
This is what I thought, but didn't have any evidence for it.
-Nekar Xenos-
Date: 19 Jul 2013 16:02:15
Message: <51e99b47$1@news.povray.org>
Le 19/07/2013 20:54, Nekar Xenos nous fit lire :
> I don't know.
Well, if anything else, that's never the answer.
You have to be aware that some Infinity are bigger than some other
Infinity. (rahh... not now!)
To ease the understanding, the smallest infinity is called Aleph-0.
(well, that still a controversial subject, linked to the Axiom of Choice)
The natural integer (0, 1, 2, .. and so on) are in the N set, whose
cardinality is indeed Aleph-0.
Imagine one hotel of infinite room, each room numbered uniquely from N
set. And now you build another one next to it, of same size.
You then renumber the room of the first hotel x--> 2x, and of the second
hotel y--> 2y+1. You now have a single hotel-company of the same size as
one of the original.
You can also split it in multiple (finite number) hotels, all of
infinite size... they were already there!
Date: 19 Jul 2013 16:10:02
Message: <51e99d1a$1@news.povray.org>
On 19/07/2013 07:54 PM, Nekar Xenos wrote:
> I don't know.
> -Unlike Warp I don't know the answer and really want to know :)
"Infinity" is rather vague.
Let's talk specifics. Suppose we have the set of all natural numbers
(i.e., all positive whole numbers). There are infinity of these.
This set is commonly denoted by the latter N. I'm going to refer to the
size of this set as being A0.
Now, suppose we compare N, the set of all *positive* integers, to Z, the
set of *all* integers, negative and positive. Clearly there are twice as
many of these. For every item in N, there are two corresponding items in
Z, one negative and one positive. So the size of Z is A0 + A0.
But wait...
I can map every odd number in N to a negative number in Z, and every
even number in N to a positive number in Z. In this way, every element
of N is mapped to *one* element of Z, and every element of Z is mapped
to *one* element of N.
The existence of this mapping _proves_ that the sets N and Z are
ACTUALLY THE SAME SIZE! O_O
In other words, A0 + A0 = A0, exactly unchanged.
This seems utterly bizarre. But it's a consequence of infinitely large
quantities. To understand, try doing the same trick to prove that the
set {1 .. 5} is the same size as the set {-5 .. +5}. If you try this,
you'll discover the following:
   {1 .. 5}   {-5 .. +5}
      1    <->    -1
      2    <->    +1
      3    <->    -2
      4    <->    +2
      5    <->    -3
                  +3
                  -4
   Oh bugger!     +4
                  -5
                  +5
It doesn't work. You can't match them up. Because - AS IS FRIGGING
OBVIOUS - the sets aren't the same size. Basically you run out of
elements of the left set before you've matched up all the elements of
the right set.
The ONLY reason this works with infinite sets is that, because they're
infinite, you will never "run out" of stuff to match up. Because of
this, even "doubling" the size of an infinite set actually leaves its
size unchanged - bizarre as that is!
If adding a set to itself once does nothing, doing this twice also does
nothing. That is,
   A0 + A0 + A0 = A0
In general,
   x * A0 = A0
This is clearly true for any finite x. But what if x ISN'T FINITE? What
happens if we do this:
   A0 * A0 = ???
Remember that A0 is the size of N, the set of all integers. So if we
construct the set of all PAIRS of integers, like this...
    (1, 1)
    (1, 2)
    (1, 3)
   infinity
    (2, 1)
    (2, 2)
    (2, 3)
   infinity
    (3, 1)
    (3, 2)
    (3, 3)
   infinity
Surely, the size of this set is CLEARLY equal to A0 * A0.
But wait...
If I take both numbers, add zeros to pad them out to the same length,
and then interleave their digits, I get this:
   (123, 456) <-> 142536
   (123, 457) <-> 142537
   (123, 458) <-> 142538
Every number on the right matches exactly one pair on the left. Every
pair matches on number on the right. THE SETS HAVE THE SAME SIZE! We
just proved that A0 * A0 = A0.
Just when it's starting to look like A0 is A0 no matter what you do to
it, something interesting happens.
The size of N is A0. If we construct all possible subsets of N, then for
each element of N, a given subset of N either DOES or DOES NOT contain
that element. That's 2 possibilities, independently for each element of
N. So that's a total of 2 ^ A0 possible subsets.
It turns out that (2 ^ A0) > A0.
Yes sir, there are actually DIFFERENT SIZES of infinity. Let us write
   A1 = 2 ^ A0
   A1 > A0
But, by the same algorithm, 2 ^ A1 > A1, so we actually have
   A(n+1) = 2 ^ A(n)
   A(n+1) > A(n)
In summary, infinity comes in different sizes. (Now you see why the
original question "what is infinity plus infinity?" is vague; there's
one than one infinity you may ask about.)
In general,
   A(x) + A(y) = A(y)   iff y >= x
That is, if you add two infinities, the result is the size of whichever
is the largest infinity. (Thus, when you add a particular infinity to
itself, nothing happens.)
Date: 19 Jul 2013 16:34:02
Message: <51e9a2ba$1@news.povray.org>
On 7/19/2013 11:54 AM, Nekar Xenos wrote:
> I don't know.
If you've even hung around people majoring in math in undergrad, you may
have heard stories of a set theory class in which a they actually spend
a day's class proving that 1+1 = 2.  On the face of it this seems like a
huge waste of time, why would you bother to construct a proof of such an
obvious fact?  Well, it's in answering questions such as yours in which
such effort pays off.
There are a few rather subtle points to a simple question like "what is
1+1":
1) What is a number?
2) What is addition?
And in addition, for your question:
3) What do we mean by infinity?
For the most part your answers to these questions don't matter for
ordinary finite numbers, but as soon as you start treating infinity like
a number these subtle points start to matter a great deal.
In terms of your question "Infinity + Infinity = ??" you most commonly
see one of two answers:
a) Infinity * 2   (note: not 2 * Infinity, the order often matters)
b) Infinity
And this entirely glosses over issues that for some answers to questions
1-3 you can get more than one infinite number, at which point it matters
which infinities you were adding!
Sorry I don't have a simpler answer.  But basically the only real way to
answer it is "tell me what you really mean by Infinity, and only then
can I tell you what Infinity+Infinity is".  The answers given by clipka
and Le_Forgeron/Orchid are but two of many possibilities (although they
both get the same result, they are using different interpretations of
"infinity" to do it).
Date: 19 Jul 2013 16:37:48
Message: <op.w0hkw5h0ufxv4h@xena>
On Fri, 19 Jul 2013 22:10:11 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
>> I don't know.
> But wait...
>    {1 .. 5}   {-5 .. +5}
>       1    <->    -1
>       2    <->    +1
>       3    <->    -2
>       4    <->    +2
>       5    <->    -3
>                   +3
>                   -4
>    Oh bugger!     +4
>                   -5
>                   +5
> the right set.
> nothing. That is,
>    A0 + A0 + A0 = A0
> In general,
>    x * A0 = A0
>    A0 * A0 = ???
>     (1, 1)
>     (1, 2)
>     (1, 3)
>    infinity
>     (2, 1)
>     (2, 2)
>     (2, 3)
>    infinity
>     (3, 1)
>     (3, 2)
>     (3, 3)
>    infinity
> But wait...
>    A1 = 2 ^ A0
>    A1 > A0
>    A(n+1) = 2 ^ A(n)
>    A(n+1) > A(n)
> In general,
This is all very interesting. :)
I was thinking of adding any particular infinity to itself.
-Nekar Xenos-
Date: 19 Jul 2013 16:48:58
Message: <op.w0hlfragufxv4h@xena>
On Fri, 19 Jul 2013 22:34:29 +0200, Kevin Wampler <nob### [at] nowherenet>
>> I don't know.
> 1+1":
> b) Infinity
I think I could say the specific infinity I'm thinking of would be the
biggest type of infinity.
What would that be?
Complex Infinity? (if that could be considered)
-Nekar Xenos-
Date: 19 Jul 2013 16:54:30
Message: <51e9a786$1@news.povray.org>
> What would that be?
You will be sorry you asked that. :-P
Regards
Date: 19 Jul 2013 16:56:59
Message: <51e9a81b@news.povray.org>
How about and we may have an infinity of authors spinning in their graves:
The sum of all the odd numbers is infinity.
The sum of all even numbers is infinity.
The sum of all numbers odd and even is infinity.
So by doing ordinary sums:
infinity + infinity = infinity
and
infinity = infinity * 2
Can't be right. And that is because infinity is not a number but an idea.
But if you make a mathematics using infinity as an object it opens a
whole new way for mathematicians to think.
It was at this point that I thought that I would leave it for minds that
want to see things with out drugs.
Give the book that I mentioned at the beginning of this thread "White
Light" a try if you can find it.
Regards
Date: 19 Jul 2013 17:01:36
Message: <51e9a930$1@news.povray.org>
> What would that be?
There are two different ways I'm tempted to interpret your question, but
only one of them makes sense.  I'll try to answer them both anyway:
Q1) "Out of all the different ways you can define Infinity, what's the
biggest?
A1) Because the different definitions of Infinity use different
definitions of what a "number" is, there is no way to compare them at
all to say which is bigger -- they are just completely different things.
  It's like asking "which is bigger, 4 or fish?".
Q2) "You mentioned that for some definitions you get multiple different
types of infinity, what's the biggest of those?"
A2) The answers depends on what particular definition of Infinity you're
talking about, but the most common answers is that there is no biggest
Infinity -- just like there's no biggest finite integer.  Sometimes
people will try to add a "biggest infinity" to things, but you don't
generally allow addition with it anyway.
As I mentioned in (A1), it doesn't make sense to ask if "complex
Infinity" is bigger than another definition of infinity.
As an aside, a notion of "complex Infinity" is actually extremely useful
in some areas mathematics.  Arguably much more useful than "real
Infinity" is.  The standard definition of complex Infinity does not
allow Infinity+Infinity though (it treats it as undefined, much like 1/0
is commonly treated as undefined for the reals).
Date: 19 Jul 2013 17:03:57
Message: <51e9a9bd$1@news.povray.org>
>> What would that be?
Haha, that seems to be the answer to a lot of math questions of this
sort!  I did what I could to make my answer not too painful though.
Date: 19 Jul 2013 17:06:34
Message: <51e9aa5a$1@news.povray.org>
> and
You know, if you wrote that as "2 * infinity" the equation would
actually be correct as far as the major definitions of infinity go.
Ain't math grand?
Date: 19 Jul 2013 17:16:28
Message: <51e9acac$1@news.povray.org>
>> whichever is the largest infinity. (Thus, when you add a particular
>> infinity to itself, nothing happens.)
Then my last paragraph contains all you need to know. ;-)
Date: 19 Jul 2013 17:19:07
Message: <51e9ad4b$1@news.povray.org>
I SEE WHAT YOU DID THERE! ;-)
Date: 19 Jul 2013 17:21:07
Message: <51e9adc3$1@news.povray.org>
I may also have glossed over the fact that the results you get from set
theory vary slightly depending on WHICH VERSION OF SET THEORY you happen
to be talking about. There are several slight variations of it.
Think of it like playing chess; different chess tournaments have very
slightly different rules. Usually it doesn't matter, but sometimes the
outcome of a particular match can depend on exactly which rules you
choose to play by.
(One of the fun things about mathematics is simply INVENTING new rules
out of thin air and seeing where that takes you...)
Date: 19 Jul 2013 17:26:06
Message: <51e9aeee@news.povray.org>
>>> What would that be?
Indeed I understood it while I was reading it. ;-)
Seriously there a some pretty good minds around here but Nekar hasn't
mentioned to what standard his maths is. No offence Nekar, I only
studded maths, no every thing, to the end of highschool. (I think that
is what you call it. To just before university about 19 in the UK.)
And we all know that it is different answers for different folk.
Regards
Date: 19 Jul 2013 17:27:13
Message: <51e9af31$1@news.povray.org>
+1
Regards
Date: 19 Jul 2013 17:31:21
Message: <op.w0hneeswufxv4h@xena>
>>>> What would that be?
High school maths...
-Nekar Xenos-
Date: 19 Jul 2013 17:32:16
Message: <51e9b060$1@news.povray.org>
>> graves:
>> and
> Ain't math grand?
Damn! that was what I was going to do but thought that it was too big a
leap to say that infinity * infinity = infinity. From what I had written
before.
So out of (a passing) interest what is the difference?
PS the passing is my little joke. ;-)
Regards
Date: 19 Jul 2013 17:35:02
Message: <51e9b106$1@news.povray.org>
Is that a RTFM comment?
Regards
Date: 19 Jul 2013 17:38:54
Message: <op.w0hnqzelufxv4h@xena>
On Fri, 19 Jul 2013 23:02:04 +0200, Kevin Wampler <nob### [at] nowherenet>
>> What would that be?
> biggest?
I imagined the complex set would have a larger "density" if you could call
it that. (Real numbers would have a larger "density" than integers)
So if I have this right
is correct for real numbers and not for complex numbers.
-Nekar Xenos-
Date: 19 Jul 2013 17:43:58
Message: <51e9b31e$1@news.povray.org>
Like me then. What everyone is saying is correct but they are saying it
with the understanding of the language "mathematics". It is not what we
mortals understand as the same language that we speak. There is no
option but to learn it or consign it to "all very well but does it pay
the bills". (A topic I will leave to the tabloids. :-) )
I've read a little about it and to be truthful if the threat goes any
deeper then it goes over my head. Infinity is a great thought but after
a while. My eyes cross when I try focusing on it.
Regards
Date: 19 Jul 2013 17:46:38
Message: <51e9b3be$1@news.povray.org>
> +1
"Add one"?
I SEE WHAT YOU DID THERE! :-D
Date: 19 Jul 2013 17:49:28
Message: <51e9b468$1@news.povray.org>
> call it that. (Real numbers would have a larger "density" than integers)
Why don’t I mix it a little. :-D
Imagine infinity * infinity.
Which is infinity ^2
Now think about infinity ^ infinity.
Night night. ;-)
(Sorry I'm in that sort of mood. I've had a long day.)
Regards
Date: 19 Jul 2013 17:53:46
Message: <51e9b56a$1@news.povray.org>
>> +1
> "Add one"?
And I saw what YOU did there.
Unfortunately I wrote plus one.
Which is different to plus four's
Regards
Date: 19 Jul 2013 17:59:22
Message: <op.w0hoo3crufxv4h@xena>
rs)
> Night night. ;-)
How about:
Complex Infinity ^ Complex Infinity
But I suppose if you can't add them, you can't power them...
-Nekar Xenos-
Date: 19 Jul 2013 18:01:44
Message: <51e9b748$1@news.povray.org>
> before.
I'm trying to think of an answer which won't make you regret asking that
question :)
For some definitions of infinity there isn't a difference and 2*infinity
= infinity*2 = infinity
The most common definition of infinity for which there *is* a difference
can be thought of as reasoning about (possibly infinitely long)
sequences of things.  In order to not get into the confusing details
about this, let me just say that it turns out that if you follow this
logic through you find that you're allowed to take a sequence, A, and
create a new sequence by replacing each entry in A with another sequence B.
Let me give an example.  I'll denote each element in a sequence tieh the
character @.  You can represent a finite number by a sequence of a
certain length, so 1 is "@", 2 is "@@", 3 is "@@@", 7 is "@@@@@@@" etc.
  So let's say we take the sequence for 3:
and replace each element in it by the sequence for 2, the we get:
Where I've put parentheses in for readability.  Writing it without the
parens you get:
Which is the sequence of 6.  And what a coincidence 2*3 = 6!  In fact,
this strange process works exactly like the multiplication you've come
to know and love for all finite numbers.  Since it works just like
multiplication, we'll just say that this is what we mean by multiplying
two of these sequences together (if it walks like a duck and it quacks
like a duck).  Here's a slightly more precise definition:
If A and B are sequences, then by "A*B" we mean the sequence which would
result by replacing each element in B by the sequence A.
By this definition:
2*3 = (@@)*(@@@) = (@@)(@@)(@@) = @@@@@@ = 6
3*2 = (@@@)*(@@) = (@@@)(@@@) = @@@@@@ = 6
So we get 2*3 = 3*2 = 6 like you'd expect.  But notice that the
parentheses were different in that middle step.  This is where
everything goes to hell when you allow infinite sequences.
Let me give an example.  Say you've got your basic infinite sequence
(which I'll write as "w" since writing "infinity" get confusing when you
have more than one infinity).  So:
w = @@@@@...
Where the "..." just means "goes on forever".  I won't force you to
endure a mathematically precise definition of that.  So with our
previous definition of multiplication:
2*w = (@@)(@@)(@@)... = @@@@@@... = w
w*2 = (@@@@...)(@@@@...) = @@@@...@@@@... = now you may be confused
I don't have a way to make that w*2 feel like it's not a little crazy,
but the best I can do is restate it in plain English:
2*w = "count in forever in multiple of two"
w*2 = "count forever, then when you're done, do it again."
So while counting forever by multiples of two is basically the same as
counting forever normally, counting forever and then doing it again is
another thing entirely.
Provided you're willing to accept that any of this makes sense at all,
that's what the difference is (for that definition of "number" of
course, which surprisingly is a relatively common one).
Date: 19 Jul 2013 18:07:34
Message: <op.w0ho2rcfufxv4h@xena>
On Sat, 20 Jul 2013 00:02:11 +0200, Kevin Wampler <nob### [at] nowherenet>
I see a light bulb! ;)
-Nekar Xenos-
Date: 19 Jul 2013 18:12:04
Message: <51e9b9b4$1@news.povray.org>
On 19/07/2013 11:59 PM, Nekar Xenos wrote:
> How about:
Good question. What do you think?
Who said that? I can't find it in the thread as it is getting long.
I thought you could, if it makes any in ordinary language. Is it a
property of them having one more dimension?
Regards
Date: 19 Jul 2013 18:13:20
Message: <51e9ba00$1@news.povray.org>
if it makes any sense in ordinary language
Regards
Date: 19 Jul 2013 18:16:14
Message: <51e9baae$1@news.povray.org>
> question :)
In that case I'll leave it 'till the morning to read it. As I said
earlier. "I've had a long day" and I've crossed a timezone. The wrong
way. :-(
Regards
Date: 19 Jul 2013 18:21:31
Message: <51e9bbeb$1@news.povray.org>
Eureka! :-D
But from what you quoted.
Don’t they have a BODMAS? (well that is what I was taught the order of
operations, was called). And the meanings.
Regards
Date: 19 Jul 2013 18:22:45
Message: <51e9bc35$1@news.povray.org>
What you mean be "density" is a whole 'nother issue which is
surprisingly complex when you get into it.  When talking about questions
like "Infinity+Infinity" it's best not to worry about things like "density".
That's basically correct.  More precisely, for the definition of
infinity which turns out to be most useful for the reals
Infinity+Infinity=Infinity.  For the definition of Infinity which turns
out to be the most useful for the complex numbers Infinity+Infinity is
undefined.
People can (and occasionally do) use different definitions of Infinity
for the reals/complexes than these, depending on what's useful for the
problem they want to solve.  But you've got the right idea for the most
common choices.
Date: 19 Jul 2013 18:29:37
Message: <51e9bdd1$1@news.povray.org>
Excellent!  I should point out that this is an entirely different
definition of "number" than Le_Forgeron/Orchid have been using.  They
were treating numbers as reasoning about quantities, whereas which I
wrote treats numbers as reasoning about sequences/orders.  Both are
equally valid, but they give different answers to your question.
Date: 19 Jul 2013 19:06:53
Message: <51e9c68d$1@news.povray.org>
Am 19.07.2013 23:38, schrieb Nekar Xenos:
>> useful in some areas mathematics.  Arguably much more useful than
>> "real Infinity" is.  The standard definition of complex Infinity does
>> not allow Infinity+Infinity though (it treats it as undefined, much
>> like 1/0 is commonly treated as undefined for the reals).
No, the set of complex numbers is just "as infinite" as the set of real
numbers; you can use a digit-interleaving technique similar to that
which gets you from the natural numbers to all of the integers.
If you mean
   Infinity := (number of elements in the set of complex numbers)
then no, Infinity + Infinity = Infinity still holds there.
I guess what he meant was that some
   ComplexInfinity := an infinite that behaves much like a
                      complex number, and possibly even has
                      a representation of the form (a + bi)
                      for some presumably weird choice of a,b
Gives you
   ComplexInfinity + ComplexInfinity = <undefined>
Date: 19 Jul 2013 19:19:05
Message: <51e9c969$1@news.povray.org>
> Gives you
This is indeed what I meant by "complex infinity".  As far as I'm aware,
it's not decomposable into the form a+bi where "a" and "b" are real,
since doing so would require a "real infinity" which is distinct from
the complex infinity (I mean, you probably *could* define such a thing,
but I've never seen it done).
Good catch that Nekar was using "complex infinity" in a different way
than I was thinking he was.
Date: 20 Jul 2013 06:34:13
Message: <51ea67a5$1@news.povray.org>
That all made sense and no new ideas. Knowing the syntax and putting it
in context, helps. Thanks.
It was well explained, so do you lecture in mathematics or is it just
part of your job?
Regards
Date: 20 Jul 2013 13:05:20
Message: <51eac350$1@news.povray.org>
> part of your job?
Thanks!  I'm glad to hear that you liked the explanation.  I don't
lecture in mathematics or use this sort of math for my job.  I just
enjoy mathematics and have studied various bits of it more or less for fun.
I do use a lot of math in my job though, but it's just applied math and
not set theory stuff like this.
Date: 20 Jul 2013 14:28:15
Message: <51ead6bf@news.povray.org>
In a sense, adding infinity to itself doesn't make any sense because
infinity is not a number. It's a concept used to describe an abstraction.
There are certain situations where you can use mathematical operators
on infinities as a kind of special notation.
Calculating limits is one situation where infinity-as-a-notation can be
useful.
For example, if lim(x->a) f(x) is infinity, and lim(x->a) g(x) is
infinity, then you can use the notation that lim(x->a) f(x)+g(x) =
infinity + infinity = infinity. In other words, since both f(x) and
g(x) approach infinity when x approaches a, you know that their sum
will also do so.
This doesn't mean that "infinity" is some kind of "special number" that
you can add or do special operations. It's not a number. As said, this
is just a notation you can use to make such calculations easier.
The same is true for multiplication. lim(x->a) f(x)*g(x) is also infinity.
This is also the reason why it's said that eg. "infinity - infinity" is
indetermined. It basically means that the notation system fails and
cannot be used to determine the correct result.
In other words, if it were lim(x->a) f(x)-g(x), the result depends on
what f(x) and g(x) are. You cannot know the answer only from knowing
that their individual limits go to infinity.
Date: 20 Jul 2013 14:33:43
Message: <51ead807@news.povray.org>
You can uniquely map each complex number to each real number on a
one-to-one basis, which means that the set of complex numbers is as
big as the set of reals.
Likewise you can map each rational number to each natural number on
a one-to-one basis, which means that the set of rational numbers is as
big as the set of natural numbers. (There's actually a rather easy way
to do this enumeration. See if you can figure it out.)
Perhaps a bit surprisingly, there is no one-to-one mapping between
rational numbers and real numbers, which means that the set of real
numbers is larger than the set of rational numbers.
This last thing is quite curious given that, for example, between any
two real numbers there is an infinite amount of rational numbers, and
vice-versa. It feels like there should be the same amount...
Date: 20 Jul 2013 14:48:49
Message: <51eadb91$1@news.povray.org>
Huh?  Certainly infinity isn't an integer/real/rational/etc, but there
are consistent and sensible definitions for "number" which include
infinity(s) (I'm pretty sure you're aware of this, so maybe I'm missing
your point?).
Of course infinity is *also* used as an abstraction (as in the case with
limits you mention), but this doesn't mean that in other cases you can't
use it as a perfectly fine number.
Date: 20 Jul 2013 19:27:03
Message: <51eb1cc7@news.povray.org>
> your point?).
So it's a number that's not any kind of number? It's not an integer,
it's not rational, it's not irrational, it's not transcendental, and it
doesn't follow any of the rules of any of the other sets (eg. if you
add 1 to any number, you get a new number that's larger than the
original; or if you multiply any number by 0 you get 0.) All mathematical
operators and functions work completely different for it than for any
other numbers (moreover, most of them aren't even well-defined for
infinity.)
Infinity is not a number. It's just a concept that's used to describe
a more abstract notion. You can use it a bit like if it were a number
when dealing with things like limits, but even then it's just a shortcut
notation.
Date: 20 Jul 2013 21:03:08
Message: <51eb334c@news.povray.org>
Am 21.07.2013 01:27, schrieb Warp:
>> your point?).
> infinity.)
> notation.
Well, I guess it simply boils down to definitions again: What, actually,
/is/ a "number" (in the system you're currently examining)?
Date: 20 Jul 2013 21:25:35
Message: <51eb388f$1@news.povray.org>
> infinity.)
Before I say anything, it's important to point out that I don't find the
term "number" to be particularly mathematically meaningful in the first
place.  It's probably best to just be explicit to say "integer", "real",
"cardinal number" etc., and not bother too much about what counts as a
"true number" and what doesn't.  That said, if you're going to take some
sort of definition as to what counts as a "number", then there are some
good reasons that you might want to include some notions of infinity as
numbers.
What you say above is true for the particular type of infinity you seem
to be thinking of, but it is *not* true in general for other definitions
of infinity.  I'll address it point by point:
Q) It's not an integer, it's not rational, it's not irrational, it's not
transcendental
A) If this is your criteria then you've basically said from the
beginning that infinity isn't a number by definition -- no matter how
much like a number it behaves.  You can certainly take this approach,
but you'll need to accept the existence of "number-like things which are
not numbers".  This is completely valid, in which case I don't think we
really disagree in any substantial way but just draw the line between
"number" and "number-like thing" is different places.
Q) it doesn't follow any of the rules of any of the other sets (eg. if
you add 1 to any number, you get a new number that's larger than the
A) This is not true in general.  There are definitions of infinity for
which infinity+1 > infinity, and for which infinity*0 = 0.  And besides,
there are similar situations with "normal" numbers anyway.  For instance
in the reals you can calculate 1/x for every number x except 0, and
something like x+1 > x doesn't makes sense with complex numbers.  Heck,
in the integers x/y only makes sense if y if a factor of x.  "Normal"
numbers have arithmetic exceptions too, and it doesn't prevent you from
thinking of them as genuine numbers.
Q) All mathematical operators and functions work completely different
for it than for any other numbers (moreover, most of them aren't even
well-defined for infinity.)
A) I actually find the change in how things work by including infinite
numbers to be *less* than the difference between the integers and the
reals.  Saying "All mathematical operators and functions work completely
different for it than for any other numbers" simply isn't true in
general.  It's certainly true for *some* definitions of infinity, but
for other definitions you get perfectly well defined addition and
multiplication, and for a few you even get commutative addition and
multiplication, as well as division, subtraction, etc.  Heck there are
some with these properties where you even maintain that either a <= b or
b <= a, which isn't even true of the complex numbers!
I mean, obviously you need to draw the line somewhere between what you
call a number, and what behaves differently enough that the term
"number" no longer makes sense, but I think it's pretty reasonable to
consider some (but all) definitions of infinity as sufficiently
number-like to be genuine numbers.  I also think that it's fine to call
complex numbers, quaternions, elements in cyclic groups etc. as numbers
too, so maybe I just take a pretty broad stance as to what I think of as
a number.
> notation.
This is math we're talking about, everything is abstract in some sense.
  I agree with limits that it's a notational shortcut, but there are
many many other ways of defining infinity quantities, and some of them
behave quite a bit like numbers.
Date: 21 Jul 2013 03:34:17
Message: <51eb8ef9@news.povray.org>
So how do you define infinity so that it's a number?
Date: 21 Jul 2013 03:37:28
Message: <op.w0j94p1sufxv4h@xena>
On Sun, 21 Jul 2013 03:26:02 +0200, Kevin Wampler <nob### [at] nowherenet>
It almost seems that any mathematical operation using infinity has the
same answer: Infinity
-Nekar Xenos-
Date: 21 Jul 2013 03:55:45
Message: <51eb9401$1@news.povray.org>
And some answer only to themselves. O.o
Regards
Date: 21 Jul 2013 11:11:44
Message: <51ebfa30@news.povray.org>
Well, for some of these you get a whole slew of different "infinite
numbers", so the result of many mathematical operations using infinity
just give you different infinities as their answers (which is pretty
much what you'd expect if you count these infinite quantities as actual
numbers).
In situations where such things are allowed, dividing by infinity can be
useful, in which case it gives you either zero or an infinitesimal,
depending on which system you're using.
Date: 21 Jul 2013 11:12:35
Message: <51ebfa63$1@news.povray.org>
I would count any of the following, but you may find the last two to be
better examples than the first two:
1) cardinal numbers: http://en.wikipedia.org/wiki/Cardinal_number
2) ordinal numbers: http://en.wikipedia.org/wiki/Ordinal_number
3) extended complex plane: http://en.wikipedia.org/wiki/Riemann_sphere
4) surreal numbers: http://en.wikipedia.org/wiki/Surreal_number
There are probably plenty of other ways too, but these are the ones that
come to mind for me.
Date: 20 Aug 2013 04:58:45
Message: <52132fc5@news.povray.org>
I wanted to post about this earlier but couldn't remember the name.
Anyway stumbled across it again today, possibly relevant to this thread:
http://en.wikipedia.org/wiki/Banach%E2%80%93Tarski_paradox
