POV-Ray : Newsgroups : povray.off-topic : Learning C# Server Time
15 Jan 2026 09:55:45 EST (-0500)
  Learning C# (Message 1 to 10 of 32)
Subject: Learning C#
Date: 28 Sep 2012 10:13:04
Message: <5065b070@news.povray.org>
OK, so most companies don't seem to be interested in Java any more. Most
of them are asking for something.net, and the most popular one is C#,
unsurprisingly. So I'm sitting hear reading some C# books.
Like anything else, there are some good things, and not so good things.
The one that really tickles me is the author insisting that because
assemblies are loaded dynamically, and because CIL takes up less space
than machine code and is JIT-compiled, you can "drastically reduce the
working set of your application".
Uhuh. Erm... you realise this thing uses a GC for memory management,
right? ;-)
I also love the way it raves about why "metadata" is so great, without
actually explaining precisely what it solves.
But anyway, early days...
Subject: Re: Learning C#
Date: 28 Sep 2012 10:21:47
Message: <5065b27b$1@news.povray.org>
I assume you've downloaded and installed MS Visual C# Express already?
If not do it now :-)
Date: 28 Sep 2012 10:51:22
Message: <5065b96a$1@news.povray.org>
Twice, in fact.
First I downloaded the full install. Apparently the only way to do that
is to download an ISO image. Which means you have to burn it to a CD
before you can access it. [Unless you use Unix. :-P ] Unfortunately,
when I tried to install, I got a CRC32 error, and it died half way
through the installation.
So then I had to try again. I've now got it to the point where VS opens.
I don't know if it actually works yet, or whether I need to completely
reinstall Windows to fix it...
Date: 28 Sep 2012 11:40:05
Message: <5065c4d5$1@news.povray.org>
On Fri, 28 Sep 2012 15:51:34 +0100, Orchid Win7 v1 wrote:
> Apparently the only way to do that is to download an ISO image. Which
> means you have to burn it to a CD before you can access it. [Unless you
> use Unix. :-P ]
Daemon Tools.
Jim
Date: 28 Sep 2012 12:57:26
Message: <5065d6f6$1@news.povray.org>
Heh. It amuses me that run-time polymorphism via inheritance is /the/
central contribution of the OO movement, and here I am reading a book
warning me not to use inheritance under any circumstances unless
absolutely unavoidable...
Date: 28 Sep 2012 13:39:03
Message: <5065e0b7$1@news.povray.org>
> Twice, in fact.
You can mount ISOs as a file system under Windows.  Microsoft has an
utility for it, but in only works up to Vista.  For Windows 7 or 8, you
need Virtual Clonedrive ( http://www.slysoft.com/en/download.html )
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 28 Sep 2012 13:41:47
Message: <5065e15b$1@news.povray.org>
So, what's their solution?  You have to reinvent the wheel all the time?
So if you need a linked list of widgets and a linked list of gizmos, you
have to have two complete sets of add(), remove() and iterate() methods?
Date: 28 Sep 2012 14:05:00
Message: <web.5065e646a7abe40febb90cbd0@news.povray.org>
forget all those silly concepts from olde ages.  Apps today are just a
multi-tiered assemblage of multiple layers of API calls to multiple frameworks.
The language you use is irrelevant, which is why .net allows you to use your
favorite language syntax to call the APIs.
it's all dynamic and marshaled in real-time wrapped in zipped xml sent
asynchronously via http. bwahahahaha
Date: 28 Sep 2012 16:27:15
Message: <50660823@news.povray.org>
Does it explain why?
Date: 28 Sep 2012 16:32:37
Message: <50660965@news.povray.org>
I don't even understand what that means.
I have seen several arguments in the past (but I think they have mostly
died alongside the prejudice against C++ and templates) that C++ templates
are bad because they increase code size, thus increasing memory usage.
That's one of the stupidest arguments ever. The reason is that the
alternative proposed by these critics is to use runtime polymorphism.
Yes, rather than have the same function repeated for each used type you
will have one single function that handles all the types. However, if all
your objects are dynamically allocated and dynamically bound (which is
necessary for runtime polymorphism) they will end up taking enormously
more memory than duplicating that function a few times (optimized to handle
each type statically).
In other words, their solution to the "huge" "problem" of increased code
size is to increase memory usage ten-fold in order to make the executable
binary slightly smaller. Great job.
