POV-Ray : Newsgroups : povray.off-topic : Just ask Google Server Time
28 Jul 2026 12:33:37 EDT (-0400)
  Just ask Google (Message 31 to 40 of 47)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Just ask Google
Date: 19 Jul 2012 11:52:02
Message: <50082d22$1@news.povray.org>
On Thu, 19 Jul 2012 08:56:56 +0100, Invisible wrote:
>>> Most of the discussions appear to be /very/ old.
>> It's an example of how to do a search.  Use the search tools to
>> constrain the results to a more recent timeframe.
> One of the discussions suggests that the correct search term is "shell
> host". This does indeed appear to generate a lot of hits...
*That's* how searching on Google is accomplished.  Learning is an
iterative process - sometimes finding the right search combinations are a
learning process. :)
Jim
Subject: Re: Just ask PHP
Date: 19 Jul 2012 11:54:03
Message: <50082d9b$1@news.povray.org>
On Thu, 19 Jul 2012 09:50:29 +0100, Invisible wrote:
> So perhaps I should try compiling a 32-bit ELF binary and see if that
> works? (Man, is there even a way to do that with a 64-bit Linux distro?
> I'm sure there is, but finding it...)
Yes, x64 Linux systems can run ia32 ELF binaries if the library
dependencies are met using 32-bit libraries.
Jim
Subject: Re: Just ask Unix
Date: 19 Jul 2012 11:54:55
Message: <50082dcf$1@news.povray.org>
On Thu, 19 Jul 2012 10:24:00 +0100, Invisible wrote:
> Now, how much do you want to bet that a non-trivial program compiled on
> one Unix box won't run on another Unix box? :-/
If the library requirements are met, it'll run.
If they aren't, then it won't.
Jim
Date: 19 Jul 2012 12:18:31
Message: <50083357$1@news.povray.org>
Trouble is, a typical Haskell program compiled with GHC has a vast list
of dependencies. (Off the top of my head, GMP, ncurses, libffi...)
Without shell access, it's going to be fun trying to fake that lot.
Date: 19 Jul 2012 13:12:02
Message: <50083fe2$1@news.povray.org>
>>> on one Unix box won't run on another Unix box? :-/
Doesn't ghc provide a static linking option?
Jim
Date: 19 Jul 2012 13:13:51
Message: <5008404f$1@news.povray.org>
On Thu, 19 Jul 2012 10:20:06 +0100, Invisible wrote:
> Interestingly, the documentation claims that all CGI scripts must begin
> with a shebang and must have execute permissions. For at least PHP, this
> is clearly untrue...
That's because with apache, php is something it knows about with mod_php*,
so it calls scripts with the php* extensions with the php processor.
But php script does accept a #!/path/to/executable at the start as well,
and if the path is right and the script is executable, it'll work as Perl
or any other scripted *nix language.
Jim
Date: 19 Jul 2012 13:57:17
Message: <50084a7d$1@news.povray.org>
By default, GHC statically links all *Haskell* libraries. However, it
usually does not statically link *external* libraries, as far as I can
tell. Perhaps there's a switch somewhere to make it do that...
(And then, of course, we get into the fun of deciding which libraries
should or should not be statically linked. E.g., apparently statically
linking glibc is a bad idea.)
Date: 19 Jul 2012 14:14:39
Message: <50084e8f@news.povray.org>
Maybe, I don't know. :)
Well, glibc is a big library, but if the library you compile against has
what you need, then it's not really any worse an idea than any other
library.
Jim
Date: 19 Jul 2012 14:39:37
Message: <50085469$1@news.povray.org>
Neither do I. But I know who to ask...
> library.
According to the research I've done, you really don't want to statically
link glibc, because it intimately depends on half the low-level stuff in
the entire system. Just taking one version of glibc and trying to run it
against the support files for another version tends to break spectacularly.
Similarly, you wouldn't want to statically link the OpenGL libraries,
because they are specific to your GPU. Similar remarks apply to ALSA,
apparently. And X11. And a few other things.
Let me see if I can figure out where I read all this... Ah yes, here we go:
http://freegamedev.net/wiki/Portable_binaries
Basically, it seems this stuff is pretty complicated. I suppose package
managers were invented for a reason, eh? Pity I can't use one to solve
my problem...
Date: 19 Jul 2012 15:09:11
Message: <50085b57@news.povray.org>
On a related note, back in grad school in the early 90's, I once spent 2 or
3 days tracking down a technical paper from 1985 that I needed to read. I
had the reference and everything, and I just had to find where it was in the
library.
The other day, I ran across someone mentioning "it makes error recovery in
distributed systems easier" and remembered this paper. All I remembered was
one author's name and the name of the programming language (NIL) in which it
was being tested.
It took me about 10 minutes to find the complete text through google search,
just by following through half a dozen references, tracking down the full
title that way, and then googling for the full title.
I thought that was pretty cool.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
