POV-Ray : Newsgroups : povray.off-topic : Quote of the day Server Time
29 Jul 2024 04:30:56 EDT (-0400)
  Quote of the day (Message 1 to 9 of 9)
Subject: Quote of the day
Date: 2 Jul 2012 09:43:07
Message: <4ff1a56b@news.povray.org>
I found the following quote on LinkedIn (of all places):
"Which financial firms (buyside or/and sellside) are currently actively
using functional programming (FP) languages like F#, OCaml, Lisp, Scheme
or Haskell?"
"I keep hearing buzz around this space. I think most of Investment Banks
have have at last research initiatives ongoing.
OCaml (and F#) look to be much more promising in the realm of writing
production systems de novo. Haskell isn't deterministic in its return
time (it's Lazy so it may come back in 5 secs or may take 5 hours - and
you cant really predict up front which - this is fatal for use in eg
pricing libraries)"
You heard it here folks - Haskell "isn't deterministic". :-D
While obviously this statement is false (you /can/ predict run-time,
it's just harder than you might imagine), the assertion that "this is
fatal" is probably bang-on.
Subject: Re: Quote of the day
Date: 2 Jul 2012 14:00:01
Message: <web.4ff1e1792e017d32773c9a3e0@news.povray.org>
> or Haskell?"
> pricing libraries)"
was that our OCaml/F# friend Jon Harrop? ;)
Date: 2 Jul 2012 16:03:46
Message: <4ff1fea2$1@news.povray.org>
Well, it's certainly /possible/... I didn't actually check.
Even so, it has a ring of inevitable truth to it...
Date: 3 Jul 2012 00:40:39
Message: <4ff277c7@news.povray.org>
> pricing libraries)"
  I don't understand at which point Haskell decides to stop laziness and
start actually computing results. It cannot be lazy forever because it
would just run out of memory sooner or later (probably even with algorithms
that would normally require O(1) memory in an imperative language).
Date: 3 Jul 2012 06:49:21
Message: <4ff2ce31@news.povray.org>
> start actually computing results. It cannot be lazy forever.
This is an important question, and one which I haven't seen really
explained properly anywhere. The only time I've seen it explained is
when people try to write complicated mathematical equations which
rigorously expound the rules... These are not the sort of things your
average Joe Programmer is likely to comprehend. And comprehending this
stuff is really rather important if you want to write code with good
performance!
The rules aren't especially complicated. They just don't appear to be
written down anywhere in an easily digestible form.
1. Execution starts from "main".
2. I/O actions execute sequentially, in the order written.
3. Any arguments to an I/O action get executed when the I/O action
executes. (Usually.)
4. If there is a conditional branch in the I/O sequence, the condition
is evaluated so we can decide which branch to take.
Together, these rules tell us when I/O actions execute, and when that
causes pure expressions to execute. When a pure expression executes, we
walk down the expression tree in a certain order, recursively executing
the sub-expressions.
For the most part, there are two rules to pure code:
1. If the result of a function is another expression, execute that
expression.
2. If the result of a function depends on a conditional branch, execute
the conditional so we can decide which branch to take.
An example may help to clarify:
   or1 False False = False
   or1 False True  = True
   or1 True  False = True
   or1 True  True  = True
   or2 False x = x
   or2 True  x = True
The first function /obviously/ implements the truth-table of the
logical-OR function. It might not be immediately obvious, but for any
True/False combination, or2 produces the same result as or1. (Try it!)
Given this, you might think that these are two equivalent ways of
writing the same function. But actually, they are not. or1 takes a
conditional branch based on the values of /both arguments/. Therefore,
whenever or1 is called, /both arguments/ will be computed. or2, on the
other hand, takes a conditional branch based on /one/ argument only. If
that argument is False, then the second argument will be returned (and
hence immediately computed). However, if the first argument is True,
then the second argument will /never/ be computed.
Hopefully that gives you some idea how pure code implicitly defines
execution order. Admittedly it's quite subtle; even the experts get this
stuff occasionally. Arguably that's Haskell's greatest weakness. (Even
some of the original language architects seem ambivilent about whether
default-lazy was the right choice.)
As well as conditional constructs, there are various ways that you can
/force/ stuff to execute Right Now, rather than at some later time. The
main one is the "seq" function. seq is magical, in that it doesn't
"need" its first argument, and yet the language spec guarantees that it
will always be executed. For example,
   length list = work 0 list
     where
       work n (head : tail) = work (n+1) tail
       work n []            = n
This counts the number of elements in a list. However, what it does is
fill "n" with a giant expression that looks like 1+(1+(1+(1+...)))). And
then, right at the end, it returns n, forcing this giant expression to
be executed. If the input list is large enough, this easily overflows
the stack.
To fix this, we need to do two things. First, we create a local variable
for the new, updated count:
   work (n+1) tail
becomes
   let n1 = n+1 in work n1 tail
By itself, this does nothing. But now we can apply the seq function:
   let n1 = n+1 in n1 `seq` work n1 tail
This /forces/ n1 to be executed /before/ the recursive call to work is
executed. Since this happens every time round the loop, n always ends up
holding an evaluated integer.
In fact, now the compiler can /see/ that n is always evaluated, and it
starts applying optimisations like treating n is a normal
machine-integer rather than a heap object, producing a tight loop like a
Java or C programmer would write.
seq is used for other reasons; for example, when doing parallel
programming, you /want/ the parallel threads to compute stuff, even
though they don't "do" anything with the result. (You may remember the
magical "par" function forces something to be evaluated in parallel,
much like "seq" forces it in series.)
It's also important to remember that values are not simple "evaluated"
or "unevaluated". It's not black and white, it's shades of grey. Each
individual heap object is either black or white; a given expression's
result might consist of hundreds of individual heap objects, hence the
shades of grey. Anything atomic like an integer or a Bool is black or
white; things like lists or strings or whatever have shades of grey.
(Actually, saying that, it's not inconceivable that an /arbitrary
precision/ integer might consists of more than one heap object...)
Actually, having written Logic Box, one of the next projects I was
thinking about attacking was writing an interactive simulator that shows
you how the computer runs Haskell code. I actually ended up with a mild
case of analysis-paralysis, but I think it's tractable. Would that be
something that interests you? (Or anybody else here...?)
Date: 3 Jul 2012 15:27:56
Message: <4FF347BC.7030308@gmail.com>
>> pricing libraries)"
Wow, just wow. Let me rephrase: 'you should never use a sorting
algorithm because the runtime depends on the input'.
Deterministic is not the right word, he meant unpredictable. And even
that is wrong (see also Andrews reply). I know of only one language that
is unpredictable and that is Dijkstra's guarded command language. OTOH I
don't know if anybody ever made an implementation of that.
No. Although you could write a program that needs an infinite amount of
space. Such a program would make as much sense as a program in an
imperative language that has an infinite loop.
Laziness basically means that you don't start computing things when you
don't know if you are ever going to need the result. It is just the way
you traverse your statespace in search of a solution. If we cut some
corners we might say that it is a depth first search. So it is going to
work on a branch if the branch on the left (or the right for Hebrew and
Arabic speaking persons) is exhausted. For every specification and every
input there might be another way of going through your statespace that
is faster for that particular problem. But that is not the point. If you
know the optimal strategy you can always force Haskell to use that. Yet,
if you don't know the answer it is in general a good strategy (if you
are running on a single thread machine).
tip: do not run in an unknown place when it is too dark to see the
floor, unless you prefer to not use uppercase.
Date: 3 Jul 2012 16:05:30
Message: <4ff3508a$1@news.povray.org>
And yet, everybody prefers the unpredictable quicksort over the
perfectly consistent mergesort, even though on paper they should be
equally fast...
Yeah, most things a computer program does are /deterministic/. This is
not the same as /predictable/ at all.
(In some sense, whether a program ever halts at all is "unpredictable".
For example, even though it's completely /deterministic/, it's provably
not /computable/.)
 From a practical perspective, if you have no idea whatsoever how
efficient or not the code you just wrote is going to be... you have a
problem.
OOC, do you have a reference for that?
>> algorithms
It's true though that a lazy language can unexpectedly change the
complexity class of your algorithm if you're not paying attention.
For example, counting the number of nodes in a list /should/ be O(1) in
time and space. However, the "obvious" thing to write is
   length (x:xs) = 1 + length xs
   length []     = 0
This gives the correct answer, but is unfortunately O(n) in time and
space - which is very silly, of course. The "correct" solution is the
much less obvious function
   length = count 0
     where
       count n (x:xs) = let n' = n+1 in n' `seq` count n' xs
       count n []     = n
This is actually O(1) like you'd expect.
On the other hand, the "obvious" way to implement the Fibonacci numbers
[as if any computer program ever in the history of mankind will ever
/need/ to look up a Fibonacci number for any purpose other than
micro-benchmarks] is:
   fib 0 = 1
   fib 1 = 1
   fib n = fib (n-1) + fib (n+2)
This is unfortunately O(n^2). But the trixy incantation
   fibs = 1 : 1 : zipWith (+) fibs (tail fibs)
is only O(n). And it works exactly /because/ of laziness. Otherwise,
this would be an infinite loop which would never end.
(There are similar incantations for the prime numbers and for Pascal's
triangle.)
Date: 3 Jul 2012 16:07:14
Message: <4ff350f2$1@news.povray.org>
...as opposed to those infinite loops that end after a while. o_O
Date: 4 Jul 2012 11:38:17
Message: <4FF46365.6060706@gmail.com>
I reference for not knowing something???
For Dijkstra's GCL I think the most obvious source is A discipline of
programming. I think he even explains in there why it is essential that
the execution is non-deterministic.
