POV-Ray : Newsgroups : povray.off-topic : Logic programming Server Time
16 Jun 2026 10:05:48 EDT (-0400)
  Logic programming (Message 19 to 28 of 28)
Subject: Turning-complete
Date: 1 Jun 2012 06:48:16
Message: <4fc89df0$1@news.povray.org>
Theorem: The language implemented by Logic Box is Turing-complete.
Proof: I have written a program in Logic Box which executes any program
written in the SKI calculus. The SKI calculus is known to be
Turing-complete.
Actually, things are not quite so simple. But here goes...
First, the SKI calculus consists of abstract variables, and the three
combinators "S", "K" and "I", which have the following rules:
   Sfgx => (fx)(gx) => fx(gx)
   Kxy  => x
   Ix   => x
It may seem absurd that this trivial system is Turing-complete. But
there is actually several even /more/ trivial systems which are somehow
Turing-complete.
So, how do we implement these transformation rules in Logic Box? Well,
first we need to decide how to store this stuff. I have chosen to use
S[], K[] and I[] to stand for the three combinators, and used the
structure at[x, y] to represent a function application. (In other words,
what is normally written as "xy" becomes "at[x, y]".) This makes things
very verbose, but it does work.
The actual transformation rules are now simple enough to write:
   Reduce1{in, out}:
     (~x in = at[I[], x] & out = x) |
     (~x y in = at[at[K[], x], y] & out = x) |
     (~f ~g ~x in = at[at[at[S[], f], g], x] & out = at[at[f, x], at[g, x]])
This simple predicate takes an SKI expression as its first argument, and
arranges for the second argument to be made equal to the result of a
single reduction.
Actually, to get a "complete" reduction, you need to add a few extra
rules to recursively reduce sub-expressions, or the thing never makes
any progress.
This only performs one reduction step. To make it reduce /all/ the
steps, you can do
   Reduce{in, out}:
     out = in | ~new Reduce1{in, new} & Reduce{new, out}
Unfortunately, because the OR operator tries /all/ possibilities rather
than just keeping the first successful one, what this does is to produce
a result set containing all possible reductions, using all possible
reduction orders.
So in summary, we can say that running the program produces a result set
which contains the correct answer /somewhere/, plus a whole heap of
various intermediate results. As best as I can tell, there's no way to
determine /where/ in the solutions it is. So I'm not completely sure
this counts as a valid proof.
The complete test code is here:
Reduce1{in, out}:
   (~arg1 at[I[], arg1] = in & out = arg1) |
   (~arg1 ~arg2 at[at[K[], arg1], arg2] = in & out = arg1) |
   (~fn1 ~fn2 ~arg3 at[at[at[S[], fn1], fn2], arg3] = in & out =
at[at[fn1, arg3], at[fn2, arg3]]) |
   (~left ~right
     at[left, right] = in &
       ( ~left2 Reduce1{ left,  left2} & out = at[left2, right ]) |
       (~right2 Reduce1{right, right2} & out = at[left , right2])
Reduce{in, out}:
   in = out | ~new Reduce1{in, new} & Reduce{new, out}
Test1{out}:
   ~s s = S[] &
   ~k k = K[] &
   ~i i = I[] &
   out = at[at[at[at[s, at[at[s, at[k, s]], k]], i], f[]], x[]]
The final bit generates the expression S(S(KS)K)Ifx - the Church numeral
2 - as a simple example which you can run.
   Test1{test} & Reduce{test, out}
It takes many, many steps, but it does eventually produce f(fx) as
result #7. (And several more times after that, as it explores every
possible reduction sequence. The number of these is presumably
exponential in the size of the input...)
I would have to add either a NOT predicate, or an exclusive-OR predicate
to get this to terminate at normal form.
Subject: Re: Turning-complete
Date: 1 Jun 2012 07:03:55
Message: <4fc8a19b@news.povray.org>
Not so much the /size/ of the input, but the number of redexes
("reducible expressions") it contains.
At every point, the solver chooses a redex by some algorithm, and then
reduces it. Overall, the solver makes all possible choices, and
generates [at least] one result per choice. So clearly the number of
redexes put a lower bound on the number of solutions.
Reducing a K-redex or an I-redex results in one fewer redexes. However,
reducing an S-redex can duplicate an existing redex into /two/ new
redexes. (Or it can leave the number of redexes unchanged. It depends on
the exact expression.)
I would hazard a guess, therefore, that the number of possible reduction
orders is a non-computable function of the input expression.
Look at it this way: It appears that the only way to compute the number
of reduction orders is to actually /find/ all possible reduction orders.
In other words, to execute the program and count how many ways you can
do it. If the program is non-terminating, then the counting procedure is
also non-terminating. So it appears that counting the number of
reduction orders is trivially equivalent to the Halting Problem.
(This relies on the assumption that running the program is the /only/
way to compute the number of reduction orders...)
Subject: Arithmetic
Date: 1 Jun 2012 10:01:33
Message: <4fc8cb3d$1@news.povray.org>
On 31/05/2012 11:47 AM, scott wrote:
> Also how hard would it be to add support for arithmetic operators? Then
> you would have an equation solver, which arguably would be more useful.
Peano arithmetic. Basically, you use Z[] to represent 0, and S[x] to
represent x+1. In this way, 3 is represented by S[S[S[Z[]]]]. (In other
words, 3 lots of S[].)
It's then quite easy to write sum and product predicates:
ISum{x, y, z}:
   (x = Z[] & y = z) |
   (~px ~pz
     x = S[px] &
     z = S[pz] &
     ISum{px, y, pz}
IProduct{x, y, z}:
   (x = Z[] & z = Z[]) |
   (~px ~t
     x = S[px] &
     IProduct{px, y, t} &
     ISum{t, y, z}
Using this, I was able to solve the following system of simultaneous
equations:
   x + y = 9
   2x = y
The first equation can be represented by
   ISum{x, y, nine}
where nine is S[S[S[S[S[S[S[S[S[Z[]]]]]]]]]]. The second equation can be
written
   IProduct{two, x, y}
where, again, two is S[S[Z[]]].
It takes several thousand steps, but Logic Box finds exactly one solutions:
   x := S[S[S[Z[]]]];
   y := S[S[S[S[S[S[Z[]]]]]]];
In other words, x=3 and y=6, which does solve the given equations.
Notice that the ISum{} predicate on its own gives the solution set
   x := 0; y := 9;
   x := 1; y := 8;
   x := 2; y := 7;
   x := 3; y := 6;
   x := 8; y := 1;
   x := 9; y := 0;
Note also that the ISum{} predicate needs to come first, since it has a
finite solution set. The IProduct{} predicate has the infinite solution set
   x := 0; y := 0;
   x := 1; y := 2;
   x := 2; y := 4;
   x := 3; y := 6;
Either way, the correct solution is located. But if IProduct{} comes
first, the solver never terminates, fruitlessly searching the infinite
search space for non-existent further solutions. If ISum{} comes first,
the search terminates eventually.
Either way, it's pretty damned slow. It's basically searching for all
possible combinations of numbers having the requested properties.
It shouldn't be too hard to add an IExponent{} predicate too, and ask
the solver to solve some polynomial equations. Remember, though, that at
this point it handles only integers.
More generally, I'm going to see whether I can implement some more
efficient type of arithmetic. (E.g., binary arithmetic.)
Subject: Re: Logic Box v2 release #1
Date: 2 Jun 2012 16:39:59
Message: <4fca7a1f$1@news.povray.org>
On 5/31/2012 5:27, scott wrote:
> Now that would be a very cool solution, as in you wouldn't need to tell the
> computer *how* to solve it (as you have to when writing a "traditional"
> sudoku solver), just what the rules are.
I saw one discussion of writing a soduko solver with backtracking and etc.
The guy gave it an empty grid and said "solve this one". And it did.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 3 Jun 2012 10:15:31
Message: <4fcb7183$1@news.povray.org>
>> Having written something like this is also very good for CVs and job
>> interviews :-)
> yes, at least if he's willing to change "written by Orphi the AweKid"... :p
Please. I have the source code. And the Git repo. ;-) Nobody else on
Earth has that...
Date: 3 Jun 2012 18:30:35
Message: <4fcbe58b$1@news.povray.org>
>> tell the
> etc. The guy gave it an empty grid and said "solve this one". And it did.
It's also pretty trivial to modify the algorithm so that it enumerates
all the possible solutions from any starting state (or at least tries
to, if you run on an empty board it'll be listing them for quite a while).
Subject: Re: Arithmetic
Date: 4 Jun 2012 09:11:39
Message: <4fccb40b$1@news.povray.org>
One might think about implementing some kind of primitive which allows
you to add and subtract real integers. Actually, this turns out to be
less helpful than you might imagine.
Using Peano arithmetic, we can write things such as
   x = S[y]
this denotes the fact that x = y+1, without specifying which actual
integer y contains. We can work that out later. By contrast, if you
wanted to implement some primitive which works in definite integers, you
would have to somehow augment the solution language to support
constraints like "x is one greater than y". Using Peano arithmetic, you
get that for free.
Perhaps the only primitive I ought to be adding is one to convert
between real integers and Peano integers...
I did manage to implement addition (and therefore subtraction) of binary
numbers. On the one hand, that makes numbers much shorter to write. (The
amount of characters required to represent N is now O(log N) rather than
O(N).) On the other hand, the predicates become quite a lot more
complicated, so it's dubious whether it actually runs any /faster/. It's
also much harder to debug if it doesn't work properly.
Date: 4 Jun 2012 09:14:03
Message: <4fccb49b$1@news.povray.org>
> numbers.
The sum of two Peano integers:
ISum{x, y, z}:
   (x = Z[] & y = z) |
     ~predX x = S[predX] &
     ~predZ z = S[predZ] &
     ISum{predX, y, predZ}
The sum of two binary integers:
ISum{x, y, z}:
   ~co ~t ISum_Dn{x, y, 0, co, t} &
     (co = 0 & z = t) |
     (co = 1 & z = D[1, t])
ISum_D1{x, y, ci, co, z}:
   (x = 0 & y = 0 & ci = 0 & co = 0 & z = 0) |
   (x = 0 & y = 0 & ci = 1 & co = 0 & z = 1) |
   (x = 0 & y = 1 & ci = 0 & co = 0 & z = 1) |
   (x = 0 & y = 1 & ci = 1 & co = 1 & z = 0) |
   (x = 1 & y = 0 & ci = 0 & co = 0 & z = 1) |
   (x = 1 & y = 0 & ci = 1 & co = 1 & z = 0) |
   (x = 1 & y = 1 & ci = 0 & co = 1 & z = 0) |
   (x = 1 & y = 1 & ci = 1 & co = 1 & z = 1)
ISum_Dn{x, y, ci, co, z}:
   ~headX ~tailX x = D[headX, tailX] &
   ~headY ~tailY y = D[headY, tailY] &
   ~headZ ~tailZ z = D[headZ, tailZ] &
       tailX = D[] &
       tailY = D[] &
       tailZ = D[] &
       ISum_D1{headX, headY, ci, co, headZ}
       ~ct ISum_Dn{tailX, tailY, ci, ct, tailZ} &
           ISum_D1{headX, headY, ct, co, headZ}
Note also that if we use Peano integers, there is exactly one way to
write each number. With binary, there are several ways. For example, 11
and 0011 both denote 3. The ISum{} predicate above works only for
numbers containing the same number of bits. I haven't even attempted to
implement binary multiplication yet. (That would probably turn out to be
drastically faster, however...)
Subject: Re: Logic Box v3 release #1
Date: 22 Jun 2012 09:41:52
Message: <4fe47620$1@news.povray.org>
On 01/06/2012 09:02 AM, Invisible wrote:
> There's a couple of other ideas I have for what could be done with this
> program. (E.g., improving the output, refactoring the code, adding new
> features.) But honestly, I think I'm bored with it now. I don't suppose
> I'll be making any further releases soon. It's time for a different
> project...
Heh. So much for that!
Attached is v3, which is a 100% rewrite of the entire codebase. (I mean,
it's not like it's /large/ or anything...) In particular, you can now
step /backwards/ as well as forwards. And I've tried to make the status
display a little less perplexing. (Not sure I succeeded!)
Also, the previous version of this program has a bug relating to named
predicate calls. Basically, a name capture bug. I believe this new
version is free of such flaws.
I know how excited everybody has been about this program (i.e., not in
the slightest), so I imagine this new release will generate a wave of
excitement...
Download 'logicbox-03 release1.jar.zip' (225 KB)
Date: 17 Jul 2012 10:10:51
Message: <5005726b$1@news.povray.org>
> Turing-complete.
> reduction orders.
Actually, it turns out that by swapping the order of some predicates,
you can make it so that Normal Order Reduction is always solution #1.
This conclusively proves the Turing-completeness of my little
programming language.
It also conclusively proves something that will surprise nobody: My
talents are wasted here.
