POV-Ray : Newsgroups : povray.off-topic : Windows growing over time is now an official feature Server Time
16 Jun 2026 09:46:02 EDT (-0400)
  Windows growing over time is now an official feature (Message 18 to 27 of 27)
Subject: Re: Windows growing over time is now an official feature
Date: 28 May 2012 06:08:19
Message: <4fc34e93$1@news.povray.org>
On 28/05/2012 9:02 AM, Invisible wrote:
> On 27/05/2012 02:43 AM, Darren New wrote:
>> On 5/18/2012 1:09, Invisible wrote:
>>> and also spends eighty BILLION years scanning your
>>> entire harddrive to see if there are any files which haven't been
>>> accessed
>>> in the last 24 hours and could therefore be compressed.
>> Actually, it only does that for new files. The first time it takes a
>> long time. After that, not so much. Me, I go in the registry, find the
>> string that describes that operation, delete that key, and don't have to
>> deal with that any more.
> Yeah, but manually doing that for 30 PCs isn't much fun.
That is why it is called work.
Regards
Date: 28 May 2012 08:32:35
Message: <4fc37063$1@news.povray.org>
>>> accessed
Can't you push a .reg that does it automagically?
>>> But it does /not/ offer to empty your temp folder,
>> Yes it does.
> Really? I've never seen it.
>>> delete old OS updates,
>> No, but you used to be able to do that on XP from the add/remove, IIRC.
> I think NT4 offered it, but I don't think XP does.
Yes it does.  There's a checkmark at the top of the Add/Remove Programs
window that allows you to see all of the patches and remove them
individually, if you want to.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 28 May 2012 09:14:21
Message: <4fc37a2d$1@news.povray.org>
There's probably a way of doing it. It's not particularly simple though.
No, not uninstall the update, but remove the uninstall capability.
Date: 28 May 2012 14:34:05
Message: <4fc3c51d$1@news.povray.org>
We used to do this with 6,000 PCs at a place I worked at.
There are tools to do this, and they're not difficult to use.
Jim
Date: 29 May 2012 08:57:02
Message: <4fc4c79e@news.povray.org>
Type "disable compress old files" in Google.  while the two first
entries appear legitimate, the third option is:
http://support.microsoft.com/kb/812248
Which tells you exactly which key to delete, just like Darren said, and
is free from publicity.
Now, to automate the task, you can type ".reg file format" in Google.
"I'm feeling lucky" should send you to:
http://support.microsoft.com/kb/310516
Tada!
There's a link at the bottom of that knowledge-base article that
explains how to distribute it using group policies.
How much simpler did you want it to be?
I'm sorry.  Your complete sentence from the previous message was:
 >>>>> But it does /not/ offer to empty your temp folder, delete old OS
 >>>>> updates, empty the recycle bin, trim the DLL cache, empty the
 >>>>> precache folder, or indeed do /anything/ which might actually,
 >>>>> you know, REDUCE DISK USAGE...
To most readers of the english language, it would appear that you wanted
to be able to delete old OS updates.  If you wanted to be able to
prevent someone from deleting an OS update, you worded it very poorly.
Date: 2 Jun 2012 16:14:58
Message: <4fca7442@news.povray.org>
Not unless you automate it, no.
> Oh, really? I thought it just contains a redundant copy of all the recently
> used DLLs so Windows doesn't have to search for them again.
No. If it was doing that, it would use a different structure rather than
copying the entire DLL, don't you think?
> Clearly the dire warnings of "this is why Windows gradually slows down" were
> wrong.
They often are.
>> They did SP3, which was a rollup of everything up until they basically
>> stopped supporting it. Honestly not sure if XP has SxS in this form.
> It probably doesn't. It seems to generate a folder like
> C:\WINDOWS\$NtUninstallKB485734654$
> for every single update it installs. So if you open the WINDOWS folder, you
> have to scroll past several billion of these folders before you get to the
> thing you were actually looking for - which is a bit annoying.
That's pre SxS, so I guess if you're worried about it, you delete the
uninstall folders. That's how I always cleaned up.
>> Wait for Windows 8? There's a limit on how much you can do on each
>> release of an OS. :-)
> I don't see why that would be a problem for the biggest software producer on
> Earth, but hey...
It takes 9 months to make a baby regardless of how many women you assign.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 2 Jun 2012 16:15:43
Message: <4fca746f$1@news.povray.org>
Delete the uninstall directory you're complaining about. Problem solved.
    in the cabinet."
Date: 3 Jun 2012 04:52:03
Message: <4fcb25b3$1@news.povray.org>
You have to play with the registry to remove the uninstall entry from
the menu though.
But yeah, this thread started out by Warp pointing out that in later
versions of Windows, it no longer works that way.
Date: 3 Jun 2012 12:39:19
Message: <4fcb9337$1@news.povray.org>
On 6/3/2012 1:52, Orchid Win7 v1 wrote:
> You have to play with the registry to remove the uninstall entry from the
> menu though.
Nope. You can just ask to uninstall it, and add/remove will say "Oh, gee,
looks like it's already uninstalled."  But heck, if you're going around
deleting folders with funky names out of the windows boot directory, you
should be handy with the registry.
Yep.
    in the cabinet."
Date: 3 Jun 2012 15:10:26
Message: <4fcbb6a2@news.povray.org>
>> menu though.
> gee, looks like it's already uninstalled."
Last time I tried it, it crashed with some error message - but did offer
to remove the entry from Add/Remove Programs, since it couldn't actually
do the uninstall.
> around deleting folders with funky names out of the windows boot
> directory, you should be handy with the registry.
Seems reasonable.
