POV-Ray : Newsgroups : povray.off-topic : I'm in the mood for monads Server Time
4 Jul 2026 05:43:19 EDT (-0400)
  I'm in the mood for monads (Message 31 to 40 of 93)
Subject: Re: I'm in the mood for monads
Date: 22 Apr 2012 13:03:36
Message: <4f9439e8@news.povray.org>
> (You could achieve the same syntax by having multiplierFunction() return
> an object with an overridden () operator rather than a function, but of
> course that would be cheating.)
  That's kind of what the C++ lambda does internally: It puts the captured
variables in some kind of internal struct, which the function then operates
with (similarly to how a class member function operates with the object
using the 'this' pointer). You could achieve a similar behavior by writing
a class, but a lambda achieves this with significantly less effort.
  There is a significant difference to a class, though. In this example
std::function<int(int)> can manage *any* lambda function that takes an
int and returns an int, not just ones that have captured a 'multiplier'
variable and perform a "value * multiplier" on it.
  If you implemented the functionality of the example I wrote with a
class, you would be fixing the "lambda" function to be only and exactly
a multiplier function that has to be used with exactly your class and
nothing else. std::function<int(int)> has no such limitation. Any function
(be it a static function or a lambda) that takes an int and returns one
will do.
  This can make a difference especially with non-templated functions that
take a std::function as parameter. (One advantage of std::function over a
generic functor is that the former does not require for the code that uses
it to be templated and thus doesn't suffer form the few limitations that
templated code has.)
Subject: Re: Living in a box
Date: 22 Apr 2012 13:15:46
Message: <4f943cc2@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> >    You can create anonymous functions. The syntax is:
> >      [](int x) { return 2*x; }
> >    (Of course that alone won't do anything because you can't call it, as
> > it has no name. However, you can eg. create a variable that represents
> > the function, like: "auto func = [](int x) { return 2*x; };". If you need
> > to eg. return that function from another function, you'll have to use the
> > std::function wrapper. Likewise if you need to give one as parameter to
> > a non-templated or anonymous function.)
> Mmm, interesting.
> So how do you call such a function? Does it just override the usual
> function call notation?
  A variable that points to such an anonymous function works like any
function pointer, which means you can call it like a regular function.
Thus if you have, for example:
then you can simply call it like
    func(5);
  Templates taking a functor as parameter work the same way. You could
have something like:
    template<typename T, typename Comparator>
    bool compare(const T& value1, const T& value2,
                 const Comparator& comparatorFunction)
        return comparatorFunction(value1, value2);
  In the above example any comparator function will do (a comparator
function is something that behaves like a function taking two parameters
and returns a boolean). This can be a regular function, a functor (a class
that behaves like a function), a lambda, or an object of type std::function.
Thus you can call it eg. like:
    compare(1, 3, [](int v1, int v2) { return v1 < v2; })
Date: 22 Apr 2012 13:44:28
Message: <4f94437c$1@news.povray.org>
On 04/22/2012 09:06 AM, Stephen wrote:
> On 22/04/2012 1:38 PM, James Holsenback wrote:
>> On 04/21/2012 06:14 PM, Stephen wrote:
>>> I should have said that I am none the wiser. I still do not know what a
>>> monad is.
>> Oh that's easy ... it's just the singular form of gonad ... THUD ...
>> couldn't resist ;-)
> That calls for a kick in both monads. :-P
hmmmm ... nonads (well that's self explanatory) better yet faux-nads ...
someone who thinks that gotta pair. OK I'll stop now ;-)
Date: 22 Apr 2012 14:19:50
Message: <4f944bc6@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> One Haskell VFAQ is "What is a monad?"
http://byorgey.files.wordpress.com/2011/05/monad_tutorial.jpg
Date: 22 Apr 2012 14:32:30
Message: <4f944ebe@news.povray.org>
>> The question is, does
>>     multiplierFunction(3)(4)
>> or similar yield a 12?
>    Yes.
Right. So if you implemented all your stuff to take one argument at a
time like this [which would presumably be a little bit of work], IMHO
you could perfectly well call that "curried functions".
Date: 22 Apr 2012 14:34:24
Message: <4f944f30$1@news.povray.org>
Oh, so it can capture local variables too? That's even better than I
thought...
Date: 22 Apr 2012 14:36:23
Message: <4f944fa7$1@news.povray.org>
On 22/04/2012 05:34 PM, clipka wrote:
> Maybe that's what scrambles my mind whenever I read "Haskellists'"
> explanations of stuff: They're so proud that Haskell does it
> automatically for you, that they tend to deny the obvious parallels.
> So yes: Currying *is* like writing a function that takes fewer
> arguments, calling the original one and supplying (unchangeable)
> defaults for the missing arguments.
> And yes, apparently Haskell provides syntactic sugar for that. Wow. Big
> deal.
>> Finally, like I said, currying works backwards too: If a function call
>> happens to return a function as its result, you can just keep appending
>> arguments. "head function_list 7" and all that.
> Again, nice-to-have syntactic sugar, but nothing conceptually
> fascinating (as you noted yourself).
You seem to be missing the third point: Function currying allows you to
write code that polymorphically accepts functions with ANY number of
arguments.
That can be a Big Deal.
That said, yeah, of all the things that Haskell does, function currying
is one of the less exciting ones.
Date: 22 Apr 2012 14:37:59
Message: <4f945007$1@news.povray.org>
Download '960526421_mnnqb-o-1.jpg' (24 KB)
Preview of image '960526421_mnnqb-o-1.jpg'
Date: 22 Apr 2012 15:44:48
Message: <4f945fb0@news.povray.org>
I think, for everyone's sake, that you had better. ;-)
Regards
Date: 22 Apr 2012 15:52:02
Message: <4f946162$1@news.povray.org>
Christ knows what happens if I ever try to explain group
homomorphisms... o_O
