POV-Ray : Newsgroups : povray.off-topic : Teach yourself C++ in 21 days Server Time
26 Nov 2026 10:21:16 EST (-0500)
  Teach yourself C++ in 21 days (Message 69 to 118 of 168)
<<< Previous 50 Messages Goto Latest 50 Messages Next 50 Messages >>>
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 19 Apr 2012 18:13:31
Message: <4f908e0b@news.povray.org>
Orchid Win7 v1 escreveu:
>>>> so, all your programs are some monolithic piece of software with all
>>>> parts compiled in one go?
>>> Yes. Why?
>> because it's both wrong and dumb.
> That's right up there with saying that Haskell is better than C because
> C is both wrong and dumb. Yeah, it's true, but it won't convince anybody...
The time of monolithic pieces of software is long buried in the past.
Today it's all composable by hundreds of small libs, perhaps even loaded
at runtime.  Ever even heard of web mashups?  Application servers?
well, ok, for sufficiently small toy applications and scripts,
monolithic is good enough.
> How hard would it be to allow each directory to contain a file saying
> what commands each key should be bound to?
with a Makefile file in each directory each time you press make on the
command-line it makes that part. ;)
>>>> you're nuts. Any decent editor has support for several file buffers.
>>> Any decent GUI-mode text editor, yes. On the a text terminal, you
>>> can't do that.
>>> (Correction: Emacs can do it. And it looks awful.)
>> emacs, vi, pico etc...
>> it may look awful, but it behaves great. Ever heard "don't judge a book
>> by its cover"?
> The whole point of a text editor is for looking at text.
no, the whole point of a text *editor* is for *editing* text.
> Why make it
> look awful when you can make it look good? Why make your job harder when
> you can make it easier?
Nobody is making it look awful.  But between spending time making it
look good and do nothing and looking awful and doing a shitton of stuff,
you know what open-source developers will do...
plus, looking awful does not your job harder.  On the contrary:  in my
experience the most beautiful-looking text editors out there are usually
the most featureless and useless there are.  Why implement features that
will make it complex and awful-looking?  Better just have a simple
interface and when the user wants to copy the next 5 long paragraphs and
paste them 5 times they should do it manually by constant repetition of
the basic, beautiful and simple mechanisms, rather than just typing
y5}5p... clearly the latter is making your job far harder!
Subject: Re: Days 1-5
Date: 19 Apr 2012 20:57:11
Message: <4f90b467@news.povray.org>
On 4/17/2012 1:52, Invisible wrote:
> Except that assembly generally follows a simple and consistent syntax,
... says the man who never programmed in an assembly language for machines
designed to be programmed in assembly language.
> an "obscure feature" which you don't need to know about. :-P
It *is* outside the C standard, tho, in terms of what it "means".
> I dislike code that's so littered with comments that you can't see the code
Except in assembler.
> That's pretty messed up.
Why is it messed up? Ada even has a type for "one byte of memory" and a
different type for "one byte of I/O".  You might read 8-bit strings from an
I/O channel into 9-bit memory.
>> One warning: sizeof() will return the size in char, not bytes.
> Oh, that's fun. Let us hope that char *is* one byte, otherwise... damn!
Nah. There's a header file that tells you how many bits per byte. I'm pretty
sure C assumes binary computers, tho. :-)
> I guess this is why autoconf exists. :-P
That and amongst many, many, *many* other reasons. Note that C isn't a
portable language. It just lets you stick many versions of the source code
into one file.
>> Second warning: the signedness of char is local to the compiler.
> Really? The book seems to say that all integer types default to signed,
> unless you request unsigned. (AFAIK, there isn't a way to request signed.)
Except characters. Because PDP-11.
> So much for C and C++ being for system-level programming. :-P
It was never very *good* for it. It was just better than its competitors of
the time.
> microcontroller, I might be worried. On a desktop PC, I'm not too concerned.
Now, yeah. Note that IEEE standardized floating point *long* after C was
around. Heck, even after x86 was around IIRC.
>> Usually, float is a 32 bits, double is 64 bits. But it is known that
>> some compiler would perform the computation on 80 bits registers...
> Is there a way to explicitly request 80 bits?
No, of course not. C doesn't provide any way to ask for a type based on what
you need. You can only ask for types based on what the CPU provides, and
header files to tell you what the CPU provides so you can write code to try
to compile the right version. In Ada, in contrast, you'd say "give me the
float with X range and Y precision."
> Right. So if I request a 2GB array, it won't actually sit there trying to
> zero all 2GB of RAM, right before my for-loop rolls over it to initialise it
> /again/.
The OS probably will, tho, if you have a multi-user OS.
> So, it always rounds downwards?
It might depend on the sign. Two positive integers always rounds down.
> Oh that's sick. So comma really /is/ an operator? Wow, that's evil.
Why? It's just an operator. Is it really worse than Haskell's "." or ">=="
operators, or whatever they're called?
> I was referring more to the fact that it's legal to not specify the return
> type, and if you don't, it defaults to something absurd.
It defaults to integer. Not sure what makes that "absurd".
>>> Next, we learn that function arguments can have default values. But get
>>> this:
>>> "Any or all of the function's parameters can be assigned default
>>> values. The one restriction is this: If any of the parameters does not
>>> have a default value, no previous parameter may have a default value."
>>> ...um, what?
>> At one point in the argument list, you must start providing default
>> values, for all argument at the right of that point.
> ...which makes infinitely more sense than what the book said. :-P
Really!?  What the book said was clearly and simply a mathematical-type
statement. No parameter without defaults can be preceeded by one with
defaults. Hence all defaults must come after all non-defaults.
The previous statement is inaccurate in that it does not take into account
no-defaults and all-defaults.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Subject: Re: Days 5-
Date: 19 Apr 2012 21:07:29
Message: <4f90b6d1$1@news.povray.org>
On 4/17/2012 3:47, Invisible wrote:
> Now, I'm used to programming languages where the decision to inline
> something or not is down to the compiler. It's not something an application
> programmer would ever have to worry about. And it seems that the inline
> directive is only a "hint" in C++ anyway, so I have to wonder, whether this
> particular directive is now obsolete.
This explains it better.
http://yosefk.com/c++fqa/inline.html
> In other words, yet again, "now you know how this works, you don't need to
> actually use it".
Right. Except in very limited circumstances when you know how deeply you'll
recurse, because there's no guarantee it'll work and no way to check.
> I'm not sure what's so "unmanageable" about it all. Provided you don't try
> to reach behind the abstraction, there's no particular need to understand
> how it works.
As long as you never make a mistake, yes. If you pass the wrong type, the
wrong number, or do something with a bad pointer that makes you clobber the
stack, it's helpful to know how it works. ;-)
> "Registers are a special area of memory built right into the CPU."
> Erm...
What's questionable about that? Heck, on the Sigma 9, the registers 0 thru
15 were actually addressed as memory locations 0 thru 15, to the point where
you could store program code in the registers and branch to it.
> "They take care of internal housekeeping."
> ...actually...
Program Status Word.
> So I'm guessing an architecture exists where the instruction pointer /isn't/
> a single register then? :-P
Yep. Anything with memory mapping hardware, segment registers, etc.
> Still, it does answer something I've always wondered about: What *is* the C
> calling convention?
Undefined, generally speaking. Or rather, implementation-specific. And
depends on pragmas, sometimes.
    in the cabinet."
Date: 19 Apr 2012 21:14:05
Message: <4f90b85d$1@news.povray.org>
On 4/17/2012 7:17, Invisible wrote:
> would inlining it "bring its own performance costs"? I don't get that.
If you have several copies inlined different places, it may not be in CPU
cache (or might even be paged out). I.e., by inlining, if you make it
bigger, that's possibly a performance hit. Or not. Depends.
> OK, /that/ sounds rather more significant.
Not really.
> The book claims that if you write a function body inside a class definition,
> that makes the method inline. Is this true? I thought there was no
> difference either way...
It *has* to be. The reason it's inline if it's in a class definition is the
class definition gets compiled every time you #include it. Hence you're
going to have lots of copies of the same function compiled, which therefore
won't link, *unless* they're inline, because inline functions get merged by
the compiler, see.
*That* is why it's "significant".
> Even so, there might be 15^2 function calls, but only at most 15 of them
> will be /active/ simultaneously - which means only 15 stack frames at once. No?
Also, again, depends on your computer. I think we have 6 stack levels on the
credit card terminal available.
> Well, yes. As I understand it, by default C++ doesn't reserve a whole lot of
> stack space,
That's really nothing to do with C++ per se.
> I'm a curious soul. I think to have some idea how things work, even if I
> don't know all of the details... ;-)
It still depends on the compiler, the declaration, etc. "printf" isn't going
to pass any arguments in registers, most likely. abs() probably will. You
can declare (with pragmas, for example) different calling conventions for
different routines. (There is, for example, the Pascal calling convention,
which means the caller removes the arguments from the stack, because each
function in Pascal takes only a fixed number of arguments, so "remove them
from the stack" code logically can be in only one place.
    in the cabinet."
Date: 19 Apr 2012 21:16:14
Message: <4f90b8de$1@news.povray.org>
On 4/17/2012 8:06, Warp wrote:
> Invisible<voi### [at] devnull>  wrote:
>>>     Likewise template functions are implicitly 'inline' without having to
>>> explicitly say so.
>> Well, by definition a template generates a new copy of the function each
>> time you use it, no?
>    No. A new version is created for each used *type*.
Technically, I think a new copy of the function is generated/compiled for
each compilation unit that uses it for each type, but the different versions
for the same type are merged, right?
I.e., if x.c uses myfunc<int>() and y.c uses myfunc<int>() you'd need to
compile that function twice and toss one at link time, right?
    in the cabinet."
Date: 19 Apr 2012 21:26:36
Message: <4f90bb4c@news.povray.org>
On 4/17/2012 6:40, Warp wrote:
> and that sizeof(char) = 1 (which does not mean "1 byte", but "1 indexable
> memory unit".)
There are lots of RISC CPUs that only allow word-size transfers. But the C
compiler generates code to do a load, mask, manipulate, merge, and write.
>> The book casually mentions something which /seems/ to be claiming that
>> variables are not initialised to anything in particular unless you
>> specifically request this. That's interesting; I didn't know that.
>    C hackers don't want the extra clock cycle to initialize a variable
> which will be immediately assigned a new value anyways.
Because, of course, the compiler can't reliably figure out if you're using
it before you assign to it. ;-)
>    The former casts *anything* into a double, while the latter casts only
> compatible types. (Which means that the latter will give you a compiler
> error if you try to cast from an incompatible type by mistake.)
Because, as already explained, C++ is designed to make the compiler complain
about questionable things you might have done accidentally. Like using a
variable that you might not have assigned to. ;-)
>    If you define a variable (or function) in the global namespace, it will
> be visible in the entire program. (Yes, you can access it from a different
> compilation unit. You just need to declare it with "extern" in that other
> compilation unit to do that.)
I think you're mixing up scope and lifetime here. The variable is "visible"
in the scope sense only below where you declared it. You can declare it
anywhere and get to the same variable, sure. I'd call that "accessible" more
than "visible" maybe?
>    (Also, from a design point of view, global variables decrease abstraction,
> which is bad.)
Meh. My rule is that a global is OK (especially in languages with actual
namespaces) if you can define the meaning for the entire lifetime of the
variable. The problem with most globals is that they usually only have
meaningful values for a portion of the program's execution. But stdin being
global? Yeah, no problem with that.
    in the cabinet."
Date: 19 Apr 2012 21:33:07
Message: <4f90bcd3$1@news.povray.org>
On 4/17/2012 7:04, Invisible wrote:
>> The integral part of the value is assigned to the int.
> So... it always rounds towards zero?
As long as they're both positive.
> Aren't expressions guaranteed to execute left-to-right?
No. That's what the comma operator is for that you dislike so much. ;-)
> always struggle to remember whether zero means true or false. The solution,
You're aware that boolean math matches up with + and * right? So remember it
that way.
>  From what I'm seeing, just having multiple compilation units is a
> nightmare.
Multiple compilation units is only a nightmare when each can't refer to any
other compilation units. The problem isn't that there's multiple compilation
units, which pretty much every modern language above assembler supports. The
problem is that xyz.c can't refer to abc.c, so it needs to recompile abc.h
in order to know what's in abc.c, which of course can get out of sync
because they're separate compilation units.
If you could #include <abc.o> you'd get rid of all the silliness of
declaring inline functions multiple times, function prototypes, and all that
kind of BS.
    in the cabinet."
Date: 19 Apr 2012 21:36:36
Message: <4f90bda4$1@news.povray.org>
On 4/17/2012 3:16, Invisible wrote:
> It gives you warnings if code is unreachable.
It gives you warnings if it thinks the code is unreachable. It gives you an
error and won't let it compile if it can prove you have unreachable code.
{ int x = 0; return; x = 1; } // Gives an error.
{ int x = 0; if (true) return; x = 2; } // gives a warning.
> It even complains if you have a void function that uses return just to exit
> early, and there's nothing afterwards...)
I didn't run into that.
    in the cabinet."
Date: 19 Apr 2012 21:38:13
Message: <4f90be05@news.povray.org>
Le 2012/04/17 09:40, Warp a écrit :
>> is a perfectly valid statement in C++. On the other hand, it also means that
>>     while (x[i] = y[i--]) ;
>> is perfectly valid. You sick, sick people.
>    I think that's Undefined Behavior because the same variable is being
> modified and referenced more than once in the same expression.
Nothing undefined here.
It's a simple loop that compare the array x[] and y[] untill it find a
value that is different.
You get the value of x[i] and see if it's the same as the value of y[i]
then you decrement i by one.
On exit, i will point to the value preceding the first different value.
You must initiate i to the last valid index of your array.
If all elements of both arrays are the same, you can realy screw things,
so you beter make sure that the elements zero are different.
Date: 19 Apr 2012 21:39:34
Message: <4f90be56$1@news.povray.org>
>> For a start, F# is functional in the same way that C++ is
>> object-oriented. I.e., not very. F# is a normal OO language with a few
>> slightly functional ideas bolted on the side as an afterthought.
>    When will we see the Haskell# language?
I'm pretty sure the whole .NET bit is too OO to make that useful.There's way
too much stateful stuff (like I/O) that you'd want to use from .NET to make
it reasonable to have a purely function .net language.
    in the cabinet."
Date: 19 Apr 2012 21:41:32
Message: <4f90becc$1@news.povray.org>
On 4/17/2012 12:26, nemesis wrote:
> IDEs are only really useful for OO languages.
I'm pretty sure LISP machines had exceedlingly kick-ass IDEs long before
there was CLOS.
Plus, the IDE for Smalltalk doesn't really deal too much with the fact that
it's OO. It didn't do any of the sorts of completion you're talking about.
    in the cabinet."
Date: 19 Apr 2012 21:45:52
Message: <4f90bfd0@news.povray.org>
On 4/19/2012 10:14, nemesis wrote:
> yes. It's easy to rewrite Make from scratch for your every projects.
Maybe your projects. Mine compiles 1934 packages, and it's a pretty trivial
program by google standards. :-)
> BTW, do your scripts handle automatic compilation of only the parts that
> were last updated?
Even better. Mine doesn't even compile code that *you* compiled previously.
It also doesn't run unit tests for code that didn't change since last time
it was tested. It also tells the builders of the libraries I use if they
change code that breaks my code that depends on them.
It's pretty cool, but still a fair PITA sometimes.
>> (I wonder why nobody has yet thought of making an editor where you can add
>> buttons to the toolbar and kind arbitrary commands to them? You could even
>> give them keyboard shortcuts...)
> emacs can do that. And any decent text editor allows you to bind some
> keyboard shortcut to some command.
Yah. We call it an IDE. ;-)
    in the cabinet."
Date: 19 Apr 2012 21:47:26
Message: <4f90c02e$1@news.povray.org>
On 4/19/2012 12:32, nemesis wrote:
> so, all your programs are some monolithic piece of software with all parts
> compiled in one go?
Mine are. But then, they get deployed to google's production machines, where
you really would like them to run stably even if someone else changes their
code. :-)
    in the cabinet."
Date: 19 Apr 2012 21:50:17
Message: <4f90c0d9$1@news.povray.org>
On 4/17/2012 12:51, Warp wrote:
>      // Execution will *never* reach here
>      // It's valid to omit a 'return'
But the compiler can prove that statically, so I'm not sure the problem.
I'm also not sure what the problem is with preventing use of uninitialized
values without requiring the compiler to initialize them.
    in the cabinet."
Date: 19 Apr 2012 21:53:06
Message: <4f90c182@news.povray.org>
On 4/18/2012 4:13, Warp wrote:>    But the C++ compiler cannot break the
standard by making the situation
> an error. It can only issue a warning.
You mean, the C++ compiler cannot break the C standard by making this
illegal. Even tho it makes other valid C programs illegal. :-)
>    (And besides, any kind of detection of this cannot be 100% accurate,
> as the problem "will this line of code ever be reached?" is unsolvable
> in the general case.)
But detecting type errors isn't 100% accurate either.
   int x = 1 ? 5 : "hello";
That's not legal, but it's not a type violation either.
    in the cabinet."
Date: 19 Apr 2012 21:56:30
Message: <4f90c24e$1@news.povray.org>
ns that
Does it compare x[i] to y[i] or to y[i-1]?  Why do you answer that way?
    in the cabinet."
Date: 20 Apr 2012 03:15:39
Message: <4f910d1b$1@news.povray.org>
>>>> having to
>>>> explicitly say so.
> for each compilation unit that uses it for each type, but the different
> versions for the same type are merged, right?
IIRC, If the call to myfunc<int>() is done in the same compilation unit
(same top level cpp file), it will be generated once as "static
function" (jump to local symbol, at best; that does not work if it
become inlined code of course).
If they are in separate compilation units (different top level *.cpp
files), each units will get its own version.
Linker will not remove either. (because it has no way to know if the one
in unit A is identical to the one in unit B: naming is no use, you might
have compiled unit A with the version of Monday, and unit B with the
version of Saturday.
(that's the issue with template: generated code can grow very fast if
you use the template in many *.cpp files)
Date: 20 Apr 2012 03:20:50
Message: <4f910e52$1@news.povray.org>
>>>> means that
You missed the point: let's name k the initial value of i;
Would you expect the test to be between:
 x[k] & y[k]
 x[k-1] & y[k]
It cannot be x[k] & y[k-1], per the definition of the post-decrement
operator.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Date: 20 Apr 2012 03:44:36
Message: <4f9113e4$1@news.povray.org>
I'm presuming that's why it's implicitly inline - to allow the merging.
Date: 20 Apr 2012 03:51:36
Message: <4f911588$1@news.povray.org>
Does it round towards zero, or towards negative infinity?
Oh good. The book /insists/ that left-to-right order is guaranteed. Nice
to know that in addition to being poorly explained, it's also factually
inaccurate. :-P
>> solution,
> remember it that way.
A better way might be to think of true and false as 1 and 0. (Although
of course C allows true to be /anything/ that isn't 0, not just 1.)
>> nightmare.
> any other compilation units.
I'm currently trying to work out how I can compile a program where
module 1 refers to module 2, but module 2 also refers to module 1. As
far as I can figure out, this is impossible...
Date: 20 Apr 2012 03:55:20
Message: <4f911668@news.povray.org>
Last time I checked, the /comparison/ operator is ==.
The = operator performs *assignment*. :-P
(Assuming that neither x[] nor y[] contains any zero bytes, presumably
this is also an infinite loop...)
Date: 20 Apr 2012 03:57:11
Message: <4f9116d7@news.povray.org>
> way too much stateful stuff (like I/O) that you'd want to use from .NET
> to make it reasonable to have a purely function .net language.
Haskell already supports a wide range of I/O operations. That's pretty
stateful, and it's not a problem.
Yeah, if you wanted to talk to the .NET libraries, it would all end up
being monadic. (Even the .NET stuff that's actually pure - since it
isn't /marked/ as pure.) But it would still work fine.
I think it's probably vacuous to try to estimate how "useful" it would
be without actually trying it...
Date: 20 Apr 2012 04:00:53
Message: <4f9117b5$1@news.povray.org>
Well, unfortunately Haskell does not yet support dynamic linking very
well. (At least it now has /some/ support for it...)
Yeah, that could work.
Well, if that's your attitude, then surely ed is good enough for you?
>> Why make it look awful when you can make it look good? Why make your
>> job harder when you can make it easier?
> Nobody is making it look awful. But between spending time making it look
> good and do nothing and looking awful and doing a shitton of stuff, you
I can't even tell what the hell you're saying now. :-P
Date: 20 Apr 2012 04:07:42
Message: <4f91194e$1@news.povray.org>
The general problem of determining whether every possible code path is
well-typed is undecidable. Type systems insert artificial restrictions
to /make/ the problem decidable. Hence, there are expressions and
statements which are well-typed, but do not type-check.
Date: 20 Apr 2012 04:08:49
Message: <4f911991@news.povray.org>
>> exit early, and there's nothing afterwards...)
By "complains" I mean it gives you a warning. It still compiles OK.
Date: 20 Apr 2012 04:28:18
Message: <4f911e22@news.povray.org>
> machines designed to be programmed in assembly language.
So what /was/ the Motorola 68000 designed to be programmed in then?
Sure. But in terms of writing practical code that runs on common
hardware under common operating systems - which is the target of this
book - it's not exactly "obscure". It's not like this is a book about
how to program microcontrollers. (That would be something else entirely...)
>> code
I found another one:
http://tinyurl.com/32vda9
>> signed.)
It worries me that we're still using a language who's fundamental design
decisions are based on hardware first produced in the 1970s.
But it worries me more that they only stopped manufacturing the PDP-11
in the 1990s. o_O
> of the time.
Jesus, did it even *have* any competitors?!
> what you need. You can only ask for types based on what the CPU
> provides
OK, well IA-32 provides 80-bit floats. So... is there a standard way to
get them?
>> initialise it
>> /again/.
Not much I can do about that. ;-) But yeah, it does make the whole
design decision seems a be out-dated. (Then again, calling the default
constructor for each array element might do a lot more work than just
zeroing some bytes. Presumably the way the OS zeros memory is quite
efficient.)
> ">==" operators, or whatever they're called?
You'd expect part of the language's basic syntax to be, you know... part
of the language's basic syntax. But it isn't. It's just a regular
operator, which means you can use it in places where you shouldn't be
putting random commas, and that makes it do strange stuff. (And, being
C, this isn't checked in any way.)
>> return
The /logical/ thing is for a function that doesn't mention a return type
to default to returning nothing. And yet, it doesn't. It arbitrarily
defaults to int. Not bool, not void*, not w_char, but int. No reason, it
just does.
> account no-defaults and all-defaults.
I forget who said it: comprehension = 2 ^ -precision.
Date: 20 Apr 2012 04:38:14
Message: <4f912076@news.povray.org>
>> need to actually use it".
> you'll recurse, because there's no guarantee it'll work and no way to
> check.
...what?
>> Erm...
> thru 15 were actually addressed as memory locations 0 thru 15, to the
> point where you could store program code in the registers and branch to it.
Nobody designs hardware like that any more. Haven't done for decades. :-P
>> ...actually...
The /registers/ do not take care of anything. The /processor/ does.
>> /isn't/ a single register then? :-P
None of which are relevant in the current day and age, unless you're
writing an OS. Certainly this technicality has no place in an
introductory programming text.
>> the C calling convention?
So you're telling me that the de facto calling convention that all
software always uses is "undefined"?
Date: 20 Apr 2012 07:57:54
Message: <4f914f42@news.povray.org>
  Yes. (Except if the function is inlined by the compiler, in which case
there's no need.)
Date: 20 Apr 2012 08:01:35
Message: <4f91501f@news.povray.org>
  No, they will be merged by the linker (although I'm not completely sure
now if the standard requires it; at the very least it requires for all
static variables inside the function to be merged, IIRC).
  If the context of the template instantiation affects its behavior, then
instantiating it under differing contexts is actually undefined behavior.
(In practice what will usually happen is that only one of them will end up
in the final binary and all the code will call that one; the other contexts
will have no effect on it.)
  Object files might grow, but not the final binary.
Date: 20 Apr 2012 08:11:12
Message: <4f915260@news.povray.org>
> It *has* to be.
  It doesn't *have* to be (any more than any other function defined in a
header file, or anywhere else), but the standard says it is, and so it is.
  The difference can be seen eg. like this:
//-------- Example 1 ----------
class A
 public:
    // This function is implicitly 'inline',
    // no need to specify the keyword:
    void foo() { std::cout << "Hello\n"; }
//-------- Example 2 ----------
class A
 public:
    void foo();
// This function is *not* implicitly 'inline' and will cause linker
// errors unless the keyword is used:
void A::foo() { std::cout << "Hello\n"; }
Date: 20 Apr 2012 08:18:50
Message: <4f91542a@news.povray.org>
> kind of BS.
  So you would be simply changing the dependency to a .h file to dependency
to a .o file. What would be the relevant difference?
  Also, I assume you understand that templated code cannot be precompiled
into an object file? They need to be recompiled each time they are used...
which is kind of the whole idea.
Date: 20 Apr 2012 08:22:01
Message: <4f9154e9@news.povray.org>
  The only thing that's impossible for a class to have another class
as member variable, and that another class having the first class as
member variable. (For obvious reasons. It would be an infinitely large
class.)
  Other than that, any kind of cross-referencing should be possible.
Date: 20 Apr 2012 08:29:48
Message: <4f9156bc@news.povray.org>
  The compiler is free to decrement 'i' before it evaluates 'x[i]' or
after it. Hence you might get 'x[i]' as it was before the decrement, or
after. (The only thing that is guaranteed is that 'y[i]' is evaluated
before 'i' is decremented.) That's why it's undefined behavior.
Subject: Re: Day 6
Date: 20 Apr 2012 08:36:59
Message: <4f91586b@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> On the other hand, it appears to be aimed at people who already know the
> C++ language. That isn't really me, yet. I know some of the syntax, but
> certainly not all of it, or what all of it actually does.
  I think you'll learn on the fly (at least if you have the right
attitude).
Date: 20 Apr 2012 09:02:12
Message: <4f915e54$1@news.povray.org>
> member variable.
Yeah, that's exactly what I'm trying to do.
Actually, no, wait... Class X has class Y as a member, but class Y only
/mentions/ class X. (It has member functions that return objects of
class X.)
> (For obvious reasons. It would be an infinitely large class.)
It can if at least one of the classes refers to the other through a
pointer or a reference. (Think about it: A binary tree class has no
problem containing /itself/ as a member variable or two.)
So, the way I see it, I have two options:
1. Put class X and class Y in the same header file.
2. Start throwing unchecked casts around the place.
Subject: Re: Day 6
Date: 20 Apr 2012 09:03:43
Message: <4f915eaf$1@news.povray.org>
> attitude).
Given that I already some some clue about C++, that might actually work...
Date: 20 Apr 2012 10:15:30
Message: <4f916f82@news.povray.org>
> > member variable.
  I don't think so.
> class X.)
  Sounds like a rather complicated design. Anyways, you can declare classes
(as opposed to defining them). In other words, you can do this:
// This could be eg. in a "Y.hh" header file
class X; // declaration of X
class Y
 public:
    void foo() { std::cout << "I'm an Y\n"; }
    X gimmeAnX();
  You can then define X for example like:
// This could be eg. in a "X.hh" header file,
// in which case you would have a
// #include "Y.hh" here.
class X
    Y anObjectOfY;
 public:
    void bar() { anObjectOfY.foo(); }
  After both definitions you can now implement the Y::gimmeAnX() function,
eg. like:
// This could be eg. in a "Y.cc" source file,
// #include "X.hh" here.
X Y::gimmeAnX() { return X(); }
  (All of the above code could be in one single source file as well,
in that order, which is why I didn't explicitly use any #include lines.)
  It wouldn't be a member variable then.
  Not necessary (and even if you put it in the same header file, that alone
wouldn't solve your problem).
  The correct solution is to use class declarations.
Date: 20 Apr 2012 10:19:53
Message: <4f917089$1@news.povray.org>
Ah, I see. This is the fact I was looking for. :-)
So this does... what? Tells the compiler "hey, this type exists, but I'm
not going to tell you anything about it"?
What would it be then?
Quite right. That doesn't help at all...
Date: 20 Apr 2012 10:29:32
Message: <4f9172cc@news.povray.org>
  It tells that there's a class named X.
  From that point forward you can do anything with that type that does not
require calling its member functions or accessing its contents. (In other
words, you can handle pointers and references of that type.) You can also
make further declarations using it (such as declaring it as the return
type of a function).
  Doing anything else with an object of that type requires a full class
definition, but that can be done later in the code.
  This allows inter-dependency between classes.
  A pointer/reference to an object of that type.
  What I mean is that you can't do this:
class A { B b; };
class B { A a; };
  That would be a pair of infinitely large classes.
Date: 20 Apr 2012 10:34:22
Message: <4f9173ee@news.povray.org>
  (Oh, and of course anything requiring knowing the size of X doesn't work
with the declaration only, of course. For instance, "sizeof(X)" obviously
doesn't work without the full class definition.)
Date: 20 Apr 2012 10:36:54
Message: <4f917486@news.povray.org>
Le 2012-04-19 09:21, Invisible a écrit :
>>>> in any case, even humble C can do that, provided a Makefile is ready.
>>>> heck, Makefiles are language-agnostic even...
>>> Makefiles only work on Unix. :-P But hey, you can write a simple script
>>> to build your project under Windows.
>> WAT?
> To tell you the truth, I don't even /like/ Make all that much. (I think
> it's the tab characters. Or the slightly clunky way it deals with
> targets that aren't files.) I only really use it for building C, because
> it's either that or work out how to invoke the compiler manually...
> But as I say, a tiny amount of shell scripting will automate most tasks,
> without the need for Make.
If you like reinventing the wheel... ;)
>>> The /real/ problem, of course, is that you have to open a command
>>> window, CD to the right folder, and type in "make program1" or whatever.
>>> This takes significantly longer than pressing F7 (or whatever).
>> Which you only have to do once... After that you only need to hit
>> ALT-TAB and the up arrow.
> That works great - /until/ your command history has more than one
> command in it. E.g., if you use the same window to run the compiler, run
> the main program, and control your SCM. Then you end up jabbing up-arrow
> endlessly, or executing the wrong command, or both. Very annoying.
You know you can open more than one command promt.
> add buttons to the toolbar and kind arbitrary commands to them? You
> could even give them keyboard shortcuts...)
Dare I say it?  Oh... sure... why not...
Emacs does it.  ;)
Notepad++ too.
>> Starting notepad++ and a command prompt take significantly less time
>> than starting any IDE.
> Depends on the IDE. Some are slower than others. I do take your point
> though - some of them do take an absurd amount of time to start. Then
> again, "you only do that once". :-P
>>> Sure, once you take your hands off the keyboard and onto the mouse to
>>> switch from the text editor window to the command prompt window. :-P
>> As mentioned previously, ALT-TAB. Much faster.
> And if in the middle of your coding session, you quickly switch to your
> email client to check something, next time you try to use Alt+Tab, it
> takes you to the wrong window.
Keep you thumb on ALT, and hit TAB repeatedly until you get to the right
application.
> It sounds trivial, but it's really very, very annoying.
> (It becomes even more fun when what you're working on involves more
> windows. E.g., right now I'm writing some TeX, so I have my text editor
> open, my command window open, and my DVI window open. You can 100%
> guarantee that almost every time I change window I change to the wrong
> one...)
I usually have my e-mail client, corporate instant messenger app (
usually with a few chat windows opened), 3 or four browser windows, a
couple Excel sheets, two VPN apps (don't ask!) and a couple other
network monitoring apps loaded at any one time.  Mastering the ALT-TAB
combo is much, much, much, faster than using the mouse to switch apps
from the task bar.  Not to mention a lot cheaper than a dozen
occupational therapy sessions due to tendinitis or carpal tunnel syndrome.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 20 Apr 2012 10:41:47
Message: <4f9175ab$1@news.povray.org>
Right. So I can declare functions that take it or return it, and I can
declare (but not define) variables of that type. And then I can #include
the full description before I try implementing anything that actually
needs to touch it "for real". (?)
> class A { B b; };
> class B { A a; };
Yes, clearly that can't work.
Date: 20 Apr 2012 10:47:30
Message: <4f917702$1@news.povray.org>
Not so much "reinventing the wheel". More like "I don't actually need
the full power of Make".
...which just changes the problem from "hitting the up arrow the right
number of times" to "hitting Alt+Tab the right number of times".
> Emacs does it. ;)
Yeah, but... WHY WOULD YOU DO THAT? >_<
> application.
I know that. It's still more fiddly and error-prone than just jabbing a
button that always does the same thing, regardless of which application
window you used most recently.
>> windows.
> from the task bar.
It depends how far back in the stack you need to cycle. At some point,
the mouse becomes faster.
Nobody gets tendinitis just from using a mouse.
You /might/ get tendinitis from working on a production line, executing
the exact same pick up, solder, put down movements eight times per
minute for hours on end without stopping for so much as twenty seconds
for a break. (Yes, I've tried it.) You don't get it just from operating
a computer normally. Not if you have sane desk height, etc.
Date: 20 Apr 2012 11:16:53
Message: <4f917de4@news.povray.org>
  Btw, a class that has only been declared but not defined (in other words,
you have only said "class X;") is called an "incomplete type" in C++
parlance.
  You can have pointers and references to an incomplete type, and you can
use it wherever a type is required (without any actual object), such as in
function declarations. In other words, you can do eg. like this:
class MyClass;
// Function that takes an object of type MyClass as parameter and
// returns another object of that type:
MyClass aFunction(MyClass object);
  (Of course if you try to *call* that function without a full class
definition, you'll get a compiler error.)
  You could also declare an extern variable of that type (although that's
a quite rare circumstance, but it's still possible). In other words:
class MyClass;
extern MyClass aGlobalObject;
  One situation where you ought to not be able to do it, but you can, due
to a quirk in the language, is deleting an object using an incomplete
type. In other words, this will compile, albeit usually with a warning:
class MyClass;
void foo(MyClass* objPtr)
    delete objPtr; // Never do this!
  The major, major problem with that is that, while the memory taken by
that object will be freed, the destructor of the object will *not* be
called. Bad things will happen. (There was some reasoning why it's
nevertheless allowed by the standard, but I don't remember now what it
was.)
  This, however, will work ok:
class MyClass
// An extern function that allocates an object of type MyClass and
// returns it:
std::shared_ptr<MyClass> gimmeAnObjectOfTypeMyClass();
void foo()
    std::shared_ptr<MyClass> ptr = gimmeAnObjectOfTypeMyClass();
    // When foo() is exited, the allocated object will be destroyed
    // properly. In other words, its destructor will be called ok.
  The implementation of gimmeAnObjectOfTypeMyClass() (in a completely
different source file) can simply be:
#include "FullDefinitionOfMyClass.hh"
    return new MyClass(); // Constructs and returns an object of MyClass
  In the code above where the returned object is destroyed, at no point do we
have a full definition of 'MyClass'. Nevertheless, when the std::shared_ptr
that's managing it goes out of scope, it will delete it and its destructor
will be called. It achieves this through template magic.
  (Nevertheless, you seldom need to resort to this kind of trickery in
practical code. At least not this explicitly. Don't take this as an
example of what kind of code people usually write in C++.)
Date: 20 Apr 2012 11:25:44
Message: <4f917ff8$1@news.povray.org>
> parlance.
Right.
> class MyClass;
How about if you try to write the function body without the full class?
I'm presuming that will fail too, since the compiler needs to know how
much space to allocate...
Right. But presumably you can't actually /create/ the variable, because
you don't know it's size. (?)
> class MyClass;
> was.)
Oooohhhhh that's evil.
Sure. When the template expands, we /do/ have the full class spec, so it
works. (At least, I'm presuming that's what happens.)
Oh hell yes - I don't intend on trying this... ever, actually.
Date: 20 Apr 2012 12:06:00
Message: <4f918968@news.povray.org>
  The std::shared_ptr object in that example doesn't see the complete
definition of the class at any moment, because it hasn't been defined.
It gets initialized with another instance of std::shared_ptr (which was
created in that function somewhere else), but it itself doesn't see the
full definition of the class it's managing.
  To recapitulate:
class MyClass; // incomplete type
// A function somewhere else that returns a std::shared_ptr object:
std::shared_ptr<MyClass> foo();
void bar()
    std::shared_ptr<MyClass> ptr;
    // *this* shared_ptr object does not see a MyClass definition
    // at any point
    ptr = foo();
    // The shared_ptr returned by foo() is assigned to it.
    // Now when bar() ends, 'ptr' will destroy the object.
    // And properly at that. The destructor will be called ok.
    // Yet 'ptr' never sees the full definition of 'MyClass'.
  Even though 'ptr' above at no point sees the full definition of
'MyClass', it just works. It does so by employing template magic.
Date: 20 Apr 2012 13:02:44
Message: <4f9196b4$1@news.povray.org>
> that it's OO. It didn't do any of the sorts of completion you're talking
> about.
Well, to be fair, since Smalltalk isn't statically typed, you'd be
hard-pressed to figure out what messages are applicable to a given
variable. ;-)
Date: 20 Apr 2012 23:39:43
Message: <4f922bff$1@news.povray.org>
I would guess C or Algol or some such. There's a separation between address
and data registers, there's a stack pointer, there are various addressing
modes that (IIRC) include auto-increment, etc.
The 8086 was designed to be efficient for Pascal, for example. But not too
efficient, given that it doesn't have proper frame pointers.
>>> code
At least on machines designed to be programmed in assembler, one can
generally put a useful and informative comment on pretty much every line.
Yep.
>> of the time.
Assembly. ;-)  Probably LISP.  COBOL to a large extent.
>> provides
> OK, well IA-32 provides 80-bit floats. So... is there a standard way to get
> them?
AFAIK, you have float and double. Maybe there's now a long double, but I
don't recall.
> You'd expect part of the language's basic syntax to be, you know... part of
> the language's basic syntax. But it isn't. It's just a regular operator,
> which means you can use it in places where you shouldn't be putting random
> commas, and that makes it do strange stuff. (And, being C, this isn't
Why would you put randomg *anything* in? This isn't a sonnet. It's computer
code.  Why would you put random commas in any more than you put random quote
marks in?
> The /logical/ thing is for a function that doesn't mention a return type to
> default to returning nothing. And yet, it doesn't. It arbitrarily defaults
> to int. Not bool, not void*, not w_char, but int. No reason, it just does.
Remember the compilation model.  Plus, "void" is a relatively recent
development.
You just have to think mathely.
    in the cabinet."
Date: 20 Apr 2012 23:43:18
Message: <4f922cd6$1@news.povray.org>
I don't think mis-matched declarations were ever something that C worried
about. Does C++ actually check that sort of thing now?
I know that with Ada, you can't link incompatible object code, in the sense
that if you have (the equivalent of) A.h and A.c and B.c, and B.c uses A.h,
then both A.c and B.c have to get compiled after A.h gets compiled. If you
go change A.h after you've already compiled A.c, you can no longer link
against the old binary. The compiler winds up doing stuff like putting the
hashes of every header file (equivalent) into each object code generated,
and then checking they all match up at link time.
    in the cabinet."
Date: 20 Apr 2012 23:45:55
Message: <4f922d73$1@news.povray.org>
>> It *has* to be.
I meant, it *has* to be or it will link but won't compile, because you wind
up compiling a version of the header file in each .c file it's included in.
Sure, it doesn't *have* to be implicitly inline, but since every function in
a header file is either inline, or shouldn't be in the header file in the
first place, or fails to link, it made sense to make the default "yes,
please work."
    in the cabinet."
