POV-Ray : Newsgroups : povray.off-topic : Teach yourself C++ in 21 days Server Time
4 Jul 2026 11:31:12 EDT (-0400)
  Teach yourself C++ in 21 days (Message 159 to 168 of 168)
Subject: Re: Days 5-
Date: 28 Apr 2012 04:33:05
Message: <4f9bab41@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> That said, I've found I rarely need it
  It's not usual to need it, but sometimes it can be quite useful.
Almost anything involving things like permutations and combinations
are significantly easier to express recursively than iteratively.
> If you can handle the program crashing when you
> give it too much data in a way that generates bogus results, then sure, feel
> free. :-)
  As I said, if the recursion depth is O(log n), then you *can't* give it
so much data as for the stack space to run out. It's physically impossible.
  If your recursion level is O(n), then it sounds a lot like an iterative
algorithm that has been expressed recursively for no good reason. (Of
course exceptions probably exist, but are rare.)
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 28 Apr 2012 05:56:16
Message: <4f9bbec0$1@news.povray.org>
>> OK. And I was just saying that Haskell /already/ lets you use libraries
>> written in C, which aren't functional at all.
> And can the C call back into the Haskell?
Yes. I demonstrated using the C sort() function to sort Haskell data,
remember?
> And if so, are all the Haskell invariants and such maintained?
You have to tell the compiler whether or not you consider the C function
to be "pure" or not. Obviously, you can lie. Don't do that.
> And can you do that without telling the
> caller whether they're calling C or compiled Haskell?
Does sort() know what it's calling?
>> What I /meant/ to write was that you start a transaction, fetch the next
>> work item, and then end the transaction. Once the transaction is over,
>> you can do as much I/O as you like.
> Right. But if "fetch the transaction" means "obtain it from the server
> over there using TCP/IP", then you're kind of screwed, aren't you?
Yeah. STM only works for stuff local to one machine.
Or rather, the implementations I've seen only work local to one machine.
It's quite plausible you could extend it so that the transactional data
you're mutating might be remote - but them it would be the STM engine
sending network traffic, not you.
> Heck, even a regular expression match isn't functional in .NET.
Probably. In fact, I doubt much of the .NET libraries are. So you would
probably end up using existing Haskell libraries for anything except
actual I/O - the thing that .NET is good at.
>> The problem (I assume) that you're talking about is that all the existing
>> .NET stuff is structured under the assumption that you can do I/O
>> whenever
>> you feel like it. I can see a few ways to approach that. (Perhaps the
>> simplest possibility being "only Haskell is allows to use STM". :-P )
> And that's the kind of incompatibility I'm saying makes .NET much less
> useful.
Certainly it makes it less useful, yes. Whether it makes it "not worth
it at all" is more open to debate.
Date: 28 Apr 2012 12:39:29
Message: <4f9c1d41$1@news.povray.org>
Fair enough. That said, you can usually tell by looking at the input
structure how deeply you'll likely need to recurse for something like that.
>> free. :-)
Oh? How deep is your stack? Are you sure your on-the-heap data structure
hasn't used up all your potential stack space?
The point is not that if the algorithm is all you're doing, you won't run
out of stack space. The point is that you don't know how much stack depth
you have, what's on the stack above you, or how big your data structure is,
even assuming you're recursing due to a data structure.
Or how much stack space the thing you're calling during the recursion takes,
if your recursion is part of a more generic data structure. If you say
"process each node of the DOM with this lambda", you don't know what that
lambda is going to do.
Why does C++ limit the depth of template instantiation required to 17
levels, or whatever it is? Clearly, it's possible to run out of stack doing
recursion.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 28 Apr 2012 12:43:47
Message: <4f9c1e43$1@news.povray.org>
On 4/28/2012 2:56, Orchid Win7 v1 wrote:
> You have to tell the compiler whether or not you consider the C function to
Fair enough.
I don't know. That's why I'm asking. :-)
> probably end up using existing Haskell libraries for anything except actual
I think .NET is good at more than just I/O. :-) Actually, I don't think .NET
is any better at I/O that anything else on Windows is.
>> useful.
> Certainly it makes it less useful, yes. Whether it makes it "not worth it at
It breaks a fundamental tenet of .NET, which is that it doesn't matter what
language the caller is written in vs the callee. MS saying that "yes, this
.NET library works, but only if you call it from Haskell and not C# or VB or
F#" would not fly well.
    in the cabinet."
Date: 28 Apr 2012 12:52:23
Message: <4f9c2047@news.povray.org>
  As I said, if your recursion depth is O(log n), then you would need a
ridiculous amount of data in order to run out of stack space even with
a very stack-hungry recursive function. (For example, if your recursion
level were 50, then the input data, even if it took just 1 byte per element,
would require something like 1024 terabytes of RAM. How likely are you going
to run out of stack space with that few recursion levels? You could easily
have that many function calls on the stack even without recursion.)
  It's highly unusual to require enormous amounts of stack on one single
function call, especially if you are implementing a recursive algorithm.
If each function call takes exponentially more stack space than there's
input, you are doing something wrong. (And even if you did, your algorithm
would be quite slow, as each function call would be operating on a rather
large amount of local data.)
  Never heard of such a limit.
Date: 28 Apr 2012 12:57:43
Message: <4f9c2187$1@news.povray.org>
On 4/28/2012 9:52, Warp wrote:
> level were 50,
I understand your argument. I'm unconvinced that you're (a) not already 40
levels of stack deep when you get invoked, and (b) know what your stack
recursion depth can be.
Maybe I'm just used to working on machines with actual limited address space
and RAM. 50 levels of recursion sounds like a lot of stack space used, to me.
function call,
I would think that depends on the program. If you're making an image of your
input data for each level, you're screwed, which is why people tend not to
do that sort of thing. If (maybe) you're parsing a programming language, I
can see each level having a fairly large amount of data associated with it.
That's my point! :-)
IIRC, template function nesting is only required to be supported to some
realtively small depth.
    in the cabinet."
Date: 28 Apr 2012 13:14:11
Message: <4f9c2563@news.povray.org>
> > level were 50,
  My point is that you are not going to get even close to 50. Perhaps
something like 20.
  If your stack can't hold hundreds of recursive function calls, then
you should upgrade your computer to the new millenium.
  What? Even if each function call took like a kilobyte of space (which is
quite a lot for one single function call), it would still be just 50 kB.
I think stack sizes are counted in megabytes in modern systems.
> function call,
doing it wrong. (If for nothing else, then because it increases the
computational complexity of your algorithm by a factor of n, which is quite
a lot. Eg. a fast O(n log n) algorithm becomes a crawling O(n^2 log n).
Not to talk about if the original algorithm was eg. O(n^2) to begin with...)
  I suppose the standard probably as a minimum recommended amount (like
it has for many other things, like the length of variable names). However,
if you surpass that limit your program won't even compile, so it's not
a question of running out of memory when running the program. (And most
C++ compilers have an option to increase the space dedicated to type
names.)
  Consider that some projects use template metaprogramming quite
extensively, and the internal type names that result from it can be
quite large (we are talking about thousands and thousands of characters).
Most C++ programs don't use type names that long.
Date: 28 Apr 2012 13:38:55
Message: <4f9c2b2f$1@news.povray.org>
Well, that's what I said. If I have a machine with enough power to support
that sort of thing, I'm probably not going to be using C. :-)
PS: Pro-tip. I work for google. Don't try to spider the web recursively. ;-)
As the machines get bigger, so do the problems people throw at them.
But you have a database with a B-Tree index? Sure, chances are you're not
going to blow the stack walking down that tree.
I'm not saying recursion isn't useful. I'm saying that one must keep in mind
the possible depth of recursion, because C doesn't tell you when you overrun
the stack. You just get the same random errors you get when you run off the
end of an array, except you haven't actually violated the spec, as far as I
know.
Depends on the system. Credit card terminal? No. Last card terminal I worked
on had 14K of space free for code and data and stack. :-)
In any case, would you call malloc() inside each level of recursion as you
go without checking whether malloc() returned NULL? I wouldn't think so. So
if malloc() can fail and you want to check, why not recursion? Why not just
use the returned value from malloc() and let it crash out when you try to
write to offset 0?
> doing it wrong.
Yep. As I said, that's why people don't do it that way.
Note, however, that we're also comparing to things like Haskell, where the
"naive recursive algorithm" *is* the iterative algorithm.
> names.)
Yep. All to get around problems with naive recursive algorithms.
In any case, that's the sort of thing I'm talking about. If you add a level
of template indirection and your compiler crashes, that's one thing. If you
add another web page to the list of web sites you're selling ads on and your
revenue stream collapses, that's another thing.
Hope that you don't wind up adding another level to your templates and your
compiler finishes but generates the incorrect code.
    in the cabinet."
Date: 30 Apr 2012 05:03:13
Message: <4f9e5551$1@news.povray.org>
> .NET is any better at I/O that anything else on Windows is.
Well, I haven't ever used .NET, so I couldn't say.
>>> useful.
>> it at
> what language the caller is written in vs the callee. MS saying that
> "yes, this .NET library works, but only if you call it from Haskell and
> not C# or VB or F#" would not fly well.
Well, another possibility would be "you can use this library, but it's
up to you to not do any I/O within transactions. If you do, anything
could happen, and it will be Your Fault."
Subject: Frege
Date: 9 May 2012 06:33:20
Message: <4faa47f0$1@news.povray.org>
>> When will we see the Haskell# language?
> I'm pretty sure the whole .NET bit is too OO to make that useful.There's
> way too much stateful stuff (like I/O) that you'd want to use from .NET
> to make it reasonable to have a purely function .net language.
I've been thinking for years that it would be cool to write a Haskell to
Java compiler.
Yesterday night, I discovered that somebody has actually done this.
Specifically, there is a compiler which translates a language called
"Frege" into Java. Frege is basically the same as Haskell, with a few
tiny syntax changes. The compiler takes your Frege source code and turns
it into Java source code, which the standard Java compiler then compiles
as normal.
At the moment, it's all quite experimental. There's basically one person
maintaining it, and it's still brand new. Documentation is nearly
non-existent. The compiler is fairly slow, and error reporting leaves a
lot to be desired. But it /works/.
I wrote 2KB of Frege code. The Frege compiler translated this into 47KB
of Java code. The Java compiler then translated this into 12 class files
totalling 30KB. The compilation process took just under 6 seconds.
Of course, the program I wrote is only a simple CLI thing for test
purposes. The interesting question is "how easily can I use the features
of Java?"
It looks like it only takes 1 line of code to turn an existing Java
class into a valid Frege data type. (A data type which Frege then knows
nothing about.) It takes a further 1 line of code to turn any Java
method into a valid Frege function. I haven't actually attempted to use
this yet, but there's some example code showing the creation of a Swing
GUI from Frege. The example is only 50 lines long.
Clearly I'm going to have to play with this for much, much longer before
I can say how truly /useful/ it is. It's pretty damned exciting though! :-D
