POV-Ray : Newsgroups : povray.off-topic : Teach yourself C++ in 21 days Server Time
26 Nov 2026 10:09:15 EST (-0500)
  Teach yourself C++ in 21 days (Message 151 to 168 of 168)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: Days 5-
Date: 25 Apr 2012 09:12:30
Message: <4f97f83e$1@news.povray.org>
>>> Almost all business logic.
>> I suppose I should consider myself lucky that I'm never going to be
>> writing anything like that.
> Why not? Didn't you rewrite the code to compile your danse tournament
> rankings?
I did not "rewrite" anything. I merely wrote a program that downloads
some web pages and attempts to extract the raw data from them. And that
is all.
(The organiser's website is obnoxiously difficult to navigate.
Fortunately I was able to reverse-engineer how the URLs are generated...)
> I know you only did it for yourself, but that was business
> logic, even if you weren't using WebSphere, J2EE, Weblogic or some big
> platform like that.
OK.
>> So... how is it ever possible to statically link software?
> You have to take extra steps to make sure it works.
Really?
> For example, back in
> the days of Windows 3.1, you had to use the Pascal calling convention
> for your functions in order to make sure that they could interact with
> other modules. (Maybe it's still that way, I haven't touched a C program
> in 15 years.)
So what you're saying is "the C calling convention is undefined, but the
OS calling convention is not"?
Date: 25 Apr 2012 10:25:33
Message: <4f98095d$1@news.povray.org>
> Really?
Yes.  For example: Miocrsoft dictating that all Windows applications and
DLLs must use the Pascal calling convention.
(I know DLLs are not statically linked... but you get my drift.  If you
want to use library XYZ, you need to use the same calling convention as
library X uses.
>> in 15 years.)
No.  I'm saying - as Darren pointed out - that the C calling convention
is not undefined, but implementation-defined.  There's a difference.
Division by zero = undefined.
Number of bits in an integer = implementation-defined.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 25 Apr 2012 23:33:45
Message: <4f98c219$1@news.povray.org>
On 4/25/2012 1:22, Invisible wrote:
> Really? That's surprising. No recursive sorting algorithms for balancing the
> B*-trees that the directory nodes use, or for sorting the ready thread list
> by priority?
If you can limit the recursion a priori, then sure. If you know you'll only
have at most 4 levels of tree, or only 128 entries in the list to sort, or
something like that, recursion is fine. I wouldn't write production code to
manipulate an arbitrary data structure with actual machine-stack-based
recursion in C.
> SQL is a rather special-purpose language. I'm not sure it even /supports/
> recursion...
That's kind of my point.
> In other words, you manually implement the stack.
Yes.
> Tell me, in what way does this prevent you running out of stack?
It doesn't. It just keeps you from running out of stack without knowing it.
If your language runtime already supplies that service (e.g., C# throwing an
exception when it runs out of stack or something) then recursive algorithms
are fine.
>> Unless you have a CPU that actually enforces calling conventions.
You appear to be having a hard time distinguishing "it's
implemention-defined and not specified in the standard' from "we don't know
what it is, ever."
> I mean, if every compiler uses its own random calling convention,
It doesn't.
> then how
> /the hell/ is it possible to write some C, link it against GMP, wxWidgets
> and the OS header files, and get a usable binary? You know, given that you
> have no idea which compiler these libraries are compiled with...
Because sometimes the OS defines the calling convention to be used.
> I would, however, expect that on any given architecture, the C calling
> convention is always the same.
In spite of the page I pointed you to showing all the different calling
conventions used by the x86 line, right?
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 25 Apr 2012 23:36:36
Message: <4f98c2c4$1@news.povray.org>
On 4/25/2012 1:12, Invisible wrote:
> You do all of that stuff from /outside/ your transactions, that's all.
Except that .NET is about components, so that doesn't work out too well.
And if you're talking about putting Haskell on .NET, then your entire
program becomes one "transaction". (Note we've moved to talking about STM
from talking about Haskell, which was not my intention. It was an analogy.)
> Remember, transactions are only for thread communication. You start a
> transaction, fetch the next work item from the shared work queue, and the
> transaction. Then you process the work item, calling whatever libraries you
> need. Simples.
And if the work item is in a class written that does I/O to obtain it, or to
log a message, or etc etc etc?
    in the cabinet."
Date: 26 Apr 2012 04:13:42
Message: <4f9903b6$1@news.povray.org>
How so?
> STM from talking about Haskell, which was not my intention. It was an
> analogy.)
OK. And I was just saying that Haskell /already/ lets you use libraries
written in C, which aren't functional at all. I don't see why using the
.NET libraries would be any harder. [Assuming you solve the problem of
how to make your program run on the CLR in the first place, obviously.]
>> libraries you need.
> or to log a message, or etc etc etc?
I am really bad at typing, aren't I? :-S
What I /meant/ to write was that you start a transaction, fetch the next
work item, and then end the transaction. Once the transaction is over,
you can do as much I/O as you like.
The problem (I assume) that you're talking about is that all the
existing .NET stuff is structured under the assumption that you can do
I/O whenever you feel like it. I can see a few ways to approach that.
(Perhaps the simplest possibility being "only Haskell is allows to use
STM". :-P )
Date: 26 Apr 2012 08:09:56
Message: <4f993b14@news.povray.org>
> recursion in C.
  Very usually the recursion depth of a typical recursive algorithm is
O(log n). This means that the computer wouldn't be able to hold as much
data as to make you run out of stack space when running the recursive
algorithm on it. (For example, if the recursion depth is 50, that means
that there's about 10^15 elements of data. Even if each element took just
one single byte, that would be like 1024 terabytes of RAM.)
Date: 27 Apr 2012 20:38:17
Message: <4f9b3bf9$1@news.povray.org>
> algorithm on it.
Assuming that you're not writing a library that might invoke you 40 levels down.
That said, I've found I rarely need it, and that the undefined behavior
isn't worth the risks. YMMV. If you can handle the program crashing when you
give it too much data in a way that generates bogus results, then sure, feel
free. :-)  (I'm not being sarcastic - there are lots of programs like that.)
    in the cabinet."
Date: 27 Apr 2012 20:40:58
Message: <4f9b3c9a@news.povray.org>
And can the C call back into the Haskell? And if so, are all the Haskell
invariants and such maintained? And can you do that without telling the
caller whether they're calling C or compiled Haskell?
> work item, and then end the transaction. Once the transaction is over, you
Right. But if "fetch the transaction" means "obtain it from the server over
there using TCP/IP", then you're kind of screwed, aren't you?
Heck, even a regular expression match isn't functional in .NET.
> The problem (I assume) that you're talking about is that all the existing
> .NET stuff is structured under the assumption that you can do I/O whenever
> you feel like it. I can see a few ways to approach that. (Perhaps the
> simplest possibility being "only Haskell is allows to use STM". :-P )
And that's the kind of incompatibility I'm saying makes .NET much less useful.
    in the cabinet."
Date: 28 Apr 2012 04:33:05
Message: <4f9bab41@news.povray.org>
  It's not usual to need it, but sometimes it can be quite useful.
Almost anything involving things like permutations and combinations
are significantly easier to express recursively than iteratively.
> free. :-)
  As I said, if the recursion depth is O(log n), then you *can't* give it
so much data as for the stack space to run out. It's physically impossible.
  If your recursion level is O(n), then it sounds a lot like an iterative
algorithm that has been expressed recursively for no good reason. (Of
course exceptions probably exist, but are rare.)
Date: 28 Apr 2012 05:56:16
Message: <4f9bbec0$1@news.povray.org>
Yes. I demonstrated using the C sort() function to sort Haskell data,
remember?
> And if so, are all the Haskell invariants and such maintained?
You have to tell the compiler whether or not you consider the C function
to be "pure" or not. Obviously, you can lie. Don't do that.
Does sort() know what it's calling?
> over there using TCP/IP", then you're kind of screwed, aren't you?
Yeah. STM only works for stuff local to one machine.
Or rather, the implementations I've seen only work local to one machine.
It's quite plausible you could extend it so that the transactional data
you're mutating might be remote - but them it would be the STM engine
sending network traffic, not you.
Probably. In fact, I doubt much of the .NET libraries are. So you would
probably end up using existing Haskell libraries for anything except
actual I/O - the thing that .NET is good at.
>> whenever
> useful.
Certainly it makes it less useful, yes. Whether it makes it "not worth
it at all" is more open to debate.
Date: 28 Apr 2012 12:39:29
Message: <4f9c1d41$1@news.povray.org>
Fair enough. That said, you can usually tell by looking at the input
structure how deeply you'll likely need to recurse for something like that.
>> free. :-)
Oh? How deep is your stack? Are you sure your on-the-heap data structure
hasn't used up all your potential stack space?
The point is not that if the algorithm is all you're doing, you won't run
out of stack space. The point is that you don't know how much stack depth
you have, what's on the stack above you, or how big your data structure is,
even assuming you're recursing due to a data structure.
Or how much stack space the thing you're calling during the recursion takes,
if your recursion is part of a more generic data structure. If you say
"process each node of the DOM with this lambda", you don't know what that
lambda is going to do.
Why does C++ limit the depth of template instantiation required to 17
levels, or whatever it is? Clearly, it's possible to run out of stack doing
recursion.
    in the cabinet."
Date: 28 Apr 2012 12:43:47
Message: <4f9c1e43$1@news.povray.org>
On 4/28/2012 2:56, Orchid Win7 v1 wrote:
> You have to tell the compiler whether or not you consider the C function to
Fair enough.
I don't know. That's why I'm asking. :-)
> probably end up using existing Haskell libraries for anything except actual
I think .NET is good at more than just I/O. :-) Actually, I don't think .NET
is any better at I/O that anything else on Windows is.
>> useful.
> Certainly it makes it less useful, yes. Whether it makes it "not worth it at
It breaks a fundamental tenet of .NET, which is that it doesn't matter what
language the caller is written in vs the callee. MS saying that "yes, this
.NET library works, but only if you call it from Haskell and not C# or VB or
F#" would not fly well.
    in the cabinet."
Date: 28 Apr 2012 12:52:23
Message: <4f9c2047@news.povray.org>
  As I said, if your recursion depth is O(log n), then you would need a
ridiculous amount of data in order to run out of stack space even with
a very stack-hungry recursive function. (For example, if your recursion
level were 50, then the input data, even if it took just 1 byte per element,
would require something like 1024 terabytes of RAM. How likely are you going
to run out of stack space with that few recursion levels? You could easily
have that many function calls on the stack even without recursion.)
  It's highly unusual to require enormous amounts of stack on one single
function call, especially if you are implementing a recursive algorithm.
If each function call takes exponentially more stack space than there's
input, you are doing something wrong. (And even if you did, your algorithm
would be quite slow, as each function call would be operating on a rather
large amount of local data.)
  Never heard of such a limit.
Date: 28 Apr 2012 12:57:43
Message: <4f9c2187$1@news.povray.org>
On 4/28/2012 9:52, Warp wrote:
> level were 50,
I understand your argument. I'm unconvinced that you're (a) not already 40
levels of stack deep when you get invoked, and (b) know what your stack
recursion depth can be.
Maybe I'm just used to working on machines with actual limited address space
and RAM. 50 levels of recursion sounds like a lot of stack space used, to me.
function call,
I would think that depends on the program. If you're making an image of your
input data for each level, you're screwed, which is why people tend not to
do that sort of thing. If (maybe) you're parsing a programming language, I
can see each level having a fairly large amount of data associated with it.
That's my point! :-)
IIRC, template function nesting is only required to be supported to some
realtively small depth.
    in the cabinet."
Date: 28 Apr 2012 13:14:11
Message: <4f9c2563@news.povray.org>
> > level were 50,
  My point is that you are not going to get even close to 50. Perhaps
something like 20.
  If your stack can't hold hundreds of recursive function calls, then
you should upgrade your computer to the new millenium.
  What? Even if each function call took like a kilobyte of space (which is
quite a lot for one single function call), it would still be just 50 kB.
I think stack sizes are counted in megabytes in modern systems.
> function call,
doing it wrong. (If for nothing else, then because it increases the
computational complexity of your algorithm by a factor of n, which is quite
a lot. Eg. a fast O(n log n) algorithm becomes a crawling O(n^2 log n).
Not to talk about if the original algorithm was eg. O(n^2) to begin with...)
  I suppose the standard probably as a minimum recommended amount (like
it has for many other things, like the length of variable names). However,
if you surpass that limit your program won't even compile, so it's not
a question of running out of memory when running the program. (And most
C++ compilers have an option to increase the space dedicated to type
names.)
  Consider that some projects use template metaprogramming quite
extensively, and the internal type names that result from it can be
quite large (we are talking about thousands and thousands of characters).
Most C++ programs don't use type names that long.
Date: 28 Apr 2012 13:38:55
Message: <4f9c2b2f$1@news.povray.org>
Well, that's what I said. If I have a machine with enough power to support
that sort of thing, I'm probably not going to be using C. :-)
PS: Pro-tip. I work for google. Don't try to spider the web recursively. ;-)
As the machines get bigger, so do the problems people throw at them.
But you have a database with a B-Tree index? Sure, chances are you're not
going to blow the stack walking down that tree.
I'm not saying recursion isn't useful. I'm saying that one must keep in mind
the possible depth of recursion, because C doesn't tell you when you overrun
the stack. You just get the same random errors you get when you run off the
end of an array, except you haven't actually violated the spec, as far as I
know.
Depends on the system. Credit card terminal? No. Last card terminal I worked
on had 14K of space free for code and data and stack. :-)
In any case, would you call malloc() inside each level of recursion as you
go without checking whether malloc() returned NULL? I wouldn't think so. So
if malloc() can fail and you want to check, why not recursion? Why not just
use the returned value from malloc() and let it crash out when you try to
write to offset 0?
> doing it wrong.
Yep. As I said, that's why people don't do it that way.
Note, however, that we're also comparing to things like Haskell, where the
"naive recursive algorithm" *is* the iterative algorithm.
> names.)
Yep. All to get around problems with naive recursive algorithms.
In any case, that's the sort of thing I'm talking about. If you add a level
of template indirection and your compiler crashes, that's one thing. If you
add another web page to the list of web sites you're selling ads on and your
revenue stream collapses, that's another thing.
Hope that you don't wind up adding another level to your templates and your
compiler finishes but generates the incorrect code.
    in the cabinet."
Date: 30 Apr 2012 05:03:13
Message: <4f9e5551$1@news.povray.org>
> .NET is any better at I/O that anything else on Windows is.
Well, I haven't ever used .NET, so I couldn't say.
>>> useful.
>> it at
> what language the caller is written in vs the callee. MS saying that
> "yes, this .NET library works, but only if you call it from Haskell and
> not C# or VB or F#" would not fly well.
Well, another possibility would be "you can use this library, but it's
up to you to not do any I/O within transactions. If you do, anything
could happen, and it will be Your Fault."
Subject: Frege
Date: 9 May 2012 06:33:20
Message: <4faa47f0$1@news.povray.org>
>> When will we see the Haskell# language?
> I'm pretty sure the whole .NET bit is too OO to make that useful.There's
> way too much stateful stuff (like I/O) that you'd want to use from .NET
> to make it reasonable to have a purely function .net language.
I've been thinking for years that it would be cool to write a Haskell to
Java compiler.
Yesterday night, I discovered that somebody has actually done this.
Specifically, there is a compiler which translates a language called
"Frege" into Java. Frege is basically the same as Haskell, with a few
tiny syntax changes. The compiler takes your Frege source code and turns
it into Java source code, which the standard Java compiler then compiles
as normal.
At the moment, it's all quite experimental. There's basically one person
maintaining it, and it's still brand new. Documentation is nearly
non-existent. The compiler is fairly slow, and error reporting leaves a
lot to be desired. But it /works/.
I wrote 2KB of Frege code. The Frege compiler translated this into 47KB
of Java code. The Java compiler then translated this into 12 class files
totalling 30KB. The compilation process took just under 6 seconds.
Of course, the program I wrote is only a simple CLI thing for test
purposes. The interesting question is "how easily can I use the features
of Java?"
It looks like it only takes 1 line of code to turn an existing Java
class into a valid Frege data type. (A data type which Frege then knows
nothing about.) It takes a further 1 line of code to turn any Java
method into a valid Frege function. I haven't actually attempted to use
this yet, but there's some example code showing the creation of a Swing
GUI from Frege. The example is only 50 lines long.
Clearly I'm going to have to play with this for much, much longer before
I can say how truly /useful/ it is. It's pretty damned exciting though! :-D
