POV-Ray : Newsgroups : povray.off-topic : A tale of two cities Server Time
26 Jun 2026 15:12:04 EDT (-0400)
  A tale of two cities (Message 46 to 55 of 105)
Subject: Re: A tale of two cities
Date: 14 Mar 2012 11:50:18
Message: <4f60be3a@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> >> Heh, really? Most languages I work with can allocate new objects in O(1)
> >> time and using O(1) memory for bookkeeping. I'm not used to dynamic
> >> allocation being anything to worry about.
> >    Last time I checked, 16 bytes is O(1) memory.
> You seem to suggest that there's 16 bytes of overhead /per object/. I'm
> saying I'm used to there being a fixed number of bytes of overhead,
> regardless of the number of objects. That's O(N) vs O(1).
  That's obviously impossible. The only way to achieve that would be
to allocate an array of objects (by value).
  If you allocate individual objects, the allocator has to know where they
are and if those memory blocks are free or not. At least if the allocator
ever wants to reuse freed memory blocks.
> >>>> Mmm, I hadn't even thought of using an /array/. I suppose the upper
> >>>> bound on the tree size is statically known, so why not?
> >>>     The array doesn't necessarily have to be fixed in size.
> >> It does if it's static. Either that or the source I'm reading is
> >> incorrect...
> >    You don't have to use a static array.
> Sure. But then you're dynamically allocating again.
  You are allocating *an array* dynamically, not individual objects.
You are making like a couple of 'news' rather than thousands or millions.
> Right. I think I know how to redesign to avoid that. Should make things
> a bit more coherent...
  If you are creating a dynamic binary tree, there's no avoiding memory
allocation. (One of the very few cases where you can avoid it is with
things like a heap. While a heap is a dynamic binary tree, it can be
implemented as a single array rather than each object being allocated
separately. In fact, the C++ standard library offers heap creation and
managing functions.)
  A possible approach is that the nodes themselves do not manage the
objects they are pointing to, but rather the data container module
itself. This is, for example, what std::set does (in other words,
the nodes in a std::set do not manage the other objects they are
pointing to, but it's the std::set class itself that takes care of
allocating and deleting them as needed.) Of course this requires a
careful design as well, in order to avoid leaks or double deletions.
Date: 14 Mar 2012 11:52:05
Message: <4f60bea4@news.povray.org>
> While this is true, it is not a problem specific to reference counting,
> but one that is inherent in /any/ attempt at automatic object lifetime
> management.
  It's not a problem for a garbage collector.
  And btw, cyclic references are not the only problematic situation with
reference counting. There are cases where objects may be deleted too early,
while there's still code using them.
Date: 14 Mar 2012 12:05:36
Message: <4f60c1d0@news.povray.org>
Am 14.03.2012 16:37, schrieb Invisible:
>> And then you'd also expect MS to give away VS for free (the real thing,
>> with the tools to write the real powerful software, not just crappy
>> hello world stuff), yet for some reason they don't.
> Um... So how is the pro version actually different from VS Express?
Last time I checked (though I must confess that's years ago) one
difference was that the Express editions had quite limited flexibility
regarding the project settings, to an extent that I didn't even bother
trying them out further.
>> I think there's another reason why VS is so good. I'm convinced they're
>> not trying to make it easy for /anyone/ to write code - they're trying
>> to make it easy for /themselves/. And make extra money by selling the
>> toolset.
> Quite possibly. ;-)
> Then again, Valve released their editing tools, and (from what I hear)
> they are really, really hard to use...
Maybe that's because the development cycle in game engines is faster
than that in general-purpose programming languages, so it wouldn't have
paid off to develop better tools?
Remember that VS has been developed over how long now? Two decades?
Date: 14 Mar 2012 12:07:59
Message: <4f60c25f$1@news.povray.org>
If you're using garbage collection, it's quite possible - and, indeed,
usual. Each time the GC collects the garbage, it also defragments the
free space. You therefore need only store a pointer to the next free
byte of memory. To allocate, just increment this pointer by the size of
the block allocated. Allocation is now O(1) in time and space.
What you're saying is that C++ (and any other language with manual
memory management) can't do it this way, since there would be no way to
move stuff around without breaking all the things trying to point to it.
So free space becomes fragmented, and you start needing O(N) storage to
keep track of it - and, presumably, O(N) to allocate and deallocate stuff...
Right, OK. You seem to be saying essentially the same thing as I am -
dynamic allocation is OK, just try not to individually allocate millions
of blocks.
> allocation.
I meant, I think can avoid copying bits of tree around while I'm
building the tree.
Yeah, I believe I've read about that. (Heaps in arrays, that is.) Which
property of a heap is it that makes this possible?
Yeah, with manual memory management, almost /everything/ requires
careful thought and design. You want to make damned sure you know what
you're trying to implement before you implement it...
Date: 14 Mar 2012 12:14:41
Message: <4f60c3f1$1@news.povray.org>
Am 14.03.2012 16:52, schrieb Warp:
>> management.
Last time I heard, reference counting /is/ a garbage collection mechanism.
I can't think of any reason why that could possibly happen, provided
that the reference counting is implemented in a thread-safe manner.
Date: 14 Mar 2012 12:24:20
Message: <4f60c634$1@news.povray.org>
Am 14.03.2012 17:07, schrieb Invisible:
So far, so good. But how does the GC know how long each chunk of
garbage-to-collect is?
Date: 14 Mar 2012 12:29:32
Message: <4f60c76c$1@news.povray.org>
The GC engine needs to know quite a bit about the objects it's scanning
- how big they are, where their pointer fields are, etc. It also usually
needs access to each thread's stack, to see what local variables are
pointing to objects. And so on and so forth. There's a /reason/ why it's
usually hard-coded into the language run-time system rather than being
an add-on library.
Date: 14 Mar 2012 12:33:08
Message: <4f60c844$1@news.povray.org>
>> early,
Imagine you've implemented a tree where each node is an object which has
a "delete" method that removes the node from the tree.  If you're not
careful the node could end up removing all references-counted pointers
to itself (since "this" isn't reference counted) and be reclaimed while
still running its own delete method.
Date: 14 Mar 2012 12:37:18
Message: <4f60c93e$1@news.povray.org>
Am 14.03.2012 17:29, schrieb Invisible:
> an add-on library.
You didn't quite /exactly/ answer my question :-P
My point here being that without any per-object memory overhead in
addition to the raw data, you can't do any dynamic memory management at
all. Whether that overhead is accounted for in the language run-time or
an added library is quite irrelevant in that respect.
Date: 14 Mar 2012 12:44:09
Message: <4f60cad9@news.povray.org>
>> an add-on library.
OK. Well typically each object has some overhead that tells you which
class it belongs to. Typically the GC engine is going to go off that
information, so you're arguably not adding any additional cost there.
Typically each object just gets one pointer wider.
Whether a static allocator can match that or not is open to debate. In
particular, I'd imagine a static allocator might have O(N) cost per
/free block/, whereas a typical GC implementation doesn't need to track
free blocks at all...
