POV-Ray : Newsgroups : povray.off-topic : Ancient history Server Time
16 Jun 2026 12:08:52 EDT (-0400)
  Ancient history (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Ancient history
Date: 6 Mar 2012 08:48:15
Message: <4f56159f$1@news.povray.org>
Le 2012-03-06 04:11, Invisible a écrit :
>>> OTOH, it seems that any equipment that says "rack mountable" on it is
>>> instantly 5x the price, for no apparent reason...
>> Of course, the engineering that goes in designing the special connectors
>> to power and manage these boards, as well as keep them ventilated comes
>> free of charge, in your world...
> What "special connectors"?
I was talking more about "blade servers", since the original topic was
the Google servers, where each blade gets its power, remote management
and network connections from a central backplane.
but even if we are talking about a "desktop" PC case vs. a
rack-mountable server with a similar CPU.  The rackmountable server will
have a lot more consideration put into its ventilation and heat
disspation since it is made to be in a closed space full of other
heat-generating devices.  Secondly, rack-mounted servers usually come
with a lot of extra feautres not usually found on classical desktop
hardware, such as hot-swappable disks, power supplies, and in some
cases, memory and CPUs.
You need to realise that these things also contribute to the price of a
rack-mountable server.
> Buy a UPS that sits under your desk. That's £50. Buy a UPS that is rack
> mountable. That's £800, minimum. Sure, they probably don't sell rack UPS
> with capacities as low as they do for the desktop. But 16x the price?
> Really? For a battery and an inverter?
It depends on the battery.  And besides, you are comparing apples and
bulldozers.
Maybe besides size there are other factors to consider...  Let's compare
a "home" unit, vs. a rackmountable unit of the same power rating and
same supplier.
"Home" UPS
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BE750G&total_watts=200
Output capacity: 450W/750VA.
Run time @400W: 3 min.
Run time @100W: 40 min.
Recharge time: 16 hrs.
Alarms: power/on battery/replace battery led display.
Management: N/A
Price: ~100$
"Rackmountable" UPS
Output capacity: 480W/750VA.
Run time @400W: 8 min.
Run time @100W: 50 min.
Recharge time: 4 hrs.
Alarms: Audible alarms when on battery/low battery/Replace battery
Management: vis DB-9, RS-232, SmartSlot or USB.  Network management card
optional.
Price: ~500$
So the rackmountable unit recharges 4x faster and has much better
management capabilities - I mean what good does a LED display do you in
an unattended server room? - for 5x the price.  Seems reasonable to me.
The "entry-level" rackmountable unit has a lot more to offer than the
"top-of-the-line" standalone unit, besides mounting brackets.
> Buy a 12-port desktop switch. £30, maybe? Now buy a rack mountable one.
> That'll be £200 please. Sure, it's physically bigger. There's more metal
> in it. Metal costs money. But does it cost /that/ much money?
What's the MTBF of your 30$ desktop switch?   Does it have remote
management capabilities?  What about problem diagnostics?  How many
packets per second can it process?  Does it support vlans?  QoS?  PPPoE?
  802.1x authentication?  Etc...
> (Before anyone asks - no, just because it can be rack mounted, that does
> /not/ mean it has management features. When I joined the company, we had
> a whole rack full of switches, all rack mounted, none of them managed.
> And all about £400 each.)
Not manageABLE or simply not managed? Also [citation needed] brand and
model?
> Redundant power supplies cost extra. RAID controllers cost extra.
> Hot-swap drive bays cost extra. And yet, a server that has these costs
> nowhere near as much as a rack-mount server.
[citation needed] Brand and model?
> Now sure, making something
> like a server actually small enough to be rack mounted is nontrivial.
> There's a reason laptops cost 5x the price of a similar desktop. I
> understand that. But for goodness' sake, if you make a /wire clamp/
> that's rack mountable, suddenly it goes from being £2 to £80. It's like
> it's a license to print money...
Then make one and sell it for only £50 and drive the £80-clamp guy out
of business, if it's that easy.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 6 Mar 2012 10:23:17
Message: <4f562be5$1@news.povray.org>
Oh, right.
Yes, those really /are/ expensive. If nothing else, each manufacturer's
blades only fit in their own blade centre. So once you have their blade
centre, they are the only people who can sell you blades. So they can
charge any arbitrary price they want.
When I joined the company, we had floor-standing servers with hot-swap
drives, dual redundant power supplies, a floor-standing UPS, and all the
rest. It still didn't cost anywhere near what a rack-mountable setup
would cost.
My original point was, /anything/ sold as rack mountable seems to
suddenly jump drastically in price, regardless of whether it's anything
special beyond having the necessary mounting points.
Heck, a USB keyboard costs, what, £2 maybe? Oh, but if you want a
keyboard draw for a rack? Suddenly it isn't £2 any more. More like £200.
Sure, the draw runners clearly cost money. Do they cost £198? I don't
think so.
> same supplier.
> "Home" UPS
> Management: N/A
> Price: ~100$
> "Rackmountable" UPS
> optional.
> Price: ~500$
I don't see why management facilities should cost 5x extra. If somebody
can make something as complex as a mobile phone and sell it for £10,
building something which closes a connection when a voltage goes below a
threshold can't be that damned expensive.
I don't know why there's such a massive difference in recharge time.
Since I don't know what's different about the second unit which allows
it to recharge so much faster, I can't say whether or not that justifies
the price difference.
Isn't MTBF an arbitrarily-chosen marketing number?
> Does it have remote management capabilities?
Unlikely. (Although not impossible, believe it or not.) But then, for
£200 your rack mount unit probably won't either.
Same statements as per management.
> model?
No management features. You just plug them in, turn them on, and they
work. (Once they finished learning MAC addresses, anyway...)
I don't recall the exact model off the top of my head. They were
definitely SMC "EZ switch", but I can't remember the precise model
numbers. A mixture of 12-port and 24-port units.
A cursory inspection of the nearest product catalogue indicates that the
starting price for a HP server is about £200, while the cheapest
possible rack-mountable unit is £400. Which, actually, isn't nearly as
bad as I'd expected. (I was thinking nearer £2,000. It /is/ HP, after all.)
It just seems that being rack-mountable is one of those "premium"
features that makes manufacturers instantly put the price up, just
because they can.
It's like printers with network cards. A network card costs, what,
£0.0016? And yet, a printer without one is £30 or something, but one
with it is £150. Presumably because they figure that your average home
user doesn't give a fig whether there's a network card, they just want
the cheapest one in the shop, but your average business user cannot
afford to do without one, and won't think twice about splashing a few
hundred pounds for something they actually need...
Date: 6 Mar 2012 11:45:00
Message: <web.4f563df0dde0759e3771cd8e0@news.povray.org>
You do know that a network card for a printer is actually a print server, right?
Regards
Aydan
Date: 6 Mar 2012 11:50:09
Message: <4f564041@news.povray.org>
You do know that a laser printer already has an entire computing
environment inside it running an embedded PostScript engine, right?
Adding an embedded TCP/IP stack can't be /that/ damned hard.
Also, explain this:
How can the entire printer be /cheaper/ than just the network card?!
That makes no logical sense!
Date: 6 Mar 2012 12:20:00
Message: <web.4f56472edde0759e3771cd8e0@news.povray.org>
You were talking about a 30GBP printer.
You don't get a laser printer for 30 pounds.
Even if you do it's unlikely that the printer supports PostScript.
The cheapest postscript capable printer I could find on short notice is a
Lexmark E260 for 169 Euros.
Date: 6 Mar 2012 14:38:28
Message: <4f5667b4@news.povray.org>
Le 2012/03/05 19:54, Francois Labreque a écrit :
> Le 2012-03-05 14:42, Orchid Win7 v1 a écrit :
>> On 05/03/2012 18:47, Alain wrote:
>>> I agree, rack mounting normal motherboards is not the brightest idea.
Also, don't forget that most rack mountable components are hot swapable.
That account for some price increase.
Want to change that board holding those 4 old single core CPUs with one
holding 6 8 cores CPUs of the last generation? Disable the board, pull
it out, push in the new one, fire it and you are good to go.
Date: 6 Mar 2012 14:46:23
Message: <4f56698f@news.povray.org>
>> connectors to power and manage these boards, as well as keep them
>> ventilated comes free of charge, in your world...
Most server-class hardware also comes with a support contract with fast
turnaround.  Service is like insurance - expensive, and you hope you
never need to use it.
Jim
Date: 6 Mar 2012 16:10:26
Message: <4f567d42$1@news.povray.org>
> turnaround.
Yes, but you can perfectly well get tower servers with that too. So
comparing that to a rack-mount server would seem to nullify this point.
Yep - usually because when you /do/ need it, you find out it isn't very
good. ;-)
Date: 6 Mar 2012 16:18:46
Message: <4f567f36@news.povray.org>
>> turnaround.
I've never seen a tower server with hot-pluggable power supplies or hot-
pluggable PCI.  (Doesn't mean they don't exist, but I've yet to see one).
>> Service is like insurance - expensive, and you hope you never need to
>> use it.
> good. ;-)
That's also usually true. :)
Jim
Date: 6 Mar 2012 16:46:22
Message: <4f5685ae$1@news.povray.org>
>>> turnaround.
Our old server towers had hot-swap PSUs. In fact, one of the tests in
the disaster recovery plan verification procedure that I wrote was to
physically unplug one and make sure the server doesn't die. ;-)
No hot-swap PCI though; IIRC, it had ISA, not PCI.
>>> use it.
>> good. ;-)
Ah, you too have bitter experience, I see. :-)
