POV-Ray : Newsgroups : povray.off-topic : The trouble with XSLT Server Time
26 Nov 2026 12:29:07 EST (-0500)
  The trouble with XSLT (Message 35 to 84 of 84)
<<< Previous 34 Messages Goto Initial 50 Messages
Subject: Re: The trouble with XML
Date: 23 Feb 2012 13:04:28
Message: <4f467fac@news.povray.org>
The trouble with the whole xml thing is that it's just another
enterprisey BS to grind CPUs idle times.  You need an xml document, an
xml document describing the structure of the previous document, yet
another xml document to describe how to style the original document
itens, perhaps a xml document describing how to transform your xml
document into another xml document.  It's an insanely verbose and
homogeneous pile of human and machine barely readable crap.
People resented it and thus insist on saner formats, such as CSS, JSON
and real programming languages rather than a shitload of xml abstraction
layers, tools and java frameworks.
Subject: Re: The trouble with XSLT
Date: 23 Feb 2012 13:19:50
Message: <4f468346$1@news.povray.org>
Am 23.02.2012 18:35, schrieb Warp:
> clipka<ano### [at] anonymousorg>  wrote:
>> As an alternative, forget UTF-8 and go for UTF-16.
>    UTF-16 is more compact if the text consists mostly of non-ascii
> characters, especially if it contains eg. kanji symbols, hiragana, etc.
> (The vast majority of Japanese kanji can be expressed with 2 bytes using
> UTF-16 but require 3 bytes with UTF-8.)
>    However, if the text consists mostly of ascii characters, such as
> English usually does, then UTF-8 is more compact than UTF-16 (which will
> basically double the size of the file).
I guess a factor 2 in text stream size is not a serious problem with
today's internet bandwidths.
>    Support for UTF-16 is still relatively poor (although getting better).
> Most modern browsers should handle it ok, though, but it requires for the
> server to send the proper http header to tell the browser the encoding,
> and configuring the server to do this might not be trivial. (A html file
> encoded in UTF-16 will look like garbage.)
It didn't sound like Andy would want to retrieve the XML file from a web
server, but rather directly from the local file system. Otherwise he
could simply go for server-side XSLT processing.
Date: 23 Feb 2012 13:37:20
Message: <4f468760$1@news.povray.org>
Am 23.02.2012 19:04, schrieb nemesis:
Businesses do use it quite a lot for data exchange.
But yes, XML as a mere replacement for HTML is a rather silly thing
(except in its incarnation as XHTML); its legitimate ecologic niche on
the web is on the server side (if anywhere), and its native habitat is
actually totally somewhere else.
In some sense, XML is today's CSV: A generic file or data stream format
a human /can/ create, read and/or modify with an ASCII text editor, but
that still follows certain clear-cut rules that it can also be evaluated
by software; and actually just a meta-format, in the sense that the
content of the individual data fields needs to be agreed upon separately.
Date: 23 Feb 2012 14:06:27
Message: <4f468e32@news.povray.org>
  It's verbose, but it has one advantage over most other formats: It's
standardized and pretty well supported.
  It has many advantages over many other formats. One example is character
encoding. With all types of character encodings out there, and support
for them in different file formats and programs being what they are, a
*standardized* form for representing special characters can be really
useful. Also, any program that reads XML ought to support it regardless
of which character encoding it uses (at least if the program uses a
generic XML parser internally).
  Compare this to, for example, just a simple raw .txt file. Which encoding
does it use? ISO-Latin-1? ISO-Latin-9? UTF-8? Shift JIS? EUC-JP? ISO-2022-JP?
Something else completely? Impossible to say. With an XML file you don't have
to care. (As said, if your program uses a generic XML parser, the character
encoding used in the input XML file becomes a non-issue.)
  Not that this exact same thing wouldn't be possible with a less verbose
format, but as said, XML is widely supported so it has this implicit
Date: 23 Feb 2012 15:08:11
Message: <4f469cab@news.povray.org>
Le 23/02/2012 20:06, Warp nous fit lire :
Well, XML is a container. The problem is lack of intelligent design for
the inside. It is too often the Excel sheet of today: A bunch of
entries, without consistency.
Indeed, with a bit of base64 encapsulation, you could put an BINARY
excel sheet file into a XML document. And advertise that you output XML.
And to make matter more interesting, some find it enterprisey to have
xml inside xml... and other old CSV into XML too (without reinterpreting
the data, so it's just a formatting. A dumb formatting).
Read it, yes. Understand it, that's another whole story!
Same as: I can read latin or japanese in katakana, with few error on
sound. That does not means I get the meaning. At least I can edit it
like a monkey.
XML is interesting when exchanging documents/data, once the big bosses
and their technical staffs have agreed on a XSD. But whenever you add a
third company, you need to negociate another XSD (with a totally
different approach of the data, not even compatible with the first one).
Date: 23 Feb 2012 16:14:21
Message: <4f46ac2d@news.povray.org>
Isn't that what the HTML encoding tag is for? Or the XML encoding
declaration?
Date: 23 Feb 2012 20:49:10
Message: <4f46ec96$1@news.povray.org>
Am 23.02.2012 22:14, schrieb Orchid Win7 v1:
> declaration?
You can't read those until you know at least some basics about the
encoding :-P
That's /one/ reason why XML requires UTF-16 files to start with a byte
order mark: If the file starts with "FE FF" or "FF FE", it's either
UTF-16, malformed XML (not starting with optional whitespace followed by
"<?"), or indeed garbish, so UTF-16 is a safe bet in that case.
Otherwise rely on the file format being backward compatible with ASCII,
and treat it as UTF-8 (which is ASCII-compatible as well) until an
encoding declaration tells you otherwise.
Date: 23 Feb 2012 22:43:51
Message: <4f470777@news.povray.org>
It also has an advantage in that it's a *markup language*. That's what it's
for. Just as it sucks for passing around arrays of floats or passing pov-ray
data objects between clusters of renderers or encoding routing table
updates, it does pretty darn good at things like writing help pages, user
manuals, and so on.
Bitching that XML is poorly suited for something it was never designed to do
is just pointless.
It's only verbose if you're not using it to pass around human-readable prose.
   People tell me I am the counter-example.
Date: 24 Feb 2012 04:02:15
Message: <4f475217$1@news.povray.org>
>> declaration?
> encoding :-P
Yeah. Isn't that fun? :-D
Date: 24 Feb 2012 04:10:09
Message: <4f4753f1$1@news.povray.org>
Well, it was that or JSON.
In my case, XML has XSLT. JSON does not possess anything comparable.
What that means is that just by outputting my data as XML, I can easily
transform it into something usable later. And I don't have to implement
the transformation engine myself - just the actual transformation rules.
(Which is still pretty non-trivial, mind you.)
(The other possibility is the unspeakably awful YAML...)
Some people /do/ use XML in some pretty inappropriate ways. (E.g., "if
we store all our data as XML, we won't have to ask the DB admin to
change the DB schema for us, and we can just run all the queries on the
client-side instead".) Just because people do stupid things with XML,
does not mean that XML is stupid.
That said, it /does/ seem overly complicated for the simple problem it's
supposed to solve...
Date: 24 Feb 2012 07:09:45
Message: <4f477e09@news.povray.org>
  OTOH, it would be quite trivial to guess that a HTML/XML file is
UTF-16-encoded: If each other byte is 0 and each other form valid
HTML/XML (at least up to the header section that specifies the encoding),
then it's a safe bet that it's UTF16-encoded.
Date: 24 Feb 2012 09:40:40
Message: <4f47a168$1@news.povray.org>
Darren New escreveu:
> it's for. Just as it sucks for passing around arrays of floats or
> passing pov-ray data objects between clusters of renderers or encoding
> routing table updates, it does pretty darn good at things like writing
> help pages, user manuals, and so on.
> to do is just pointless.
Precisely so, like implementing validators or transformers for xml docs.
  How recursive and verbose you can get?  "Hey, Darren, have you already
wrote that xml document to validate the xml document validator that
validates our client xml document?"
I can't actually believe a typeful haskell supporter (I'm looking at
Orchid) is here advocating an xml document rather than writing a typeful
haskell program to validate data marshalling.
Date: 25 Feb 2012 01:04:12
Message: <4f4879dc$1@news.povray.org>
What simple problem do you think it was supposed to solve?
Date: 25 Feb 2012 05:37:21
Message: <4f48b9e1@news.povray.org>
The problem of marking up textual data.
A lot of people seem to think that if you just write some stuff in angle
brackets, that's XML. But it' actually far more complicated than that.
(As an aside, those aren't angle brackets. They're inequality signs. :-P
But I digress...)
For example, to say "this XML file actually contains XHTML", you're
supposed to add something like 5 separate headers, each about 25 million
miles long, to the top of the file. Why? Would one header not be sufficient?
Then there's all that stupidity with character entities. It should be
possible to include character entities in /all/ XML documents, not just
XHTML. But to this day, I have never discovered a way of doing this.
One of the nice ideas of XML is that you can use namespaces to include
one sort of XML document inside enought - e.g., you could put an SVG
file inside an XHTML file. But nooo, apparently you need a specialised
DTD to do that. In fact, you need one DTD for XHTML + SVG, another,
different DTD for XHTML + MathML, a third, different DTD for XHTML +
MathML + SVG, and... ARE YOU PEOPLE INSANE?!
In short, most people just end up sticking stuff in angle brackets and
calling that XML. /Actual/ XML is far too complicated.
Date: 25 Feb 2012 19:35:48
Message: <4f497e64@news.povray.org>
On 2/25/2012 2:37, Orchid Win7 v1 wrote:
> For example, to say "this XML file actually contains XHTML", you're supposed
> to add something like 5 separate headers, each about 25 million miles long,
Really? What do you have to add? I suspect you exaggerate a bit.
You have to declare the entities. Otherwise, you run across &frump; and
don't know what it means. That's what DTDs are for.
> One of the nice ideas of XML is that you can use namespaces to include one
> sort of XML document inside enought - e.g., you could put an SVG file inside
> an XHTML file. But nooo, apparently you need a specialised DTD to do that.
You can. Of course, your various processors have to know what the various
namespaces *mean*, so you have to declare them and you have to have a
processor that understands them (which is where the DTDs come in).
Date: 27 Feb 2012 04:15:06
Message: <4f4b499a$1@news.povray.org>
>> supposed
>> long,
First, you must say
<?xml version="1.0" encoding="ISO-8859-1" ?>
Which is fair enough, although the 5-digit ISO code number isn't exactly
easy to remember. Then you have to say
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
Yeah, I'm really going to remember that without looking it up. :-P No,
you can't just say "this is XHTML". You really do have to write all that
crap. And after /that/, you still have to say
<html xmlns="http://www.w3.org/1999/xhtml">
Um, didn't I just declare this as XHTML already? At least this URL is a
bit shorter, I guess...
In short, that's a /hell/ of a lot of typing, before I've even written
my document. It's also a lot of typing that I have to go look up on
three different websites every single damned time I want to write XHTML.
So why isn't there a DTD somewhere that contains all the entities that
everybody uses, which I can just link to? More to the point, since
everybody uses the same set of entities, why aren't they built in?
>> one
>> inside
>> that.
> various namespaces *mean*, so you have to declare them and you have to
> have a processor that understands them (which is where the DTDs come in).
You would /think/ you could just say "hey, this stuff here is in the
XHTML namespace, this stuff here is in the SVG namespace", and that
would work. But it doesn't. You need to use a DTD specially written for
the exact combination of XHTML+SVG. To me, this indicates that the
system is fundamentally broken. It should not be necessary to write a
separate DTD for every possible combination of XML documents imaginable.
You should just be able to refer to the DTD for XHTML and the DTD for
SVG and have it work.
Date: 28 Feb 2012 21:47:11
Message: <4f4d91af@news.povray.org>
>>> supposed
>>> long,
> First, you must say
You have to do that for XML anyway, so you don't have to do that for "this
contains XHTML."  Yes, it's more than you need for HTML, but then you don't
have to rely on a web browser header to tell you what type it is.
> easy to remember.
I guess if you don't do it often you don't already have such memorized. :-)
Right. That's the one line that you need to make it xhtml.
> Yeah, I'm really going to remember that without looking it up. :-P No, you
> can't just say "this is XHTML". You really do have to write all that crap.
Er, no, you don't, unless you want an "html" namespace in your XML. If you
don't want to use anything *except* html in your html document, you don't
need this line.
> In short, that's a /hell/ of a lot of typing, before I've even written my
> document. It's also a lot of typing that I have to go look up on three
So, store it somewhere. The first line says it's XML, the second says it's
XHTML, and the third says how you'll name things if you *don't* use XHTML.
There is. That's what the <!DOCTYPE> tag you complain about is doing. It's
linking to the entities for xhtml. See that ".dtd" on the end of the URL?
> More to the point, since everybody
Because they don't. Only the people using XHTML use that set of entities,
and you complain about having to supply the URL to them. :-)
> You would /think/ you could just say "hey, this stuff here is in the XHTML
> namespace, this stuff here is in the SVG namespace", and that would work.
> But it doesn't. You need to use a DTD specially written for the exact
http://www.rpbourret.com/xml/NamespacesFAQ.htm#valid_2
Plus, things like SOAP wouldn't work at all, where you're embedding an
arbitrary XML inside another arbitrary XML and expecting the processor of
the latter to be able to understand the former without change.
 > To me, this indicates that the system is
> fundamentally broken. It should not be necessary to write a separate DTD for
> every possible combination of XML documents imaginable. You should just be
> able to refer to the DTD for XHTML and the DTD for SVG and have it work.
http://www.rpbourret.com/xml/NamespacesFAQ.htm#use_5
The basic problem is that you still have to define how the bits combine. Can
you attach XHTML color declarations to color svg shapes? Can you use svg
shapes as the shape for bullet points in a bulletted list? If you combined a
vcard with xhtml, would you be allowed to nest a html:hr element inside the
street address element of a vcard? Without a DTD that says the allowable
combinations, there's no way to validate a complete document against a DTD.
The purpose of the DTD is to ensure that the <hr> element goes inside the
body and not the head of the HTML document, and that there's only one head
and one body. How is a generic XML parser supposed to know that you can't
put an SVG <use> in the header, or a <symbol> between </body> and </html>?
Date: 29 Feb 2012 04:24:19
Message: <4f4deec3@news.povray.org>
>> First, you must say
> "this contains XHTML."
Well, that at least is true enough.
>> easy to remember.
I don't generally make a habit of memorising long code numbers, no.
Well, it's more like 3 lines. :-P
> you don't want to use anything *except* html in your html document, you
> don't need this line.
The W3C validator disagrees.
The above declaration sets the default namespace for any elements which
do not have a namespace explicitly declared. W3C seems to insist that
this is /required/, even though a doctype has already been given.
(For example, my personal web pages do not have this third declaration.
When I wrote them, the validator accepted them. Today, it rejects them
because of the missing third declaration. Gotta love how a set of
standards compliant pages are no longer compliant with the same
standard, even though the pages haven't changed...)
That's what I end up doing. And then every time I go to a different
computer, I have to look it up all over again.
> It's linking to the entities for xhtml. See that ".dtd" on the end of
> the URL?
It's linking the entire definition of the XHTML language, not just the
character entities.
As far as I know, there is no way of using XHTML entities without also
declaring that this is an XHTML document. If just the entity definitions
were in a separate DTD, you could maybe do it. (But even then, I have a
sinking feeling you can only have one DTD per document, so you'd still
be stuffed.)
> entities, and you complain about having to supply the URL to them. :-)
Well, 3 URLs. :-P
>> XHTML
I'm not sure what this is trying to say.
I know that you /can/ stuff more than one namespace into an XML
document. It's just that it doesn't /work/ when you try to use it.
> of the latter to be able to understand the former without change.
Didn't we just...? Oh wait, that's SOPA. Never mind.
>> DTD for
>> just be
I still don't follow.
> Can you attach XHTML color declarations to color svg shapes? Can you use
> svg shapes as the shape for bullet points in a bulletted list? If you
> combined a vcard with xhtml, would you be allowed to nest a html:hr
> element inside the street address element of a vcard? Without a DTD that
> says the allowable combinations, there's no way to validate a complete
Isn't that the purpose of the HTML <object> tag though? So it can
contain an arbitrary object? If you just state that <object> is the only
place where elements from another namespace can go, the problem is solved.
Date: 2 Mar 2012 00:54:30
Message: <4f506096$1@news.povray.org>
Their validator might not be compliant with the standard.
> (For example, my personal web pages do not have this third declaration. When
> I wrote them, the validator accepted them. Today, it rejects them because of
> the missing third declaration. Gotta love how a set of standards compliant
> pages are no longer compliant with the same standard, even though the pages
> haven't changed...)
See? Either it wasn't before, or it isn't now. Hard to say without actually
delving deep into the mess.
>> the URL?
> character entities.
Right. Well, what do you expect?
Right. Because that would be meaningless.
> sinking feeling you can only have one DTD per document, so you'd still be
> stuffed.)
Correct and correct, and it makes perfect sense why this is so.
It's explaining why it doesn't make sense to ask to have more than one DTD
for a document. An XML document forms a tree. A DTD describes which types of
nodes can be descendants of other types of nodes. It wouldn't make sense to
have two of those declarations for one tree.
It's like complaining in Haskell that if you want to use either an integer
or a string in a variable, you have to declare a type that supports a choice
between *both*, instead of just mixing them together.
If you don't check structure with a DTD, you can mix and match whatever you
want. But a DTD is the "strong typing" for XML (and SGML), and it doesn't
make sense to say "here's a set of two independant declarations of types."
> I know that you /can/ stuff more than one namespace into an XML document.
It ... works for me. You just have to (a) do it right and (b) have a tool
that supports it.
> Isn't that the purpose of the HTML <object> tag though? So it can contain an
> arbitrary object? If you just state that <object> is the only place where
1) Can HTML appear inside the <object> tag? If so, can your other namespace
also appear inside the <object> tag inside the <html> tag inside the
<object> tag?  Etc.
2) Sure, for HTML. Solve that in a general way. What if you want only some
tags to appear in the <head> and only other tags appear in the <body>? No,
there's no notation in a DTD that says "by the way, don't check the validity
of anything inside this particular type of tag." Other than CDATA maybe.
Date: 2 Mar 2012 04:25:57
Message: <4f509225$1@news.povray.org>
That sounds /highly/ implausible...
> actually delving deep into the mess.
I'm going to suggest that they changed the standard to be more
restrictive, or they added a missing check to the validator. It seems
unlikely that the validator would become /less/ compliant over time. But
sure, "mess" seems like an accurate way to describe it. :-P
>> character entities.
The point is, any XML document that contains text may potentially need
non-ASCII characters. But only XML documents which are also XHTML can
contain non-ASCII characters. How is that sensible?
Sure, having more than one DTD doesn't make a lot of sense. (Except that
it would be nice to apply different DTDs to different namespaces. But
that has little to do with entities.) The problem is that character
entities are in the DTD, not defined in the XML spec for /everyone/ to use.
> DTD for a document. An XML document forms a tree. A DTD describes which
> types of nodes can be descendants of other types of nodes. It wouldn't
> make sense to have two of those declarations for one tree.
OK. But it could make sense for different DTDs to apply to different
subtrees, surely?
> tool that supports it.
Write at XHTML document which contains some MathML. Unless you use the
magic XHTML+MathML DTD, it doesn't work at all. Clearly it /should/, but
it doesn't.
>> contain an
> namespace also appear inside the <object> tag inside the <html> tag
> inside the <object> tag? Etc.
> some tags to appear in the <head> and only other tags appear in the
> <body>? No, there's no notation in a DTD that says "by the way, don't
> check the validity of anything inside this particular type of tag."
In summary, XML doesn't provide the necessary tools to solve common
problems such as mixing more than one markup together.
Date: 2 Mar 2012 09:43:03
Message: <4f50dc77$1@news.povray.org>
Non-XHTML documents can and do contain non-ASCII characters.  What you
meant to say is that you can't use their XHTML representations outside
an XHTML document.  Case in point: a .DOCX file does not use é or
à but can most definitely contain the characters represented by
those entities.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 2 Mar 2012 23:37:53
Message: <4f51a021$1@news.povray.org>
No. Only XML documents which are also XHTML documents can use the XHTML
standard for specifying ASCII-only names for non-ASCII characters.
You *can* put non-ASCII characters in an XML document. That's what the first
line is for, with the hard-to-remember code numbers, remember? Different
standards can have different entities. If I want an XML entity that
represents the symbol for the left eyeball, or an XML entity that represents
a internal link to the document management system of google, I can do that
-- just not in XHTML. Look at the triglyphs for C-on-punched-cards. Same
sort of thing. They're only applicable to C.
> Sure, having more than one DTD doesn't make a lot of sense. (Except that it
> would be nice to apply different DTDs to different namespaces. But that has
> little to do with entities.) The problem is that character entities are in
So type the characters directly. Nothing stops you from embedding a thron or
an omega in your document except that you don't want to learn how to type
one on the keyboard you have.
> subtrees, surely?
You still have to have one DTD that says where the trees are allowed to join
up. There's nothing that says that DTD isn't trivial to construct from two
other DTDs.
> Write at XHTML document which contains some MathML. Unless you use the magic
> XHTML+MathML DTD, it doesn't work at all. Clearly it /should/, but it doesn't.
Sure. You have to have the right DTD, because MathML expressions can't
appear inside URLs, nor can they appear as a child of a <meta> link in the
header, etc. You have to know the rules of where each can appear in the
other if you want to actually check it's right.
> In summary, XML doesn't provide the necessary tools to solve common problems
It does. You just don't like the solution. It's like you're saying "Haskell
doesn't provide the necessary tools to incorporate C syntax into its type
declarations." No, they're completely different type systems.
Date: 3 Mar 2012 04:29:49
Message: <4f51e48d$1@news.povray.org>
Why would you want three different standard names for the same character?
> thron or an omega in your document except that you don't want to learn
> how to type one on the keyboard you have.
Well, for that matter, you can just type the Unicode code number
directly. (This at least works with all operating systems and text
editors, doesn't break every five minutes, etc.) It's just that
memorising large quantities of code numbers isn't exactly trivial.
>> subtrees, surely?
> join up. There's nothing that says that DTD isn't trivial to construct
> from two other DTDs.
Well, if it were possible for one DTD to import several others, then it
could be pretty easy... As it is, constructing even one DTD is so
insanely hard that only the professionals can do it.
>> problems
What, a combinatorial explosion of DTDs for every possible combination
of XML applications that you might ever want to combine? No, that's just
silly.
> "Haskell doesn't provide the necessary tools to incorporate C syntax
> into its type declarations." No, they're completely different type systems.
Not relevant, but: Actually Haskell does let you do this. There's a
standard preprocessor for exactly this task. People use it when binding
to external C or C++ libraries.
Date: 3 Mar 2012 15:47:59
Message: <4f52837f$1@news.povray.org>
What's the chinese word for "quotation mark"? For that matter, why would you
even want a "name" for a character, unless your text editor is too lame to
actually store the character? Leap-frog into the 21st century and start
using Windows Notepad to edit your text or something.
> Well, for that matter, you can just type the Unicode code number directly.
> (This at least works with all operating systems and text editors, doesn't
> break every five minutes, etc.) It's just that memorising large quantities
Right. So you're complaining that XML is broken because your text editor
can't handle Unicode?  Just type the unicode characters directly into the
text document, without using any code numbers.
> could be pretty easy... As it is, constructing even one DTD is so insanely
... says the man who programs in Haskell. ;-)
You don't really have to *import* DTDs. You can pretty much just concatenate
them, as long as there aren't conflicting definitions, and fix up only the
places where they actually interact. I mean, if you have some java-specific
XML (say, a build system), and you want to embed SVG into that (say, to
define the splash screen for the completed program), your build system is
going to have to understand how to interpret SVG.
> What, a combinatorial explosion of DTDs for every possible combination of
> XML applications that you might ever want to combine? No, that's just silly.
Why not? You get a combinatorial explosion of types in your computer
programs for every new program you write.
Generally, your XML processor has to understand the combination you're using
anyway, so it's not really obvious there's a problem here. It's not like
you're going to combine SEP and XHTML in one program and expect to not do
more work than frobbing around the DTD.
Date: 3 Mar 2012 17:05:00
Message: <4f52958c$1@news.povray.org>
> you even want a "name" for a character, unless your text editor is too
> lame to actually store the character? Leap-frog into the 21st century
> and start using Windows Notepad to edit your text or something.
It's not possible to type exotic characters. But it's trivial to type in
their names.
...aaaand then watch it break into a thousand pieces because raw text
files have no way of specifying what actual character encoding is being
used. :-P
The problem is, the only real documentation on how to write DTDs is the
antiquated SGML reference documentation, which is hardly easy going.
 From what I've seen from other written DTDs, it's just damned hard,
that's all.
>> silly.
Actually... no, you don't.
In any half-decent language, you can implement sorting and searching.
Once. In a language that's not so good, you have to reimplement this for
every individual datatype. And that's what the DTD situation feels like;
endlessly reimplementing the same language specs over and over again.
And these aren't exactly trivial languages... It would be frighteningly
easy to come up with an XHTML+MathML DTD where the XHTML part doesn't
actually match the stand-alone XHTML DTD, for example.
Date: 3 Mar 2012 19:08:03
Message: <4f52b263$1@news.povray.org>
Sure it is. I just turned on chinese for my wife. Use alt-shift to toggle
between languages. :-)
The problem is that your *editor* doesn't make it simple to type exotic
characters, yes? Why do you complain that your XML processor doesn't
understand exotic characters when its your editor that makes them difficult
to type?
> ...aaaand then watch it break into a thousand pieces because raw text files
> have no way of specifying what actual character encoding is being used. :-P
That's why the first line of your XML document includes the character set in
which the rest of the document is written. *right there* is the reason you
have to put <?xml ...> at the start, along with the funky code number for
your character set.
> antiquated SGML reference documentation, which is hardly easy going. From
> what I've seen from other written DTDs, it's just damned hard, that's all.
It's actually pretty straightforward. Google "dtd tutorial".
> It would be frighteningly easy to come up with
> an XHTML+MathML DTD where the XHTML part doesn't actually match the
Sure. And it would be frighteningly easy to come up with a generic sorting
algorithm that works incorrectly on certain types. Don't do that.
The point is that a DTD is a type specification. It also originally
specified what closing tags could be left out by specifying what could be
nested inside what. (You don't have to close a paragraph in a book if the
next tag opens a new chapter, because chapters don't nest and paragraphs
can't contain chapters.)
So don't use a DTD. Use an XSL or whatever they call it these days.
Date: 4 Mar 2012 12:07:44
Message: <4f53a160$1@news.povray.org>
> toggle between languages. :-)
That doesn't make the characters available on your keyboard though. It's
not like you can just press a button and have a different set of
characters printed on your physical keyboard.
> difficult to type?
It's not the editor that makes them hard to type. It's the fact that
computer keyboards only have a few hundred keys, not several billion
keys. (Heck, even then it would be pretty difficult to actually /find/
the one you want...)
In most situations, that just means that you flat-out /can't/ use
unusual characters. HTML, and now XHTML, are fairly unusual in that they
let you type in the character's name if you can't easily type the
character itself. Unfortunately, rather than make this useful feature
available to all XML applications, they arbitrarily chose to make it
available to only one.
>> files
>> used. :-P
> set in which the rest of the document is written. *right there* is the
> reason you have to put <?xml ...> at the start, along with the funky
> code number for your character set.
That tells an XML processor what the character encoding is. It does not
tell your text editor what the encoding is.
> sorting algorithm that works incorrectly on certain types. Don't do that.
The point is, to make a DTD for a combination of trees, you have to
/copy/ the DTDs for each subtree - and hope that you don't do it wrong.
Talk above violating the DRY printiple...
Date: 4 Mar 2012 14:50:20
Message: <4f53c77c$1@news.povray.org>
On 3/4/2012 9:07, Orchid Win7 v1 wrote:
> That doesn't make the characters available on your keyboard though. It's not
> like you can just press a button and have a different set of characters
Actually, you can, yes. http://www.lcd-keys.com/english/history.htm
> computer keyboards only have a few hundred keys, not several billion keys.
And yet, oddly enough, billions of chinese people seem to get along OK.
It's still the case that you're addressing the wrong technology. The file
itself has no trouble storing the characters, yet you want the file storage
technology to compensate for your computer's inability to put the characters
into the file conveniently.
Fix your input mechanism, and store the characters. Don't fix every program
that reads characters to deal with names. Fix your *editor* to deal with
names. Make it so when you type &acut; into your editor, it replaces it with
the right unicode character. Problem solved.
> type in the character's name if you can't easily type the character itself.
Why doesn't your editor do this?
> Unfortunately, rather than make this useful feature available to all XML
> applications, they arbitrarily chose to make it available to only one.
Because different XML applications need different character entities.
> That tells an XML processor what the character encoding is. It does not tell
So always use UTF-8 or something. Or write your editor to recognize an XML
header and parse it.
> The point is, to make a DTD for a combination of trees, you have to /copy/
> the DTDs for each subtree - and hope that you don't do it wrong. Talk above
But to *use* a DTD for a combination of trees, you have to implement an
entire program to do so. So the actual concatenation of two files is rather
simple, comparatively speaking.
Date: 4 Mar 2012 21:05:40
Message: <4f541f74$1@news.povray.org>
Am 04.03.2012 18:07, schrieb Orchid Win7 v1:
That /may/ depend on your keyboard...
http://www.artlebedev.com/everything/optimus/maximus/
Did anyone already mention that they did /not/ "arbitrarily" choose "to
make it available to only one", but rather /deliberately/ chose to make
it availabe to /this/ one (despite the general decision to keep the XML
set of character entities simple), because "we'll never get people to
convert from HTML if they can't do this in XHTML"?
>>> files
>>> used. :-P
How about rephrasing this: "It does not /necessarily/ tell your text
editor what the encoding is."
What part of "get a decent text editor" didn't you understand? :-P
... which is why there is XML Schema. And XML namespaces.
Date: 5 Mar 2012 03:53:46
Message: <4f547f1a$1@news.povray.org>
Can you name one single text editor which can actually change character
encoding based on a mere XML encoding specification?
Date: 5 Mar 2012 08:25:45
Message: <4f54bed9$1@news.povray.org>
I would bet emacs does it, since it does everything, including sorting
laundry and fixing tires.
But seriously, though, http://www.lmgtfy.com/?q=xml+editors
Date: 5 Mar 2012 13:19:11
Message: <4f55039f$1@news.povray.org>
Yeah. But then I'd have to use Emacs...
Right. Because my text editor only needs to edit XML. Oh, wait...
In all seriousness though. I could probably just configure my editor to
always use UTF-8. That still doesn't solve the problem of typing obscure
characters in the first place. And it still doesn't change the fact that
as soon as I open the file in any other program, it's going to break
because that other program doesn't know what the hell character encoding
to use.
Date: 5 Mar 2012 13:51:17
Message: <4f550b25$1@news.povray.org>
Am 05.03.2012 09:54, schrieb Invisible:
The integrated text editors of both MS Visual Studio 2010 and
BeyondCompare 3.0 definitely do it (and yes, I'm talking about plain
"ASCII" text editors, not dedicated XML editor components).
As for stand-alone text editors, I've not used any for years, but I
wouldn't be surprised if current versions of e.g. UltraEdit would be
doing this as well (it does have some "auto-detect UTF-8 encoding"
option after all, though I can't find any details about the magic used
in there).
Date: 5 Mar 2012 14:10:57
Message: <4f550fc1$1@news.povray.org>
Am 05.03.2012 19:19, schrieb Orchid Win7 v1:
Did you know that good text editors allow you to define your own fancy
keystroke combinations? So you can place your favorite special
characters on some easily memorizable combo of Alt-Shift-Explode or
whatever suits your needs.
> to use.
That's plain stupid nonsense. A non-UTF-8-aware text editor (or any
other piece of software capable of processing extended-ASCII text files)
confronted with a UTF-8 text file will display apparently random stuff
in place of any non-ASCII characters, but that random stuff saves fine,
and parses back as later UTF-8 without problem. Just make sure you don't
insert non-ASCII characters in the troublesome editor, and don't insert
anything into that random stuff.
This property is one of the fun things about UTF-8: Anything that can
handle at least /one/ extended-ASCII codepage can also handle UTF-8
transparently without even knowing.
(You /will/ get into trouble though if your <?xml ...?> declaration
doesn't match the actual character encoding of the file, but I guess
that should be obvious.)
Date: 5 Mar 2012 16:01:59
Message: <4f5529c7$1@news.povray.org>
On Mon, 05 Mar 2012 20:10:56 +0100, clipka wrote:
> Alt-Shift-Explode
I need a keyboard that has that as an option on it. :)
Jim
Date: 5 Mar 2012 22:13:44
Message: <4f5580e8$1@news.povray.org>
Actually, I'd be happy if once, once in my career, someone would provide me
"an XML feed" that could actually be parsed by an XML library without first
having to do a bunch of string crap to it to make it right.
Date: 5 Mar 2012 22:15:57
Message: <4f55816d$1@news.povray.org>
I expect you could set up vim to do it, since you can set it up to recognize
Python, Bash, etc.
Date: 9 Mar 2012 15:50:01
Message: <web.4f5a6cccc07fe63964c6b3fb0@news.povray.org>
> >> supposed
> >> long,
> First, you must say
Gaah! No! Use UTF-8! 8859-1 is Western European/United States only! Any
characters that are not in this set will be rendered as ? or worse. UTF-8 gives
access to the whole of the Unicode codeset, so no data will be mangled by the
encoding. Sorry, I'm a big proponent of using a more universal character set,
especially when handling data.
Yeah, the DTD is a bear; what you do is set up a starting point and use that so
you don't have to remember the DTD all the time.
You set a doctype processing instruction that gives a web browser information on
how to handle your document, remember, HTML comes in many different flavors.
Your xhtml document is an xml document. The xmlns attrubute is specifying that
this document should conform to the specifications of the xhtml standard. I
think this is actually optional, but allows better validation. This uses an xsd
file which defines the schema.
Meh. You create a starter file and copy that when you want to do an xhtml file.
Because sgml is a standard that allows a large amount of flexibility in what it
actually is.
> >> one
> >> inside
> >> that.
Thing is, the DTD and schema can be defined anywhere. That's why all of the
clunky URL's.
Date: 9 Mar 2012 15:55:01
Message: <web.4f5a6d50f77903f464c6b3fb0@news.povray.org>
Le_Forgeron <lef### [at] freefr> wrote:
> Le 23/02/2012 10:11, Invisible a écrit :
> > This still leaves me with the problem of how to generate unusual
> > characters in the first place. Typing → is pretty simple. Figuring
> > out how to actually generate the arrow character is not.
> You just need the right documentation.
> Either you search it each time on the web (like "utf-8 chartable"... )
> or you call it correctly, and ask for unicode (utf-8 is one
> presentation, unicode is what you really want), and get to print the
> parts that you need often.
> See http://unicode.org/charts/
> And soon you will discover that there is no single font to display all
> possible unicode glyphs.
> You also need a unicode-compatible editor...
Code2000 comes close for Plane 1... The higher planes are a different story
alltogether, but most of those are rather specialized anyway.
Date: 9 Mar 2012 15:56:10
Message: <4f5a6e6a@news.povray.org>
  Nothing stops you from using &#xx; codes regardless of the encoding.
Date: 9 Mar 2012 16:00:00
Message: <web.4f5a6e76f77903f464c6b3fb0@news.povray.org>
> OK, so I've written a program that generates a bunch of XML as output.
> If you open that in a web browser, it shows up as a simple parse tree.
> Which is OK, but a little verbose.
> Fortunately, using the wonders of XSL (specifically, XSLT) you can have
> the browser transform the raw XML into a pretty-looking XHTML document.
> But *only* if you edit the original XML file to mention the XSLT file
> that you want to apply.
> Now, it ought to be simple to write a 3-line file that says "take this
> XML file and that XSLT file, and display the result". But after over a
> week searching the Internet and even consulting Stack Overflow, I cannot
> find any way of doing this. I literally cannot *believe* that something
> so trivially simple is also so utterly impossible.
> If there /is/ a way of doing this, every single XSL tutorial in
> Christendom fails to mention it. No XSL FAQs mention it either - it's
> not even that they say it can't be done, it's that none of them even
> contain a question about this topic. This raises the alarming
> possibility that what I'm trying to do might actually be impossible
> after all. (Which is slightly daft, given that it's the entire point of
> XSL existing in the first place...)
> To be clear: It seems to be perfectly possible to apply any XSL to any
> XML if you use an external 3rd-party tool. You just can't do it with a
> *web browser*. You know, those programs that know about XML and XSL and
> are installed on every computer in the world. No, you have to select and
> download a special CLI utility if you want to perform such advanced
> wizardry. *sigh*
> My first thought: XSL lets you include one stylesheet inside another, so
> maybe you can include one source document inside... erm, no. No you can't.
> It looks like it /might/ be plausible to do something with the XSL
> document() function - but I haven't figured out exactly how yet.
> Apparently XML itself has a general include feature called XInclude.
> According to Wikipedia, "Browser support: None". *facepalm* OK, so
> that's really going to help then.
> About the closest thing I've found is a website that says that if you
> copy and paste a few miles of convoluted JavaScript code, you can make a
> web page that runs the script which then loads the required XML in the
> background, lots the XSL, applies one to the other, and inserts the
> result into a specific position in the DOM of the current document. In
> particular, it cannot /replace/ the current document, it can only be
> /inserted into/ it. So if your XSL generates an entire XHTML document...
> forget it.
> (I presume it goes without saying that the first thing this code snippet
> has to do is test whether it's running on Internet Explorer or a
> standards compliant browser. :-P Some things never change...)
> So it looks like I'm going to have to sit down and write a special tool
> to take an XML file and copy it, inserting the correct XSL reference
> into the header. How pathetic...
I coded one up in C# in about 15 minutes. It doesn't take much if your language
of choice already has a library for handling xml/xslt.
I found this post rather interesting as my current project is one big stylesheet
to turn raw xml into a legible report. I've learned just how powerful the
language is. There's a ton you can do with it, and I now wonder why everyone
always moans and groans about how difficult it is to deal with.
Date: 9 Mar 2012 16:37:09
Message: <4f5a7805$1@news.povray.org>
On 09/03/2012 20:56, Warp wrote:
>    Nothing stops you from using&#xx; codes regardless of the encoding.
Correction: The finite limitations of the human mind stop you using hex
codes. :-P
Date: 9 Mar 2012 16:38:18
Message: <4f5a784a$1@news.povray.org>
Tell it to [every piece of Windows software that inspects text files].
All of these programs seem to default to that encoding, not UTF-8.
Date: 9 Mar 2012 16:43:15
Message: <4f5a7973$1@news.povray.org>
It only takes 15 /seconds/ to type in a command if you have a 3rd party
external XSLT processor (e.g., Saxon). But apparently you can't get the
/web browser/ to do this. You have to create a new, separate,
transformed version of the file.
It might not sound like much, but it means every time you change the
program that generates the XML, you can't just rerun that program. You
have to rerun the program, and then rerun Saxon (or whatever), and then
reload the browser page. It's a PITA.
What I ended up doing, obviously, was providing a way to change the XSL
reference that the original program inserts into the XML file. :-P
[I presume you're talking about XSLT here.]
It's interesting that there's one set of facilities for processing the
input functionally, and a separate, redundant set for processing it
imperatively. The latter set is much less powerful to boot. (Perhaps
that was deliberate.)
What I can't figure out is this: How do I make it process an element one
way if it contains a "small" amount of content, and process it a
different way if it contains a "large" amount of content?
Date: 9 Mar 2012 20:06:35
Message: <4f5aa91b$1@news.povray.org>
> codes. :-P
step 1: www.google.com
step 2: "unicode chart for _____ characters"
step 3: File | print
step 4: Tape to side of computer screen.
Back when dinosaurs roamed the Earth, that's what most of us did for
DOS-based editors when we needed accented characters, or for the more
daring, ASCII graphics.
Date: 9 Mar 2012 20:07:58
Message: <4f5aa96e$1@news.povray.org>
Change your local settings to Bulgaria or Czech Republic and it won't!
Date: 10 Mar 2012 04:23:01
Message: <4f5b1d75$1@news.povray.org>
Won't default to UTF-8? Yes, I know. ;-)
Date: 19 Mar 2012 12:21:27
Message: <4f675d07$1@news.povray.org>
This is true, but, in general, UTF-8 is the better way to go, but if the
data displayed on the page comes form a different source...
Date: 19 Mar 2012 12:23:23
Message: <4f675d7b$1@news.povray.org>
That's because nobody bothers with the encoding. But what drives me nuts
is when web-authors stick in an encoding, then use UTF-8 characters in
it. You get all sorts of ugliness.
Date: 19 Mar 2012 12:27:38
Message: <4f675e7a$1@news.povray.org>
Use xsl:choose and have the when statements with the appropriate test?
I'm unclear as to what constitutes a small amount of content v.s. a
large amount of content.
You could have it trigger on the string-length of the node's value, for
instance. Or, you could trigger on the number of nodes (using count)
