POV-Ray : Newsgroups : povray.off-topic : The trouble with XSLT Server Time
28 Jul 2026 13:18:46 EDT (-0400)
  The trouble with XSLT (Message 11 to 20 of 84)
Subject: Re: The trouble with XSLT
Date: 21 Feb 2012 05:26:20
Message: <4f43714c@news.povray.org>
>> Fortunately, using the wonders of XSL (specifically, XSLT) you can have
>> the browser transform the raw XML into a pretty-looking XHTML document.
>> But *only* if you edit the original XML file to mention the XSLT file
>> that you want to apply.
> Why does this come as such a surprise to you?
> Remember that the same thing is common practice for HTML and CSS as
> well: If you want the HTML to be rendered using a particular style
> sheet, you'll usually specify that in the HTML header.
Well, what you say is of course true.
Then again, CSS just applies a few font settings to an HTML file. XSL
transforms one file into a totally different one. If every single time
you open that file you're always going to apply the same transformation,
you might as well just not bother keeping the original file, and only
store the transformed version. It completely defeats the whole purpose
of XSL.
Actually, no, that's not /completely/ true. If several files all use the
same XSL, then changing that one XSL file immediately changes /all/ of
the files that use it.
Even so, XSL is clearly crying out for the ability to apply more than
one XSL file to the same source file. And indeed you can trivially do
that - just not with a web browser, unfortunately.
> I'm not sure whether all modern browsers support client-supplied CSS,
> but I wouldn't be surprised if there were still some out there that
> don't. For instance I have no idea how to choose a custom CSS in
> Firefox; you can disable all CSS, or choose which of multiple
> server-supplied CSS to use, but that seems to be about it.
I only recently discovered that Firefox even has a UI for changing the
CSS. ;-) (Or turning it off, for that matter.) I have no idea whether
you can supply your own CSS; isn't that an optional feature of the spec?
There's probably a way to do it, but there might not be a UI. (E.g.,
there may be something hidden in about:config somewhere.)
Date: 21 Feb 2012 08:44:05
Message: <4f439fa5$1@news.povray.org>
Le 2012-02-21 04:12, Invisible a écrit :
>>> So it looks like I'm going to have to sit down and write a special tool
>>> to take an XML file and copy it, inserting the correct XSL reference
>>> into the header. How pathetic...
>> That's merely a shell-script:
>> 1. find the closing of the first<?xml tag
>> 2. insert your xsl tokens
>> 3. copy verbatim the remaining document
>> 4.
>> 5. Profit.
> How the heck do you do that from a shell script?
> ...oh, wait. You probably meant a /real/ shell, not CMD.EXE, right?
1. write the program that will do it using your favorite language
(*cough*Haskell*cough*) and name it BAR.EXE
2. FOR %FOO in (*.xml) DO TYPE %FOO | BAR > new%FOO
Assuming BAR.EXE reads from stdin and output to stdout, this will run it
against all the .xml files in the directory and create a second set
called new*.xml
Alternately, find Win32 versions of awk, sed, perl, or something like that.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 21 Feb 2012 08:58:22
Message: <4f43a2fe$1@news.povray.org>
and positioning, and size, and background image, and whether the object
shows up at all on a particular media, etc... but let's not let that get
in the way of a good argument.
> XSL
> of XSL.
You can override server-side CSS in Firefox by putting stuff in [your
profiledir]\Chrome\userContent.css.
Date: 21 Feb 2012 12:14:07
Message: <4f43d0df@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Sure, that works. But now suppose I have /more than one/ XSL file. In
> order to select which one I want applied, I have to actually edit the
> XML file.
  What do you expect? For the XML file to read your mind?
Date: 21 Feb 2012 14:25:28
Message: <4f43efa8@news.povray.org>
>> XML file.
No, I wanted to put that information into a separate file, that's all.
It's not a complex idea.
Date: 21 Feb 2012 15:40:07
Message: <4f440127@news.povray.org>
> >> XML file.
  Create an xml file that includes (using XInclude) the other XML file
you want as well as the xsl file?
Date: 21 Feb 2012 21:55:35
Message: <4f445927$1@news.povray.org>
Am 21.02.2012 11:09, schrieb Invisible:
>> The spec concludes that "Since disabling output escaping may not work
>> with all XSLT processors and can result in XML that is not well-formed,
>> it should be used only when there is no alternative."
> Ah. So in fact, the W3C specification is broken, since /clearly/ a
> system should not be specified to suddenly produce completely incorrect
> output if an optional feature is not implemented.
That's why they warn about this possible difference, so that the user
can decide whether to (a) make sure that the XSLT file is only used with
an XSLT processor that supports the feature, or (b) make sure that the
output is not *completely* incorrect if the feature is unavailable.
That's not broken spec, that's just perfectly normal optional features.
> Meanwhile, it looks like my only options are either to start memorising
> Unicode code points by ID, or to save my XSL file as UTF-8 and watch the
> encoding get screwed up every time I touch the file...
Ah, so your /real/ problem is a crappy text editor.
> (Let's not even get into the question of why the standard character
> names /only/ work in HTML, and not all SGML file types...)
Because they're a HTML-specific invention?
Date: 22 Feb 2012 04:04:13
Message: <4f44af8d$1@news.povray.org>
>>>> XML file.
That's a great idea. Except that apparently no browser supports XInclude
yet. As I pointed out in my original post.
Date: 22 Feb 2012 04:07:53
Message: <4f44b069@news.povray.org>
It's a broken spec, in that it provides no way to design a transform so
that if DEO is not implemented, the output still looks sane. There isn't
even a way to say "sorry, the required feature is not available".
Instead, it just prints random gibberish without telling you or giving
you any chance to correct it.
The /real/ problem is that there is no way of knowing what encoding a
given text file has. So it's not safe to use non-ASCII characters in a
text file. Which is why character entities were invented in the first
place...
Um, why?
It's not like only HTML could possibly need non-ASCII characters.
Date: 22 Feb 2012 15:42:12
Message: <4f455324@news.povray.org>
Am 22.02.2012 10:07, schrieb Invisible:
> place...
Use an editor that places a BOM at the start of UFT-8 files and bob's
your uncle.
