POV-Ray : Newsgroups : povray.off-topic : Today's annoyance Server Time
27 May 2026 13:49:26 EDT (-0400)
  Today's annoyance (Message 1 to 10 of 10)
Subject: Today's annoyance
Date: 9 Feb 2012 09:23:21
Message: <4f33d6d9$1@news.povray.org>
Under Unix, if you say
   rm file1
it deletes the specified file. If you say
   rm folder1
it deletes the specified folder. So far so good, eh?
Now consider CMD.EXE, the Windows NT command processor. If you do
   DEL file1
it deletes the specified file. If you now say
   DEL folder1
it asks you "are you sure?". If you add the /Q switch, it will just
delete the folder... hahaha! No, it won't. Actually, it merely deletes
the /contents/ of the folder. Actually, you know what? No it doesn't. It
deletes the /files/ within the folder. Unless you add /S (recursive
delete), in which case all files in all folders are deleted, but the
folders themselves remain.
In order to /actually/ delete a folder, you must do
  RMDIR folder1
Oh, but that fails if the folder is not empty, so you must add /S. Oh,
but that asks for confirmation, so you must add /Q as well.
Short version: To delete an object, you must know whether it is a file
or a folder. Thanks for that... :-P
Special bonus for failing to document this fact anywhere. (E.g., the
manual for DEL doesn't mention that there's an RMDIR command.)
Subject: Re: Today's annoyance
Date: 9 Feb 2012 12:15:01
Message: <web.4f33fedecfe4adb6773c9a3e0@news.povray.org>
>    rm file1
>    rm folder1
>    DEL file1
>    DEL folder1
>   RMDIR folder1
there actually is rmdir in Unix too.  And rm dir will only work with the -r
recursive switch.  Unless you simply use rmdir dir, that deletes dir and all.
Date: 9 Feb 2012 14:15:19
Message: <4f341b47$1@news.povray.org>
I think -r for "recursive" is more logical than /S, but whatever. And
isn't it -rf actually? I seem to recall that otherwise it asks for
confirmation...
I've never seen nor heard of rmdir.
Date: 9 Feb 2012 14:38:17
Message: <4f3420a9@news.povray.org>
>> the -r recursive switch.  Unless you simply use rmdir dir, that deletes
>> dir and all.
> confirmation...
/S = subtree
Jim
Date: 10 Feb 2012 07:48:20
Message: <4f351214@news.povray.org>
  Actually rmdir will remove a directory only if it's empty.
Date: 10 Feb 2012 07:49:43
Message: <4f351267@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> And isn't it -rf actually? I seem to recall that otherwise it asks for
> confirmation...
  The -f is just to force it to remove files that wouldn't be removed
otherwise (without that flag). This is a relatively rare circumstance,
but unix people write it nevertheless as a matter of course.
Date: 10 Feb 2012 17:37:41
Message: <4f359c35@news.povray.org>
Way back to the DOS era, you had deltree that would suppress a directory
and all it's content including any sub-directory.
I think, not sure, that it could be used without a following directory
name, and would suppress the content of the current directory... Prety
dangerous if isued from the root.
Also, in DOS, rd dir suppressed a given directory.
Date: 10 Feb 2012 23:10:53
Message: <4f35ea4d$1@news.povray.org>
On 2/9/2012 6:23, Invisible wrote:
> rm folder1
No it doesn't.
> Oh, but that fails if the folder is not empty, so you must add /S. Oh, but
Other than the confirmation, this is all identical to how unix works. "rm"
doesn't delete directories on unix unless you add "-r".  Unix has an rmdir
command.
> Short version: To delete an object, you must know whether it is a file or a
Or you could run both commands.
   People tell me I am the counter-example.
Date: 10 Feb 2012 23:11:47
Message: <4f35ea83@news.povray.org>
It also stops it from complaining if the file isn't there, fwiw.
Date: 11 Feb 2012 00:43:41
Message: <4f36000d$1@news.povray.org>
This is I normally see it used.  Tangentially, this reminds me of the
time I typed
rm * .txt
in my home directory.  Thank goodness I didn't add the -rf flag!
