POV-Ray : Newsgroups : povray.off-topic : Recursive testing Server Time
14 Aug 2026 11:23:46 EDT (-0400)
  Recursive testing (Message 1 to 7 of 7)
Subject: Recursive testing
Date: 8 Feb 2012 06:14:32
Message: <4f325918@news.povray.org>
It's slightly bizarre when you build a new test framework, and have to
build a /second/ test framework to test the first one!
Also: Apparently "inception" now means "recursion". :-P
Subject: Re: Recursive testing
Date: 8 Feb 2012 12:05:01
Message: <web.4f32aa3128cd7fb2352a052d0@news.povray.org>
obviously you need to test your tests to make sure they will test ok.
did you watch the movie, BTW?
Date: 8 Feb 2012 16:18:31
Message: <4F32E6AA.2020207@gmail.com>
It is a pity you never read Goedel Escher Bach.
tip: do not run in an unknown place when it is too dark to see the
floor, unless you prefer to not use uppercase.
Date: 9 Feb 2012 04:19:13
Message: <4f338f91@news.povray.org>
Yeah, well, it's a general-purpose testing library. So obviously I want
to make sure it works correctly. The daft thing is, there's no automated
way to do that; I built a big automated system that makes it generate
lots of test logs, and then I manually look at each one to check that
the test output matches the test spec.
Yeah. It wasn't as great as I had imagined.
Date: 9 Feb 2012 04:19:52
Message: <4f338fb8@news.povray.org>
Never read /all/ of GEB. I read some of it, and eventually got so bored
that I couldn't be bothered to finish it. It's actually sitting a few
feet away from me right now...
Date: 9 Feb 2012 04:49:45
Message: <4f3396b9@news.povray.org>
Or possibly "meta". As in the new word "failception", which means
"meta-failure". :-P
Date: 10 Feb 2012 03:21:18
Message: <4F34D385.2000106@gmail.com>
Among the parts you did read is the Bithday Cantatatata? (I assume that
is what it is called, I only have a Dutch translation at hand)
