POV-Ray : Newsgroups : povray.off-topic : Deblurring Server Time
16 Jun 2026 13:23:01 EDT (-0400)
  Deblurring (Message 11 to 20 of 20)
Subject: Re: Deblurring
Date: 2 Dec 2011 10:08:08
Message: <4ed8e9d8$1@news.povray.org>
On 12/2/2011 7:01 AM, Invisible wrote:
> On 02/12/2011 02:40 PM, Kevin Wampler wrote:
>> On 12/2/2011 2:30 AM, Invisible wrote:
>>> (As an aside, where the HELL do you obtain the sited paper from? Unless
>>> you work in a research laboratory, I can't figure out how the hell you
>>> would obtain a copy of this...)
>> Probably by using the subtle and mysterious technique of typing the
>> paper's name into Google and clicking on the top link:
> I tried typing the journal's name in...
That was your mistake then.  Always try searching for the name of the
paper first.
Date: 2 Dec 2011 10:11:21
Message: <4ed8ea99$1@news.povray.org>
> paper first.
The journal's name is short, while the paper's title is long. Searches
don't work properly for long phrases, only short ones.
Perhaps the author's name would have worked. (Although it's very
difficult to spell...)
Date: 2 Dec 2011 10:21:00
Message: <4ed8ecdc$1@news.povray.org>
not true
copy and paste
Date: 2 Dec 2011 10:29:26
Message: <4ed8eed6@news.povray.org>
> not true
In my experience, the more specific the search term, the lower the
probability of Google returning any matches at all.
> copy and paste
For reasons unknown, the appendix is normal, selectable text, but the
references section at the end of it is a [low resolution] bitmap image
of some text. WTF?
Fortunately, this particular citation is repeated on the body text. (I
didn't realise that until I wrote this post.)
Date: 2 Dec 2011 10:35:21
Message: <4ed8f039$1@news.povray.org>
>> not true
Blimey man, just take the advice.  If you want to find a paper try
putting the paper's title into Google.  It worked on this one and it'll
work on many others too.
Date: 2 Dec 2011 11:01:44
Message: <4ed8f668$1@news.povray.org>
Am 02.12.2011 16:11, schrieb Invisible:
>> paper first.
Apparently you're wrong there.
Remember to put long phrases in quotation marks, so that Google actually
searches for the phrase rather than the individual words.
Date: 2 Dec 2011 11:05:27
Message: <4ed8f747$1@news.povray.org>
>>> paper first.
Ironically that doesn't work in this case (although in most cases it's
still a good idea).  The reason is that the title as Invisible posted it
had the word "an" at the beginning which doesn't appear in the actual
title of the paper.  Only a search without the quotations seems to yield
the correct result. Fortunately the solution is trivial: if searching
with quotations doesn't work, try it without.
Date: 2 Dec 2011 11:17:16
Message: <4ed8fa0c$1@news.povray.org>
> http://optics.nuigalway.ie/people/chris/chrispapers/Paper046.pdf
Oh... Well that was easy. The whole thing is only 3 pages, and written
in language that a DSP novice can understand. (Although some of the
notation still baffles me.)
Date: 2 Dec 2011 14:52:28
Message: <4ed92c7c$1@news.povray.org>
On 12/2/2011 7:11, Invisible wrote:
> The journal's name is short, while the paper's title is long. Searches don't
What are you smoking.
Anyway, paste the entire abstract in, and it'll likely work too.
   People tell me I am the counter-example.
Date: 5 Dec 2011 11:51:04
Message: <4edcf678@news.povray.org>
So today I sat down and implemented the algorithm. I was unsurprised but
rather disappointed to discover that IT DOESN'T WORK.
I tried it on an artificially simplified 1D example. Invented a fake
signal, convolved it with a simple filter kernel, and then let the
algorithm try to recover the original signal. The end result bore
absolutely no resemblance to the original.
It's possible that 44 samples just isn't enough for a reasonably unique
solution to exist. More likely I've implemented the DFT wrong or
something...
