POV-Ray : Newsgroups : povray.off-topic : Web frameworks Server Time
3 Aug 2026 06:01:37 EDT (-0400)
  Web frameworks (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Web frameworks
Date: 19 Nov 2011 01:30:57
Message: <4ec74d21@news.povray.org>
On 11/18/2011 1:43, Invisible wrote:
> Well, yeah, and Haskell has defence contractors, investment bankers,
> cryptographers and IC designers using it. AND NOBODY GIVES A DAMN. :-P
Sure. But average people don't see that. It's easy to point to the phone
system and say "See? Doesn't crash." :-)
> And hence, I thought you might be interested to see how a couple of tools
> approach [or ignore] the problem. I know I was...
Indeed I was. Thanks for that.
> On the plus side, this is Haskell. Sometimes the type signature is enough to
> actually tell you WHAT THE CODE DOES. That's a pretty amazing property,
> which few other languages have.
Actually, I think perhaps Hermes does even better, in some senses, because
it has typestate. So you can say things like "This returns a record where
either the array of results has more than one entry and the error code
hasn't been assigned, or the error code has been assigned and the rest of
the results have not."  Maybe you can do that with the Maybe bit of Haskell
or something, tho.
> On the other hand, sometimes the type signature DOES NOT tell you what the
> code does. And then not having any *real* documentation utterly sucks.
That's always the problem yes.
> Also, Haskellers have this bizarre perversion where some people think that
> describing the axioms that a structure satisfies as the same thing as
> explaining WHAT IT DOES, WHY THAT'S USEFUL or HOW YOU USE IT. :-P
Not uncommon. I prefer both, myself. Lazy vague prose doesn't work as
documentation either.
>> This is how most systems that compile templates work, including Java and
>> ASP.NET.
> I've never heard of a system which actually /compiles/ templates.
Any template system written in a compiled language, like ASP.NET.
Heck, GWT takes Java code and compiles the half that runs on the browser
into optimized javascript.
> I'm not seeing how type erasure is in any way related to the ability or
> inability to dynamically load new code.
If you don't know what types are in the code you're loading, how do you load it?
>> And ASP.NET even notices
>> the executable changed and reloads it (or notices the source changed and
>> recompiles it and reloads it), letting existing transactions finish and
>> new transactions power up the new code.
> Well, yeah, the Yesod scaffolder sets things up so that if you change any
> code, and then restart the server, it recompiles anything first.
Right. I'm saying ASP.NET does the Erlang thing, where it lets existing
transactions finish with the old code while new transaction (i.e., hits)
gets the new code. You don't have to restart anything, lose any session
state, close any database connections, etc.
I'm not sure it works if you assume a new database schema, mind.
I'm sure both systems have their plusses and minuses. Don't read this as
"Ha, ASP.NET is better!"  I'm just pointing out that much of what you're
talking about isn't conceptually new, so don't embarrass yourself by talking
about this cool new Haskell stuff with an ASP.NET programmer. :-)
>> Very convenient for deployment, you must exist. If you're writing an
>> application (like, a wiki manager say), distributing it this way is an
>> excellent way of doing it.
> "You must exist"? What, I post, therefore I am? ;-)
You must admit, is what I meant to type.
> But yeah, it's probably quite nice for final deployment. I'm unsure what
> it's like for development.
Depends how fast it restarts. At least it isn't GWT, which takes 5 minutes
to recompile a simple page even given 1000 machines to compile on. :-)
>>> It also means that any time anything in any template changes, that
>>> template
>>> must be recompiled, and then the entire program relinked. And then you
>>> have
>>> to shut down the running server and fire up the newly compiled on.
>> Generally not a problem, really.
> Well, assuming you're not hacking up changes on your production box. (Why
> would you *ever* do that?)
If you can't afford downtime, but you only have one server, you're screwed
more than your development environment will ever screw you.
>>> All of which seems... a bit strange, to me. Then again, if you want to
>>> use
>>> Apache, you can build your application for Fast-CGI instead. Then only
>>> the
>>> application logic and presentation templates get linked into a giant
>>> binary
>>> blob, and you don't have to restart the entire server to update. It still
>>> seems like a rather heavyweight approach.
>> If you need better than that, you're probably doing it wrong anyway. Or
>> you should be using something like Erlang instead.
> I'm not sure I follow.
If restarting the server is a problem, and you don't have a second server
capable of taking care of the load while the first one restarts, then you're
utterly screwed the instant the power goes out, the hard drive dies, or the
power supply makes your RAM act flakey.
If "you have to restart the entire server to update" is a problem, then
you're screwed. You either have few enough customers that a few seconds of
down-time isn't a problem, or you're out of business at the first hardware
failure.
>>> worst thing that can happen is that you say UserProfile 138, and there
>>> *isn't* a user number 138 at the moment.
>> Or the user dicks with the URL and bypasses something in your code you
>> thought would be enforced.
> No, that's kind of the point. Each URL is checked against the list of valid
> URL structures. If it matches one, it gets passed off to that chunk of code.
> If it matches none, it's 404. (That includes checking that, say, the user ID
> *is* a valid number, and *isn't* negative, and so forth.)
As long as you can check everything the type system agrees to enforce
(which, thinking on it, I guess you can), then sure. As long as the user
doesn't change the user ID to the number of some other user, or a deleted
user, or something like that, or you can catch such a thing. I.e., it's not
a panacea.
> What it does mean is that you can take a string, insert it into a small HTML
> template, insert the small HTML template into a larger HTML template, and
> bolt on some other templates. The original string gets escaped before
> insertion. The HTML does /not/ get escaped when inserted into the rest. And
> so forth. All of which you /could/ keep track of manually, but it would be
> really easy to get it wrong...
Yep. That's what a good powerful type system can do for you that even
"strongly" typed machine-level (vs application-level) typing can't do.
> Yesod claims to be "RESTful". I have literally no idea WTF that actually
> means. (As best as I can tell, it's a philosophy, not something more concrete.)
Kind of, yes. REST means "Representative State" or something like that.
Basically, a URL refers to some "object" or "document", and the links to
other objects are embedded as URLs inside that document. I.e., the way HTML
and HTTP works. Rather than the way (for example) RPC works.
> Of course, desktop interfaces have always worked like this. It's news to me
> that anyone has ever successfully implemented this for a web interface,
> however.
It's pretty frighteningly gruesome.
>>> Again, I'm unconvinced of how well
>>> it really works, but I admire the idea.
>> Given that pretty much everyone in the world does it this way, yah, it
>> seems it's an idea that's here to stay. :-)
> Again, I've never seen it done on the web.
It's relatively recent stuff, and it takes an entire complex IDE cooperating
with the software stack to make it usable. But yah, it's common at the
"enterprise" level.
> 1. Every system I've seen makes it unnecessarily hard to use cookies.
> 2. I haven't seen a system which actually applies cryptography to the problem.
Yeah. Old stuff was like that. Newer stuff makes it easier. Just sayin'. :-)
Glad you're getting into it now, and I feel sorry for you if you ever *have*
to get into it. Because it means you've been sucked into the "web-app"
world, which is by far the kludgyest environment ever invented.
> ...which is why this is an interesting point to discuss.
Yep. Just making sure you realize that *was* what I meant, and now you're
experiencing it first-hand, as it were.
> This is precisely my point, and it seems to be lost on most people.
Agreed.
> If you want to store just the data your application uses, go ahead. Knock
> yourself out. You can just dump it all into a flat file. That works, right?
> And you can structure that file in whatever way is most efficient for your
> particular application.
That's what bugs me about all the folks that insist the flat files that UNIX
offer are the only thing you'll ever need, because everything else can be a
library. Because they never actually used a system that offered more and
realized that the universality of it was useful.
> And yet, everybody seems to think that a database is just a flat file, but
> better...
Only *most* people. :-)
> I'm definitely not Google. o_O
I mean, everyone writing code thinks they are going to be able to overwhelm
a 96-processor 16TB RAM SQL server machine with their app, to the point
where they need nosql storage for ACID data.
> It did amuse me how Yesod says that "by being non-relational, we gain more
> flexibility and the ability to avoid the overhead of table joins". Well, you
> know what? Table joins have overhead in time. But denormalised data has
> overhead in space. And redundancy. And you know what else? Every half-sane
> RDBMS optimises the **** out of table joins. You can even cache the result
> on disk if you want. And you know what? Then you have denormalised data,
> without any of the runtime overhead, but the database MANAGES THE REDUNDANCY
> FOR YOU! Whereas the alternative is to store all your data denormalised, and
> manage the redundancy yourself, manually. Oh, I hope you don't make a
> mistake. Because, let's face it, there's lots of opportunities to get it
> wrong...
Yep. *And* you're actually doing the joins. You're just doing it manually,
so you're not really avoiding any overhead. If you need the result of a
join, you're doing the join when you store instead of when you fetch.
The only time nosql really works is when you have data that you can shard
very specifically. When you have one user's emailbox for example, and you
can deal with that ACIDly, and not worry about the other users. Stuff like
accounting? Nope.
   People tell me I am the counter-example.
Date: 19 Nov 2011 08:43:10
Message: <4ec7b26e$1@news.povray.org>
Le 2011-11-18 09:18, Invisible a écrit :
>>>>> Erlang has Wings 3D.
>>>> Errr, no. Erlang has the north american telephone switching system. :-)
>> Aren't defense contractors all using ADA? Or did that change over the
>> last 10 years?
> "All" might be an exaggeration. But you're right, there's probably more
> of them using Ada than there are using Haskell...
It used to be a requirement for US DoD contractors, and since most NATO
countries shop at the same places, everyone was using ADA.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 19 Nov 2011 11:58:41
Message: <4ec7e041$1@news.povray.org>
Is it actually true that the /entire/ phone system is Erlang? I know
Ericson use it, but is it really running *everything*?
NP.
>> enough to
> because it has typestate. So you can say things like "This returns a
> record where either the array of results has more than one entry and the
> error code hasn't been assigned, or the error code has been assigned and
> the rest of the results have not." Maybe you can do that with the Maybe
> bit of Haskell or something, tho.
Well, it depends how far you want to go. There are people who have built
things like a library that statically checks that your client and server
speak an identical protocol, and there can never be a message mismatch.
Trouble is, the type signatures became insane, and it gives the compiler
a bit of a headache.
It's a question of degree, though. You already have the IO type, which
means "this function might perform arbitrary input/output operations",
the ST type which means "this function might use mutable state, but
cannot communicate with the outside world or other running threads", and
the STM type, which means "this function might use shared mutable
variables, but cannot perform I/O". You can take this further, if you
desire. Most people don't.
>> the
I should think that /any/ system is eventually going to come to a point
where you need real documentation. There are those who say "the source
*is* the documentation". But looking at Yesod, with almost 100 packages,
I wouldn't want to have to read all that lot to try to /guess/ what the
designer's intensions were. :-P
>> that
You could say
   "The fmap function must satisfy fmap id == id and fmap (f . g) ==
fmap f . fmap g". Or you can say "fmap applies a function to every
element of a container without affecting the structure of the container
itself". The latter tells you what the function is *for*.
It's also news to me that ASP.NET is compiled. I thought it was just
another scripting language.
That's pretty hardcore, right there.
> load it?
Doesn't seem to stop C. :-P
Well, yeah, being able to smoothly transition from one to the other is
much nicer. I suppose you might perhaps be able to do that by having
multiple physical servers and bouncing them one at a time? (I'm just
trying to think of obvious ways that might go wrong...)
> minutes to recompile a simple page even given 1000 machines to compile
> on. :-)
Compiling is pretty instant. /Linking/ seems to take a while. (Then
again, it's linking a 37MB binary...) I'll have to see what it runs like
interpretted.
> of down-time isn't a problem, or you're out of business at the first
> hardware failure.
Right, I see.
>> valid
>> code.
>> user ID
> deleted user, or something like that, or you can catch such a thing.
> I.e., it's not a panacea.
Sure. It removes one level of stuff that can go wrong. There's still
plenty of other stuff that can break.
(I'm assuming here that you're only using a user ID in the URL to allow
people to view somebody's public user profile. You should NOT be using
this for actual authentication or anything like that...)
Indeed.
>> to me
>> however.
Required XKCD quote: http://www.xkcd.com/934/ [Esp. the alt. text.]
> :-) Glad you're getting into it now, and I feel sorry for you if you
> ever *have* to get into it. Because it means you've been sucked into the
> "web-app" world, which is by far the kludgyest environment ever invented.
IMHO, the entire concept of trying to make an "application" using a
document description language and a document access protocol is
fundamentally flawed. But WTF do I know?
>> but better...
Perhaps I've spent too long on The Daily WTF.
I did see a guy on the Oracle forum once asking how to write a certain
DB query. It seems their application was a Java thing that used the Java
object serialisation thingy to turn its data into a binary blob to store
in the DB. And the guy was asking how to do a query against this data.
Oracle's answer being "you've been a very silly boy, haven't you?"
> overwhelm a 96-processor 16TB RAM SQL server machine with their app, to
> the point where they need nosql storage for ACID data.
I am *definitely* not one of those people. I doubt I'll ever write
anything that actually gets hit by more than 2 users concurrently.
>> more
> manually, so you're not really avoiding any overhead. If you need the
> result of a join, you're doing the join when you store instead of when
> you fetch.
Quite.
> shard very specifically. When you have one user's emailbox for example,
> and you can deal with that ACIDly, and not worry about the other users.
> Stuff like accounting? Nope.
Dude, accountants *invented* the concept of "transactions"! :-D
http://blog.orphi.me.uk/
Date: 19 Nov 2011 13:13:41
Message: <4ec7f1d5$1@news.povray.org>
On 11/19/2011 8:58, Orchid XP v8 wrote:
> Is it actually true that the /entire/ phone system is Erlang? I know Ericson
I don't know. It runs the critical 100%-uptime infrastructure.
> where you need real documentation. There are those who say "the source *is*
> the documentation". But looking at Yesod, with almost 100 packages, I
I find it annoying when I get 50 source code files, and there's not even a
single sentence anywhere saying "this file deals with users" or "that file
handles cookie storage" or something. How f'ing lazy do you have to be?
I got complemented on my comments the other day. They asked which tool I
used to generate them. I said "Easy: I write the comments first to tell me
what I need to implement."
> "The fmap function must satisfy fmap id == id and fmap (f . g) == fmap f .
> fmap g". Or you can say "fmap applies a function to every element of a
> container without affecting the structure of the container itself". The
Yes. I usually include both. But unit tests tell you the first, so the
people who tell you that unit tests serve as documentation are also wrong. :-)
> It's also news to me that ASP.NET is compiled. I thought it was just another
> scripting language.
ASP was. ASP.NET is C# or VB.NET implementing the logic.
It's really quite insane, yes.
>> load it?
That's because C isn't strongly typed.
> Well, yeah, being able to smoothly transition from one to the other is much
> nicer. I suppose you might perhaps be able to do that by having multiple
> physical servers and bouncing them one at a time? (I'm just trying to think
Yes. That's my point. If you don't have enough servers you can do that, then
you don't have enough servers that you can repair your hardware.
> people to view somebody's public user profile. You should NOT be using this
Yep. Unless you sign it or something.
Indeed. He missed HTTP fumblingly reinventing all the stuff that others had
already implemented, like persistent connections, chunked downloads, etc etc
etc.
> But WTF do I know?
I agree entirely.
> I am *definitely* not one of those people. I doubt I'll ever write anything
Not at your current job, for sure. :-)
Heh. Pretty much, yes.
Date: 19 Nov 2011 15:35:19
Message: <4ec81307@news.povray.org>
>> Ericson
Sometimes, people make it sound like Erlang is some kind of silver
bullet that makes everything perfect. I think I can pretty much
guarantee that all that 100% uptime stuff has a crapload of coders,
testers, and on-call fault diagnostics engineers behind it. It's not
like you just write the code in Erlang and it magically becomes reliable.
>> *is*
> a single sentence anywhere saying "this file deals with users" or "that
> file handles cookie storage" or something. How f'ing lazy do you have to
> be?
Well, if there's a module named "Cookies", then it's a pretty good bet
what that does. Then again, if you're looking for the bit that lets you
pretend that HTTP is stateful, is that in the Cookies module, or the
HTTP module, or somewhere else? Sometimes it's not very obvious. No
module ever does just *one* thing - and yet it must have just *one* name.
> me what I need to implement."
Yeah, that could work. I mean, it wouldn't work with my usual iterative
prototyping method, but hey...
>> f .
> wrong. :-)
Heh, yeah. And for that matter, some properties are too hard to write
unit tests for. (E.g., you can test that two different functions produce
the same result for every input you can think of, but it's rather harder
to *prove* that it works for *all* inputs.)
Oh, I see.
It's actually the sort of thing I've been thinking about trying to do
myself. As a matter of fact, there is apparently an extension for one of
the more experimental Haskell compilers that compiles Haskell to JS
rather than machine code. (If the compiler can compile it at all, that
is... It's still experimental, after all.)
>>> load it?
OK. So before you erase the types, note down enough information to allow
dynamic loading. It's not that hard. [People have managed to do it for
Haskell, for example.]
>> much
>> think
> then you don't have enough servers that you can repair your hardware.
OK.
> had already implemented, like persistent connections, chunked downloads,
> etc etc etc.
Unfortunately, every PC on Earth has a web browser installed. If you
want to use some other protocol, you have to have the software for it
first. That's why Hotmail got started. (And as best as I can tell,
that's where this whole crazy idea originated.)
>> But WTF do I know?
> I agree entirely.
Irony? ;-)
I hadn't thought of that. Yeah, I guess we sometimes have more than 2
users log in at once while I'm scanning their profile folders. :-P
Ooo, and recording everything twice, for error recovery. (They call it
"double-entry book keeping". We call it "write-ahead logging".)
Date: 20 Nov 2011 11:58:27
Message: <4ec931b3$1@news.povray.org>
On 11/19/2011 12:35, Orchid XP v8 wrote:
> It's not like you just write the code in
No, of course not. You certainly have to write the code to be
fault-tollerant. The difference is that in Erlang it's much easier, and you
have bunches of libraries to help out.
> Well, if there's a module named "Cookies", then it's a pretty good bet what
> that does.
Yeah, if only everything was named that well.
You would be surprised. You can still write a one or two sentence comment at
the start of a function before you code it. It's no harder than deciding
what to name the function and the arguments. And of course you go back and
fix the comments as you code.
> result for every input you can think of, but it's rather harder to *prove*
Yeah. You can throw a bunch of random data at both, tho.
Well, sure. As long as your interface is skinny enough that you can do that,
then you're golden.
And, more importantly, every firewall has a hole for port 80. *That* was the
real impetus.
> why Hotmail got started. (And as best as I can tell, that's where this whole
Nah. There were lots of systems putting apps over http because it would go
thru firewalls long before anyone tried to reimplement stuff that everyone
already had software for like email.
Journaling. :-)
Date: 21 Nov 2011 04:27:07
Message: <4eca196b$1@news.povray.org>
>>> last 10 years?
Rechecking my sources, it seems there's one company in Ohio that claims
to be a defence contractor, and which uses Haskell for building AI systems.
http://cufp.galois.com/2006/slides/GaryMorris.pdf
(Interestingly, the company's web server currently won't answer me...)
Date: 21 Nov 2011 04:31:50
Message: <4eca1a86$1@news.povray.org>
> you have bunches of libraries to help out.
Other than providing a library that says "if this thread dies, restart
it", I'm not sure what help the libraries actually provide. (Then again,
I'm not very familiar with Erlang.) Certainly the dynamic loading and
hot code swapping makes things easier.
>> what that does.
As I wrote a bit further down, it's sometimes how /possible/ to name
everything perfectly.
> comment at the start of a function before you code it. It's no harder
> than deciding what to name the function and the arguments. And of course
> you go back and fix the comments as you code.
The usual problem is that I start writing all the code, and half way
through I suddenly discover that due to some interaction I hadn't
thought of, the program basically won't work the way it's currently
structured. (Or won't work very well, anyway.) I don't think writing
comments would prevent that. It might make a useful to-do list, however.
> the real impetus.
To this day I have never yet seem a firewall which blocks *outbound*
traffic. So I don't see why this would even be an issue.
> go thru firewalls long before anyone tried to reimplement stuff that
> everyone already had software for like email.
Really?
Date: 21 Nov 2011 12:24:05
Message: <4eca8935$1@news.povray.org>
On 11/21/2011 1:31, Invisible wrote:
> Other than providing a library that says "if this thread dies, restart it",
The whole distributed processing thing? "If this thread dies, restart it"
isn't especially robust if both threads are on the same machine.
The heartbeat monitor, that restarts the entire VM if it locks up?
The logging libraries that let you know there's a problem so you can fix it?
The debugging libraries that let you debug a process that's running on some
other machine somewhere?
> The usual problem is that I start writing all the code, and half way through
> I suddenly discover that due to some interaction I hadn't thought of, the
> program basically won't work the way it's currently structured. (Or won't
> work very well, anyway.) I don't think writing comments would prevent that.
No, of course not. If you're writing the wrong code, commenting what you're
writing before you write it won't prevent that. Of course, I find if I
comment it before I write it, the number of times I miss a corner case
plummets drastically, because I'm not totally focused on the minutia of the
current line of code, but rather on what I'm trying to accomplish.
"Some interaction I hadn't thought of" needs a higher-level design document,
like an actual requirements spec, to avoid. And of course you still can't
always avoid it, by definition of the phrase "hadn't thought of."
And it's handy when you come back six months later and you have to read the
code to see if it's the code you want to look at.
> traffic.
It's not uncommon in even a fairly small corporation.
> Really?
Yep
Date: 24 Nov 2011 08:59:26
Message: <4ece4dbe@news.povray.org>
That's because you haven't seen many firewalls!
At my current place of employment, there are three different layers of
firewalls between the user environment and the public Internet.  not
only do each layer block unauthorized traffic in both directions, there
isn't even a default route out to the Internet.  You need to talk to the
proxy server infrastructure, and it only accepts specific ports.
And looking in the other direction, there are also firewalls between the
labs, UAT environments, and regular network, as well as protecting the
mainframes from the unwashed masses.
For B2B extranets, it's even more prevalent. There, firewalls will
usually also be very strict in what they allow out, because the last
thing you want is a letter from the legal dept. of Boeing, NASA, or say,
the London Stock Exchange saying you are trying to infect their network
with bots.
> Really?
RealPlayer and ICQ, both of which predate Hotmail, are the first I came
across that did that, I'm sure there were others.
