POV-Ray : Newsgroups : povray.off-topic : Java Server Time
28 Jul 2026 19:08:09 EDT (-0400)
  Java (Message 21 to 23 of 23)
Subject: Re: Java
Date: 19 Nov 2011 01:08:08
Message: <4ec747c8@news.povray.org>
On 11/18/2011 7:55, nemesis wrote:
> problem is that you're trying to make java look worse than it is
Well, it's the way this particular project at google was written. But yes,
making Java functional without lambdas is messy.
I went thru something like 300 classes in this particular hugely
overengineered project and didn't find a single noun in the bunch of them.
They were all stuff like "CustomerUpdater" and "StorageManagerImplementor"
and such.  I think it comes from doing too much networking, since networks
don't do a real good job of shipping objects around. I've been trying to
introduce the team to the wonders of actually having the code and the data
in the same class. :-)
> var z = from y select z where z.id = myID
> in it would be something like:
> List<OrganizationIndividualRelationshipEntity> y, z;
> for (OrganizationIndividualRelationshipEntity x : y)
> if (x.id = myID) z.add(x);
Yep.
   People tell me I am the counter-example.
Subject: Re: Java
Date: 19 Nov 2011 04:33:52
Message: <4ec77800$1@news.povray.org>
Le 19/11/2011 07:07, Darren New nous fit lire :
> I've been trying to introduce the team to the wonders of actually having
> the code and the data in the same class. :-)
Well, from the old relational database experience... they shouldn't.
At least, they shouldn't be too tighly coupled until the code is
specific to the data and the data are usable only by the code.
Have a SQL schema (data) and only stored procedures usually ends up in
nightmare.
Data should have their invariants and rules.
Code should be in charge of transforming the data with respect to the
rules and adding new pieces of data which also match the rules.
But you're right, having data in very distant classes from the ones
which have the code is also a PITA. (and from an isolation point of
view, the code classes should not be friend of data class, so no ugly
shortcuts...)
Subject: Re: Java
Date: 19 Nov 2011 12:20:15
Message: <4ec7e54f@news.povray.org>
Well, the data in the database shouldn't be exposed to the user at all, any
more than if your web site is stored in a database the browser should need
to know that.
What I'm saying is that if you have a routine that (for example) marks a
video as having been watched by the current user, it shouldn't be in some
third class called "VideoWatcherRecorder" taking an integer video number and
a long user ID. It should be in the video class and take a reference to a
user object, or vice versa. Otherwise, you're just writing procedural code
in Java.
Yep. And that's very hard to do without doing OO programming. Or relational
programming. And if you're using an OO language like Java, it should be
enforced in the objects that interface to the database (along with the
database, if possible, which it isn't in this case).
Sure. But the difference is where that code live. Is it in some other
package or compilation unit, or is it in the same class that reads and
writes the database?
