POV-Ray : Newsgroups : povray.off-topic : Vampires? Server Time
17 Jun 2026 18:09:32 EDT (-0400)
  Vampires? (Message 61 to 70 of 100)
Subject: Re: Vampires?
Date: 16 Sep 2011 16:29:55
Message: <4e73b1c3$1@news.povray.org>
On 9/16/2011 10:33, Warp wrote:
>    The diffraction pattern isn't there even with elemental particles if you
> measure which slit the particles go through.
It's a little more complicated than that, really.
>    How do you set up a situation where it's not possible to tell which slit
> the football went through? I don't think it's physically possible.
The same way you do it with electrons or photons or whatever. You don't look.
>    You could perhaps try having the experiment in an absolute vacuum (something
> which is already very hard), and in an environment with no electromagnetic
> radiation of any kind, that could hit the ball and tell its trajectory
> (maybe it would be theoretically possible, but I'm not sure it is in
> practice). Also anything else that could hit the ball and hence possibly
> tell its trajectory (eg. neutrinos and cosmic rays) would have to be
> completely absent.
Not really. You get the diffraction/interference pattern even with photons
going through air, so there's no reason to expect a football going through
air is going to be more affected.
>    In fact, thinking about it. would the ball and the walls themselves emit
> photons that could tell the trajectory? Are they black body radiators?
> I suppose that if that's the case, the ball and the walls would have to be
> cooled to absolute zero to stop them from emitting any particles.
It's not a question of emitting particles or not. It's a question of whether
you *measure* whether they're emitted.
>    If yes, what explains the deviation in the trajectory of the ball?
That's just how the quantum world works. The same explanation you give for
photons or electrons applies to footballs, as far as I know (or as far as
anyone knows, last I heard).
> One of the fundamental interactions (gravity, electromagnetism, strong
> interaction, weak interaction)?
Well, for the football, it would be quantum electrodynamics, which is the
interaction of photons with electrons.
> How can they deviate the ball so much?
Remember that the diffraction pattern is going to be on the same scale as
the wavelength of the football. The wavelength of the football is
exceedingly tiny, quite possibly smaller than a proton, for example. So it
doesn't take a large deviation.
   How come I never get only one kudo?
Date: 16 Sep 2011 16:31:04
Message: <4e73b208$1@news.povray.org>
On 9/16/2011 11:23, Warp wrote:
> Alain<aze### [at] qwertyorg>  wrote:
>> For a footbal, it would be in the 10e-20 to 10e-30 m range. So, your
>> interference pattern would be smaller than a proton.
>    That starts being awfully close to the planck length.
I guess if 15 orders of magnitude is "awfully close"... :-)
I do wonder how big something would have to be for the wavelength to be
close to the planck length.  It would be cool if that was, like, close to
the size of the observable universe.
Date: 16 Sep 2011 17:11:09
Message: <4e73bb6d@news.povray.org>
  Those particles are going to hit something. It's very unlikely that they
will go to the end of the universe without hitting anything.
  Now, how does the football (or atom, or particle) "know" that what those
emitted particles hit is not "measurement"? Does it make a conscious
decision like "yeah, these particles are not being measured by any conscious
mind, nor any device which would record the difference, so it's safe for
me to do the interference dance"? How does the traveling object know the
difference between those emitted particles hitting a rock or hitting a
measurement device that can tell the difference?
  Or is it the *interaction* between the traveling object and the particles
that hit it (or which it emits), particles that *could* be used to measure
which slit the object went through, that makes the difference?
Date: 16 Sep 2011 17:27:16
Message: <4e73bf34$1@news.povray.org>
Am 14.09.2011 20:46, schrieb Alain:
> Le 2011/09/14 04:44, Invisible a écrit :
>>>> It ALWAYS make a _sound_.
>>> How do you know?
>> If Schroeder's cat dies and no one observes it, is it still dead?
> Shroeder's cat is always both dead and alive untill someone does observe
> it. Then, the cat is ether alive or dead.
http://cheezburger.com/View/5209969152
Date: 16 Sep 2011 17:33:07
Message: <4e73c093@news.povray.org>
We ended up with much smaller values:
A person, around 10e-50.
A medium car, around 10e-75.
The Earth, in the 10e-200 range.
I don't remember the formula and don't think that I still have it, after
over 30 years ;)
Date: 16 Sep 2011 17:35:13
Message: <4e73c111$1@news.povray.org>
Not even close, the Earth fit the bill, if I remember corectly.
The Sun would be a few order of magnitude smaller.
Date: 16 Sep 2011 17:56:40
Message: <4e73c618@news.povray.org>
> over 30 years ;)
  So if the interference pattern of an object the size of a person is
15 orders of magnitude smaller than the planck length, does that mean
that there is no interference pattern, and hence no interference?
Date: 16 Sep 2011 18:01:32
Message: <4e73c73c$1@news.povray.org>
Only if a tree in the forest makes a noise if nobody is there to hear it. ;-)
Date: 16 Sep 2011 18:07:06
Message: <4e73c88a@news.povray.org>
Well, that is indeed the fundamental problem exposed by Schrodinger's cat.
It doesn't matter if it hits a measuring device. It only matters if you look
at the measurement.
No, because you can take the measurement as to which way it went, *then*
erase that measurement after the particle has already hit the sensor, and
you will or won't get interference depending on whether you don't or do
erase the measurement after the fact.
https://secure.wikimedia.org/wikipedia/en/wiki/Quantum_erasure
https://secure.wikimedia.org/wikipedia/en/wiki/Delayed_choice_quantum_eraser
It's not a question of whether it goes thru one slit or two, or whether you
interfere with it or not at that time. It's (weirdly enough) a question of
whether you know what the answer was supposed to be.
Remember, tho, that each particle lands in exactly one place. One particle
doesn't give an interference pattern like one wave would. Each particle in
the two-slit experiment is just more or less likely to hit different places
on the screen, but each hits at only one place.
Date: 17 Sep 2011 02:37:54
Message: <4e744042@news.povray.org>
> at the measurement.
  And how does the particle know that the measurement was looked at?
  But that has nothing to do with whether someone "looked" at the measurement
or not. It has to do with whether the two possible paths of the emitted
particle were kept separate or whether they were merged before the particle
hit the measurement device. If I understand correctly, the interference
pattern would disappear if the emitted particles are kept separate even if
nobody "looks" at the result. It has nothing to do with an observer, only
with how the original particles and the emitted particles interact.
  While at macroscopic levels it's hard to understand how particles affect
each other from a significant distance (and even time) this way, it kind of
makes sense, if you imagine that the particles are somehow "bound" together
even though they are in their own separate paths: This way what happens to
one particle affects what happens to the other. If the path of the
"measurement" particle is merged, it affects the original particle (even
through time, via some quantum oddity), and if it's not merged, it also
likewise affects it.
  However, what does not make sense even in this context is that the particle
somehow "knows" whether someone "looked" or not.
