POV-Ray : Newsgroups : povray.off-topic : Data transfer Server Time
27 May 2026 17:20:52 EDT (-0400)
  Data transfer (Message 1 to 10 of 195)
Subject: Data transfer
Date: 12 Sep 2011 04:41:19
Message: <4e6dc5af$1@news.povray.org>
Occasionally XKCD makes a valid point. One example is
http://xkcd.com/732/
The latest example is
http://xkcd.com/949/
One insightful poster commented
"I suspect Randall often uses the webcomic to make people talk about
some issue he's having to find out a solution. Not that I'm against
that, I really want to find a better way of transferring files."
After reading several dozen forum posts, it seems nobody has a really
good solution for doing this.
Subject: Re: Data transfer
Date: 12 Sep 2011 05:39:20
Message: <4e6dd348$1@news.povray.org>
I guess the problem is security. If you have two machines with an
Ethernet cable between them, it's really quite easy to transfer files
from one to the other. The trouble is, if *you* can connect to my home
PC to retrieve a file, then ANY RANDOM INTERNET USER can connect to my
PC and obtain that same file. (And possibly others, if I configured it
wrong.) Problems get far worse if I'm expecting you to *send* me a file...
Then of course there's the fact that both PCs have to be switched on at
the same time. That's probably only an issue for large files. Logically,
there is only one way around this: a 3rd party server. That immediately
means that some 3rd party has to pay for your file transfer. That means
that either you pay them, or they spam you with adverts.
Me? I have a web server. (It costs money.) So I can use that. Safe in
the knowledge that I can post a URL here, and I won't have half the
POV-Ray forum DDoSing my home PC off the Internet. But if you don't
already have something like that set up... oh dears.
Oh, and if you're not trying to transfer a file between *your* PC and
another, but trying to explain to your auntie how to transfer a file to
your uncle... suddenly "oh dears" doesn't even cover it.
Date: 12 Sep 2011 15:14:36
Message: <4e6e5a1b@news.povray.org>
  You can thank Windows for this. Traditionally in the unix world
transferring files from one computer to another has been one of the
most basic features (and it's the reason why there are so many ways
of doing that, including rsync, rcp, scp, ftp, sftp, wget, and so on).
Of course this requires for one of the computers to act as a server.
This is made difficult in Windows. (Yes, I know it's not impossible.
I didn't say that.)
  The other traditional method to send files is through irc. This has
worked in the unix world for something like 20 years. Given that irc is
mostly dead nowadays (it's too "old-fashioned") most people don't even
know what it is. This works perfectly in Windows too, if only irc was
still popular there.
  One of the most common modern variants of this, one which also works
easily in Windows, is skype. Of course many people refuse to use skype
out of principle (the same kind of principle as avoiding facebook).
  If you are regularly transferring files to someone, just make him install
skype.
Date: 12 Sep 2011 16:17:36
Message: <4e6e68e0$1@news.povray.org>
> I didn't say that.)
I don't know about "impossible". It's actually pretty simple. By
default, *every* Windows PC acts as a fileserver. If you have two PCs on
the same network, open Windows Explorer, type the name (or more likely
IP address) of the other machine. The syntax "\\machine\c$" works by
default. Type in the administrator password for the remote machine. You
now have access to the entire local filesystem.
This is the default configuration. You don't have to do *anything* to
make it work. It's worked since Windows NT 4.0, if not before.
I'm not aware of any Unix system which *defaults* to letting remote
users access the entire filesystem if they know the root password.
Probably because it's a stunningly bad idea, unless the local network is
trusted. But anyway...
This obviously completely fails over the Internet. Or at least, you
better *hope* it fails. Otherwise your Windows box is liable to get
rooted very shortly...
(You can, of course, set up proper shared folders to give specific
people specific access levels to different parts of the filesystem. And
unlike editing a million HTTP-access files or twiddling text
configuration files for an FTP client, it's as trivial as right-clicking
the folder you want to share and saying "share this". Of course, it's
only really useful if network-wide user authentication is set up, which
is a whole *other* topic... And, again, it's designed for the LAN, not
the Internet.)
While we're on the subject, by default you can log in to any remote
Windows PC that you happen to know the administrator password to. No
special software required. Again, try getting X11 to let you do that.
Good luck.
It's news to me that IRC is "dead". Indeed, I still use it from time to
time.
I'm talking on an NNTP server, aren't I? o_O
> skype.
Doesn't have to be Skype. Various IM clients have this function too. The
problem, generally, is the inexplicably slow transfer speeds.
http://blog.orphi.me.uk/
Date: 12 Sep 2011 16:39:13
Message: <4e6e6df1$1@news.povray.org>
Am 12.09.2011 22:17, schrieb Orchid XP v8:
To the contrary: Unix doesn't only let users who know the root password
access the /filesystem/, but do /anything/ they like on the machine.
I would yet have to hear of any admin who only has local console access
to the servers he administers.
That's why you normally keep root passwords a secret ;-)
> Good luck.
Depends on the server's configuration regarding X11. But you do know
that X11 is not the only way to log on to a Unix machine, don't you?
Not inexplicabe if you're on an ADSL line. Hint: The "A" is for
"asymmetric" ;-)
Date: 12 Sep 2011 16:55:52
Message: <4e6e71d8$1@news.povray.org>
Well, yeah, if I'm on a default Windows box and I've got network access
to a second default Windows box, I can log in to it interactively, I can
access the entire filesystem, the entire registry, read the event log,
run device manager on it, and a whole heap of other stuff. Without
having to configure *anything*.
Windows installations at home generally don't do this. (I blame MS, not
the user.)
>> Good luck.
Sure. But no other protocols are configured by default either. And with
good reason: not turning stuff on by default is more secure.
> "asymmetric" ;-)
I know how fast my upload speed is. And it isn't this slow. :-P
Date: 12 Sep 2011 17:20:11
Message: <4e6e778b$1@news.povray.org>
Every unix system can do this with something like sshfs installed - on
the client side only - and sshd running on the server.
Jim
Date: 12 Sep 2011 17:36:21
Message: <4e6e7b55$1@news.povray.org>
Am 12.09.2011 22:55, schrieb Orchid XP v8:
>> "asymmetric" ;-)
Don't forget that with Skype you typically have a voice stream to be
transmitted at the same time.
Date: 12 Sep 2011 17:39:56
Message: <4e6e7c2c$1@news.povray.org>
>>>> The
>>> "asymmetric" ;-)
I've never used Skype. But I've used various IM clients. And my point
is, they all tend to be inexplicably slow to transfer files.
Date: 12 Sep 2011 18:56:31
Message: <4e6e8e1f@news.povray.org>
Nah. You can thank NAT for this.
Note how all of those require a running server on a public IP address.
> I didn't say that.)
Transferring files in Windows is trivial. You RDP into the other machine,
and use copy/paste just like in the file manager. Or you mount the share off
the other machine. Or let RDP mount the share for you.
It just requires you not be behind a NAT.
All the chat programs still have this, including messanger and all (afaik)
the other chat clients like jabber and AIM and such.
The principle being "I don't route my phone calls through random third-party
computers, especially those who haven't given me permission to use their
public computer as a NAT bridge."
For example, you can't use skype in google because google has enough
bandwidth that half the world would be routing their skype calls over
google's links if you did.
> skype.
Or any IM client, really.
   How come I never get only one kudo?
