POV-Ray : Newsgroups : povray.off-topic : Data transfer Server Time
8 Nov 2026 03:00:32 EST (-0500)
  Data transfer (Message 86 to 135 of 195)
<<< Previous 50 Messages Goto Latest 50 Messages Next 50 Messages >>>
Subject: Re: Data transfer
Date: 13 Sep 2011 17:17:05
Message: <4e6fc851$1@news.povray.org>
On Tue, 13 Sep 2011 17:14:02 -0400, Jim Henderson wrote:
>> So how do you prevent somebody connecting to your server a thousand
>> times per second and feeding it duff credentials, thereby preventing
>> any legitimate users logging in, and wasting lots of CPU power?
> On my system, I use a tool called blockhosts.  After 5 failed attempts,
> the portmapper won't allow them to connect to the service any more -
> which slows them down (because it doesn't send an ack) and allows legit
> users to login - even on the same port/service - and doesn't waste any
> CPU power at all.
Additionally, if I wanted to be more secure on my system, I could run sshd
on a non-standard port (or forward from a non-standard port in my
firewall).  Then they have to find the service first, and most of the
scripts that do that won't bother, because there are easier targets.
Jim
Date: 13 Sep 2011 17:32:48
Message: <4e6fcc00$1@news.povray.org>
On 9/13/2011 7:00 AM, Warp wrote:
> Invisible<voi### [at] devnull>  wrote:
>>>> I said that Windows allows it *by default*
>>>     So how exactly would I transfer a file to you from my Windows?
>> You can't. My PC is firewalled.
>> You also can't transfer a file using Unix, for the same reason.
>    Most firewalls have the ssh port open because it's considered safe.
> (And if it's not, it's easy to open in most distros).
>    Then you can use scp, rsync or any equivalent tool to transfer files.
> (There probably isn't any linux distro that doesn't come by default with
> scp and rsync.)
>    (Btw, the great thing about rsync is that it can resume interrupted file
> transfers, a rather important feature that, oddly, most file transfer tools
> completely lack.)
And even if you do have them.. Sometimes, at least in Windows, it
doesn't work. Remember a few years back. Bad connection (disconnects
after about 5-10 minutes), a tendency of files to almost complete, but
then not, and a 1GB download, which Sony decided should be on a
non-resumable server... WTF?
Date: 13 Sep 2011 20:47:28
Message: <4e6ff9a0$1@news.povray.org>
Le 2011-09-13 14:37, Orchid XP v8 a écrit :
> On 13/09/2011 07:00 PM, Francois Labreque wrote:
>> Le 2011-09-13 11:20, Invisible a écrit :
>>>>> No, I mean there's a *hardware* firewall in the way. You know, with
>>>>> the
>>>>> big Cisco sticker on it and the 3-digit price tag? (Although obviously
>>>>> that's only because I'm at work right now. My house doesn't have
>>>>> one of
>>>>> those...)
>> You're off by two orders of magnitude. Most Cisco firewalls are in teh 5
>> digit price tag.
> True. But not this particular one.
http://www.ebuyer.com/135532-cisco-asa-5505-firewall-edition-bundle-asa5505-50-bun-k9
Ok. you got me.  I usually don't deal with small-office/home-office gear.
> (Go on, hack me. You know you want to.)
>>>> And that hardware firewall is completely incapable of forwarding ssh
>>>> connections? Pretty useless, I'd say.
>>> No, I don't have the password to configure it.
> Still stands.
>>> (And besides, have *you*
>>> tried configuring Cisco stuff? It's not exactly intuitive. You probably
>>> need Certified Engineer status to figure it out.)
>> You don't need to be a Cisco Certified Internetwork Expert to figure it
>> out. The Cisco manuals are usually pretty easy to follow, and freely
>> available on their web site.
> Really? That might be worth reading...
This is a good place to start:
For routers and switches:
http://www.cisco.com/en/US/docs/ios-xml/ios/fundamentals/command/cf-cr-book.html
Or "Support | IOS & NX OS | IOS 12.4 Mainline " from the home page.
Firewalls are a little different, but the syntax is still related.
Kinda like French and Italian.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/conf_gd.html
Or "Support | Security | PIX firewall software | Configuration Guide |
Version 8.0" from the home page.
Note: Even though Cisco firewall appliances are now called ASAs, their
documentation still cals them PIXes all over the place.
>> And it is actually pretty intuitive...
>> - Give each interface an ip address.
>> - Create your NAT tables.
>> - And off you go.
>  From what I've seen, you telnet into the router, enter a password, and
> then enter lines of gibberish such as "enh eth gw all". You would
> *definitely* need a manual to figure out WTH that actually means, or
> what the name of the command you want is.
Two things:
First thing, typing ? at any point will list all the available commands
at that point.
Second thing, you don't have to enter gibberish.  the commands are plain
english words.  They can be abbreviated for speed, but
sh ip int fa0/0 bri
Is exactly the same as typing
show ip interface fastethernet0/0 brief
which would show you a brief summary of all the stats it keeps for the
IP protocol on interface fastethernet0/0. (protocol distribution, packet
counts, etc...)
>> The only difference between a Cisco firewall and a D-link or NetGear
>> home router, besides performance and scalability, is that you can (and
>> should!) override the basic "everything outbound is ok, nothing inbound
>> can come in" configuration.
> I'm still guessing that, between the configuration for routing to
> multiple LANs, multiple VPN endpoints, and remote access, adding a line
> that forwards SSH to a port on a desktop PC who's IP address is
> configured via DHCP is probably going to take some doing. (!)
Routing for the multiple lans actually comes straigh out of the box.
You confiugre an ip address on all the interfaces and it will know that
any packets it receives whose destination is on another lan interface,
it will forward it (let's disregard security rules, for the moment!).
Remote lans are handled the same way they would be on a Windows or Unix
machine.  By either configuring a routing protocol, or by adding static
routes.
On Windows, you'd type:
route add 192.168.200.0 mask 255.255.255.0 192.168.1.1
On a router, you'd type:
ip route 192.168.200.0 255.255.255.0 192.168.1.1
On a firewall, you'd type:
ip route [interfacename] 192.168.200.0 255.255.255.0 192.168.1.1
You have to specify the interface name because, as opposed to a router,
the firewall will drop any packet that has to be routed back out the
same interface it came in.
VPN endpoints are not more complicated than on any other platform, but
that's a bit like saying that changing the transmission of a Formula One
is not more complicated than changing it on a Toyota...  It may not Be
for a complete noob.
Allowing inbound ssh connections will need that PC to have a static NAT
address, and therefore a static local IP address.  Your Netgear or
Linksys home router can work around this because it also acts as the
DHCP server, so it knows to which MAC adress to send the traffic, but in
an entreprise where the firewall is a separate piece of hardware, there
is simply no way to do this.
> And we still have the minor issue that I don't have the password. :-P
If you have physical access to the box, you can do a password recovery
and put a new password in, but since this would likely cost you your job
and may very well land you in jail, I do not recommend you try it at the
office....
> Actually, I have a NetGear router in my house. I used it to create a VPN
> between my house and my grandparents' house. It lets you do all sorts of
> port forwarding and stuff. The only trouble is... it's not reliable.
> Like, when certain datagrams pass through it, the firmware crashes, and
> you have to power-cycle it to get the Internet back. Eventually I was
> forced to take it out of the circuit, because it was pissing me off so
> much! (No, there isn't a firmware update available.)
> Given the price of the Cisco ASA, I'm almost tempted...
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 13 Sep 2011 20:55:34
Message: <4e6ffb86$1@news.povray.org>
Le 2011-09-13 14:48, Orchid XP v8 a écrit :
> On 13/09/2011 07:17 PM, Francois Labreque wrote:
>> Le 2011-09-13 10:21, Invisible a écrit :
>>> Puzzling thing: There are many, many SSH clients for Windows. There are
>>> no SSH *servers*. And I have literally no idea why.
>> Really?
>> http://www.freesshd.com/?ctt=download
>> Or maybe, running OpenSSH's sshd under Cygwin?
>> http://www.petri.co.il/setup-ssh-server-vista.htm
>> Or buying one of the many commercial versions available?
> Let me rephrase: There are no SSH servers that are free software.
> (At least, 5 years ago I wasted weeks searching for one, and never found
> one.)
And how much does Cygwin or openssh's sshd cost?
Date: 13 Sep 2011 20:58:10
Message: <4e6ffc22$1@news.povray.org>
Le 2011-09-13 15:17, Orchid XP v8 a écrit :
> On 13/09/2011 08:03 PM, Jim Henderson wrote:
>> On Tue, 13 Sep 2011 19:53:17 +0100, Orchid XP v8 wrote:
>>> I still think the main problem is that to allow somebody to send you
>>> data, you have to figure out how to prevent anybody *else* sending you
>>> data.
>> No, that's easy. It's called "authentication and authorisation".
> Ah, I see.
> times per second and feeding it duff credentials, thereby preventing any
> See, security isn't so simple...
by having a real firewall (such as the aforementioned Cisco ASA)
configured to throttle individual connections.  ;)
Now the /b/tard in question would have to use zombie PCs to do his DOS
against your machine.
Date: 13 Sep 2011 21:05:57
Message: <4e6ffdf5@news.povray.org>
Le 2011-09-13 14:53, Orchid XP v8 a écrit :
> Oh, wait, you can set the remote display to not take up the whole
> screen, can't you?
Yes.  I run my work laptop at 1440x900, but the screen sizes for my
remote desktops are 1152x864, so that I still have the contact list of
my work IM program and my local taskbar visible.  Makes it easier to
switch from one server to the other, hunt for local files, chat with the
boss, or surf the internet while still keeping an occasional eye on the
Oracle indexes rebuilding themselves.
Date: 13 Sep 2011 23:22:20
Message: <4e701dec@news.povray.org>
openssh is released under the GPL, and has been around for quite some
time now (certainly more than 5 years - I'd say more than a decade).
And there are versions that run on Windows - using cygwin or not.
Jim
Date: 14 Sep 2011 04:27:57
Message: <4e70658d$1@news.povray.org>
>>> digit price tag.
I was surprised myself. Our network switches cost about 3x what every
other manufacturer wanted.
(I soon discovered, however, that these "switches" are actually just
24-port *routers*...)
OK.
Yeah, we've still got a PIX 506e in the corner. Though damned if I know
why; that thing was starting to become quite unreliable...
> Two things:
> at that point.
So... it's some kind of hierarchical menu system? (I had assumed that
all commands are available all the time.)
> sh ip int fa0/0 bri
I see.
I'm guessing that unless you do this kind of thing all day, you'll
quickly forget what the name for each command is, and so you'll need the
manual open constantly. (I really hope the manuals contain more than
just a reference list of every command name and what it does...)
> Routing for the multiple lans actually comes straigh out of the box. You
> confiugre an ip address on all the interfaces and it will know that any
> packets it receives whose destination is on another lan interface, it
Even though there's only one connection from the firewall to the
(multiple) switches?
> routes.
1. I didn't know you could do that.
2. What does it do?
Presumably you have to specify protocol types and encryption keys and so
forth...
Quite. The only way this could work is if you wanted to /temporarily/
forward SSH (probably on a different port number) to the IP address that
my desktop PC /currently/ has.
I am *so* not trying this! :-D
Incidentally, I gather that there's two ways to control the ASA. One
involves telnet. The other involves a serial cable...
Date: 14 Sep 2011 04:31:24
Message: <4e70665c$1@news.povray.org>
On 13/09/2011 10:01 PM, Darren New wrote:
> On 9/13/2011 11:45, Orchid XP v8 wrote:
>> So what changed then? Certainly X hasn't changed since prehistoric
>> times...
> ssh port forwarding, for one. It was never hard to forward X. It was
> hard to forward X securely and hard to forward X without first logging
> in over a command line interface.
You mean SSH hasn't existed since before System V as well?
Date: 14 Sep 2011 04:32:52
Message: <4e7066b4$1@news.povray.org>
>> OK, let me put it this way: X lets you install an application on a
>> central
>> server, and have multiple X "servers" (i.e. *clients*) connect to that
>> server and have their own instance of the application appear on their
>> screen.
> Yep. You still need a computer for each user, tho.
Sure. But I mean, you can set up an application server that more than
one person can access, without doing anything particularly special.
>> If you want to do that with RDP, you need the multi-thousand dollar
>> "server"
>> version of Windows.
> Um, it's $117 online, and that's with five client licenses.
> Even if you don't find a deal, it's $525. Far from "multi-thousand
> dollars".
OK, well maybe it's the cost of the client licenses I'm thinking of then...
Date: 14 Sep 2011 04:33:49
Message: <4e7066ed$1@news.povray.org>
When I looked, I couldn't find any precompiled Windows binaries for
OpenSSH anywhere.
Date: 14 Sep 2011 04:37:16
Message: <4e7067bc$1@news.povray.org>
On 13/09/2011 09:57 PM, Darren New wrote:
> On 9/13/2011 11:53, Orchid XP v8 wrote:
>> Sure. I'm saying that if you were expecting someone to get/put a file,
> Yes, certainly. That is, after all, how things like video games do it.
Really? I thought they just connect to a central game server.
(Although... actually they mostly seem to use UDP, so "connect" is a
little nebulous.)
>> Oh, wait, you can set the remote display to not take up the whole screen,
>> can't you?
> Or iconify the remote screen, copy the file, expand the remote screen,
> paste the file.
Oh, that works?
> Or just let RDP mount the disks over the link, so they
> show up as networked drives on the remote machine.
Ah - it [optionally] connects local and remote disks, the same way it
connects printers, right?
Date: 14 Sep 2011 04:40:16
Message: <4e706870$1@news.povray.org>
I'm sorry, I thought we were still talking about "why the average home
user can't easily send a file to another average home user". :-) I doubt
many home users will pay hundreds of pounds for a Cisco ASA and spend
god-knows how long learning what "tee sea pee eye pee" is in order to
set this up.
Yeah, because none of the script kiddies have figured out how to do
that. ;-)
Then again, if somebody decides to DDoS you, it doesn't matter if you
have *no* ports exposed to the Internet... You still get no service.
Sometimes I think it would be nice if there was a widely-supported
standard for configuring the firewall at the /other end/ of the last
mile to drop certain packets. But anyway...
Date: 14 Sep 2011 04:42:32
Message: <4e7068f8@news.povray.org>
>> In seriousness, manpages are, by definition, *reference* documentation.
>> What the standard Unix system lacks entirely is any kind of
>> *explanation*.
> Depends on the manpage.
No, pretty much all of them list the command options, and that's it.
The manpage for bash practically lists the BNF grammar for shell
scripts, but fails to provide any useful introductory material for
anyone just trying to get started. (E.g., how the **** to I execute the
same command for every file in this folder?)
>       PasswordAuthentication
>               Specifies whether password authentication is allowed.  The
>               default is “yes”.
> Seems pretty straightforward to me.
Does that disable CHAP as well? Or only plain password authentication?
(If I'm remembering this right, CHAP is basically password
authentication, but with a slightly more secure wire protocol.)
>> That's... interesing. I'm damned /sure/ the manpage said to put the
>> files into /etc/sshd or similar. And to edit the SSH configuration file
>> to tell it what (local) user account goes with a given key. And how many
>> simultaneous logins that user can have, what their shell is, and a bunch
>> of other complicated stuff...
> There's a difference between configuring sshd and using the public key for
authentication.
> You *can* do a host key, but in most cases it's not necessary:
>       Normally each user wishing to use SSH with public key authentication runs
>       this once to create the authentication key in ~/.ssh/identity,
>       ~/.ssh/id_ecdsa, ~/.ssh/id_dsa or ~/.ssh/id_rsa.  Additionally, the sys-
>       tem administrator may use this to generate host keys, as seen in /etc/rc.
I thought the host key is how the server identifies itself to you, not
how you identify yourself to the server?
At any rate, it's news to me that you can create a ~/.ssh folder and
sshd will actually take note of this. I don't recall the manpage
mentioning this at all.
Date: 14 Sep 2011 10:57:09
Message: <4e70c0c5$1@news.povray.org>
>>               default is “yes”.
Indeed, for ssh, PasswordAuthentication is never going to CHAP.
PasswordAuthentication of ssh need that the lower layer negociated
already an encryption and a mac/checksum.
(it is forbidden to use password authentication over a clear connection)
Myself, I prefer signature authentication, with ~/.ssh/authorized_keys .
My password/passphrase locally unlock the private key, and the public
key is in the remote host(s) user directory.
Correct.
~/.ssh/authorized_keys !!
(name can be configured with AuthorizedKeysFile )
May be you have a different man page for sshd.
Mine talk about ~/.ssh/rc, ~/.ssh/environment, and more...
including ~/.ssh/known_hosts
In fact, the FILES section of the man page for sshd is long... very long.
Software is like dirt - it costs time and money to change it and move it
around.<br/><br/>
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 14 Sep 2011 11:03:41
Message: <4e70c24d$1@news.povray.org>
Yeah, that's basically my point. It took me *forever* to figure out how
to make it so that public key is the /only/ enabled protocol, so that if
you don't have a copy of my private key, there is NO WAY IN HELL that
you can log in to my box.
Seems like a simple thing to want to do, but I tested it several times
and it was still letting me log in with a weak-arse password instead of
demanding a key.
As is the configuration file, IIRC...
Date: 14 Sep 2011 11:09:46
Message: <4e70c3ba$1@news.povray.org>
> OpenSSH anywhere.
I'm sorry, but you are asking for something against the commercial logic
of your operating system:
You paid for your OS, you also have to pay for your applications.
Only loonies provides free stuff of excellent quality on that platform.
Serious programmers for that platform are expected to extort a lot for
the application you might install (be it shareware or direct buyware or
troyan or racket-ware... ).
Please, assume your choice.
did you look at http://www.freesshd.com/?ctt=overview
Date: 14 Sep 2011 11:34:05
Message: <4e70c96d@news.povray.org>
>> OpenSSH anywhere.
No OS fanboys in here, no sir! :-S
Date: 14 Sep 2011 12:54:29
Message: <4e70dc45@news.povray.org>
>>> times...
*Relatively* speaking, ssh is much newer than rsh. It's also relatively new
that it will do port forwarding and stuff like that. Remember that ssh was
standardized in 1995 or so, and X has been around far longer than that.
   How come I never get only one kudo?
Date: 14 Sep 2011 12:56:19
Message: <4e70dcb3$1@news.povray.org>
>>> central
>>> screen.
> Sure. But I mean, you can set up an application server that more than one
You can do exactly the same thing on Windows that you do on Unix.
Log into the windows box remotely. Start an X client and point it at your
display. Disconnect without logging out. Someone else logs into the windows
box remotely. They start an X client and points it at their display. They
disconnect without logging out.  Guess what? Windows running X clients
talking to two different X servers.
>> dollars".
That's with five client licenses. So about $110/user.
Date: 14 Sep 2011 12:58:28
Message: <4e70dd34$1@news.povray.org>
I think you just insulted every member of TAG. ;-)
Seriously, googling for "gnu win32" tends to get you ports of everything.
http://linuxmafia.com/ssh/win32.html
Date: 14 Sep 2011 12:59:42
Message: <4e70dd7e$1@news.povray.org>
On 9/14/2011 1:37, Invisible wrote:
> Really? I thought they just connect to a central game server. (Although...
> actually they mostly seem to use UDP, so "connect" is a little nebulous.)
Bingo.
>> paste the file.
> Oh, that works?
Why wouldn't it?
Yep. And sound. And USB ports.
Date: 14 Sep 2011 13:02:44
Message: <4e70de34$1@news.povray.org>
>>> documentation. What the standard Unix system lacks entirely is any
>>> kind of *explanation*.
So I'm lying, then, is that it?
I suspect that I spend just a *tiny* bit more time than you do reading
man pages - and I wouldn't make an assertion that "it depends on the man
page in question" if it weren't actually the case.
>>               The default is “yes”.
It doesn't say anything about CHAP.  I'm pretty sure it also doesn't
change the password encryption method from AES to Triple-DES as well.
It's not likely to document everything it *doesn't* do, just what it
*does* do.
>> for authentication.
>>       authentication runs this once to create the authentication key in
>>       ~/.ssh/identity, ~/.ssh/id_ecdsa, ~/.ssh/id_dsa or ~/.ssh/id_rsa.
>>        Additionally, the sys- tem administrator may use this to
Host keys aren't very commonly used AFAIK.
It's always been that way.  The cited bit above is from the man page and
says pretty explicitly that the user's keys are in ~/.ssh
Jim
Date: 14 Sep 2011 13:03:40
Message: <4e70de6c$1@news.povray.org>
As do I - I guess I wasn't as clear as I thought in explaining how the
key is put on the remote machine - it does indeed go in the
authorized_keys file.
Jim
Date: 14 Sep 2011 13:04:51
Message: <4e70deb3$1@news.povray.org>
> OpenSSH anywhere.
They are available now.  Cygwin has also been around for a while, and
includes an sshd server (in fact, a couple of the versions I found for
Windows were essentially stripped down installations of cygwin).
Jim
Date: 14 Sep 2011 16:52:46
Message: <4e71141e$1@news.povray.org>
> your display. Disconnect without logging out. Someone else logs into the
> windows box remotely. They start an X client and points it at their
> display. They disconnect without logging out. Guess what? Windows
> running X clients talking to two different X servers.
Does anyone, anywhere on Earth, actually run X on Windows?
I mean, I gather that you *can*. But does anybody actually *do* this?
http://blog.orphi.me.uk/
Date: 14 Sep 2011 17:27:40
Message: <4e711c4c$1@news.povray.org>
Or complemented them.
Regards
Date: 14 Sep 2011 18:11:22
Message: <4E71268D.4010409@gmail.com>
>>> one
I have done that, why?
Date: 15 Sep 2011 00:45:09
Message: <4e7182d5$1@news.povray.org>
>> the windows box remotely. They start an X client and points it at their
Yes.
Jim
Date: 15 Sep 2011 04:08:05
Message: <4e71b265@news.povray.org>
Am 14.09.2011 22:52, schrieb Orchid XP v8:
An X /server/ (that is, the X terminal software)? Absolutely. Guess how
I "remotely" control my Linux machine (which I use primarily for
scripted test-runs of POV-Ray) from my Windows machine (which I use for
everyday stuff, including POV-Ray development with MS Visual Studio).
Sure, I could just plug in a keyboard and mouse, and use the analog
input of one of my displays to switch between the two; but having two
keyboards and two mice on the desk really sucks, KVM switches aren't
free (as in free beer), and being able to use the Windows task bar to
switch to the Linux desktop is quite handy as well.
An X /client/ on Windows (that is, software running on a Windows host
and displaying on an X terminal)? Doesn't sound like a common use case
to me.
Date: 15 Sep 2011 04:11:51
Message: <4e71b347$1@news.povray.org>
OK, let me put it this way: I've never seen any manpage which is
anything more than a terse summary of command switches with an
incomplete description of what they do. The most in-depth manpage I've
seen is for Bash, which is still only a reference document, not an
introductory tutorial.
It seems to be that the /purpose/ of a manpage is to be a reference
document. Which is what you want when you're trying to remember the name
of the command switch that turns on the feature you want. But it's
useless when you're trying to figure out how to use a tool you've never
used before...
Then again, sometimes the manpage just says "use info". And then you had
/another/ problem...
> *does* do.
So even with this line, people can *still* authenticate by password.
Hence my original statement that it's difficult to turn off all the ways
that users can get in with a password.
All three of the SFTP systems we use commercially have them.
OK. So now I'm wondering how come I never saw this information anywhere...
Date: 15 Sep 2011 04:12:47
Message: <4e71b37f$1@news.povray.org>
>>>> times...
> new that it will do port forwarding and stuff like that. Remember that
> ssh was standardized in 1995 or so, and X has been around far longer
> than that.
1995? Jesus, that's WITHIN MY OWN LIFETIME! Compared to Unix, which
almost pre-dates binary computers, that's ultra-modernist!
Date: 15 Sep 2011 04:14:27
Message: <4e71b3e3@news.povray.org>
>> OpenSSH anywhere.
Wouldn't that mean that once you connect in, your shell can only execute
Cygwin binaries?
(Not that this matters if you're only trying to forward ports...)
Quite why you need a complete Unix emulator to run something that only
sends and receives data over network ports I don't know, but anyway...
Date: 15 Sep 2011 04:26:54
Message: <4e71b6ce$1@news.povray.org>
Mmm, OK.
Or you could just use VNC, which works on both platforms...
> to me.
OK, fair enough.
Date: 15 Sep 2011 05:44:16
Message: <4e71c8f0@news.povray.org>
> Mmm, OK.
try playing xonix via VNC... it's far easier with just a X server on the
windows system.
It's just a shame that windows applications are unable to be translated
into X clients by MS. (well, they still have that "one user at a time"
approach in a lot of their code too)
>> to me.
> OK, fair enough.
Date: 15 Sep 2011 06:09:12
Message: <4e71cec8@news.povray.org>
>>>>> times...
>> than that.
Not only, but current ssh is version 2, which leave the status of draft
only in 2006; (1.99 is drafted version 2)
ssh of 1995 was version 1 and limited to remote shell (with very limited
inband file transfer).
Date: 15 Sep 2011 09:17:06
Message: <4e71fad2$1@news.povray.org>
Am 15.09.2011 10:26, schrieb Invisible:
> Mmm, OK.
Why would I care about the thing working both ways, if my primary
machine is the Windows machine?
That aside, using VNC would of course have required me knowing of that
animal (which I didn't); X was a thing I knew would do the job I wanted
(provided I could find a free X server for Windows, which I did), so
obviously that's what I went for. (And as it runs fine now, there's also
no motivation for me to even try anything different.)
Plus, X11 is still at the core of all the fancy Linux GUIs anyway
(whether it is KDE or Gnome or whatever), and is /designed/ for remote
desktop sessions, so why bother to add yet another layer of complexity
to get a feature that's already there.
Date: 15 Sep 2011 09:22:32
Message: <4e71fc18@news.povray.org>
As far as I know, getting X to actually work remotely is extremely
difficult, whereas I know from experience that getting VNC to work
remotely is trivial.
On the other hand, if you have something that works, then there isn't
really a problem to solve.
Date: 15 Sep 2011 10:40:33
Message: <4e720e61$1@news.povray.org>
Am 15.09.2011 15:22, schrieb Invisible:
"Extremely difficult" is an exaggeration. It wasn't as trivial as
throwing some switch in YAST, but with a bit of googling it was quite
easy going, despite me being far from a Linux expert.
Date: 15 Sep 2011 13:16:19
Message: <4e7232e3@news.povray.org>
I'm told v1 isn't as secure either. I don't know if that's actually true...
Date: 15 Sep 2011 13:45:18
Message: <4e7239ae@news.povray.org>
> true...
It is.
Jim
Date: 15 Sep 2011 13:48:37
Message: <4e723a75@news.povray.org>
Man pages are not intended to be tutorials.  They're manual pages.
Ever read the Windows manual?  It's not a tutorial on how to use Windows,
it's a description of what Windows is and its features/functionality.
> used before...
And when you're looking for configuration options, a reference is
generally what people turn to.
Well, no, it's not *another* problem - you just need to use the info
command instead.
>> *does* do.
Not to the best of my knowledge.  On my systems, if I try to use password
authentication, the system tells me that only public key authentication
is enabled.
No, it's trivial.  My server is in fact a perfect example of that.
A sample size of 3 isn't exactly data supporting "commonly used".  I've
used sftp systems that don't use them at all, and just use ssh as a way
of tunneling ftp data securely.
>> and says pretty explicitly that the user's keys are in ~/.ssh
> anywhere...
Beats me.
Jim
Date: 15 Sep 2011 13:50:47
Message: <4e723af7@news.povray.org>
>> also no motivation for me to even try anything different.)
VNC is also trivially compromised unless you tunnel it over ssh or wrap
it in ssl.
For Windows, IIRC, you just need to install MingW.  IIRC, that covers X
protocol on Windows for accessing remote X servers (ie, it's a client,
not a server).
That's certainly true.
Jim
Date: 15 Sep 2011 13:51:32
Message: <4e723b24$1@news.povray.org>
>>> OpenSSH anywhere.
> Cygwin binaries?
Absolutely not.  Go read up on what Cygwin is and how it works.
That's how Cygwin is set up.  It's not the only solution, just an example.
Jim
Date: 15 Sep 2011 13:55:03
Message: <4e723bf7$1@news.povray.org>
>>>> teh 5
>>>> digit price tag.
> OK.
>> Two things:
>> at that point.
Yes and no.
there are multiple modes.  Normal display mode, "enable" mode, where you
can make some changes such as clear counters, logs or set certain
parameters, and "Configure" mode where you make ... configuration changes.
The available commands vary for each mode, however what I meant whas that
? by itself will list all the commands you can type, while
show ?
will list all the stuff the show command can display, and
show interface ?
will list all the types of interfaces that can be displayed
etc...
>> sh ip int fa0/0 bri
> I see.
Configuration guides, command references, hardware installation
checklists, etc... they're all in there.
Then, there are mulitple "VLAN" interfaces created, so the above still
stands.
>> routes.
> 2. What does it do?
It tells your PC that there's a network called 192.168.200.0 somewhere
voer there, and that to get ot it, you must forward the packets to
192.168.1.1 and he'll take care of them.
On a pc with no VPN and only one NIC, that's pointless, but if you have
more than one NIC on a server, or have "split-tunnelling" enabled on
your VPN, you need to have those set up so that the machine knows on
which interface it needs to send the packets.
> forth...
Yup.
Serial cable is required to give the machine its initial barebones
config, after that, it's telnet or preferably ssh.  Since anyone could
sniff the telnet password.
Date: 15 Sep 2011 14:18:11
Message: <4e724163$1@news.povray.org>
> it in ssl.
If the two machines are on the same LAN, this probably isn't a problem.
(And presumably the same applies to X as well anyway...)
Date: 15 Sep 2011 14:46:43
Message: <4e724813@news.povray.org>
...which is the point I'm trying to make, yes.
> command instead.
Have /you/ tried navigating the thing?
Since I'm guessing the answer is probably "yes", then I don't need to
explain to you how hard it is...
>>> *does* do.
I'm fairly sure I tested it, and discovered that I needed to turn off
multiple things to stop it accepting my password as a valid login. But
since that was then and this is now, I guess I might be incorrect.
It's infinity times larger than a sample size of zero. ;-)
Then again, one of these systems is set up to use PK authentication, and
the server administrators emailled /us/ with the private key to use to
get access. *facepalm*
Imagine it: Going to all the trouble of setting up a secure system, and
not even knowing how to secure it properly...
Date: 15 Sep 2011 15:11:52
Message: <4e724df8$1@news.povray.org>
Le 15/09/2011 20:46, Orchid XP v8 nous fit lire :
>>>> *does* do.
Did you at least refresh (aka reload) sshd when updating the configuration ?
Updating the configuration is not enough, the daemon must be flushed to
reload it.
SSH password authentication is just delegating the password to the OS
system... (bad! IMNSHO)
Host key are kind of mandatory for server. Unless you want to use ssh
without encryption at all.
That's the issue with wrong administrators: they assume people do not
have their own public key, and generate a pair for them... they need a
clue (and some users too!).
From my bad memory, there is at least 5 kinds of attacks that must be
covered. If you cannot understand them all, you're out of the trusted.
Date: 15 Sep 2011 15:29:23
Message: <4e725213$1@news.povray.org>
Is rebooting the machine sufficient to do that?
If so, yes...
The most mystifying part is, the first time we set it up, they did it
right. Only the second time around did they insist that we use their key...
Date: 15 Sep 2011 15:36:01
Message: <4e7253a1@news.povray.org>
>>> at that point.
> Yes and no.
> show ?
> show interface ?
> etc...
Oh, right, I see. Well that seems logical enough...
That's very reassuring.
> stands.
I see. (I think...)
>> 2. What does it do?
Interesting. I didn't know Windows was actually capable of doing that.
Usually when I need a router in a hurry, I load up Linux and read some
manpages...
Hmm, I wonder... If my VPN client doesn't route all the subnets I want,
can I get it to dump the packets onto the wrong LAN segment, and then
trust the router at that end to take it to the correct place?
It's neat that you can configure it via IP. Then again, if you configure
the IP stuff wrong, you need to connect somehow so you can reconfigure
it. :-}
I wonder what authentication options there are for SSH...
