POV-Ray : Newsgroups : povray.off-topic : Revelations Server Time
14 Aug 2026 15:08:37 EDT (-0400)
  Revelations (Message 1 to 2 of 2)
Subject: Revelations
Date: 5 Sep 2011 06:33:13
Message: <4e64a569$1@news.povray.org>
Last night, as I sat waiting for some compute-bound task to finish, I
was idly wandering through the contents of my hard drive. Suddenly, I
stumbled upon something utterly unexpected: I found a render I never
knew I had.
Literally. I have no recollection of designing this scene, even though
it's moderately complex. I certainly have no recollection of waiting for
it to finish rendering - despite the fact that the render time is
/obviously/ measured in multiple *months*! O_O
Most puzzlingly of all, it /looks good/. Which is extremely rare for
anything *I* designed. :-o
OK, so I know what you're thinking. You're thinking I got this from
someone else, right? Well no, that's not it. Quite apart from the file
being almost 7GB in size and the POV-Ray source code being present, it's
/obviously/ directly related to all the other files in that folder,
which I /do/ remember making.
Basically, there's a folder containing a set of animations. Each one is
roughly 5 minutes in length, and they start off trivially simple and
gradually increase in complexity. I remember designing them all...
except the final one, which is much more impressive than all of the
rest, and would have had a much larger render time.
Come to think of it, I'm surprised I actually finished rendering all of
these. 5 minutes is a /long/ animation. That's a heck of a lot of frames
to render. (7,500 to be exact.) Unless you can keep the render time per
frame below a few seconds, that rapidly spirals into multiple months of
rendering. I remember sitting through the first few animations,
rendering low-res previews and tweaking the settings, etc. But I don't
recall rendering some of the later ones. And, again, the final one I
have no recollection of it ever existing.
In short, I just discovered a really cool animation I didn't know I
made. And it's finished! It's complete and everything.
Maybe I should put the whole set on YouTube? Then again, I'd have to
transcode it somehow. Currently all the videos are uncompressed. Up to a
certain resolution, that works. But once the image size gets large
enough, it stops being possible to play them uncompressed; my harddrive
isn't fast enough. Which is a bit of a problem, since I've yet to
discover a codec which preserves all the crispness and detail that I've
waited months to painstakingly render.
Even the mighty H.264 set to 9000 kbit/sec seems to blur and smudge my
works. :-( (And it doesn't appear to be possible to set the bitrate any
higher than that. The slider doesn't move any further.)
Subject: Re: Revelations
Date: 11 Sep 2011 06:04:23
Message: <4e6c87a7@news.povray.org>
Actually, no. It's Huffyuv compressed.
I have "ffdshow" installed on my PC, which means that I can compress
videos with VirtualDub. However, for reasons I don't full understand, it
is impossible to *decompress* videos with VirtualDub. The videos play
perfectly well, but when you ask VD to open them, it utterly insists
that it can't find the correct codec. (My best guess is that it's
looking for a codec named "Huffyuv", and ffdshow isn't called "Huffyuv".)
Does anybody know how to force VD to use ffdshow to decode the video? If
you select the "advanced open dialog", it offers to let you specify a
"FOURCC code", but I don't know if that helps...
http://blog.orphi.me.uk/
