POV-Ray : Newsgroups : povray.off-topic : Programming style question - specifically Python Server Time
16 Jun 2026 18:04:51 EDT (-0400)
  Programming style question - specifically Python (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Programming style question - specifically Python
Date: 19 Aug 2011 16:49:02
Message: <4e4ecc3e$1@news.povray.org>
On 8/19/2011 13:04, Shay wrote:
> bool_a = len(A[0]) == 2
> bool_b = min([A[2] == x[2] for x in A[1:])
> bool_c = ccw_angle(*A)<  pi
> bool_b will not work if bool_a is true
bool_b = bool_a ? min(...) : false
   How come I never get only one kudo?
Date: 21 Aug 2011 01:52:04
Message: <4e509d04@news.povray.org>
>> bool_b = min([A[2] == x[2] for x in A[1:]) bool_c = ccw_angle(*A)<  pi
Beautiful, but that doesn't seem to be valid Python. However, a bit of
guess-work reveals that:
bool_b = False if bool_a else min(...)
does work. So, I learned something there.
Thanks.
 -Shay
Date: 21 Aug 2011 11:00:33
Message: <4e511d91$1@news.povray.org>
OK. I had assumed python had that operator. It's the same as
if bool_a then bool_b = min(...) else bool_b = false;
I think you *might* have the condition reversed on that. That looks like
it's saying you don't evaluate bool_b if bool_a is true.
Date: 21 Aug 2011 22:14:30
Message: <4e51bb86$1@news.povray.org>
>>>> pi
>> bool_b = False if bool_a else min(...) does work. So, I learned
>> something there.
That's what I want. I mistyped a portion of my example
should have been
bool_b = min([A[0][2] == x[2] for x in A[1:])
bool_b tests if all of the [2]s are equal. If bool_a is true, there are
no [2]s.
Thanks for the help.
 -Shay
Date: 22 Aug 2011 11:04:59
Message: <4e52701a@news.povray.org>
  That seems to have redundancy. How about:
bool_b = bool_a || min(...);
Date: 25 Aug 2011 20:08:46
Message: <4e56e40e@news.povray.org>
More efficient perhaps, but less readable IMO. You don't really want to set
bool_b to the value of bool_a, so this I would consider misleading. There's
an implication that the value of bool_a propagates, whereas in actuality
it's more a gating value.
Date: 26 Aug 2011 10:48:39
Message: <4e57b247@news.povray.org>
  Btw, I made a mistake above. Obviously it should have been:
bool_b = bool_a && min(...);
  (Yes, I understand the irony that you not catching this mistake is a
tell-tale sign of the obfuscatory nature of the expression. I still prefer
it, though.)
  You are not setting bool_b the value of bool_a. You are making a boolean
'and', and assigning the result of that to bool_b. The shortcut evaluation
of operator && is being (ab)used here to avoid evaluating the min(...)
expression in case bool_a is false. The advantage of this is that it
avoids the redundancy of the "else false" branch. (It's a bit like that
annoying "else break;" at the end of a loop, only in this case it's easily
avoidable.)
  This is, btw, a common tactic used in unix shell scripts. There the
&& operator can be used for a very similar purpose: If the command at the
left hand side succeeds, the command at the right hand side is executed.
The value of the expression is that of the first command that didn't
succeed, or success if they all succeeded.
  This means that rather than having to do something like
    if [ command1 ]; then if [ command2 ]; then command3; fi; fi
you can do it like:
    command1 && command2 && command3
  This is handy to execute several commands in succession, but have the
entire thing immediately stop if any of the commands fails. (This in
contrast with "command1; command2; command3" which will not stop if any
of those fails.)
Date: 26 Aug 2011 19:26:29
Message: <4e582ba5$1@news.povray.org>
And that's exactly my complaint. The value of bool_b is dependent on bool_a,
but not really assigned from it. I'm sure you see what I mean.
But when the first expression indicates the second can't be evaluated,
there's no reason to assign the first expression to bool_b, semantically
speaking. I.e., it looks to me like it's tying the two too closely.
True. On the other hand, the value of bool_b is never used if bool_a is
wrong, so unless your language insists it be assigned before use and doesn't
initialize it for you, there's no real reason to assign to it at all if
bool_a indicates the value is invalid.
> avoidable.)
I can see your point.
Yeah, but IME it's usually used *only* to short circut the evaluation, not
to actually use the result. YMMV.
Date: 27 Aug 2011 10:14:33
Message: <4e58fbc8@news.povray.org>
  Not really.
  bool_a is not being assigned to bool_b. The result of the expression
"something && something_else" is being assigned to bool_b.
  I don't even understand what is it that you don't like about this.
  It may be *common* for the result to be discarded, but it's perfectly
possible to take the result into account for subsequent decisions. The
advantage of using a sequence of commands separated by && is that you
don't need to put an 'if' after each of the commands, if you want to
react to one of them failing. You only need to use one 'if' to catch any
of them failing.
Date: 27 Aug 2011 16:34:42
Message: <4e5954e2@news.povray.org>
> "something&&  something_else" is being assigned to bool_b.
If bool_a is false, then bool_a is being assigned to bool_b. This implies in
a vague sense that bool_b is false when bool_a is false. In reality, bool_b
is *undefined* when bool_a is false. One assigns it "false" not because
bool_a is false, but because one must assign something in that statement,
and it doesn't matter what gets assigned.
In other words, in a language that supported tri-value logic (like PHP,
perhaps), I'd say
   bool_b = bool_a ? min(...) : undefined
to make it clear.
> advantage of using a sequence of commands separated by&&  is that you
> of them failing.
Sure. And if the person wrote
   bool_a = big_long_expression_one(alpha,beta,gamma)
   bool_b = big_long_expression_one(alpha,beta,gamma) && min(...)
then I would agree that would be the right expression.
Again, it's a matter of taste. Written with the boolean, I'd have to stop
and look at the rest of the code to see if, for example, there's a
    bool_b == bool_a
kind of expression somewhere later to try to understand what the bools meant.
Of course, picking better names for the bools would obviate the entire
debate. :-)
