POV-Ray : Newsgroups : povray.off-topic : Today's WTF moment Server Time
16 Jun 2026 23:01:00 EDT (-0400)
  Today's WTF moment (Message 21 to 30 of 64)
Subject: Re: Today's WTF moment
Date: 5 Sep 2011 11:43:23
Message: <4e64ee1b$1@news.povray.org>
On Mon, 05 Sep 2011 10:35:45 +0100, Invisible wrote:
>  that water freezes at 0°C (actually no, it
> doesn't) and boils at 100°C
It also doesn't always boil at 100C - reduce the atmospheric pressure and
see when it boils.
Jim
Date: 5 Sep 2011 11:52:50
Message: <4e64f052$1@news.povray.org>
> see when it boils.
Or increase it. Or add impurities. Or whatever.
Yes, but under /normal/ circumstances, it boils at 100°C, which is why
it's defined that way. :-P
Date: 5 Sep 2011 12:39:38
Message: <4e64fb4a$1@news.povray.org>
>> see when it boils.
Pure water at average sea level presure boils/condense at 100°C and
melt/freeze at 0°C at the same presure level. Both by definition. In
fact, it's the definition of 0°C and 100°C.
(0°F is defined as the freezing poing of sea water and 100°F as the body
temperature of a "healthy" human male, but the "healthy" human male who
was used for the original mesure was somewhat feverish at the time, and
had the flue the next day...)
Change the presure and you also change freezing temperature.
Date: 5 Sep 2011 13:17:32
Message: <4e65042c@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
  So, does water freeze or melt at exactly 0 degrees celsius?
Date: 5 Sep 2011 13:47:06
Message: <4e650b1a@news.povray.org>
 why it's
No it doesn't. At 100°C, it's in equilibrium. Just like at 0°C,
 it's neither
getting more frozen or less frozen.
   How come I never get only one kudo?
Date: 5 Sep 2011 14:29:21
Message: <4e651501$1@news.povray.org>
>> and see when it boils.
Not here at 4,000 feet - "normal" circumstances here have it boiling at a
slightly lower temperature. :P
IOW, it all depends on how you define "normal".  (Hence my suggestion of
reducing the atmospheric pressure, because here, lower pressure is
'normal').
Jim
Date: 5 Sep 2011 14:30:28
Message: <4e651544$1@news.povray.org>
Yes, at some altitudes, it does.
Jim
Date: 5 Sep 2011 14:33:14
Message: <4e6515ea$1@news.povray.org>
96.2°C, a piffling 3.8° lower.
> 'normal').
This is why the /actual/ specification is far more complicated. But for
any sane real-world purpose, you can more or less ignore such
technicallities.
http://blog.orphi.me.uk/
Date: 5 Sep 2011 18:50:22
Message: <4e65522e$1@news.povray.org>
>> it's
> No it doesn't. At 100°C, it's in equilibrium. Just like at 0°C, it's
> neither getting more frozen or less frozen.
Worse than that, in certain conditions you can "hyper-heat" water, and,
I assume, probably super cool it, without changing state. In the former
case you just need a container that has "no" places for bubbles to form.
Not sure what you would need to do in the later case to make it happen,
if you could.
Date: 5 Sep 2011 20:58:29
Message: <4e657035@news.povray.org>
At sea level, yes. Melt if you add energy, freeze if it looses energy,
As you climb or reduce presure, the freezing point slowly climb, but not
much.
As you go lower or increase presure, the freezing point goes into the
negative.
