POV-Ray : Newsgroups : povray.off-topic : Curious C / C++ defined behavior question Server Time
16 Jun 2026 20:17:32 EDT (-0400)
  Curious C / C++ defined behavior question (Message 11 to 20 of 20)
Subject: Re: Curious C / C++ defined behavior question
Date: 28 Jun 2011 12:30:38
Message: <4e0a01ae$1@news.povray.org>
On 6/28/2011 5:26, Lars R. wrote:
> On 06/22/11 21:50, Darren New wrote:
>> Does the standard say anything about how deeply nested calls can
>> recurse?
> Partially: At least 2, because it says that functions can be called
> recursively. :-)
Heh heh heh. That's a point.
> there are a lot of limits and other limitations where "no diagnostic is
> required". But I cannot find anything about a maximum of function call
> nesting levels, neither in C++ 2003 nor in C 99.
See, that bothers me. Because it implies a function call will always
succeed, because they didn't say it might fail but they do tell you the
semantics of it succeeding.  That's why I wondered what kind of wording they
were using.
   "Coding without comments is like
    driving without turn signals."
Date: 29 Jun 2011 03:44:09
Message: <4e0ad7c9@news.povray.org>
>>> recurse?
>> recursively. :-)
Me too.
> they were using.
Indeed.
I'd suggest something like “A recursion depth of at least 5 must be
supported by the platform. The actual limit might be higher and can be
determined by ...”
But such guarantee is not easily definable because the size of the
function parameters is not limited (only their number). On most
platforms the function parameters live on the CPU stack (when the
registers that are used for parameter transfer are exhausted). That
stack is on most platforms much smaller than the available memory, but
its size cannot be determined in a ISO-C++-compliant way.
So even a recursion “depth” of 1 might fail in such pathetic cases.
But statements like “Every function call might fail due to reasons that
are out of scope of this standard“ are also not sensible, I think.
Any other options or opinions? –.–
Lars R.
Date: 29 Jun 2011 12:49:19
Message: <4e0b578f@news.povray.org>
t be
> determined by ...”
Well, it's not even *recursion* depth, but just call stack depth.
Not any more. In the original version of C, you couldn't pass structs by
value, so it would have been easier to figure out how big your arguments
are.
hetic cases.
If you don't have actual *recursive* functions, you don't need to allocat
e
locals or arguments on the stack at all. On a machine with limited hardwa
re
stack (like a 6502 say), you might very well generate code that will
allocate bigger items in the heap and clean them up when you return, for
example.
I've used Pascal compilers (on a Z-80 for example) that stored all local
variables at fixed addresses. I don't remember how it handled recursion,
but
since I was writing a B-Tree library, I'm pretty sure it recursed OK.
ons that
nk.
I think you could require a minimum amount of stack space to be available
if you wanted. The standard could guarantee that the number of bytes of a
uto
and parameter values passed not exceeding a particular value could be
specified, if they wanted. It's not like the concept of "size of memory
occupied" isn't common in C.
Date: 29 Jun 2011 15:55:47
Message: <4e0b8343@news.povray.org>
Lars R. <rou### [at] gmxnet> wrote:
> I'd suggest something like ???A recursion depth of at least 5 must be
  They can't do that because then all compilers would become non-standard
in this regard.
  You can't impose a minimum amount of recursions because it depend on the
size of the stack and how much stuff is allocated on it. You can allocate
such a huge array on the stack that you might not be able to recurse even
once without running out of stack space, regardless of how large the stack
is.
Date: 29 Jun 2011 21:37:12
Message: <4e0bd348$1@news.povray.org>
> is.
That's why I thought maybe imposing a minimum stack size in bytes would work
out better. Of course, compilers wouldn't become non-standard to support
this - they'd just have to allocate big locals somewhere other than the
stack, which is of course a bad idea for any reason other than compatibility
with lame requirements. :-)
Date: 29 Jun 2011 23:40:46
Message: <4e0bf03e$1@news.povray.org>
Am 29.06.2011 18:49, schrieb Darren New:
> allocate locals or arguments on the stack at all. On a machine with
> limited hardware stack (like a 6502 say), you might very well generate
> code that will allocate bigger items in the heap and clean them up when
> you return, for example.
... which does not prevent you from failure due to hitting the memory limit.
> but since I was writing a B-Tree library, I'm pretty sure it recursed OK.
In that case it either can't have placed all local variables at fixed
addresses, or must have placed a hard limit on recursions.
Either way, there /always/ is a limit on recursion depth, and AFAIK
determining at compile-time whether an arbitrary program ever hits that
depth is as hard as solving the halting problem.
Date: 30 Jun 2011 00:25:48
Message: <4e0bfacc$1@news.povray.org>
Of course.  I wasn't trying to imply there might not be a recursion limit.
Of course anything that allocates memory might fail, and a function call
that's going to allocate a large chunk of memory for a parameter could fail.
I honestly don't remember. I remember I had to switch to a C compiler
because I didn't have enough memory for all local variables at once.
Right.  Sorry if what I wrote implied I thought that wasn't the case.
Date: 30 Jun 2011 03:46:48
Message: <4e0c29e8$1@news.povray.org>
> in this regard.
Hence I wrote: "I would". And in the next sentence I explained why this
whish is not realizable.
L.
Subject: Partially agree
Date: 30 Jun 2011 03:54:43
Message: <4e0c2bc3$1@news.povray.org>
>> determined by ...”
If a language allows recursion you need some kind of stack. If a
language only allows non-recursive function calls you can hold the local
variables at fix addresses, as you also wrote below.
Some tricks like tail recursion optimization allows such fix addresses
also for a limited kind of recursive functions, though...
> are.
Outdated non-standard versions don't interest me. ^^
> available, if you wanted.
If you require that (non-recursive) function calls use a "stack" at all.
That's why both the C and C++ standards avoid to use the term "stack" in
this context.
> of bytes of auto and parameter values passed not exceeding a particular
> value could be specified, if they wanted.
Sounds better. So it doesn't matter whether parameters are passed on
some kind of "stack" (in memory or CPU registers) or on fixed locations
(im memory or fixed CPU registers).
		Lars R.
Subject: Re: Partially agree
Date: 30 Jun 2011 13:15:57
Message: <4e0caf4d$1@news.povray.org>
ust be
e
>>> determined by ...”
l
Sure. I was just saying that supporting a call stack depth of at least fi
ve
is more precise than supporting a recursion depth of at least five. I.e.,
it's possible to run out of stack space even if there's no recursion
involved, assuming you're allocating locals on a stack.
And it's possible for each function to have its own stack, so it can get
really messy.
n
> this context.
Right. But you could still phrase it as requiring a minimum amount of spa
ce
for arguments and auto variables.  I.e., you could express it as adding u
p
the value of sizeof() for each argument in the call chain and each auto
local in the call chain and have a minimum number there. That doesn't mea
n
you can't implement it differently, but it does give some guarantees abou
t
how much space you have to provide for user variables.
Exactly. It has to be written in terms of the semantics of the language,
not
in terms of an implementation.
