POV-Ray : Newsgroups : povray.off-topic : A retro moment Server Time
29 Jul 2026 00:04:55 EDT (-0400)
  A retro moment (Message 21 to 30 of 50)
Subject: Re: A retro moment
Date: 7 Jun 2011 11:29:08
Message: <4dee43c4$1@news.povray.org>
>>>> OK. So it's called a file allocation table rather than a directory
>>>> listing. Same difference.
>>> Um, no. These are two entirely different things.
>> In what way?
> http://en.wikipedia.org/wiki/FAT_file_system#Design
Oh, I see. So the FAT is just a map of free clusters?
I don't think that impacts what I originally said though; you could
still cache it.
> In the same way that a linked list is an entirely different thing from a
> hashtable.
Conceptually, a dictionary is a dictionary, regardless of which data
structure you use to implement it.
Date: 7 Jun 2011 11:39:02
Message: <4dee4616$1@news.povray.org>
No. It's a file allocation table.
> I don't think that impacts what I originally said though; you could still
> cache it.
It is cached. It's just that the cache gets written when you close a file
after allocating space from the cache, because the system can't tell you're
going to copy more files.  Otherwirse, writing a big file would have to
slopping back and forth between three different tracks for every granule
written.
>> hashtable.
And a linked list is not a dictionary.
   "Coding without comments is like
    driving without turn signals."
Date: 7 Jun 2011 11:41:39
Message: <4dee46b3@news.povray.org>
That's like saying "an open set is any set that's open". This is a
useless description.
>> cache it.
> file after allocating space from the cache, because the system can't
> tell you're going to copy more files. Otherwirse, writing a big file
> would have to slopping back and forth between three different tracks for
> every granule written.
OK. But I still don't see why you can't cache the entire disk image on a
typical modern PC. (Obviously there was a time when this would have been
impractical.)
Date: 7 Jun 2011 11:58:15
Message: <4dee4a97$1@news.povray.org>
> That's like saying "an open set is any set that's open". This is a useless
> description.
You're sitting in front of google. And wikipedia.
> impractical.)
You can. But if you want to make it safe to remove the disk when it's
consistent, you still have to write it out after you make changes. I'm not
sure why you're not getting this point.  Floppy disks don't have a "remove
safely" feature. They have a hardware button on the front.
Date: 7 Jun 2011 13:13:04
Message: <4dee5c20$1@news.povray.org>
On 07/06/2011 03:58 PM, Darren New wrote:
> On 6/7/2011 7:49, Invisible wrote:
>> You know, the rest of the filesystem is cached too,
> Not on a removable floppy drive.
So, essentially, your entire argument is "the user can eject the disk at
any time, therefore it's unsafe to cache anything".
Correct me if I'm wrong, but wouldn't the contents of the disk be
irrepairably corrupted *anyway*? That's why there's a disk activity
light; so you don't hit eject while it's still writing stuff.
http://blog.orphi.me.uk/
Date: 7 Jun 2011 13:21:07
Message: <4dee5e03@news.povray.org>
On Tue, 07 Jun 2011 13:00:17 +0100, Invisible wrote:
> I can never remember whether it's 3.5 or 3.25 inch.
Standard sizes are/were 3.5", 5.25", and 8".
Jim
Date: 7 Jun 2011 13:23:19
Message: <4dee5e87$1@news.povray.org>
Having actually done this at several points in the past, I can assure you
that Darren is correct.  Caching removable devices tends to be *very* bad
for data integrity.
That's why, for example, in Windows (and on Linux), you need to "safely
remove" USB flash drives - they are cached for performance reasons.
Jim
Date: 7 Jun 2011 13:24:31
Message: <4dee5ecf$1@news.povray.org>
Random fact: I'm ancient enough to *remember* 5.25" floppy disks. (They
were noteable in that they were actually *floppy*.)
Date: 7 Jun 2011 13:26:35
Message: <4dee5f4b@news.povray.org>
> for data integrity.
In which way is suddenly removing a USB flash drive different from
suddenly ejecting a floppy disk?
So why is it perfectly OK to cache a USB flash drive, but completely
unthinkable to cache a floppy disk?
(Also, I'm sure I saw somewhere a setting in Windows to select whether
the "safely remove hardware" thing is optional or not. The default
setting is worse performance in exchange for pulling the drive /not/
completely screwing the filesystem. I'm guessing M$ found that too many
people actually did this...)
Date: 7 Jun 2011 13:28:49
Message: <4dee5fd1$1@news.povray.org>
>>> at any time, therefore it's unsafe to cache anything".
>> you that Darren is correct.  Caching removable devices tends to be
>> *very* bad for data integrity.
Because people are used to ejecting a diskette when they've finished
writing to it.  Sometimes you have to keep an old method around because
of the habits people form.
See above.
Performance vs. reliability.  Traditional tradeoff.
Jim
