POV-Ray : Newsgroups : povray.off-topic : Data compression Server Time
11 Apr 2026 10:43:44 EDT (-0400)
  Data compression (Message 1 to 10 of 15)
Subject: Data compression
Date: 10 May 2011 11:32:25
Message: <4dc95a89@news.povray.org>
I've got a CD at home. When I first got it, I noticed that certain
passages sound very slightly strange. Today, ten years later, I know
exactly what it sounds like: it sounds like lossy audio compression.
This raises two interesting questions:
1. Why the hell would you put compressed audio onto a CD rather than the
uncompressed original source?
2. If I can tell that it's compressed, despite not having the
uncompressed original to compare to, doesn't that mean that there's more
redundancy in the signal than the codec is taking advantage of?
Now I don't actually know which codec was used here. [Asking whether you
can tell the codec by the compression artefacts is another interesting
question.] But in this instance, there are long echo tails which are
getting audibly chewed up. Not drastically so, but enough to be noticeable.
The only audio codecs I've looked at seem to work exclusively in the
frequency domain. The general algorithm seems to be
- Chop the signal into chunks.
- Apply some Fourier-based transform to each chunk, taking it into the
frequency domain.
- Use a psychoacoustic model to priorities each element of the spectrum.
- Adjust the resolution of each spectrum sample in proportion to
priorities and available bandwidth.
- Encode each spectrum sample with the requisite number of bits.
- Apply an entropy coder to cram the results into the smallest available
space.
All of this makes no use whatsoever of the striking similarity between
consecutive audio chunks. That's the equivalent of a video codec which
encodes each individual frame completely separately, without reference
to the previous frames. (I really hope no serious video codes do this!)
This disregard for temporal redundancy is presumably why I can tell the
difference between compressed and uncompressed audio, even with no
reference to compare to. Interestingly, this /also/ suggests that it
might perhaps be possible to /recover/ the lost information. I mean, if
I can tell it's gone, perhaps it's possible to deduce what it was?
Perhaps a more interesting question is "how can we make a better codec?"
My personal feeling would be to split the audio into many narrow-band
signals, map the amplitude curve of each one, and store a compressed
description of these curves.
Now I just need to go implement that... HA! o_O
Subject: Re: Data compression
Date: 10 May 2011 12:23:11
Message: <4dc9666f$1@news.povray.org>
Because you don't have the original source, or the person mastering the CD
got the original source over a network and didn't want to spend the
bandwidth and didn't care?
There are lots of CDs out there that were copied off vinyl albums that
weren't properly compensated and have the treble turned way up. (Vinyl turns
the treble up, and the record player turns it back down, to reduce hiss.)
Tomita's "Pictures at an Exhibition" has several tracks where they put the
same audio on both the left and right channel, just because they screwed up.
> 2. If I can tell that it's compressed, despite not having the uncompressed
> original to compare to, doesn't that mean that there's more redundancy in
No. You can tell someone is talking over a telephone by the fact that too
much information is lost. Same with autotune.
> Now I don't actually know which codec was used here. [Asking whether you can
> question.] But in this instance, there are long echo tails which are getting
Sounds like nyquist limits screwing up the codec, to me.
   "Coding without comments is like
    driving without turn signals."
Date: 10 May 2011 13:13:23
Message: <4dc97233$1@news.povray.org>
> CD got the original source over a network and didn't want to spend the
I can only imaging it was the latter. This particular CD is modern
electronic dance music, after all.
> turns the treble up, and the record player turns it back down, to reduce
> hiss.)
The other day, I was listening to a CD of vintage music, and a suddenly
noticed that most of it is monophonic. Imagine that! ;-)
>> uncompressed
> too much information is lost. Same with autotune.
You can't tell that information has been lost unless you can tell that
it was there in the first place. And if you can tell there's something
missing just by looking at what's still there, there's redundancy.
>> you can
>> getting
Take any piece of sound. Apply too much MP3 compression. You can hear
the quantinisation steps in the signal levels.
This isn't that bad, of course. You have to listen fairly hard to hear
it. Then again, I'm the sort of person who owns a £100 set of headphones
and a £300 CD player, so...
http://blog.orphi.me.uk/
Date: 10 May 2011 14:23:53
Message: <4dc982b9$1@news.povray.org>
Yeah, I usually encounter it on albums that were old on vinyl. :-)
it
> was there in the first place. And if you can tell there's something mis
sing
Except you can compare to that which you've heard elsewhere. Have you eve
r
heard someone do a call-in phone interview on the radio? Could you tell t
he
difference between the DJ's voice and the phoned-in voice, even though yo
u
might never have heard either before? It's because you know what tonal
ranges you should be hearing.
You can tell an over-compressed violin because you're comparing it to oth
er,
uncompressed violins in your memory. Even if there's no redundancy left.
Indeed, why do you not think you're hearing a lack of redundancy?
> Take any piece of sound. Apply too much MP3 compression. You can hear t
he
OK.
it.
es and a
Yep.
Date: 10 May 2011 14:31:14
Message: <4dc98472@news.povray.org>
  It becomes even worse when executives demand the audio to be amplified
ten-fold due to the loudness war.
Date: 10 May 2011 15:15:18
Message: <4dc98ec6@news.povray.org>
Maybe that the original recording was done in a lossy format, or even a
non-lossy format but with a sample rate set to low and a sample
resolution also to low... Like 4000 kHz (or even less), 4 bits...
(I had a single CD that contained the whole Beatles discography encoded
as .wav at that level or about...)
It's just that you have reasons to expect a higher chromatic range than
the one you have.
If it sound like speech but misses the harmonics that are normaly
present and expected, it will sound suspicious or strange.
Same thing for any known musical instrument's sounds.
If there is some sampling of previously heard peices, you also can
perceive the lacking parts.
Even the best codec set at the highest quality can't do miracle if the
source is bad...
Date: 11 May 2011 04:04:49
Message: <4dca4321$1@news.povray.org>
A normal CD is 40 kHz, so 4000 kHz would be 10x *higher* resolution than
normal. And 4 bits per sample would be almost unrecognisable.
> the one you have.
Chromatic range? I think perhaps you meant dynamic range.
> source is bad...
In this case, that's unlikely to be the problem.
Date: 11 May 2011 04:06:48
Message: <4dca4398$1@news.povray.org>
>> You can't tell that information has been lost unless you can tell that it
>> missing
> ever heard someone do a call-in phone interview on the radio? Could you
> tell the difference between the DJ's voice and the phoned-in voice, even
> though you might never have heard either before? It's because you know
> what tonal ranges you should be hearing.
> other, uncompressed violins in your memory. Even if there's no
> redundancy left. Indeed, why do you not think you're hearing a lack of
> redundancy?
Like I said, I can hear glitches in various quiet echo trails. The sound
should die away smoothly, but instead it's stepping. The codec is
apparently ignoring temporal redundancy.
Date: 11 May 2011 04:27:09
Message: <4dca485d$1@news.povray.org>
CD is 44.1kHz, dual channel, 16 bits per sample (linear PCM).
I guess Alain was thinking of a recording at 4000 Hz.
4 bits sampling does in fact exist, but not in CD format, rather as
adaptative delta encoding (I used to have such hardware which could
record & play sound using only 4 bits per sample. All the smart was in
the chip)
Transforming a capture into a CD-style wav file is something I never
succeed to achieve.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 11 May 2011 04:36:28
Message: <4dca4a8c@news.povray.org>
Which would put the Nyquist limit at a piffling 2000 Hz. Even POTS
manages better bandwidth than that. Note that 2000 Hz is roughly 2
octaves above middle C. And that's only the fundamental frequency,
ignoring all the harmonics. Note also that the human voice runs well
outside that range as well.
Indeed. It depends on what you're trying to sample. Some applications
might not need high spatial resolution. Others might not need high
temporal resolution. For example, we sample the output of our mass
spectrometers at about 4 Hz. The signal changes so slowly that there's
really no need to sample any faster.
I would suggest, however, that 4 bits/sample would be inadequate for
audio applications.
