POV-Ray : Newsgroups : povray.off-topic : Computer language quirks Server Time
29 Jul 2026 00:03:33 EDT (-0400)
  Computer language quirks (Message 24 to 33 of 33)
Subject: Re: Computer language quirks
Date: 13 May 2011 10:43:59
Message: <4dcd43af$1@news.povray.org>
Am 13.05.2011 09:44, schrieb Zeger Knaepen:
> I suppose it wouldn't work if "bar" really had a return-value.
Indeed, but you could still cast it to void:
     return (void)bar(...);
Date: 13 May 2011 10:46:24
Message: <4dcd4440$1@news.povray.org>
Am 11.05.2011 22:17, schrieb Darren New:
> On 5/11/2011 12:57, Warp wrote:
>> compiles and runs just fine.
> Huh. I wonder if that's just a GCC thing or whether that's actually in
> the standard. I just *actually* tried it with C# and I get "since XYZ
> returns void, the return statement may not be followed by an expression."
The C language standard is pretty clear about this; quoting from
ISO/IEC 9899:TC2:
"6.8.6.4 The return statement
Constraints
1  A return statement with an expression shall not appear in a function
whose return type is void. [...]"
The C++ standard, however, explicitly allows for such a construction;
quoting from some 2005 working draft:
"6.6.3 The return statement [stmt.return]
3  A return statement with an expression of type “cv void” can be used
only in functions with a return type of cv void; [...]."
("cv" being shorthand for "an arbitrary set of cv-qualifiers, i.e., one
of {const }, {volatile }, {const, volatile}, or the empty set")
Not of Java though; quoting from "The Java(TM) Language Specification,
Third Edition":
"8.4.7 Method Body
If a method is declared void, then its body must not contain any return
statement (§14.17) that has an Expression."
So it appears that C++ is about the only member of the C-style language
family allowing for such a construct per specification.
Date: 13 May 2011 10:51:35
Message: <4dcd4577$1@news.povray.org>
> The C language standard is pretty clear about this; quoting from ISO/IEC
> 9899:TC2:
> Constraints
> Third Edition":
> "8.4.7 Method Body
Now that's what a call thorough research! O_O
Date: 13 May 2011 12:51:16
Message: <4dcd6184$1@news.povray.org>
On 5/13/2011 0:44, Zeger Knaepen wrote:
> the function "bar" doesn't return anything, so if "foo" returns the
> return-value of "bar", it also doesn't return anything.
And that's exactly why I started this thread. The syntax makes that
distinction, whereas I thought it shouldn't. Turns out that C++ at least
really doesn't make that decision.
Altho given that a simple "return;" from a function declared as returning an
int in C doesn't even raise a warning in gcc, I suspect it's at least as
much the traditional sloppiness of C in terms of parameter passing as it is
something intentionally designed into the spec.  ("return 28;" from a void
function gives a warning but not an error.)
   "Coding without comments is like
    driving without turn signals."
Date: 13 May 2011 12:54:09
Message: <4dcd6231$1@news.povray.org>
Thanks for looking all that up!   (I'll look up the C# if anyone cares. :-)
I suspect that was put in when templates and overloading and stuff made it
make sense.
Date: 14 May 2011 03:40:37
Message: <4dce31f5@news.povray.org>
> make sense.
  I get the feeling that, indeed, templates "demanded" a lot of relaxing of
the rules, which could have been much stricter (especially compared to C),
so that templated code would not break as easily if you changed between
types.
  For example, in C the only way to make an explicit cast is using the
syntax "(type) variable". However, C++ added the possibility of writing
such casts as "type(variable)". This allows for 'type' to not only be a
basic type, but also a class (in which case it would be a constructor
call).
  Moreover (something that many C++ programmers don't realize), C++ allows
the syntax "(type) variable" even for class types (in which case it's
*still* a constructor call). Basically "(type) variable" and "type(variable)"
are more or less identical expressions in C++. About the only practical
situation where this may come handy is in templated code.
  Overloading operators is useful in non-templated code as well, although
it becomes more or less syntactic sugar there. It's most useful in templated
code because it, once again, allows for the same code to handle basic types
and classes. It is, for example, what allows STL containers to handle both
types of elements. (For example std::set and std::map require for the
elements to be assignable, and comparable using the comparison operator <.
Since you can overload operator < for classes, this means that you can use
both internal types, such as ints, and classes, such as std::string, with
the same std::set or std::map.)
Date: 14 May 2011 12:34:57
Message: <4dceaf31$1@news.povray.org>
> call).
That's cool. I'm still not sure whether to like C++ or hate it. ;-)
So what's the static_cast<...> bit all about, then? Is that just something
easy to grep for, or does it have different semantics than a regular cast?
Date: 15 May 2011 04:00:04
Message: <4dcf8804@news.povray.org>
> > call).
  The C-style cast will cast from anything to anything else. Hence it's
not the safest thing in the world, as it's relatively easy to miscast and
have your program misbehave.
  static_cast will only work between compatible types. For example you can
cast an int to a char, a signed int to an unsigned int, classes to other
classes within their inheritance hierarchy, and so on. However, if you try
to static_cast between incompatible types, you will get a compiler error.
For example, you can't cast an int to a pointer, a const pointer to a
non-const one (even if the pointers are of the same type) or between classes
not in direct inheritance relationship.
  It is thus recommended to use static_cast instead of C style casts
whenever possible. Incidentally (but not surprisingly), if you use
static_cast to cast some variable to a class type, and that class has
a constructor that takes a value of that type, it will work. (It will
be the same as constructing the object with the regular syntax.) Supporting
the C style of casting exists more or less just for compatibility with C
code (which of course means that many C++ programmers are using it instead
of static_cast because it's shorter and more "convenient").
  To cast constness away between compatible types const_cast should be
used. (It's basically its only role.)
  To cast between incompatible types reinterpret_cast should be used.
(It assumes you know what you are doing.)
  reinterpret_cast should *not* be used to cast between pointers to objects
in the same inheritance hierarchy because it may forgo adjusting the pointer
offset which may be necessary in some situations.
Date: 15 May 2011 04:36:26
Message: <4dcf908a$1@news.povray.org>
Am 14.05.2011 18:34, schrieb Darren New:
>> call).
> something easy to grep for, or does it have different semantics than a
> regular cast?
"5.2.9 Static cast [expr.static.cast]
1  The result of the expression static_cast<T>(v) is the result of
converting the expression v to type T. If T is a
reference type, the result is an lvalue; otherwise, the result is an
rvalue. Types shall not be defined in a static_cast.
THE STATIC_CAST OPERATOR SHALL NOT CAST AWAY CONSTNESS (5.2.11)."
(emphasis added)
I.e. the static_cast of a const pointer remains a const pointer. It is
therefore a good idea to always use static_cast instead of a classic
cast, as it prevents accidental "stripping" of the const property;
consider, for instance, the following code:
     void foo(int* x);
     void bar(void* x) {
         foo((int*)x);
Now assume the code is refactored to use const qualifiers, but for some
reason the cast in the call to foo() goes unnoticed:
     void foo(const int* x);
     void bar(const void* x) {
         foo((int*)x);
Now assume a functionality change requires foo() to modify its parameter:
     void foo(int* x);
         foo((int*)x);
The code still compiles, so it goes unnoticed that the function
signature of bar() is now actually wrong.
If the original code author had used static_cast instead, the mistake
would have been detected by the compiler, as the following code raises
an error due to mismatching const qualifiers:
     void foo(int* x);
         foo(static_cast<int*>x);
Date: 15 May 2011 12:39:28
Message: <4dd001c0$1@news.povray.org>
Ah, cool. Again, thanks for the info!
