POV-Ray : Newsgroups : povray.off-topic : Git tutorial Server Time
2 Jul 2026 13:54:08 EDT (-0400)
  Git tutorial (Message 7 to 16 of 76)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Git tutorial
Date: 20 Apr 2011 06:08:15
Message: <4daeb08f$1@news.povray.org>
One thing which apparently can't be done with Darcs, Git or Mercurial is
managing multiple repositories at once.
For example, consider Glasgow Haskell Compiler, which is written in
Haskell itself. The compiler, interpreter and run-time system are one
repo, and the various standard libraries it requires are independent
projects with their own repos, but GHC mirrors a copy of each, lagging
behind the upstream slightly. The main GHC repo contains a special Bash
script to do things like update all the sub-repos automatically. The
existence of this script tells you that there's functionality that Darcs
itself is failing to provide. (And Git and Mercurial, apparently.)
Date: 20 Apr 2011 06:24:06
Message: <4daeb446$1@news.povray.org>
On 19/04/2011 19:25, Darren New wrote:
> Having spoken with half a dozen people who said "I hate git, it's so
> confusing" and then after showing them this they go "wow, that's really
> easy", I figured it might be worthwhile to show people this. :-)
As an aside, I do envy you to some extent for actually knowing people
IRL who know how a computer works...
Date: 20 Apr 2011 11:32:32
Message: <4daefc90$1@news.povray.org>
On 4/20/2011 2:44, Invisible wrote:
> I had assumed that all DVCSs were the same, but I now see that at least Git
> and Darcs use fundamentally different models.
GIT stores files, and deduces change sets from those files.
Mercurial stores change sets, and deduces files from those changesets.
> Fundamentally, any version control system tracks changes to files.
No, git actually tracks entire files. Every time you check something in, any
file you add to staging (i.e., any file with any change) is stored in its
entirety in the repository. And, technically, *every* file in the entire
repository is stored, but if you haven't changed it, it has the same sha-1
name, so it doesn't physically get copied.
Only later do you compress the repository into diffs. But a file can be
stored as a diff from a different file it was never related to, that was
created whole-hat *after* you checked in the file it's a diff from.
 > What Git
> appears to be doing is something similar to RCS or CVS, where each file goes
> through a strictly sequential series of "versions", and one version comes
> "before" or "after" another.
Nope. Not even close. git is storing the entire repository on every commit.
That's the completely boggling idea there.
> It seems that each commit stores the complete
> state of the entire repository.
Yes. So there's no "before" or "after" for files, technically. There's
before or after for repositories.
> (Presumably as a diff relative to the previous commit,
Nope. It stores the entire repository. Now, if you don't change a file, it
hashes to the same value, and hence doesn't need to get stored again. But
the entire file is put into the repository.
That's why git doesn't have a "rename" command. That would imply you're
storing something other than files in the repository. git looks at the same
contents disappearing from one part of the directory structure and showing
up in another and says "Gee, that must have been a rename."  If there are
minor changes between what disappeared on this commit and what showed up
somewhere else on that commit, git says "there's a 97% probability this was
a renamed file."
When you do a "git gc" to collect garbage, it then looks for a good way to
generate diffs between files, and it looks through all the files (not just
ancestors) to find good versions to diff from, and it stores the diffs. But
that's just an storage optmization, just like the fact that it gzips the
files in the repository is a storage optimization.
If I checked in a configuration file with my name in it, and 2 days later
deleted it, and then you checked in a similar configuration file with your
name in it, and then we did a "git gc", it's entirely possible (likely,
even) that my file would be stored as a diff from your file.
In contrast, it seem Mercurial actually stores a tree of changes.
The only reason git uses a pointer to earlier commits is when you merge
things, you don't want to apply changes you already applied in an earlier
merge.
For example, when you merge branch A into branch B, git finds the common
ancestor (i.e., the point at which you separated B from A in the first
place), then *generates* the diff between what's now A and where they
branched, then *applies* that diff to B, and leaves it ready for a commit.
There's no diff stored before you type "git merge" or after it returns from
the command line.
Reverting a commit involves either just throwing away the new version, or
generating a reverse diff and applying it.
That's the thing that throws people about git, apparently. They're thinking
in terms of diffs, when it's easiest to understand if you just think about
it in terms of file contents.
> Git then uses "heads" to point to the most recent commit in each branch, or to
> other interesting points in the history.
Right.
> Darcs works completely differently. Darcs doesn't track sequential file
> versions, it tracks change-sets. It defines a "change-set algebra" where
> unrelated changes to the same file are independent, and can be applied or
> reverted independently. Changes to the same part of a file are not
> independent, and can only be applied in sequence. But unrelated changes
> are... unrelated.
Yeah, from the little I read about it, Darcs is another one of those
"interesting" ideas.  An actual mathematical system for defining a
repository, like relational algebra did for databases.
> As an example, if I add some comments to file X and commit that, and then I
> add a new function to file X and commit that too, I get two change-sets. I
> can revert adding the comments but still keep the new function, even though
> the latter change happened *before* the former.
> As far as I can tell, Git would require me to create a branch where I add
> the comments, and another branch where I add the new code, and then merge
> them back into the main branch, hoping that I don't get any conflicts. To
> me, this seems like a lot more work and a lot more conceptual overhead.
Nah. That's only if you want to have both at once working in parallel. That
is, if you want one version with the comments but no function, and another
version with the function but no comments, that's trivial in git. If you
then want to combine them into a third version that has both comments and
function, then you merge, which is also trivial unless you changed the same
lines in both places. (I.e., it's as trivial as any other diff-patch based
merge.)
> It also seems that when you ask Git to perform a commit, you have to tell it
> which files to record changes for.
Sure. But you can say "add all changes" trivially. Or you can use
interactive tools to commit just bits and pieces of this and that.
Basically, there's a "staging" area where you build a new copy of the
repository by including files and directories that are different from what's
out there already. Then you add those new files and directories to the
repository and point a commit to the new top-level directory.
> With Darcs, you tell it which files to
> monitor, and when you ask to commit it detects what's changed and
> interactively asks you which differences to include and which ones not to
> include. E.g., I could add comments to file X, add a new function, do a
> commit and interactively split the modifications into two separate commits.
> (It doesn't /always/ work, of course, but mostly it does.)
This is trivial with GIT. I do it all the time. I'll be adding a new
function, and while testing, realize there's a bug in some other function.
So when everything works again, I'll do two commits, staging just particular
hunks (in the diff sense of the word) and do two commits, one for the bugfix
and one for the new change.
> I wonder how well the illusion of one single sequence of file versions works
> when you have multiple people editing the file in parallel.
There's no single sequence of file versions. Every file is a new version.
Given that it's the repository format used by Linux developers, I think it's
safe to say it works adequately for multiple people editing the file in
parallel.
> I would imagine
> the Darcs model works better, because it doesn't try to pretend that file X
> looked like this, and then this, and then this.
Neither does git.
> It just records what edits
> happened, without recording their relative ordering [except where they
> affect the same lines of code]. Git, on the other hand, appears to be trying
> to track what every file in the entire repository looked like in every
> individual commit object.
Yes, but since you have them all, you can recreate the diffs between any two
versions whenever you want.
> With Darcs, you make a branch by copying the repository. That's it.
In git you make a branch by saying "make a new branch."  That's what boggled
me about mercurial. Really, I need multiple repositories to let me have a
stable version and a development version?
> (Although there is an option to build a bunch of symlinks for you instead of
> just copying, to save a bit of disk space. Presumably only on POSIX
> platforms...) You can email individual change-sets around, and this works.
> Getting somebody else's changes just copies all change-sets from their
> repository into yours. You can then resolve any conflicts.
git is exactly the same, except it copies files instead of changes. When you
say "pull from that repository", it finds each "head" (i.e., branch tip) and
then recurses through the data structures pulling anything reachable from
them. Since they're all named after the hashes, if you already have a file
of the same name, you don't need to copy it. Then it stores the heads for
the remote repository in a different place of the namespace tree than your
own heads.
But, really, the only things in the git repository are files (blobs),
directories (trees), commits (a log message pointing to a tree and maybe
other commits), and tags (a log message pointing to a commit, possibly
pgp-signed), and then a bunch of names for specific commits or tags or trees
(i.e., branch names). There are no diffs. There is no history. There are no
users.
If you want the log history, you follow pointers from one of the heads thru
the different commit objects. If you want to see what changed, you run diff
on the two files you want to know what changed between. If you want a new
branch, you just modify some files, store them, and point a different name
at the new commit.
If you want to merge someone's repository into yours, you simply copy from
them any files or names that they have that you don't, and you're done.
You're merged.  Now if you want to incorporate their changes into your work,
you generate a diff between their latest version and some earlier version,
and apply that diff to your latest version, and you're merged.
   "Coding without comments is like
    driving without turn signals."
Date: 20 Apr 2011 11:38:52
Message: <4daefe0c@news.povray.org>
git can do this in a sorta half-assed way. Mercurial apparently can too.
> you that there's functionality that Darcs itself is failing to provide. (And
Date: 20 Apr 2011 11:40:58
Message: <4daefe8a$1@news.povray.org>
Wrong button. :-)
http://ssteiner.wordpress.com/2008/12/30/git-subprojects/
The fundamental problem is that all the DVCS systems tend to use crypto
hashes to identify things. So in git, for example, when you create a
sub-project, the parent project records where the repository is and what
commit to check out. If you change the sub-project, the old commit is still
there; you have just added to it. So the parent project is still going to
get the old version of the subproject until you tell the parent project
"hey, go update your pointer to the sub project to be commit 01A73F9E."
Date: 20 Apr 2011 11:49:57
Message: <4daf00a5$1@news.povray.org>
> still there; you have just added to it. So the parent project is still
> going to get the old version of the subproject until you tell the parent
> project "hey, go update your pointer to the sub project to be commit
> 01A73F9E."
The problem Git seems to have is that it uses heads to keep track of
things. Delete the head and the corresponding commit drops off the face
of the Earth.
Darcs manages a set [as in set theory] of changes. You don't need to
keep updating a "pointer" to point to the latest one or anything. I'd be
surprised if no over VCS has thought of this.
Date: 20 Apr 2011 12:03:49
Message: <4daf03e5$1@news.povray.org>
>> least Git
Doesn't appear to me that that's what happens, from what little
Mercurial documentation I've read.
Fundamentally, VCS are about tracking changes. Git might *implement*
that by storing the entire file, but *logically* what you're trying to
do is keep track of what you changed.
> And, technically, *every* file in the entire repository is stored.
Yes, I gradually game to that realisation. Git is managing the entire
repo as a strictly linear sequence of unumbered versions. (Until you
explicitly create branches, anyway.)
> it hashes to the same value, and hence doesn't need to get stored again.
> But the entire file is put into the repository.
How odd... Still, if you're not worried about the internal
implementation, logically Git is versioning the whole repo as one unit,
and that's all you need to know.
> That's why git doesn't have a "rename" command.git looks at the
> same contents disappearing from one part of the directory structure and
> showing up in another and says "Gee, that must have been a rename." If
> there are minor changes between what disappeared on this commit and what
> showed up somewhere else on that commit, git says "there's a 97%
> probability this was a renamed file."
o_O
OK, wow. I thought having to tell Darcs when I rename stuff was
inconvenient, but this just sounds insane...
> earlier merge.
And here I was thinking it was so you can revert to earlier versions if
you want. You know - the entire purpose for a VCS to exist in the first
place? ;-)
It sounds simple enough. If this change affects line X and that change
affects line Y, they are independent.
Ah, but wait. What if some change adds or removes lines? If change X
adds a new line between lines 50 and 51 then change Y no longer affects
line 150, it now affects line 151. But X and Y are still independent.
There's more to it than meets the eye. Of course, if you just want to
*use* Darcs, you just edit stuff and it "just works".
Isn't "working on both at once" kind of the entire point of distributed
version control?
> That is, if you want one version with the comments but no function, and
> another version with the function but no comments, that's trivial in
> git. If you then want to combine them into a third version that has both
> comments and function, then you merge, which is also trivial unless you
> changed the same lines in both places. (I.e., it's as trivial as any
> other diff-patch based merge.)
And if you merge the comments branch into the main branch, and then
somebody adds more stuff to the comments branch, then what?
>> tell it which files to record changes for.
With Darcs, I tell it what files to watch, and then when I've finished
editing stuff, I say "record this" and it shows me every modified line
of every file and asks which modifications to keep. Git doesn't support
recording half a file modification, and doesn't even figure out which
files changed.
> function. So when everything works again, I'll do two commits, staging
> just particular hunks (in the diff sense of the word) and do two
> commits, one for the bugfix and one for the new change.
Given that Git can only record the new file or the old one, how is that
possible?
>> works when you have multiple people editing the file in parallel.
> it's safe to say it works adequately for multiple people editing the
> file in parallel.
This boggles my mind. Apparently I /don't/ understand how Git works at
all, because the way it seems to work precludes two people touching the
same file at the same time...
>> trying
> two versions whenever you want.
That's my point. If multiple people are editing the same files, you do
*not* have all the changes.
And the "minor detail" that if 200 people edit the same file, that's 200
separate branches which have to be manually merged back together again.
> from them any files or names that they have that you don't, and you're
> done. You're merged.
It would be nice if Darcs worked that way.
> your work, you generate a diff between their latest version and some
> earlier version, and apply that diff to your latest version, and you're
> merged.
What a backwards way to look at it.
Date: 20 Apr 2011 12:24:02
Message: <4daf08a2@news.povray.org>
On 4/20/2011 8:49, Invisible wrote:
> The problem Git seems to have is that it uses heads to keep track of things.
> Delete the head and the corresponding commit drops off the face of the Earth.
Yes. That's why you shouldn't do that.
First, deleting a head that you can't reach from anywhere else requires you
to answer a confirmation, just like anything else. Second, the *files* are
still there. You just might not know what they're called. They're probably
still around at least a couple of weeks before git cleans them up. I.e.,
there are well-documented ways to recover from this if you do it accidentally.
On the other hand, if you work on something and decide it wasn't a good
idea, you can delete the branch and no harm no done. Darcs apparently
requires you to copy the entire repository before you even *start* making
changes if you want to recover.
> Darcs manages a set [as in set theory] of changes. You don't need to keep
But that's exactly why you need to start a new repository if you want a new
branch. If you clone a repository in Darcs, make a bunch of changes, then
accidentally delete the repository, you're in even worse shape than if you
delete a branch in git.
Date: 20 Apr 2011 12:55:24
Message: <4daf0ffc@news.povray.org>
On 4/20/2011 9:03, Invisible wrote:
> Doesn't appear to me that that's what happens, from what little Mercurial
I don't know. All the mercurial documentation I've read talks about change sets.
Fundamentally, they're about controlling versions. :-)
> Git might *implement* that by
> storing the entire file, but *logically* what you're trying to do is keep
I think it depends. If I want version 1.0 that was released, I don't really
care what changed to get there. I want that version.  There's uses for
changes, and uses for storing what you stored.
The advantage of storing what's actually there is you can write all kinds of
better tools to tell you the differences. For example, you can diff any two
files to get a compressed copy of the file. If I change a file to include an
additional 500 lines, then change it to delete 498 of them, the third
version is going to get stored as a 2-line diff from the first version, not
a 498-line diff from the second version.
Basically, you're storing absolutes and deducing differences, rather than
storing differences and deducing absolutes. That means when you want to know
what changed between release candidate 3.5RC2 and the version 4.2 that Fred
compiled over on *his* machine, you can just compare the two. You don't have
to reconstruct anything first.
> Yes, I gradually game to that realisation. Git is managing the entire repo
> as a strictly linear sequence of unumbered versions. (Until you explicitly
Or until you clone it, yes.
> How odd... Still, if you're not worried about the internal implementation,
> logically Git is versioning the whole repo as one unit, and that's all you
> need to know.
Yes, basically. That's why you can sign just the tag blob and be sure you've
signed every file that that tag refers to.
Why? You don't have to tell git you renamed something.
>> earlier merge.
> And here I was thinking it was so you can revert to earlier versions if you
> want. You know - the entire purpose for a VCS to exist in the first place? ;-)
Well, yes, it gives you a way to find those commits. But in theory you could
look up any commit by hash code and say "give me that version" whether it's
earlier or later or completely unrelated to what you have now. Indeed,
that's exactly how branches work. When you start a new branch, all you're
doing is storing the commit sha-1 into a new file named after the branch.
Yeah, until you get binary objects in there. :-)
> version control?
Only if you want to work on both at once in the same repository.
If you're working in a different repository, you don't need to start a new
branch.  Branches are nothing but names for commits. You technically never
need to use any branch at all if you want to type in a sha-1 every time.
> And if you merge the comments branch into the main branch, and then somebody
Then you get a merge and then more changes on the comments branch. And if
you merge the comments branch *again*, *that* is when git uses the parent
pointers in the commit objects to figure out which files to diff in order to
get the patches to the parent.
A--B--C--D--E--F--G--H--I
     Q--R/--S--T/
So you started with A, changed to B, branched B and made a change to create
Q, then R. In the mean time, I changed B to be C.  Now I merge your R back
to my C. This looks back, sees B is the common ancestor, so diffs R against
B and applies it to C, then creates D with C and R as parent commits. (Each
letter is a commit, which includes the state of the entire repository.)
Now you keep working on R without incorporating my B->C change, creating S
and T. I change D to include E and F. Now I merge your work again.
Git looks at F, follows it back to D, to C and R, and sees that R is a
common ancestor of both F and T. So it diffs T against R, applies those
diffs to F, and creates G.  You can then delete the branch that points to T
safely without losing anything.
It's *super* straightforward to understand what merges do in git.
And if someone comes up with a better diff algorithm, no problem. The
algorithm to do the diff during a merge isn't built into the repository.
> editing stuff, I say "record this" and it shows me every modified line of
Yes it does.  Indeed, you can even go back and retroactively say "oh, those
two commits? The second one should have come first, and the first one should
be broken up into these three commits."
As I said, I do this all the time.
 > and doesn't even figure out which files changed.
Yes it does. It compares the working directory against the staging directory
and the head to say "these files are changed and unstaged, those are changed
but already staged, and those are unchanged."
It's just a two-step process. You can build up the thing you want to commit,
and then finally commit it.  It sounds like Darcs needs you to do that all
in one step.
Git does it the other way around. First it asks you what modified lines you
want to put in the commit (and puts them in the staging area), then it
creates the commit (based on the staging area).
> possible?
The staging area lies between the repository and the working directory. So I
check out some branch, and that copies it to the WD and maybe clears the
staging area. The staging area is basically a commit that's not yet in the
repository.
Now I make changes to the WD.
Then I use something like "git add" to add all the changes from the WD to
the staging directory. Or I use "git add -i" (or, more likely, the GUI) to
diff the WD against the staging area (or the repository), pick (say) three
of the five diff hunks, and then create a new temp file that holds the
repository with those three diff hunks applied, which I then put in the
staging area.  When I have everything the way I like, I commit the change,
which copies the staging area into the repository and then adds a commit
object pointing to it.
>> file in parallel.
> This boggles my mind. Apparently I /don't/ understand how Git works at all,
> because the way it seems to work precludes two people touching the same file
> at the same time...
Sure. But you're thinking git tracks diffs. That's exactly the point. If I
change the file, and you change the file, then now there's three files. The
original, the new one I have, and the new one you have.  When we go to merge
it, we create number four, which is your new one with the differences
between my version and the original applied.
It works because if there's no merge conflicts, then my diff applied to your
file and your diff applied to my file creates the same file.
> That's my point. If multiple people are editing the same files, you do *not*
Well, no, obviously. Welcome to DVCS.  If you don't give me your files, I
can't see them. This is true of changes you don't push in Darcs and
mercurial too. Maybe I'm misunderstanding what you're trying to say.
Darcs *is* distributed, right? If you change a file and check it into your
local repository, and I change it and check it into my local repository, I
can't see your changes and you can't see mine until we connect the
repositories again, right?
And this differs from any other VCS how?
Note that if you're trying to *push* changes to a remote repository, you
have to do it to a branch where nobody else has branched off since you did.
In other words, if I say "update my repository to the DEV branch on the
company's central reposityro", and I make changes, and someone else changes
the DEV branch to point to a later version, I can no longer push my changes
into the DEV branch. Instead, I have to fetch down the new DEV branch, merge
my changes, then push the newly merged commit back up. Look up "fast-forward
merge" in the git docs if you care.
But basically what it's saying is if you're *pushing* changes to a
repository (i.e., there's no human there checking the merges) then you can't
do a two-parent merge commit. You have to create the two-parent merge commit
on your own machine, *then* push it up to the server. Sorta.
Right. In Darcs, you have to merge all the changes. In git, you have to
>> merged.
Only if you're used to looking at source control as a series of diffs to
start with. But that's (A) exactly what makes git hard to understand and (B)
exactly what makes git brilliant. :-)
Date: 20 Apr 2011 13:11:44
Message: <4daf13d0$1@news.povray.org>
> Fundamentally, VCS are about tracking changes. Git might *implement* that by
Or, as an alternate example, say you've been working and every day you
commit before lunch and you commit before you go home, even if it's not
working, just so it gets backed up. And you implement two functions, and you
write code on that, and then realize you should have put that first function
elsewhere, and you don't need the second function at all, and the other code
should be in separate objects, and etc etc etc.
And at the end of the week, you have 50 messy changes committed.
With git, you can say "OK, go diff the current version against where I
branched, and give me exactly one commit with all the changes I need." It's
trivial to do that in git and then say "now commit *that* change for
everyone else to see, and abandon all the intermediate changes."
I don't know how you'd do something like that in mercurial or darcs that
store *changes* in the repository.
