Subject: Re: A kind of revolution is happening in the United States
Date: 17 Apr 2011 12:17:09
Message: <4dab1285$1@news.povray.org>
On 4/17/2011 0:59, Warp wrote:
> You are basically asking me how to remove hunger and poverty from the
> world. If I knew the answer, do you think I would be just sitting here
> writing to this newsgroup?
No. My point wasn't in expecting the answer. My point was that complaining
that the best answer still sucks doesn't help until someone comes up with a
better answer.
> What I am saying is that burning fossil fuels is *not* a good solution
> to the problem in the long term (or the short term, for that matter).
I don't think we're disagreeing there. But complaining about a problem that
everyone in the world would like to solve that nobody has come up with a
solution for isn't too helpful. People aren't denying that burning fossil
fuels isn't the best of all possible worlds. People are merely denying that
something better is feasible.
"Coding without comments is like
driving without turn signals."
Date: 17 Apr 2011 12:28:56
Message: <4dab1548@news.povray.org>
Darren New <dne### [at] san rr com> wrote:
> On 4/17/2011 1:09, Warp wrote:
> > Lowering birth rates was kind of also implied in my statement above.
> > (Most of the first-world countries have pretty low birth rates.)
> OK. And much of the argument for letting third-world countries pollute is to
> get them up to first-world economics where the birth rate is much lower.
> See? :-)
I don't think lowering birth rates requires first-world economics.
It just requires politics. (I don't know if China is considered a
"first-world country", but they have the birth rate problem somewhat
under control at least, but not for the same reasons as many first-world
countries.)
Date: 17 Apr 2011 12:34:42
Message: <4dab16a2@news.povray.org>
First-world economics seems to be the reliable method. Basically, when you
have machinery working for you, you don't really need or want as many kids.
Unfortunately, that takes energy to run the machinery.
I think you're underestimating the difficulty of convincing someone to
starve today in order to save the world 50 years from now.
Date: 17 Apr 2011 12:36:55
Message: <4dab1727$1@news.povray.org>
Le 2011/04/16 19:02, Darren New a écrit :
> On 4/16/2011 15:47, Patrick Elliott wrote:
>> That oxidation will react with the water that's left,
>> producing highly explosive hydrogen gas."
> OK. That's what I guessed. Cracking the water to release hydrogen.
>> All in all, a bad design,
> Certainly not the best design, yeah. :-)
And that hydrogen comes handily premixed with just the right amount of
oxygen.
That's the big problem when you start heat cracking water. You get an
explosive mixture ready to recombine into water while producing yet more
heat... When it's hot enough, you don't need any spark or flame.
Date: 17 Apr 2011 13:03:02
Message: <4dab1d46@news.povray.org>
Le 2011/04/16 19:04, Patrick Elliott a écrit :
> On 4/16/2011 12:02 PM, Alain wrote:
>> Le 2011/04/15 22:53, Patrick Elliott a écrit :
>>> On 4/15/2011 5:26 AM, Bill Pragnell wrote:
>>>> Invisible<voi### [at] dev null> wrote:
>>>>> Nuclear power works in theory. In practise, if you make even the
>>>>> tiniest
>>>>> mistake, just once, everything is ruined forever. (Or at least, for
>>>>> several centuries.) And there's nothing you can do to fix it.
>>>> That's not really true. Chernobyl was caused by a very long chain of
>>>> mistakes,
>>>> all committed with a reactor design which was already itself a long
>>>> chain of
>>>> mistakes. It should be noted that most other countries have never
>>>> built a
>>>> reactor that could fail as catastrophically as this, even through
>>>> wilful
>>>> sabotage.
>>>> TMI was also long chain of mistakes, which resulted in only the
>>>> reactor being
>>>> ruined, and they did fix it.
>>>> I suppose you could say that Fukushima was really only one very big
>>>> mistake,
>>>> i.e. how big a tsunami was ever likely to be. However, they show every
>>>> sign of
>>>> being able to fix it eventually.
>>> No, the "big" mistakes where:
>>> 1. Having no way to cool it, or certainty that the power systems would
>>> still work, to do so, if enough failures happened. And, no, battery
>>> backup doesn't work, if it lasts less than 24 hours.
>>> 2. Placing the old, spent, fuel in something that was ever *less*
>>> effectively cooled.
>>> And, I would add 3. Presuming that a *big* reactor, which produces
>>> massive amounts of power, but where it would be nearly impossible to
>>> either make it less hazardous, or run battery backup long enough, or
>>> otherwise create a system that *could* compensate for major problems,
>>> remains bloody stupid.
>> Some more gross mistakes at Fukushima:
>> a. Need *EXTERIOR* power source to run the cooling system when you
>> produce that power localy.
>> The pumps failed when the power lines TO the reactor got damaged by the
>> tsunami. That's a humongously huge mistake!
>> b. NO passive shutdown mechanism. Sanity *demands* that there are
>> several controll rods suspended by electro magnets powered by the
>> reactor itself over the core. If the cooling system fails, the turbines
>> stop, they no longer produce current, shutting down the magnets whitch
>> let the controll rods fall into the core, stoping the nuclear reaction
>> and thus the heat generation. Those rods are usualy made of cadmium
>> because that metal can absorbs huge amounts of neutrons.
>> Those rods must be set and designed so that gravity alone will make them
>> fall completely into position.
>> There where obviously none! Totaly insane!
>> c. NO passive cooling mesures. A passive cooling mesure should be enough
>> to evecuate the residual heat from the shut down reactor.
>> d. Severly skipping on maintenance for over 10 years.
>> The director of the station said so himself...
>> Alain
> Yeah. Those would have been a damn good idea too.
> a) makes no damn sense to me at all (even if it was some minimal system,
> enough to just keep pumps going), unless the tsunami took out
> lines/systems in the actual turbine part of the system. I would have
> thought those would be internal to the reactor, but.. Then again, their
> systems reuse a lot of waste heat/energy, so its hard to say how complex
> the whole thing was, and thus "where" those systems where, and thus
> whether it was even feasible to have the turbines in the reactor
> buildings. Its a definite WTF for me, but may go towards the whole, "If
> you make the thing so damn big you can't do *basic* shit to keep it
> working, you may be building them too big." If I where to guess... They
> probably have "internal systems that funnel water to and from the
> reactor, then a "heat exchange" point, with and entirely separate
> system, which is external to the reactors themselves. This would then
> run out to their actual turbine systems, where the heated water produces
> the actual power, is cooled, then pumped back into the exchanger. You
> don't want to run radioactive water through the turbines, or use a
> system where water from one might get into the other. This means that,
> for practical purposes, power isn't generated "in" the reactor itself,
> at all. So...
The reactor heat water in the primary cooling loop.
It circulate between the reactor and a heat exchanger just outside the
reactor housing.
This water, in turn, turn water in the secondary loop into steam.
That steam powers the turbines.
All of this is housed in a building that contains the reactor housings.
One big buiding that contains the reactors, the primary to secondary
heat exchangers and the turbines. The transformers are located outside
and alongside that building, as shown by the satellite and aerial photos
of the site.
The link from the building to the transformers station are very short
and shielded from the sea by the large building.
The transforming station was unaffected by the stunami.
The main building did NOT suffer from the stunami at all, but did stop
it and protected a significan area.
The power lines where cut over 100m BEHIND the plant.
It's the lost of those lines that caused all the problems.
> b) not sure any of them have this. Its not enough to just drop in a few,
> in most cases, and.. well, if you can bend the damn things to shit in a
> system that runs them in slowly, you can imagine what sort of mess you
> end up with if some of them jam being "gravity dropped" into place.
> Again, the whole design seems a problem, and most of it due to scale,
> not just this one issue.
Not just a few. Those drop controll rods are realy calles *Stop* rods.
They are present in the Candu reactors and several other models. They
are also mandatory in several countrys. After Tree Miles Island, they
became mendatory in the USA. Some older US reactors where shut down
because they lacked that feature.
At the end of the drop, they are stopped from the top. They can't bend,
just stretch a little. Think of a big nail shaped rod suspended above
the core by an electro magnet.
> c) Hmm.. This is an interesting problem. How do you make a passive
> cooling system which doesn't move contaminated air, or water, or
> something else, and exchange it often/fast/effective enough to do that?
> We are talking about something heating to temperatures on massive
> scales, pretty damn fast, with a *major* exchange requirement. Again,
> size here matters. Think of it like trying to cool a high end CPU, using
> only a bit of foil taped to the top, because someone had to build the
> case so an actual radiator grill and electric fan wouldn't fit in there.
> You can get by with it if you are using low power, a lower end chip,
> etc., but... scale up to a PC, or, in the case of power plants, a full
> size nuclear reactor... and you "passive" systems are just not going to
> cut it in any practical sense.
No horizontal heat exchanger, you maximize the vertical to horizontal
proportions of the cooling loops to increase the thermal syphon mechanism.
That way, the heat will greatly help you to circulate the cooling fluids.
Then, once the stop rods are droped, you have MUCH less heat to
dicipate. This, in turn, makes passive cooling easily feasible and
practical.
> So.. Again, seems to me, once you get past the basics of, "make sure the
> damn thing can run the active systems long enough to matter", everything
> else is, "scale, scale, scale", and the impracticality of doing jack to
> solve such problems at the scales being talked about. And, short of
> building the damn things in Antarctica, and somehow getting the power
> from there to every place else, I don't see "passive" being too viable...
Date: 17 Apr 2011 14:38:16
Message: <4dab3398@news.povray.org>
On 4/17/2011 9:36, Alain wrote:
> And that hydrogen comes handily premixed with just the right amount of oxygen.
Nah. It sounds like the hydrogen gets released because something is ripping
the oxygen off it to form "corrosion".
You only get the right mixture if you put in energy without actually doing
any chemical reactions.
Date: 17 Apr 2011 17:10:35
Message: <4dab574b@news.povray.org>
> complaining that the best answer still sucks doesn't help until someone
> comes up with a better answer.
> that everyone in the world would like to solve that nobody has come up
> with a solution for isn't too helpful. People aren't denying that
> burning fossil fuels isn't the best of all possible worlds. People are
> merely denying that something better is feasible.
No, all too many of them are arguing worse. That its flat out simply not
a problem, and every step taken to limit/clean/reduce it is unnecessary.
If it was merely that its not feasible to get rid of it, we wouldn't be
having much of a heated discussion on the subject.
Date: 17 Apr 2011 17:15:03
Message: <4dab5857$1@news.povray.org>
>> at all. So...
> reactor housing.
> of the site.
In other words, there was no logical reason it couldn't have run from
the power being still generated. Well, unless there was something in
there so that, under disaster conditions, it "stopped" generating power,
so shorts couldn't happen. Still... I don't get it.
Date: 17 Apr 2011 17:16:41
Message: <4dab58b9$1@news.povray.org>
On 4/17/2011 9:09 AM, Darren New wrote:
> On 4/16/2011 16:35, Patrick Elliott wrote:
>> Try smog testing a car from Arizona in California, to re-license it, then
>> tell me how "everyone else in the use adopted their standards". lol
> It has been relatively recent. Try buying a Japanese car in the last 5
> or 10 years that doesn't meet the restrictions California imposes.
Yes, but Japan isn't in the "Hick" zone USA. The problem isn't that
people "shipping" to California would match those standards, its that
people 10 feet across a damn state line don't have to. :p
Date: 17 Apr 2011 17:21:08
Message: <4DAB59C5.6060903@gmail.com>
On 14-4-2011 21:52, Orchid XP v8 wrote:
> You've got to admit, when you read about stuff like people believing
> that ID is real science, it does make you wonder what kind of people
> live there.
If you take ID to be the idea that some protein(complexe)s can not have
been evolved from earlier proteins, then that is a testable hypothesis.
Stating and researching that idea was real science.
It turns out that all proposed systems were proven to be very easily
evolvable from known components with no intermediate non-functional
systems. All that is left now is the idea that such proteins might
exist, but haven't been found yet. IMO the *search* for such unevolvable
systems is still science. Though science that is so unlikely to be
successful that no public money should be used to fund it. If a wealthy
person want to support it, that should be OK and results should be
published in the usual way.
However *teaching* it in a classroom as an alternative hypothesis
against the theory of evolution is not science (education). Simply
because the theory as it stands was proven wrong.
BTW would dissecting the cases brought forward by Behe at al. count as
spending time on ID? Because that would be an ideal way to teach
students how real science works.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 17 Apr 2011 17:26:04
Message: <4dab5aec$1@news.povray.org>
>> live there.
There are a few teachers that have done that, as I understand, most of
them college level though. The ID people, for some reason, haven't been
at all happy with the few they found doing it. lol But, heh, what do you
expect when some moron babbled "ontological depth", and then can't show
you how to "messure" it on a pencil, never mind an organism. ;)
Date: 17 Apr 2011 17:38:23
Message: <4dab5dcf@news.povray.org>
Yes, but I don't think that's serious debate over the reality. That's just
lying.
Date: 17 Apr 2011 17:40:28
Message: <4dab5e4c$1@news.povray.org>
On 4/17/2011 14:16, Patrick Elliott wrote:
> The problem isn't that people
> "shipping" to California would match those standards, its that people 10
My point is that it's hard to buy a car outside of California that doesn't
match California standards, because it's too expensive to retool for two
different versions of the cars any more. If you buy a Toyota while you live
in Texas or New York, you're going to get one that meets CA emission
standards. And you won't have to pay to bring it into CA.
Maybe that's not the case with Detroit cars, but I would be surprised.
Date: 18 Apr 2011 04:10:46
Message: <4dabf206$1@news.povray.org>
On 15/04/2011 22:25, andrel wrote:
> Oh no, that means that someone really believes that because the society
> as a whole seems to have almost exactly the right amount of bakers,
> plumbers and housewives that must imply that the society is designed by
> a supreme being. And that the proof of that is that society is
> irreducible complex because if you remove one group, the bakers or the
> policeman, or the bus drivers, or... the whole thing stops working,
> hence it cannot have been evolved.
That's not gonna work. Society is composed of individuals with
intelligence [allegedly]. Complex things can only come about due to
intelligence, so if unintelligent chemical soup becomes living,
breathing complexity, it must be my invisible friend's intelligence that
made it so.
Date: 18 Apr 2011 04:15:55
Message: <4dabf33b@news.povray.org>
On 17/04/2011 17:07, Darren New wrote:
> On 4/17/2011 2:57, Orchid XP v8 wrote:
>> Yes, I know what a crumple zone is. But at 100MPH, there are going to be
>> fatalities, no matter which way you design a car.
> I take it the UK doesn't have any Formula-1 races?
Yeah, they do. But I'm pretty sure people driving road cars don't wear
full-body flame-retardant suits, high-end crash helmets, custom-moulded
seats, custom-calibrated seatbelts and heat restraints. I'm also fairly
sure no known road car weighs as little as an F1 car, nor is quite as
low to the ground. Also, walking around the Silverstone race circuit,
there is a rather conspicuous absence of solid objects to collide with.
If you crash a road car, you're not going to fly across a gravel trap
for half a mile and then hit a deformable tire wall. You're either going
to hit another car, or else a tree or a concrete wall. I doubt anybody
is going to walk away from that alive.
This is presumably why driving at 100MPH is an instant license revocation...
Date: 18 Apr 2011 04:17:47
Message: <4dabf3ab@news.povray.org>
>>> Improving public transportation to reduce the need for private cars is
>>> another efficient way to reduce pollution.
>> See, now, where I live, the government thinks that making private
>> transport too expensive will make everybody use public transport.
> Well, the "government" theory, at least among randian regressives is,
> "If we make driving your car expensive, companies will, for some
> unspecified reason, invest money in more public transportation"
This is the real WTF.
Date: 18 Apr 2011 04:21:43
Message: <4dabf497$1@news.povray.org>
>> live there.
So there's a theory, the theory has been repeatedly proven wrong,
there's no particular reason to believe that it might be right in some
unknown case, and yet people continue to assert the truth of this theory
as *fact*? Doesn't sound very rational to me...
I commend the idea.
Right along side showing how String Theory, despite looking far more
professional than ID, is also not [yet] science. (And examining why it
has the potential to /become/ science in a way that ID does not.)
Date: 18 Apr 2011 08:31:26
Message: <4dac2f1e$1@news.povray.org>
On 4/12/2011 4:06 PM, Warp wrote:
> Following this from abroad, I don't know if this should be amusing or
> frightening...
> http://ncse.com/news/2011/03/antievolution-bill-tennessee-progresses-006545
> http://ncse.com/news/2011/03/intelligent-design-legislation-texas-006531
> http://ncse.com/news/2011/03/antievolution-legislation-florida-006524
> http://ncse.com/news/2011/02/antievolution-legislation-new-mexico-006469
> http://ncse.com/news/2011/01/second-antievolution-bill-oklahoma-006439
> http://ncse.com/news/2011/01/antievolution-legislation-missouri-006421
> http://ncse.com/news/2011/01/antievolution-legislation-kentucky-006389
Both ....
~Mike
Date: 18 Apr 2011 12:13:50
Message: <4dac633e$1@news.povray.org>
On Sun, 17 Apr 2011 10:57:32 +0100, Orchid XP v8 wrote:
>>> Designing it so the car doesn't survive the crash but the people
>>> inside do would be even more miraculous...
>> You've never seen a car crash (or the results of one), have you? Most
>> of them are *designed* to crumple in order to protect the passengers.
Um, can you guarantee fatalities? Because I'm sure that it's happened.
100 MPH is two cars in a head-on collision doing only 50 MPH, remember.
Richard Hammond is still alive, for that matter - he was going 288 MPH
when the "car" (it was a dragster with a jet assist, as I recall) he was
in crashed. He didn't walk away from it, but he didn't die, either (as
evidenced by the fact that he's still presenting on Top Gear).
Jim
Date: 18 Apr 2011 12:15:04
Message: <4dac6388$1@news.povray.org>
>>> be fatalities, no matter which way you design a car.
Stock Car Racing.
And "the wall" and "other cars" count as solid objects to collide with,
and those happen to be on the track at the time of the race.
Jim
Date: 18 Apr 2011 12:21:46
Message: <4dac651a@news.povray.org>
You didn't say "road car" before. You said "you couldn't design a car...."
Clearly you can.
You can design a road car the same way. It'll just cost the same $100K that
a F-1 car costs.
Date: 18 Apr 2011 12:22:07
Message: <4dac652f@news.povray.org>
No it isn't.
Date: 18 Apr 2011 13:43:39
Message: <4dac784b$1@news.povray.org>
> No it isn't.
50 MPH each, that is. Yes, the rate of closure is 100 MPH.
Jim
Date: 18 Apr 2011 14:39:16
Message: <4dac8554@news.povray.org>
>> No it isn't.
But the collision of each car is the same as running into a wall at 50MPH.
So making it safe for a 50MPH crash means making it safe for two cars, each
going 50MPH, to run head on into each other.
Date: 18 Apr 2011 14:51:03
Message: <4dac8817$1@news.povray.org>
>>>> remember.
>>> No it isn't.
> 50MPH. So making it safe for a 50MPH crash means making it safe for two
> cars, each going 50MPH, to run head on into each other.
Oh, I see what you're saying - yes, the damage to each car isn't the same
as the damage to one car hitting a wall at 100 MPH.
Jim
Date: 18 Apr 2011 16:55:47
Message: <4daca553$1@news.povray.org>
> just lying.
Hard to tell sometimes. Some people really are just that nuts.
Date: 18 Apr 2011 16:58:25
Message: <4daca5f1$1@news.povray.org>
> doesn't match California standards, because it's too expensive to retool
> for two different versions of the cars any more. If you buy a Toyota
> while you live in Texas or New York, you're going to get one that meets
> CA emission standards. And you won't have to pay to bring it into CA.
Well, I get your point. The problem, unfortunately, is old, used cars,
in states that don't require those standards be "maintained". Net result
= unless its a brand new car...
Date: 18 Apr 2011 17:46:23
Message: <4DACB134.7050708@gmail.com>
>>> live there.
no it hasn't. All *cases* that have been put forward that should have
shown support have in fact turned out to be in support of evolution.
That does not prove there are none. For that to prove you need to
examine all proteins that exist anywhere in nature.
> unknown case,
You only say that because you 'believe' the theory and not the hypothesis.
That is entirely a different matter. These people need not be the same
as the ones that do the real research.
> I commend the idea.
I also disagree on that. String theory is pure maths. I tend to think
that maths is a science.
I would agree that string theory is not physics yet.
Remember that in the unlikely case they do find an example of something
that cannot have been evolved in an autonomous way, ID becomes science.
We might think that it is just as unlikely as someone handing over the
telephone number of God, but it might just happen.
citizen per day.
Date: 18 Apr 2011 18:43:42
Message: <4DACBEA4.4020204@gmail.com>
The point is that to make it work someone has to understand it all and
design it to make it function. Even if you had been intelligent, you
would still not know how much wheat, oil and bakers you need and anyone
who does, does not know how an engine works. So even if there is local
knowledge you still need global knowledge to design a society.
(FYI I do not believe any of the above. I know society has evolved from
something simpler, but as it is now, so many earlier parts are missing
that it is hard to see how it came about. Starting with just the people
living in a country then no matter how intelligent they are, they will
not form a smoothly running society before most, if not all, died from
starvation.)
> made it so.
OMG, invisible has an invisible friend.
citizen per day.
Date: 18 Apr 2011 20:02:47
Message: <4dacd127@news.povray.org>
It's just that the pumps were connected to the wrong power source.
You need that connection when you start the reactor to get everything in
motion. But once started, any power plant, using ANY technology, must be
self powered.
At Fukujima, it was'nt the case, and they payd dearly for that mistake.
Date: 18 Apr 2011 20:08:17
Message: <4dacd271$1@news.povray.org>
> revocation...
What about a head on colision against a concrete wall at over 200 Km/h?
There was such a crash here at Montréal a few years ago. The pilot was
able to walk shortly after the crash to get into the ambulance. He only
had some bruising.
Thankfuly, those F1 are realy tough, and the restrains excellent!
Date: 18 Apr 2011 20:12:30
Message: <4dacd36e@news.povray.org>
> Jim
1 car hiting a wall at 50 is similar to 1 car hiting a stationary car of
about it's mass at 100.
2 cars, each going 100, will fare about the same as ether at that speed
against a wall.
Date: 19 Apr 2011 05:04:03
Message: <4dad5003@news.povray.org>
That's like saying that to prove Newton's laws of motion, you need to
examine every object with mass in the entire universe. This isn't how
science works.
>> unknown case,
No. I say that because there's nothing special about the disproven cases
than suggests that they're unusual. If there was, you might have a case
for suggesting that other examples exist which would, if discovered,
support ID.
It's like proving that Fermat's last theorem holds for all prime numbers
less than one million. You might well argue that the fact that these are
*prime* numbers makes them special, and the theorem might not hold for
composite numbers. But if you prove it for a bunch of numbers chosen at
random, there's less room for doubt.
Of course, any scientific theory always has the possibility of being
wrong, or at least incomplete. But based on available evidence,
evolution looks pretty safe. (Then again, people said that about
Newton's laws of motion. But on the first hand again, people still
*teach* Newton's laws of motion...)
Fair enough.
>> I commend the idea.
String theory is mathematics developed explicitly for the purpose of
describing the real world. And yet, it does not yet make any testable
predictions. Someday it might, but it doesn't yet.
"Science" is usually defined as "the study of provable facts about the
real world". Mathematics would fall outside that scope.
Point being, until that day, ID is not science.
In fact, hell, even on that day, ID won't be science. The statement that
there exist natural systems which evolution cannot explain will be
science. But that's not ID. ID claims that God did it. This will *never*
be science, since it is not possible to confirm or refute it by the
scientific method.
(Note that not being science is different from not being true.)
Date: 19 Apr 2011 17:38:31
Message: <4dae00d7@news.povray.org>
>>>> live there.
Actually, this represents two huge problems with their hypothesis
(please stop using theory, since that implies they already have some
sort of evidence to imply it is/could be true).
First - Irreducible complexity is a non-starter, since it assumes,
again, without *any* evidence, literally, that if you find a bridge,
where one stone being removed makes it fall, there couldn't have been
any sort of scaffolding to hold it up, later removed, which allowed it
to be constructed. It had to have been intelligently designed. This is
idiotic, since even such a bridge, having been so designed, required
missing steps, which are not obvious from simply saying, "If you remove
that one stone, it will fall down."
Second - If you want to call something a theory, you need to do research
to test it. The only people that have *ever* tested it have been
biologists, and their tests mainly consist of pointing out, usually well
after the fact has already been established in their own research, that
pulling some random thing out and saying, "See, irreducible!", doesn't
work too well when 6 months prior someone had already described why it
wasn't, but the ID people didn't bother to read all of the papers on the
subject. The only "research" these clowns have done, to date, involves
a) writing articles, which often repeat assertions already disproven,
and sometimes using examples already shown to be invalid, b) scouring
other people's work, hoping to find something that is irreducible, and
c) writing more long winded papers, describing their hypothesis, while
usually glossing over, or rarely, making excuses, as to why they can't
yet describe what they are really looking for (in the case of ones like
ontological depth, which they *said* they would have "soon", like 7
years ago), how to find it, how to test it, how you would show it to be
incorrect, through testing, or anything else resembling science.
In short, they have a hypothesis, which they want to fit preconceived
data, but are using philosophy, instead of science, to "prove" it,
wandering about picking up bits of stuff they think fit their useless
guess.Its like if someone thought the debate over the existence of
cyclops in ancient times was real, and they went about declaring that
they *think* they found a skull (really from an elephant), and some big
bones (from some dinosaur), which suggest they are right, and cyclops
actually once existed. Meanwhile, we go on studying elephants, and
digging up dino skeletons, and wondering what these kooks are babbling
about, never mind why anyone is taking them seriously.
There is no science done by ID people, there is no research conducted by
them, unless doing the equivalent of google searches constitutes
"research", and no "theory", just a desperate guess, they want to be
true, so that either God had to do it, or, for some of the crazier ones,
they can take Genesis, and some made up "timeline" for the age of the
earth seriously.
Date: 19 Apr 2011 17:46:41
Message: <4dae02c1$1@news.povray.org>
> scientific method.
Mind, if you stated the hypothesis as, "Science can either identify, or
at least test for, whether something is true or not.", then this would,
given all collective evidence, suggest several facts - 1) In all cases
where you can actually collect data, this maxim is true, 2), in all
cases where data cannot be collected, this maxim is false, and 3) in
those cases where the maxim fails, the reason is not that the data never
existed, but has become, via time, etc., unavailable, 4) there is
usually some grounds to assume that the data had existed, and could have
been collected, had such collection been timely.
Apply the same to the god question as you get - 1) No data can be
collected, 2) There is no evidence to suggest that such data ever
existed, 3) Therefor, lacking evidence that data was *ever* available at
all, the implication is that you are attempting to find non-existent
data, for an non-existent object. QED - Its highly improbable that the
stated thing being examined is "true".
Date: 19 Apr 2011 17:51:45
Message: <4dae03f1@news.povray.org>
> science works.
What you need to examine depends on what you want to test.
For gravity, you only need a representative sampling. If all samples
falls within experimental bounds, it's comfirmed.
If you want to prove something but you did not find a single case that
match, you need to continue searching as long as you can, or find a way
to prove that it can't be.
In the case of ID, you effectively need to find and test every single
protein, enzimes, peptides and aminoacids in existance and their
predecessors to find at least one that can't possibly happen naturaly.
You also need to do the same with every sugars and glucides, as well as
lipids.
And then, finding one may not be enough, as it may be the result of the
degradation or a particuliar splitting of another molecule. So, you also
need to demonstrate that that degradation or splitting can't appen naturaly.
>>> unknown case,
>> hypothesis.
> support ID.
> Fair enough.
>>> I commend the idea.
Most scientists, starting with quantic physicists, are uneasy about the
string theory exectly for the fact that, by it's very nature, there is
no way to observe or realy test it.
It will probably stay forever at the stage of a mathematical abstraction.
> scientific method.
Date: 19 Apr 2011 18:14:55
Message: <4dae095f$1@news.povray.org>
That has nothing to do with proving ID.
The problem is that there are an infinite number of untestable theories out
there. In order to show *any* support at all for ID, you not only have to
find something that didn't/couldn't evolve naturally, but you have to show
how it *did* come from God.
Depending, of course, on what you mean by "naturally". It's entirely
possible one might find something that could not have arisen without the
interference of intelligent planning and forethought but which is
nevertheless completely naturally evolved.
But disproving that every single molecule of life on Earth is evolved does
nothing zero nada towards proving what *did* happen with that molecule. Even
*if* every single protein could not possibly have evolved naturally, that
doesn't tell you anything about how it *did* come to be.
Date: 19 Apr 2011 18:24:00
Message: <4dae0b80@news.povray.org>
Just a fair point, "theory" can also mean "hypothesis", just as it can
mean "body of knowledge about a scientific subject".
Jim
Date: 20 Apr 2011 15:14:36
Message: <4daf309c$1@news.povray.org>
On 4/13/2011 4:02 PM, Jim Henderson wrote:
> You'll get no disagreement on either of those points. The best example
> of that (at the risk of Godwinning the thread) is Hitler - some claim
> that Hitler was an atheist because he did things; others claim that he
> did bad things because he was an atheist.
> But most of the people who *actually* did the bad things (not that Hitler
> didn't) were undeniably Christians who were following Hitler. Hitler's
> actual choice of beliefs really is a minor detail in the Holocaust.
They were by no means "undeniably" Christian. There is good ground to deny.
When contacted by American chaplains, many German prisoners-of-war
professed either atheism or nature-worship. It is true that most were
nominally Christians (specifically, either Lutheran or Catholic), but
they had long abandoned whatever faith they had acquired from either of
these churches.
John
Date: 20 Apr 2011 15:33:08
Message: <4daf34f4$1@news.povray.org>
On 4/14/2011 1:42 PM, Darren New wrote:
> On 4/14/2011 10:00, Warp wrote:
>> I think Canada proves that hypothesis wrong, as Canada isn't any less
>> multicultural as the US (and guns are quite popular there too).
> Perhaps evidence against, yes. I think there's much more inter-culture
> hatred in America (intolerance?) than in Canada, even if there are the
> same number of different cultures. That's more what I was talking about.
From what I have read, an American living outside of our major inner
cities, and outside of the South, suffers the exact same crime rate as
anyone in Canada. Our high crime is very closely linked to inner-city
poverty and drug gangs. Outside of those areas we are just as peaceful
as any other industrialized nation.
John
Date: 20 Apr 2011 16:05:45
Message: <4daf3c99$1@news.povray.org>
> deny.
Explain. :)
> these churches.
Some undoubtedly did. I didn't say "all", I said "most". Finding
counterexamples really doesn't disprove the point.
Jim
Date: 20 Apr 2011 17:09:20
Message: <4DAF4B7E.80909@gmail.com>
It does unfortunately.
> out there. In order to show *any* support at all for ID, you not only
> have to find something that didn't/couldn't evolve naturally, but you
> have to show how it *did* come from God.
Don't confuse the messenger with the message. Most advocates of ID are
Christians, but they could be muslim, jews and polytheists or animists too.
The devilish scheme they use is playing within our rules. It is clear
that Creationism is not science, no hypothesis, no explanatory power, no
evidence and not testable.
So what they do is formulate something as a hypothesis that is testable.
It doesn't matter that every protein or whatever they throw at the
scientists will be taken to pieces and strengthen the case for
evolution. There will always be more examples to have them refute. The
number is finite, so it is in principle decidable and testable. Only it
will take decades to disprove all possible claims.
There are similarities with a filibuster. It is within the rules of the
game, and you can not prevent it without braking the whole process. Yet
is costs lots of time. And you can always hope that before they finished
you can think of another useless hypothesis or even better that your
party will have taken control of education and science funding.
> does nothing zero nada towards proving what *did* happen with that
> molecule. Even *if* every single protein could not possibly have evolved
> naturally, that doesn't tell you anything about how it *did* come to be.
If you look closely at the statements of ID you will find that there is
no reference to who or what that 'intelligent designer' is or even how
many there are.
In practice a lot of ID advocates do not fully understand the concept
and claim that they know the name of the designer. At that point they
invalidate their own claim of it being a scientific hypothesis and their
proposal will be taken out of the process.
I am always amazed by the number of stupid mistakes they make. If their
proposals had been more intelligently designed they could have been so
much more effective in their quest for the removal of critical thinking
from the US.
citizen per day.
Date: 20 Apr 2011 17:58:26
Message: <4daf5702$1@news.povray.org>
No, really, it doesn't, even if you accept "ID" to mean "intelligent design".
You've simply found something that evolution fails at. But nobody has proven
that there is no mechanism other than ID and evolution.
And what is the hypothesis? That a particular protein didn't evolve? Or that
some intelligence actually created that protein?
> If you look closely at the statements of ID you will find that there is no
> reference to who or what that 'intelligent designer' is or even how many
> there are.
But there's a reference to intelligence and design. "This protein could not
have evolved", even if found, does not imply "someone designed it."
Date: 20 Apr 2011 18:26:32
Message: <4DAF5D97.8070704@gmail.com>
> design".
indeed
> But nobody has
> proven that there is no mechanism other than ID and evolution.
indeed
> that some intelligence actually created that protein?
That there are proteins (etc.) that didn't evolve by natural selection.
Or even weaker that their presence is easier explained by design than as
a result of natural selection. (hijacking Occam's razor).
I know of no other way of disproving that, than by checking each and
every protein (etc.). I you know another way how to defuse this bomb,
feel free to share.
>> is no
>> there are.
> not have evolved", even if found, does not imply "someone designed it."
But in all likelihood it would imply that it's presence would be easier
explained by assuming it was designed. By someone, something, a
committee, or a mad scientist.
citizen per day.
Date: 20 Apr 2011 18:42:20
Message: <4daf614c$1@news.povray.org>
Not to split hairs here, but while its pretty damn obvious they "want"
god to be the answer, in nearly all cases, there are still a small
subset that may be serious about the whole, "Life here couldn't have
evolved, so maybe space aliens..." Yeah, I know, its bloody idiotic, but
ID can exist without god, in principle. Still doesn't help matters at
all for them, since the central premise to the whole thing is,
"Complexity doesn't happen by chance.", which is demonstratively false,
in and of itself. On the contrary, complexity happens because the
universe isn't some huge mass of stuff, all of which forms crystal
lattices when it gets jammed together. The number of things that do is
small, and even then, other things get mixed in and disorder it. The
finite state of entropy isn't perfect order, its a stable, but near
complete chaos. And, as things try to balance out and reach a stable
state, the interim result is ordered complexity.
Date: 20 Apr 2011 18:47:54
Message: <4daf629a$1@news.povray.org>
> many there are.
> from the US.
And, if you look even more carefully, with the exception of outliers,
nearly every single one of the advocates have admitted, at one point or
another, that God is the answer they want, and why they invented the
whole idiocy in the first place. Second problem is, those outliers are
not accepted by the main branch of ID at all, or even acknowledged much.
Third, no designer other than god solves the central problem, which is,
if something made life here, something else had to either have *been
made* or *evolved* some place else. A fact that gives up the entire game
right from the start line.
There is nothing about ID that isn't religion. Anything that implies
otherwise has only been added as window dressing, while being rejected
when talking about the real purpose, or the ravings of a few UFO people,
who sort of like the idea, because they never look past the implications
of life being created here, to the consequence of where/how it had to
have started some place else.
Date: 20 Apr 2011 19:01:38
Message: <4daf65d2$1@news.povray.org>
Sadly, you can make a similar argument with the bridge analogy. That
bridge, since there is no way it could stay up if you removed certain
things, "could not have been designed", so it must QED be a natural
formation. The only reason we don't hear people making this sort of
moronic claim is purely bias. In both cases, the correct answer is, "We
don't know what scaffolding may have existed, which allowed it to
evolve/be built." In either argument, lack of understanding of how it
could have formed doesn't prove the assertion that one or the other
solution is true. Only finding, a) in the case of DNA, a species that
still has part/all of the precursor, b) figuring out how such a
precursor might have happened, or c) in the case of a bridge, watching
someone build a similar one, gets you any place. What doesn't get you
any place? Postulating that some invisible architect, alien, god, or
otherwise, simply "inserted" the whole, complete, design into the genome
(or dropped a complete bridge in place), without themselves using some
sort of scaffolding to do it. Frankly, it doesn't matter if they used
mental scaffolding and then just sequenced the gene from that, or
anti-gravity beams, to lift the rocks. You still need some sort of
"process" to get the result.
ID's central premise, sadly, is that it just "poofed" into being. Hell,
even the ones arguing "front loading", fail to grasp that any such
"master genetic code", to avoid breaking the organism fatally, while
inserting new features, has to take clear steps, in which it replaces
parts of the system, only as possible, before reaching and end result.
You don't get to, in a running machine, replace entire sections of the
guts, unless you can turn the thing off, or reboot it, or something.
What "front loading" suggests is nothing less that replacing a whole
mess of "working" code, all at once, the same way you would your video
drivers and core kernel drivers, without either rebooting the machine,
or restarting the kernel. Which, doesn't work. Thus, to do it, you need,
again, something that can simply "magic" the changes in, whole cloth,
without restarting/rebooting/etc.
There is a reason why a lot of biologists use the term IDiocy to
describe this. Sadly, a few too many comp-sci people fail to grasp why
its similarly intractable in terms of computer code (where, the
equivalent in that would be taking a running application, and inserting
new code into it, without breaking links, jump points, functionality, or
mangling the data being processed, mid-change).
Date: 20 Apr 2011 19:08:35
Message: <4daf6773@news.povray.org>
> Jim
No it can't. Not in science. In science the two terms have clear and
distinct differences. The only place they mean the same thing is in
non-scientific language, where they get used damn near interchangeably.
This leads to serious confusion in the non-scientific world, since its
about the equivalent of trying to go from the normal world into
politics, where lie = reasonable opinion, and truth = negotiable
interpretation.
If you want to understand something, you need to use clear definitions.
Outside of the scientific community, the distinction between hypothesis
and theory is muddier than hell, with guess and theory being used to
mean the same thing, and hypothesis having no use at all. In reality, on
a scale of 1-10, where 1 = guess, and 10 = theory, hypothesis is, maybe
a 3 or 4. There may be sufficient cause, from experience, to presume
that an hypothesis is worthy of examination, but it isn't yet a theory,
since you haven't "done" anything to actually test it.
The last thing needed is to muddy the waters more, by claiming that an
untested hypothesis = an established theory.
Date: 20 Apr 2011 19:19:13
Message: <4daf69f1$1@news.povray.org>
To clarify, other requirements - The application be monolithic, not
include scripting/JIT compilation, and have massive crosslinking, such
that a minor change "might" be OK in the running code, but if you do
need to reboot (split off a clone, or produce other sorts of offspring),
some form of reboot "will" happen, and your change has just broken 500
other steps in the process, since its a critical part of some library,
which just happened to not cause problems in the "running"
implementation, but causes a whole shitload of errors, during start up
(like a zip library, which works fine for a set sized data sample, but
breaks when you try to unzip entire branches of the boot code, which are
larger, or smaller, than being handled in the "running" instance).
In any case, even if you could produce such a thing, and have it self
modify safely, it only helps the front load argument, not the "it didn't
evolve" one. You still have to show where the front load code is, which
means doing research, and... these people don't *do* research.
Date: 20 Apr 2011 22:37:13
Message: <4daf9859@news.povray.org>
OK. Let's grant that that is the actual hypothesis.
> even weaker that their presence is easier explained by design than as a
Designed by whom? An naturally-evolved creature? Who then selected that
protein unnaturally? As soon as you say "naturally-evolved aliens might be
the intelligence" then you've broken your hypothesis.
Seedless grapes and bananas were evolved by natural selection. It happened
to be humans doing the selecting, but it was natural selection and evolution.
So again, even if you find a protein that you think could not have evolved
naturally, then you have to prove that nobody who is naturally evolved
created it.
